Visitor Agreement.
Stillen customized suburbans, but they are just concentrating on Nissan cars now. Gemballa has a tuning program for cayenne, as does Powerchip Company. (the latter is just a chip switch, which may invalidate your warranty.) I think Gemballa also uses turbos, so it may be of no help, but it doesn't hurt to ask. Techart has a program in the works, but not out yet.... Canepa Designs also works widely with superchargers, so you may want to contact them. Did not hear from Renntech yet.
Mudman, you have any idea ? BTW, mudman did install some bypass pipes , which should be good for 10 to 15% increase in hp.
dubster , you are also right about the Cay engine. According to Powerchip co....Porsche detuned the engine to allow for the wide range of gas octane numbers and for less than ideal maintenance. The book also says the engine is capable of more HP, but that the factory thought this tuned version would be enough for now. I suspect future versions will have massaged engines that would boost hp output. Examples of this Porsche tradition can be seen in the many reincarnations of the 911 boxer engines, and the Boxster engine , which has recently been tuned to give more hp with the same displacement.
The double catalytic converter actually dampens sound , so much that the cayeene sounds quiet and timid, and has more exhaust back pressure. The Fabspeed bypass pipes would eliminate this backpressure, and get a more hp, without major modifications to the engine. I think I will go that route next.
Mudman has the info on Fabspeed....
enjoy !!
I wish I were in Hawaii too.... :-)
I think you are right about the V6 and the more spirited performance compared to the toureg...
As to your noticing the shift points when in the comfort mode, I presume you are talking about the air suspension mode. I think that the comfort only applies to the air dampening of the shocks...softer feel if on comfort mode, stiffer when on sport mode. I do not think it has any direct input into the shift points or engine displacement.
BTW, I also read that the engine has a variable camshaft, that allows for the engine to act like a smaller engine when conservative driving is done, but then increases displacement of the engine when aggressive driving is done...
hope this helps... :-)
The Cayenne has 4 cats, in 2 pairs per side. The O2 sensors are in front and behind the first cats, so removing the second pair does not cause any check engine lights.
Its been dyno'ed at +17hp. But the sound on the S is amazing.
www.fabspeed.com has all the info.
Mike
I still have not done it yet.... but will ....
mudman.....
how much was installation ?
, but would love to hear the results before I move on it. -- you know me , it took me months to buy the car in the first place.---anyway, I really appreciate the quick response of the info ..highender, mudman---you guys are great,, I went to fabspeed website They have a virtual test drive of the conversion--do you guys think it sounds to much like 60`s muscle car with those crazy mufflers--or appropriate for this type of vehicle-- and where am I going to notice the 17 hp?
Thanx, Mike D
www.mudditt.us/c2.mpg, turn the bass up.
As far as the sound is concerned, when idle it does not burble like a 73 GTO with straight pipes but it does sound like a 93 + Z28 Chevy. You hardly notice inside with the winows closed but you should see the turned heads outside !
I`m going to give the stock s some more time before I start playing with it. It`s still hasn`t totally found its legs yet. Thanx
Incidentally, mudman, I saw in the latest issue of porsche Excellence mags, that a tuner massaged a 911 engine to give out 100 more horses, and noticed that they used a BMC filter....
That 's what I 'm going to do.... :-)
Porsche = 1400
Mine = 125 + 400 to Dealer for electronics.
Good deal !
regards
the turbo is not even used most of the time ( the boost gauge is zero ) cause the V8 puts out more than enough power , even for passing !!!
congrats on your pepper...! :-)
“T-equipment add-ons”
Referring to crossbars that carry watersport/bike/ski/cargo on top of the vehicle? I installed the Yakima bar system on my Cayenne and it works fine. Plus, it costs half as much as the Porsche T-equipment. Yakima also makes accessories to its roof racks ( www. Yakima .com ). IMO, as an avid biker and retailer of Yakima products for more than 15 years, Yakima makes the best bike/cargo boxes/watersport available. Yakima’s crossbars, when used with the control towers, can be removed and easily reinstalled at the push of a button.
BTW, what’s the secret? I have never gotten more than 15.5 mpg on my drives from the Bay Area to southern California via I-5, traveling 80-100 mph. Even after resetting, my dashboard computer still miscalculates the mpg; I must use a handheld calculator to derive the real mpg, and it’s never been more than 15.5
to get over 17 mpg, I went I-5, and was going less than 75 mph most of the way. Not intentionally, it is hard to go that slow in this car, but we went during the Holidays, so I-5 was crowded...sometimes I was only going 60 mph........at that speed, the engine is working very little and easily to carry the weight and did not have to fight tooo much wind...
BTW, don't trust the computer always....it needs to be reset, or it just gives the overall mpg. I just add gas when the computer says to ...and it usually means a 21 gallon tank. So just divide the miles by 21 .... :-)
what do you think, mudman ?
I so use cruise control a lot on long stuff.
We're not talking about straight line numbers, as the FX45's 0-60 time of 6.5 seconds was .4 seconds ahead of the Cayenne. What they are referring to is the fact that the Cayenne lapped the Street Course of Willow Springs International Speedway, in the wet, a whopping 2 seconds ahead of the "quicker" Infiniti, and 4 and 5 seconds ahead of the BMW and Cadillac, respectively.
The overall finishing order was as follows: 1) Cayenne S, 2) FX45, 3) SRX, 4) X5 4.4. Here are a few quotes from the article:
"At the racetrack, we tried repeatedly to upset the Cayenne, make it push, slide, or do anything but track exactly where we pointed. As long as we had our foot firmly planted on the gas, it was nearly impossible to get the Porsche out of shape - even with the stability system defeated. There are sports cars that'd have a tough time making a 1:09 lap in the dry at the Streets of Willow, but the Cayenne did so in the wet"
"Anybody who had his doubts about the Cayenne's abilities was humbled. While it might not be the fastest in a straight line, throw some curves in front of the Porsche and things sort themselves out in a hurry. Our figure-eight test underscored this ability with the Cayenne's clearly superior run, which puts it solidly in the neighborhood of Nissan 350Z Track model or an SVT Mustang Cobra."
"Stand on the brake pedal, however, and the Cayenne S stopped in less distance (111 feet) from 60 mph than a race ready Porsche 911 GT3 (113 feet). From 100 mph, the two Porsches tied at 318 feet - astoundingly good brakes, and the FX45 was a couple feet longer."
"The next time you wish you had a Porsche sports car but need an SUV (and have a stack of U.S. fund coupons or the requisite credit rating), there's one true performance utility that satisfies both criteria. Look no further than the Cayenne S to shame any wannabes - and a few sports cars as well."
I can't wait to get mine in the mail(snail).
WOW....it proves what I have been saying all along....the Cayenne was tested at Nurburingen, and it consistently leaned in the turns as a true Porsche...and had times that were the same as the Boxster (0.91 gs) and BMW M3....!!
make no mistake ...this is truly a sports car disguised as a SUV...!!
I am looking into a 325i for my wife ( she likes it the most compared to the Mini S or the Mercedes C230 or 240....
Can you give advice over on the BMW 3 series forum ? thanks....
I'm waiting for my copy of the mag so I can read it too....snail mail...!! :-)
hope all are enjoying their Cayenne now that summer is here and vacation and road trips are possible.... :-)
I`ll go to the 3 series town hall and see if I can chime in if you`d like me to.
high...
With the lure of a free Mercedes loaner, I went to the Fremont, California, Porsche dealer for my second Cayenne service. Their loaner was a complimentary ML350 (decent - the Mercs have more legroom in the second row). Yet, Fremont’s service bill was more than $200 for the Cayenne oil change and another $135 for tire rotation. And these were discounted coupon rates.
So, what are typical service charges from Porsche dealers for simple oil changes? Can anybody recommend a particular dealer whose service department actually provides service? And treats its customers like VIPs? Thanks.
Unfortunately, only the cargo box/basket from Yakima will fit your older Porsche crossbars. Other Yakima accessories will not fit. To avail myself of all Yakima accessories, I use the Yakima crossbars in lieu of the Porsche T-equipment. I’m in Lafayette at Hank and Frank Bicycles on Mount Diablo Blvd. if you need further assistance. Ask for Steve.
jarama: was H&F used to be in Oakland near E-14th (a long time ago) ? I used to see the shop all the time.....
thanks for your info on the bike racks..... :-)
-you have to really slam the rear hatch to close
- windshield wipers squeek
- headlights have condensation
- the piece on the rear wiper flew off the first day (Called the dealer and he asked if I went through the car wash-it had been raining since I picked the car up-and I would only hand wash the car for the first few months-)
- any suggestions for car wax and wash-
thanks for your suggestions.
In my opinion:
1- rear hatch has to be slammed on all models. Mine does too. the sales man even told me it needs a good slam.....could be a German/ teutonic thing ? ?
2-yes, it is over sensitive sometimes when there is not enough rain, and its on rain sensing intermitent mode...and thus with not enough water, it does not have enough lubrication....but mine got better with time...
3- I never had this problem, but maybe on the west coast it is drier...Someone else here, carnut or ? had the same problem, but he had a fix....it was posted about 3 or 5 months ago .
4- I am using a good wax....and hand buff it...no , my rear wiper housing never fell off....yet,
have fun...!!
mudman, carnut, all, etc....what do you think ?
What are the numbers on a deal.
I am still undecided V6 or S
good luck..
I used the other brand, zymol....
which they say is very good..but you piqued my curiosity...
just got hit today,by a person in a parked Tiburon, she just opened her door into traffic, and I was just passing by....another 1 sec and I would be home free...
took it into dealer , and they will use all original parts to replace the damaged ones....
did you see the new motor trend article...which rated Cayenne #1 ?
Best wishes for the repairs...
sorry to hear about your incidents.....I guess it does happen...
anyways, you have cheered me up..!
I am glad it was not a convertible , with the passengers' arms sticking out...it would have sheared off someones' arm....!!!
Dealer is going to replace with original equipment parts, so hopefully it will be as good as new..
I used to bang my MB's mirrors all the time, on the Cay, I just fold them in as I reverse in.
It`s a shame they can`t roll the other, soon to be coming down the pike, recall in with this one for convenience sake.
On the other note, regarding DVD system installed by Porsche recommended people. Are they able to install nice screens in the back of the headrests without puckering the leatheraround the perimeter of the screens? I`ve never had a good look at one of these before.
As always any advice is greatly appreciated.
I've encountered a couple of noises that can easily be reproduced and I was just wondering if they're normal.
a. When I open the door for the first time in the morning, it sounds as if there is a motor that is operating something for a couple of seconds. I'm not sure what this is... It sounds like the seats, but I do not have the seat memory option (V6).
b. Upon startup, when I reach exactly 12mph, I can hear a distinct short click/ticking in the center of the engine compartment (sounds like it's directly behind the radio console). It's not the radio/cd though - it's definitely coming from the engine (under the hood somewhere).
Are these normal or should they be investigated?
Thank you in advance for any info you can provide.
I open the door and the seats do move back... to allow easier ingress/egress.
I do not have a ticking or clicking noise at 12 mph.....
suggest go to dealer and get mechanic, not the service advisor, to sit in the vehicle with you and listen to pinpoint the noise...
