Visitor Agreement.
someone else in the car?
I share your concerns about Honda Quality. I have owned 7 Hondas since 1983, and obviously very happy with Honda's "Quality." However, I just purchased a new 2003 Honda Accord EX-V6 Sedan, and now it appears that Honda sold it with a pre-existing "alignment" problem (see my Post #5687).
I happen to work for an Automotive supplier, so I'm not too surprised. For the past several years, the Big 3 U.S. Auto Mfgs. have been under extreme pressure to improve their Quality rating (see JD Power Survey). Although a lot of progress has been made, the effort has been hampered by the Industry's unrelenting pressure on it's suppliers to cut costs. They have recently mandated annual price reductions. This can only be achieved by "cutting corners" as you describe.
In my opinion, the majority of automotive workers are very competent and well trained. In my experience, the root cause of most "Quality" issues can be traced back to Engineering Design...further hindered by extremely short timelines from concept through production launch (hence my car's alignment problem).
Now that the Big 3 U.S. Auto Mfgs have improved Quality, I think Honda is beginning to feel more pressure too. Just think...maybe our next car will be a Ford instead of a Honda?
Have heard 97 engines are interference-wonder if it is the guys selling the service that say that or is it true.
Easiest way to find out is to call an auto parts store and ask them about your timing belt... generally speaking, the timing belt is designed differently for an interference and non interference engine and the description is designated accordingly.
One of the most annoying rattles is from my visor, when I use it to block sun from the left. I'm not sure what to do about that. I guess I could tear it out in a rage and throw it onto the freeway while driving 70 mph.
An irresponsible but satisfying solution...
same here...tons o rattles in the morning which fade away...mostly. i'm getting nervous thinking about winter weather cold...and what the rattles might sound like then. all in all i really like my '03 v6 coupe...but the rattle issue is quite annoying! thank goodness for the halfway decent stereo!
http://homepage.mac.com/julioardz/pages/accord/rattlefix/index.ht- m
The rear windshield of the parked Accord imploded during the storm. Nothing was inside the car except shattered glass. I suppose a flower pot could have fallen off a balcony and blown back out again; I suppose someone could have come during the storm with a sledge hammer and broken the windshield in, but both explanations are beyond unlikely.
My dealer said he had contacted Honda higher up and it refused to repair/replace the rear windshield under warranty. He added that this was true of most brands in this situation. I had to use my insurance which annoyed me a great deal.
Has there been any history of defective rear windshields in the Accord, innate flaws that make them unusually susceptible to wind and temperature changes?
Has anyone had any success in having the dealer solve the problem? I hate to start disassembling the car myself.
On my 5 month old '03 Accord Ex-v6 the coolant in the resevoir has to constantly be topped off. I don't see any visible leaks on the drive-way so it can't be leaking all that bad. Has any other EX-v6 owners experienced this problem also?
I am just wondering if the coolant is going inside the engine. If not then where the heck is the coolant disappearing to!!!
jebinc: I had a rattle in my 02 SI. Ended up being the wires underneath the dash. My other half cinched them up with a twist tie and the car never rattled again.
Question: They tell me that a "Re manufactured Transmission" is not a "re built transmission" because ALL the innards are new (perhaps used casing) and it's not assembled in an assembly line, but rather by humans at Honda motors... Is this true? I also demanded a new torque converter.. they told me that Honda only sends them as together to eliminate contamination concerns. Does anyone have the facts on these two items? Anyone out there work or have worked in Service?
Lastly, has anyone had a tranny replaced before? If so, what everything right after that major repair (alignment, rattles, no damage, etc.) They tell me that the car will not need wheel alignment. Can anyone confirm that?
Sorry for the long post, but given all the tranny issues and questions, I thought the replies to this one would be helpful for others as well.
First, check the fuel filter .. If you would like more info on where it is, etc and how to replace, email me and I will get it to you. Highly unlikely, though.
Second, try running some fuel system cleaner through the car. I usually don't go for the real cheap stuff, but the name brand decent stuff... I believe it is actually recommended every 12k or so. Should solve any problems with dirty fuel injectors, etc. Probably only about 8-10/bottle.
Third... rent/borrow an OBDII reader and find out what the trouble code means.
Fourth... check out the fuel lines for crmped lines, etc. unlikely as well.
Fifth... bring the car to she shop. Fuel pump or fuel pressure regulator may be acting up. If it is the fuel pressure regulator, it is probably a vacuum problem.
Hope some of this helps... the easiest thing would be to drop some fuel system cleaner, change the air/fuel filter out and if it happens again, bring it in and tell them what you changed, and that it is causing a potentially hazardous situation.
the Honda tranny problems were related to other items i thought?
at 700 miles, i love my car. just wish the tires weren't so LOUD.
there is a noticeable "extra" delay when shifting the accord automatic into drive. i noticied this right after i bought the car. when going from say R to D, there are two thunks that can be felt. the second thunk is when the car actually goes into drive. i've never had a car or truck that did this...they've always gone right into drive lickety split. the accord is different...but it doesn't bother me or make me think there is something wrong. i really wonder what was wrong with said guys tranny...if anything?
hopefully the reliable reputation proves to be accurate.
did i mention how much i HATE the Michelin Energy 205-60-16's on my car! so loud!
However, if my Accord is still under the manufacturers warranty, I would not want to be under that hood checking anything. That's what the warranty is for. Hamueller's Accord is a 2002, still under warranty. I would take the car in to the service dept., and demand that they check out his car. He was put into a near-death situation twice, and needs to have it checked immediately.
Another thing, if you start touching things under the hood of a very complex machine like the Accord, you might make it worse. Also, the service dept can't blame you for anything if you don't open the hood.
Hamueller, use your rights under the warranty! Just my $.02
All I can say is this: I expected to hear Honda service say, "It's normal" but they did not. What motivation could they possibly have to offer me a $4000 tranny job for free? I could see where they would be motivated to tell me, "everything is fine" hoping that it holds out past 36,000 miles.....
Another data point for you all. Every time I was in for add ons or this oil change, my salesman would loan me his demo car with auto tranny... Guess what? No delay, no double engagement. Armed with these two facts, I have to believe that something is amiss in the transmission.
Other thoughts?
why don't you ask them what was actually wrong with the tranny? why was it replaced? when i test drove the accords, i drove one that i didn't end up buying. and it had the same delay...
And I'm not making excuses for it and I'm not in denial. I'm quite strongly attuned to the need for transmission replacement, since they replaced the transmission on my 2000 Accord. But that transmission exhibited symptoms that were clearly abnormal. I don't get that impression at all with the 2003.
I'm also curious as to the rationale behind your service dept replacing the transmission. What condition was serious enough to warrant that decision?
I'm not afraid to speak up if I think something is wrong. But I'm not even close to being convinced so far. And I have to be convinced that there actually is a problem before I act on anything.
Was the dealer successful in stopping the rattles? Did they tell you what caused them and what they did to fix them? I'm headed to the dealer next week for this problem.
I also have a delay when engaging the transmission. Otherwise no transmission problems.
Thanks for your input.
I would have your tranny checked as well.
maybe i am just used to it by now. but the car performs flawlessly, so not worried about it. i will look for TSB's though. the delay is NOT just a Honda thing though...
