Honda Accord Quality Control Issues
1525355575869
  • Burn *some* oil. They have to. A quart every 3500 miles is nothing, really. I think GM calls a quart every 1000 miles *normal*.
  • emaleemale Member Posts: 1,380
    whitecloud,
    my point was that i didn't wait until 6750 miles for my first oil change (per manual and others here)...and it doesn't appear to have "affected" my engine's oil consumption at all. granted i usually change right around the 4k mark...and in that amount of mileage it doesn't appear to burn any at all. anyway i was being a bit sarcastic...catch my drift?
    as for oil weight...my '02 5.4l v8 ford supercrew also calls for 5w20 year round. honda and ford are using 5w20 to help with cold start emissions and fuel mileage...and i don't have a problem with that.
    as for oil consumption...it's been years since i owned a car that burned a quart in 3k miles let alone 1k miles. so, i'd be pissed if i had to add oil every thousand miles. but like the salesman says, most car makers consider 1k per quart normal ... and i think todays cars (past few years) will prolly use a little more oil vs cars that were built in the mid 80s to mid 90s. many carmakers have lowered the piston ring tension so that their cars will get better fuel mileage.
  • slawendaslawenda Member Posts: 101
    I am interested to hear a review of the common problems found on the 03-04 Accord sedans, including differences between I4 and V6, and differences between those made in Japan vs. US, etc. One frustrating thing about these boards, is that you have to almost read all of the messages to get an overall perspective--anyone care to summarize the "Cliff's Notes" for some of us? I am stressing common problems here--it is not really relevant to most of us if one person had a rare problem.
  • atlantabennyatlantabenny Member Posts: 735
    My experience has been very little (1/3 quart at most) or no oil loss between oil changes. Losing one quart in 5k miles is about, typically, 22% of total crankcase oil capacity !
    That loss impacts oil's cooling, cleaning and of course lubricating effects.
    Engineers haven't, and didn't, design engines to consume oil.
    I'd take my 3 year old car, if it was still under warranty and having observed proper drain intervals, to the dealer for a warranty claim if it's consuming a quart/5k miles.
  • chucko3chucko3 Member Posts: 793
    After over 2k miles from last oil change, the dip stick still reads full on my 89 Accord.
    If you car loses 1QT/3K miles, check for any sign of leak at the valve cover gasket and oil plug.
    It's not expensive to replace the valve cover gasket.
  • bd21bd21 Member Posts: 437
    The standard that all car makers use is anything less the 1 quart per 1000 miles is considered O.K., so your example would not even get a shop to look at your car. I do agree with you that you should not use enough oil to require adding oil in 5000 miles, but the fact is dealers will take no action unless your engine is losing more than a quart per 1000 miles. Ask your service department and you will get an eye opening answer.
    agreed....engineers haven't designed engines to consume oil...but they have designed them to get better fuel efficiecy with less friction...ala reduced ring tension. and reduced ring tension overtime leads to...
    Hmm...
    1 quart loss @ 1k miles would be a highly lax standard. The original oil would have been completely changed out by 4.5k or so miles. I'm quite sure this isn't the case, or else there'd be millions of warranty claims against car makers because the majority of motorists don't check oil levels between changes, and their motors would basically seize before the next oil change.
    As to piston ring tension, there's a direct correlation between that and compression ratio. Accord 4 cyl. motors have a c.r. of 9.7:1. The six, 10.0:1. Those rings would have to be pushing tightly against the cylinder walls to attain the desired compression. If ring tension is low, compression ratio would be low as well. And, not only will oil be burned, but gasoline will trickle down and contaminate the oil, reducing lubricity and eventually accelerating the demise of that engine.
    Given Honda's engineering repute, my guess is that a 1 quart loss between oil changes isn't acceptable. A dealer may say otherwise, but obviously that'd be a commercially influenced position.
    I've personally experienced too many logic stumpers with auto dealers to trust their opinion on mechanical aspects. Lexus appears to be an exemption from what I've heard so far. Their technicians are perfectionists who push the envelope to get things right.
  • talon95talon95 Member Posts: 1,110
    I just saw a transcript of a Edmunds chat with some highly placed tech guys from Subaru of America, and they said that 1 qt. in 1000 miles is considered acceptable. I'm sure this may vary from manufacturer to manufacturer, but I wouldn't expect Subaru's standard here to be any more lax than the competition. So it sounds like 1 qt. in 1000 miles isn't unreasonable.
    Keep in mind that we're talking a threshold for determining if a problem exists, not a design objective. I don't think Subaru or Honda or anyone else is designing their engines to consume a quart of oil in 1000 miles, but oil consumption can increase in cars over time for a variety of reasons, and they have to have some standard in place to separate an increase that's a problem from one that isn't.
    Go ahead and call several service departments of various makers and you will confirm what I have already stated "using a quart of oil or less per 1000 miles is the acceptable industry standard for taking no action". There may be one or two exceptions, but this is the majority stance. Also, read your owner's manual, you are supposed to check your oil every time you put gas in your car. If your car runs out of oil, you take the blame. Pretty crappy I know, but those are the rules of engagement. Most people just aren't aware of it though, but at least now you are.
  • anonymouspostsanonymousposts Member Posts: 3,802
    Lexus service is cool because they give you a loaner but they are no better than Honda techs. Had to take our GS back 3 times for something my husband told them to fix the first time. But hey we got to drive a 2003 IS300, a 2002 ES300, and a 2002 RX300 so that kind of lessens the pain.
    While I can see your points, bd21/emale/talon95, I also see the risk of resigning to the claim of 1 quart/5k miles as an acceptable loss, particularly for a new vehicle.
    The root of this position is that the new vehicles I've owned - and most of which I've maintained personally - weren't in that category. And if they were, they were my regrettable pre-owned purchases (my first "decent" car, a used 1975 Mitsubishi Galant, consumed 1 quart @ 1k miles. And that car demanded the oil-check-every-Saturday routine).
    In all likelihood, I agree that if I went in with my oil-burning 03 Accord with 35,900 miles for a warranty claim, the average dealer would say the subject loss rate is normal.
    That scenario is the crux of my advocacy: a) a resigned owner may not even bring his/her car in for a claim, much less press forward, while b) an owner with a reasonable standard (which for me is 1/3 quart @ 5k miles) may seek out the regional rep for resolution if the car was burning 1 quart @ 5k miles.
    "Oil Ring Tension" as brought up by emale is an interesting facet of this thread (thanks, emale, for inducing education). The link below indicates that tuners indeed install low-tension piston rings for less friction. However, the writer also assures that low tension doesn't mean a higher oil loss rate.
    http://www.rbracing-rsr.com/enginetech.html
    ...checking the oil level regularly per the owner's manual is something I, like most of you who pore over it the night of a car purchase, have been aware of.
    Carmakers ask us to do that as for presumably pre-emptive reasons - as in "did you check your oil regularly after each fill-up ?" - to deny a claim.
    Checking or not checking the oil shouldn't acquit them of an engine design or assembly flaw.
    Cheers.
    "While I can see your points, bd21/emale/talon95, I also see the risk of resigning to the claim of 1 quart/5k miles as an acceptable loss, particularly for a new vehicle."
    You'll note that my post said that oil consumption can increase over time and that they have to use some kind of standard to distinguish between problems and normal situations. If I had a brand new car that consumed 1 quart of oil per 1000 miles right away, I think I'd feel justified in complaining.
    I'm not trying to defend the 1 qt. per 1000 miles standard, but I can't fault the auto manufacturers for having set a standard. Perhaps that is a lax standard in your eyes, but on the other hand, dealing with frivolous claims takes time and money as well. Some people will accept nothing less than total perfection, and you don't often get that, even with Hondas, Toyotas, etc.
    "an owner with a reasonable standard (which for me is 1/3 quart @ 5k miles)"
    I suspect that if you complained about something that exceeded your standard by a bit (like 1/2 quart in 5000 miles), you'd most certainly get the "that's within normal limits" response. Personally, I'd have to do some long and hard soul searching to decide if I wanted them to do major surgery on my engine for such arguably low oil consumption.
    What I'd probably do, though, is report it to the service department if I noticed this during the warranty period and make sure that it's documented. That way, if the problem gets worse later on, you at least have a record of having reported a potential problem, and would be able to make a case that the problem should have been corrected while the warranty was still active.
    "Carmakers ask us to do that as for presumably pre-emptive reasons - as in "did you check your oil regularly after each fill-up ?" - to deny a claim."
    Since that's not something you're required to document, I'd have a hard time believing that they could make something like that stick through arbitration as a reason to deny a major claim. Now, if you can't prove that you changed the oil at least as often as required, that would be a different story altogether.
    Actually burning a little bit of oil is good. Personally I'd be more worried if my car consumed no oil whatsoever than if it used a shotglass or two every 3,000 miles.
    atlantabenny,
    i guess everyone has their own comfort zone when talking bout' oil consumption. to me 1qt per 1k miles would be excessive on an engine with less than 100k miles. on the other hand 1qt per 5k miles would not bother me at all. i remember when putting in a quart every 2-3k miles was NORMAL...both when the car was new and when it had 150k worth of miles.
    "What I'd probably do, though, is report it to the service department if I noticed this during the warranty period and make sure that it's documented. That way, if the problem gets worse later on, you at least have a record of having reported a potential problem"
    You nailed it here, talon95.
    I believe with a passion that it's in our interest to hold our vehicle providers to the highest standards of quality and performance. Not only is it good for us, it's also good for them.
    For that reason, I expect other carmakers to re-arrange our quality expectations, but not Honda and not of their engines.
    FWIW, after my apparently "pre-abused" 1975 Mitsubishi Galant, a Mitsu Mirage/Nissan Sentra/Dodge Caravan/and 3 Hondas came and went (all acquired new) with tight, no-oil burning motors. A new Mazda 323 and 2 other pre-owneds missed the cut.
    Excellent point... I agree that Honda should be a leader in this area. With their reputation comes the expectation of leading-edge quality. So far, I haven't been disappointed... let's hope it stays that way.
    Your list of cars is interesting... both domestics and imports did well. I was a bit surprised about the 323... how bad was it?
    ...began going through 1 quart@~800 miles at the 10,000 mark on the odo.
    Peppiest, best-handling small car I've owned. But on top of the oil burning, the rear wheel well panel began rusting through as well. Sold it before the car became 2 parallel-wheel motorcycles.
    Some of the k-series engines (the in the 02+ Si's use about a quart of oil between changes during the initial break-in period. My first 02 Si used a quart before it's first oil change at 7,000 miles and none afterwards. Maybe a few of you doomsayers should wait and see if the oil consumption improves or worsens before making such a big deal about it.
    Additionally, 10,000 mile oil changes just became recommended. Mercedes, BMW, and a few other high lines also have 10,000 mile intervals. They don't say "don't add any oil" or "don't check your oil" for 10,000 miles. They just say don't change it.
  • lelandhendrixlelandhendrix Member Posts: 240
    Let's take this 'accepatable oil consumption' to task with some math.
    I can certainly see how some manufacturers and people could agree, but it is nothing short of lunacy for a Honda tech to tell a new Accord owner this.
    I am observing the 'severe' maintenance schedule recommended by Honda, and having my oil changed every 5,000 miles. If I were burning a Qt/1K, then I would drive the last 500 miles without a drop of oil in my engine. Is that fine with Honda?
    If I was on the 'normal' schedule, and just drove the car, it would drive 5.5K miles with no oil left.
    If I'm supposed to check the oil and top it off every other fill-up, shouldn't that be mentioned in the recommended service guidelines as well?
    I would have quite a warranty claim considering the discrepancy between these two ideas.
  • gee35coupegee35coupe Member Posts: 3,387
    Your engine would seize well before that. Hopefully you would check your oil before that time. Or you would have a hefty repair bill.
    You can speculate all day. But the fact still remain industry rules say 1gt/1k miles is excessive.
    If you read that nifty little book the dealer gave you called your owner's manual you would see that Honda recommends that you check your oil at fill-ups. That same information is mentioned on the Honda Owner Link website accessible from www.hondacars.com. Here is the recommendation from the preventative maintenance section of the website:
    Engine oil
    Weekly or when you stop for gas. Add oil if the level is below the lower mark.
    thanks anony. don't forget that I have been on YOUR side before.. haha! just kidding.
    Anyway, yes I check mine, I'm just trying to point out that an overwhelming number of people don't, and if an engine consumed that much oil then it would run dry before the next oil change. That is, considering the person didn't check and replenish.
    Luckily I found out a long time ago what the industry standard was. Car and Driver had a long term Porche 911 that went through oil like a Trump goes through champagne. Porche told them too bad so sad until it started burning at that rate. Needless to say lotsa Mobile one put a real hurting on the cents/mile.
  • jjaxonjjaxon Member Posts: 27
    i had a honda... i got rid of my problem.. i bought a new buick,,, 3800 v-6,,, the difference is like night and day... the buick is by far the better car...may i repeat.. BY FAR THE BETTER CAR
    " the difference is like night and day..."
    You got that right... having driven an Accord EX V6 and a Century Limited (both 2003 models), the Buick, by comparison, features the following:
    - 60's throwback American luxo-boat ride, with sub-par suspension control
    - numb, lifeless steering
    - massive understeer and plow in even moderate speed driving
    - Barcalounger feel to the seats, with no support... belong in your living room, not in your car
    - a dash that's loaded with cheap looking and feeling plastic trim pieces and controls
    - fit and finish so bad that GM should hide its head in shame...you'd think that they'd have gotten it right after building it for 7 years, but you'd be wrong
    Glad you're happy with your choice, but you're not going to even begin to convince Accord owners that the Buick is a better car. Not even close.
  • barryssbarryss Member Posts: 41
    Oh yeah, a Buick--that's the ticket. Too bad the Buick's demographic is...dead! I suggest you start an Accord vs. Regal thread. LOL. It's a good thing GM finally stumbled on a way to move those things out of the show room--give them away!
    yea right.. my honda lost the right outside mirror as i crossed railroad tracks..left hanging from the wiring.. nice job there honda.. my buick gets over 30 m p g highway with a 205 hp engine.. my honda couldnt do that with a 4 cyl. engine.. which was probably better suited for my riding lawn mower by the way...that is as long as the grass wasnt too deep... and plastic radiators just arent my bag.. hondas are fine as long as you baby them along..however i dont have the time or the patience to baby a car.. i want a car that can handle me and honda doesnt fill that bill..
  • mikefm58mikefm58 Member Posts: 2,882
    What Honda model are you comparing to the Buick? Model/year/mileage would help. If you want to continue this discussion, then start a comparison forum, but the Honda Accord Quality Control forum is not the place for this.
  • Now I feel like I've been abusing my cars.
    Our Hondas usually get their oil changed around the 4000 mile mark. I rarely, if ever bother checking it between changes. On the rare ocassion I do decide to take a look, the oil level is fine.
    A far cry from the old beaters I grew up with!
    Whatever... my experience is much different than yours. In addition to the Buick drive that I described, I had the misfortune of owning a late 90's GM midsize (Oldsmobile) before my first Accord. Junk, junk and more junk... the quality was atrocious. After that car, my first Accord was a revelation in quality and driving experience. And driving the Buick recently told me that GM's midsize cars hadn't improved one bit by 2003. Still junk, junk and more junk.
    By the way, perhaps we should get past the rhetoric and anecdotal reports about gas mileage and look at real comparisons. If you have a recent vintage Buick sedan with 205 hp., it must be either a LeSabre or a Park Avenue.
    Here's what Consumer Reports has to say about gas mileage:
    LeSabre 3.8L V6 (205 hp)
    Overall: 20 mpg
    Highway: 31 mpg
    CU Trip: 25 mpg
    Accord 2.4L I4 (160 hp)
    Overall: 24 mpg
    Highway: 38 mpg (beats LeSabre by 7 mpg)
    CU Trip: 28 mpg
    Accord 3.0L V6 (240 hp)
    Overall: 23 mpg
    Highway: 34 mpg (beats LeSabre by 3 mpg)
    CU Trip: 26 mpg
    These are CU's instrumented results, not EPA estimates. Seems like they didn't have any problems achieving much higher highway mileage with both Accords when compared to the LeSabre. And the I4 (your so-called "lawn mower engine") beat your LeSabre in acceleration from 45-65 mph (representative of a passing maneuver) by nearly 1 second (Accord, 5.5 seconds... LeSabre, 6.4 seconds). Lawn mower engine... yeah, right.
    At any rate, enjoy your Buick... as for me, sorry, I've been there and I'm not even remotely convinced. Especially when confronted with your dubious claims for gas mileage.
    This is my last post regarding this comparison, since it's only partially on-topic.
    Funny how no specific model information was given. Sounds like a bait of a post if I ever saw one.
    BTW: My 04 EX-L automatic gets 30 MPG + in my mix of city/highway driving.
    and you guys fall for the bait EVERYTIME!
  • whitecloudwhitecloud Member Posts: 29
    Thanks for the info. about the oil. I thought it was a drastic change that had just occurred. I also thought that maybe you were driving a defective vehicle with your statement. I sometimes miss the joke. I'm with you now.
  • tblazer503tblazer503 Member Posts: 620
    I don't know if anyone has answered your question yet...
    I4 vs V6/handling... IMHO... drive them.. 2 reasons I didn't buy the V6... the I4 has more than enough power for me, and IMHO the v6 handled oddly(probably due to the extra weight, and non-specific tuned suspention). This is something you have to see for yourself... I tend to drive agressively, and like the I4's nimbleness(for a 3300lb car) and the power. I have heard rumors that the v6 sometimes drifts during hard braking, but never experienced it.
    As for the US vs Japan versions, some people will swear the japan made ones are better, but if you get the V6 it doesn't matter because they are all made in Mexico/US. I personally like mine('03 Accord EX 5MT I4 Japan built purchased 10/02 14k miles) the only problem I had was a few missing screws on delivery, and I had some water in the fuel line/tank causing some backfiring and causing me to spend $15 on a new fuel filter at 13k miles(took me that long to figure it out backfiring about once a month sheesh)
    As for the problems, there is the vibrating steering wheel at stop lights, stiff brakes(good in my opinion), stiff ride(again, good to me)...
    I like the car, and actually plan to keep it for a while(coming from someone who is on his 6th car('86 Corolla, '94 Tempo, '94 Corolla, '00 Civic EX, '02 Trailblazer, '03 Accord) in ~7 years. by far this is the best of all of them. It won't win any races (actually, it'll beat an F-250, Escape AWD, Ranger, Camry)... but it's a great car IMO.
    Hope this helps some
    A slightly different viewpoint... ;)
    My 2003 EX V6 handles just great... certainly, the lighter I4 may feel a little more nimble, but there are no problems whatsoever with the V6 handling. With its quick, direct and communicative steering, the V6 also feels quite nimble. Check out reviews by Edmunds, Motor Trend, Road and Track, etc. if you want additional confirmation.
    "the only problem I had was a few missing screws on delivery, and I had some water in the fuel line/tank causing some backfiring and causing me to spend $15 on a new fuel filter at 13k miles(took me that long to figure it out backfiring about once a month sheesh)"
    My US built Accord didn't suffer from even these kinds of minor problems... it's the first new car that I've ever owned that has had NO issues at all in 10 months and 11,000 miles.
    I'm not suggesting to slawenda that the V6 is necessarily the better choice (the I4 is a fine choice as well) nor am I suggesting that tblazer's comments don't have merit just because my experience differs, but I feel I should point out that the issues that tblazer listed for the V6 aren't issues for everyone. In fact, based on my experiences, those of other owners I know, and what I've read, I'd have to conclude that most people don't share those issues.
    So obviously, such opinions are very personal, so you really need to drive both to see how you feel about them. And my feeling is that the V6's smoothness and abundant power can be absolutely intoxicating...
  • imidazol97imidazol97 Member Posts: 27,803
    Honda Accord Owners: Problems & Solutions
    anonymousposts "Honda Accord Owners: Problems & Solutions" Jan 27, 2004 5:51pm
    Is another discussion group here about experiences with older and the new Accords --
    in case you haven't found it yet! I suggest reading through several of the pages through the last year's postings.
    I have never experienced the drifting during braking, but if you check the problems & solutions, you will see numerous posts.
    As for the water in the tank, I haven't had a problem like that before, but it doesn't really surprise me a whole lot considering the ~6 weeks on the sea for shipping. Minor problems as I said.
    I also suggested that the V6/I4 difference was something that would have to be decided yourself. True that the problems that I mentioned are not problems for everyone, and not everyone has experienced it. The poster asked for a summary of the problems listed in the board, and I gave it to them.
    I don't recall that being an issue since late 02 early 03.
    I DO recall separate issues of drifting (pulling mostly to the right actually) and braking, but none combined.
  • randy04randy04 Member Posts: 1
    If anyone can answer, I'd appreciate it...
    I plan on buying an '04 EX-L 4cyl Accord this weekend. 2 Questions: I understand that these are made in Japan,Ohio,Mexico. Since I am going to buy in Baltimore,MD can I expect to get a Ohio-made car? If so, have there been quality issues on cars coming out of one plant that differ from those of another?
    I guess the driver-side doorjam will tell me when it was manufactured...will it give location as well or do I have to run a check on the VIN?
  • bburton3bburton3 Member Posts: 185
    Look at the Vin in the window-think the Japan versions start with J. Rumor is the J built accords have better paint and components such as alternators. If you find a J built-see if the alternator is made in Japan by Nippondenso and check out the Ami made-think it is made by a former GM division. Oh if possible also try to find one with Bridgestone tires-supposedly better traction than the Michelin energy tires.
    Also ask the sales person if it was a Monday built car-avoid if possible-I understand Wednesday/Thursday built are better.
    By now your sales person is suffering from apoplexy:)
  • It's a placebo effect. I've never been able to detect the SLIGHTEST difference between Japan and US Accords.
    Others will argue, I'm sure.
    Not many "J" cars out there anyway.
    My 04 EX-L is Japanese built and it's no better than the US built 03 Accord coupe I owned. The whole US vs. Japan thing is just a vicious cycle that refuses to die.
    I agree with the perception being a visicous cycle. Build qualty is the reult of tolerances observed, and are likely the same in each plant.
    However, when one car has parts of a different manufacturer (nippondenso vs. delco) then the argument holds some weight.
  • inthewestinthewest Member Posts: 2
    I have an 01 Accord V6. I have had "hard to turn" complaints since 700 miles (in 2000) when the dealer added 2-3 ozs of fluid. This is an early 01. Now I am out of warantee and it is worse. Today the dealer preasure tested it (again). It is on the high end of 6.5 to 7 pounds (probably at 7.1 or more - they have never let me see the report.) Any suggestions on this? It usually feels like I am parking with no power steering - very frustrating. The only place it steers fine is on the freeway (which is straight). This is my first honda and probably the last - the dealer has such an attitude: just drive the car and turn up the radio. (Right, that's why I bought the top of the line.) Has anyone experienced this?
    I remember my wife complaining that our 6th gen Accord like yours, even if just a 4-cyl, had heavy steering. Her 03 EX-L has much lighter steering.
    If you plan on keeping the car, look for a dealership/independent shop who can adjust the the steering boost (technically, the VASP or variable assist power steering).
    A web search shows it can be done with some work.
  • rcc8179rcc8179 Member Posts: 131
    The first thing I would do is to have someone else look at it. I personally have used 4 Honda dealer service departments in the past and have had some good experiences and some bad. The dealer I go to now is not closest to me, but they are always straightforward with me and treat me very well. They get about 95% of my business.
    If you have taken it in a couple (or even several) times, this indicates that this has been a consistent problem that hasn't been fixed. You might get it fixed under warranty (because the problem occurred under warranty and wasn't fixed). Take the receipts with you to the new dealer and see if they will help you out. If the first dealer had to add fluid, it sounds like there is a leak in the system somewhere. But, as atlantabenny mentioned, it could just be a different steering "feel" than other cars. But I would definitely have someone else look at it.
