Honda Accord Quality Control Issues
1545557596069
  • roudy04roudy04 Member Posts: 2
    I have vibrations at low speeds and high speeds. I have replaced tires, had them rotated and balenced, replaced brakes, new rotors and still have slight vibrations in the steering wheel. So if we can assume that I have eliminated all of the obvious stuff is there anything else I can check? I have not replaced rims because of the cost but is that a next logical step?
  • abromsonabromson Member Posts: 16
    Latest is:
         1) At 700 mi. service manager agrees that rotors were warped and is replacing them. Could have been driven hard off the assembly line by the factory personnel, he speculates. Wasn't me, as I drive like as gently as an old man. I think, the car had defective rotors to begin with.
         2 Engine ticking, which was initially dismissed as not existing by the Honda technician and, upon appeal, also by service manager, was, upon further examination, due to a broken valve lifter which, they surmise, was that way when it left the factory.
        I'll be about 5 days without my brand new car.
        I'm beginning to wonder a bit about the future with this car...
    Had a broken roller on Camshaft---came like that from the factory Honda guy says. Now repaired and the ticking in the engine is gone. Maybe I'm imagining but the car seems more powerful than ever.
    New rotors---no pulsating anymore.
    I'm starting over and giving my brand new car a whole new second chance.
    Could any damage have been done by this broken whatever?
  • chucko3chucko3 Member Posts: 793
    Have you checked the engine mounts?
    I have not checked the motor mounts, but I will. Reading other posts I am thinking it might be worn out tie-rod ends (but the problem surfaced at about 40K mile) or a bad half shaft. Any other ideas??
    I would check for any broken seal at ball joints and outer tie-rod ends. While you are at it, check the CV boots for any torn.
    Last year the steering wheel on my 89 experienced a vibration at slow and high speeds. It turned out the right outer tie-rod end wore out.
    The seal broke and lost most of the grease. I could hear the metal rubbing against metal every time the car ran over a pot hole.
    Also, don't let the shop tight the wheels with the air gun.
    I don't know why, but my 89 experienced a mystery vibration after the shop did a front brake job. I had to re-torque the wheel by hand.
    The vibration went away.
  • five0ninerfive0niner Member Posts: 4
    The dealer ordered and installed an '04 mirror... it still vibrates horribly... they are checking/reporting to Honda... I have also noticed that the passenger air bag off light no longer stays lit when there is not a passenger in the seat... My husband didn't put his seat belt on once the car had been started and there was no warning on the dash or by audio??? I thought that there was at least a light on the dash that stayed lit up??? The audio alert stopped after a short time in our '89 Honda Accord LXi Coupe, but the light stayed lit...
  • snakehairsnakehair Member Posts: 120
    Had a mirror installed in my '03 and it vibrates also over any sort of washboard surface or bumps. Please post if you find a fix. My side air bag passenger light has never lighted except at the self test when starting, no matter how much or little I have in the passenger seat. Dealer says there are no codes in computer so all must be fine (??)
    Do you know what is supposed to light the dash symbol for the passenger side air bag light?
  • pj23pj23 Member Posts: 158
    The '03 mirror is what was causing the airbag light to light up without anyone in the seat. The side airbag light should only come on when the path of the airbag is obstructed, or possibly if there is some other sort of malfunction. An empty seat should not cause it to light up.
    And no, the seatbelt light does not stay lit if the passenger does not have a seatbelt on. If it did that, it would be lit the entire time there was only the driver in the car (which, I would venture to guess, is much of the time for many of us).
    As for the mirror vibrating, I notice that my auto mirror vibrates more than the standard one (mine is an '03), but I think that is due mainly to the added weight of the mirror - it is quite heavy compared to the standard mirror.
    I don't know if anyone reads the 03 Owner's manual or not.
    The manual says if there is no front passenger, the side airbag light should come on. But it does not.
    The manual confuses people including me.
    five0niner,
    My 89 Accord sedan generates audible warning & flashes the seatbelt light a couple times when the engine is started (if the driver does not have a seatbelt on). The light does not stay on.
    It works as described in the manual.
    The light does not stay on for the 03 Accord either.
    The manual says that the passenger side airbag light off should be lighted when a small person or load is in the passenger seat (that the airbag would cause damage to) or if someone or something is blocking the egress of the airbag (as I read it). My light is never lighted except for the initial self check, no matter if I have 20# or 40# or hang my wife out the passenger window. Dealer says no codes means all is o.k.(??). Question is...has anyone seen the light come on when a child or small load is in the passenger seat??
  • ken972ken972 Member Posts: 162
    I have an 04 and I have seen the light come on when something is placed on the seat. I usually strap in my computer case on the seat to transport it and the light will come on then.
  • talon95talon95 Member Posts: 1,110
    My 2000 Accord came with side air bags, and I recall that the manual said that the condition that usually would cause the airbag light to come on was when a short or light person was in the seat and leaned toward the door. That would put them in the path of the airbag deployment, possibly causing injury. When my mom (just under 5 feet) would ride in the car, she has a tendency to lean toward the door, so the light would go on and off the whole time... just about drove me nuts.
    I don't know if they changed the calibration or what, but the light on my 2003 has never gone on (other than self-check at start), even when mini-mom is sitting in the passenger seat.
  • jmaxejmaxe Member Posts: 198
    My airbag light also comes on when a light load is placed on the seat. I can make it turn of and on by changing the load on the seat.
  • desmonsmdesmonsm Member Posts: 48
    My airbag light also comes on at startup, and will shut off when either: 1. there's nothing in the front passenger seat, or 2. there's a "normal" sized person sitting in the front seat. I've noticed that when I place my briefcase on the seat, the light comes on saying the airbag is off. The sensor detects a very light weight (like that of a small child who could be injured by the force of the airbag) and automatically shuts off the airbag to that side.
    Regarding the seatbelt light and warning sound...mine makes the sound I think 7 times, then stops. The light stays on, I think, as long as you don't have your belt on. I don't wear my belt, so I don't really notice the sound or the light!
    Do you have to be moving for the light to come on when there is a light load in the front seat?? I have tried to illuminate the light with a light load, a small child, in Park and in Drive with no sucess. Only thing I have not tried is actually driving with a small child in the front seat.
  • abpelch1abpelch1 Member Posts: 48
    You don't need to be moving to get the side airbag off light to illuminate. I got the light to turn on by pushing on a sensor located on the front of the side bolstering nearest the door. The owners manual says there is one in this location, and it will turn the airbag off if someone is slumped to the side, say, sleeping in the seat. The reasoning is that the person won't be in the correct seating position facing the airbag, and could cause additional injury. You should be able to find this sensor by feeling for a slight weakness in the foam bolstering material. I did this while the car was parked in the garage.
  • anonymouspostsanonymousposts Member Posts: 3,802
    Our light came on once in our 04 Accord. I was leaning forward and slanted towards the door.
    Thanks for the info. I'll give it a try just to prove to myself the thing is hooked up.
  • hondasuckbighondasuckbig Member Posts: 3
    I really hope someone at honda reads this message.
    I bought my honda accord ex brand new in Jan'2001 with just
    7 miles on it. I have never missed a scheduled
    maintenance and always took good care of the vehicle. I have had two major problems with it
    already, the drivers side window motor stopped
    working and the entire unit had to be replaced, and the the cruise control stopped working and
    the control unit had to be replaced. All my friends recommended a honda because you could
    count on it. From what I have seen, you cannot
    count on it. The first problem was fixed because
    it was under warranty and the second problem
    honda was willing to pay only for the part.
    For both the events, I ended up spending about
    $500 out of my pocket, after paying about $26000
    for the vehicle (including interest at 5.9%).
    It just amazes me that in this world
    of 10 year auto warranties (hyundai,kia etc) honda is not willing to stand behind their vehicles. I mean sure kia, and hyundai might be cheap cars and you expect this sort of thing to
    happen with them, but after paying honda so much
    money, it just disgusts me that I have to spend
    another $500 to fix issues when driving under
    normal conditions.
    The customer service manager was really rude, not
    even to return a phone call, she had the time to
    call the dealer and find out what happend, but
    not return my call.
    Honda really needs to review their quality. I know
    for sure, this is the last honda, I will ever buy.
    If I could, I would get rid of this car right now.
    I hope this helps others in making a decision. Please dont buy a honda.
    Almost forgot about the ABS control unit that had to be replaced(under warranty) when the car was about 6months old.
    This is the second time I have seen this exact post. If you are unhappy with your Accord buy something else. And when that car has a problem then trade that car and buy something else and when that car has a problem ... well you get the idea.
    Fact is, a perfect car does not exist. Luckily all of my Accords have been pretty flawless (knock on wood). Looks to me as if Honda did step up and cover part of one of the repairs even though the problem occurred outside of their warranty period. As for the warranty on Hondas not being long enough, you knew what the warranty was when you bought the car. If you wanted a longer warranty you should've bought the extended warranty or a different car altogether. BTW:Those 10 year warranties are only good for the powertrain. Electricals aren't covered beyond 5/60.
  • emaleemale Member Posts: 1,380
    while i do believe that post #2900 is nothing but a troll post...i will say that i agree that honda should up their warranty to match at least toyota!
    for the record...the only real problems i've had with my '03 coupe are odd noises and rattles. stealership got rid of a couple...but many still exist. especially around the glove box and up in the headliner/front window area. irritating to say the least, but i'm not sure i want them tearing into the headliner to try and figure out what the problem is.
  • imidazol97imidazol97 Member Posts: 27,758
    Does anonymouspost work for Honda in some way? At a dealership?
    Anytime someone posts a criticism about their experiences with a honda, there's immediate rebuttal. Others are allowed to post their comments just as we read the same grand support note about owning many hondas and never having had trouble.
    People buy a car to use it. Trading is a money loser each time compared to long term ownership. Telling someone to just trade a car is not a good solution when they bought on the supposed reputation for a particular vehicle. The company and the dealership should stand up to suppose the image they built as well as the car itself.
  • gregoryc1gregoryc1 Member Posts: 764
    There are two reasons why I do not like my 2003 Honda Accord, (four door 4 cylinder vehicle). 1.) It only has a key cylinder on the driver's side of the vehicle. (I like to have a key cylinder on each front door. If I would have noticed this prior to the "purchase process", I would not have purchased this vehicle). ------ 2.) There is a "blind spot" in the driver's outside mirror. YES, I have adjusted the three mirrors, but the "blind spot" is still there in the driver's mirror.----(I is VERY annoying! Our 2000 Accord did not have this problem. Had I noticed this on the test ride, I would not have purchased this vehicle.)---- From a mechanical point of view the vehicle is "GREAT"! ---- When the time comes to replace this Accord, if these issues still exist on the new Accord, Honda will be "history" for us! We will then look at a Chevrolet or a Toyota.
  • snarkssnarks Member Posts: 207
    Won't a $5 stick on blind spot remover mirror take care of your "problem"?
  • tntitantntitan Member Posts: 306
    I have the 4 cyl engine with the manual transmission. I had one rattle in the passenger side door that was fixed by taking off the door panel and just putting it back on again. That's it. Great Car!
    I think many of the people posting here about their problem cars and how they will never buy another Honda are in for big disappointments the rest of their life. I have owned over 15 vehicles and found no perfect cars yet. After you own several cars with real problems (not just minor annoyances) you will appreciate your Honda. No it is not bulletproof and Hondas have their flaws.
    I have noticed that many of the more serious problems have come from the 6 cylinder Hondas while the Honda reputation was built on 4 cylinder engines. I fully expect these problems to be remedied as time goes on (I think a major improvement was made with the 2003 6 cylinder with its MAJOR low end torque and horsepower improvement).
    I have had Cadillacs, Chevrolets, Volkswagens, Buicks, Pontiacs, Fords, Dodge, Chrysler, Volvo, Toyota, Triumph, Fiat, MGB, Nissan but my last 4 and two current vehicles are Hondas. If I was more affluent they would be Acuras.
    Hondas are still the best bang for the buck for me.
  • whitecloud1whitecloud1 Member Posts: 268
    I would never minimize problems that others are having with their cars unless I know those folks personally. As far as problems with cars though, I don't think Honda is any worse than all the best. Even the top of the line cars have problems. Quality of parts and a careful manufacturing process can keep
    big problems at bay but there will be problems. I've
    had cars with the "powertrain" warranties; and of course there were no powertrain problems but the rest of the car seemed to be falling apart. I have one car on which every major electrical component has been replaced with a higher than factory quality part. Defects were known during the manufacturing process and the car was still put out
    for the consumer with known issues. Hopefully you sell or trade or the part breaks down before your extended warranty ends. One thing that seems to be the case with Hondas is once the repair is made, the repair lasts.
    No I don't work for Honda but all of my Hondas have worked for me.
    I am sure people have legitimate problems with their Hondas just as people have legitimate problems with every other vehicle. However, someone who is ready to write off a whole car company because of a few repairs will likely be unsatisfied with any vehicle as the miles add up.
    Just like there are those who blindly defend Honda's there are thosewho jump on any little post, legitimate or not, to say that Hondas aren't that great while xyz is. A quick look at Edmunds repair forums will show lots of cars have problems.
    http://townhall-talk.edmunds.com/WebX?14@@/Maintenance%20%26%20Re- pair
    As for the dealership and Honda standing up, it appears that they did by covering the cost of the faulty part even though the car was out of warranty.
    I never cease to be amazed about some of the little things (to me and to the masses) that are a big deal to someone else.
    I've sold a lot of 2003-2004 Accords and NEVER ONCE have I had anyone complain over the lack of a passenger door keyhole. I've also owned, literally, dozens of cars in my lifetime and I can't for the life of me ever remember opening my passenger door with a key.
    For one thing, that Accord has keyless remote entry, so what difference would it possibly make anyway?
    As far as blind spots go...I've had nothing but praise about the visability out of the new Accords. ALL cars have some kind of blind spot and this is why, when we took Driver's Training, the instructors taught us to always look back over our shoulder when changing lanes and not to depend on mirrors.
    We are, indeed, all different!
    I think the kind of complaint posts our regular users object to are ones classified more or less as "rants".
    Folks are upset naturally, so they rush in here, dump a lot of emotional stuff, don't ask a question or for help and then leave.
    This bothers some people and I think it's a criticism more of their "style" or "courtesy level" rather than a lack of sympathy on people's part.
    It's no fun to have problems with a new car, but it is YOUR problem. We're here to help but not take a beating.
    Shifty the Host
  • tlccar1tlccar1 Member Posts: 3
    I have to agree with you - it looks like people are dying to NITPICK - consumers are so tough today I wouldn't want to be in the manufacturers' shoes!! I have owned so many different brands of cars, and Hondas are always my #1 favorite. They drive well, are well put together and hold their value. I tried a different brand - VW Passat to be exact - and it was a NIGHTMARE!! Let me see Mr. Jones in his "other" brand of car at 200,000 miles. I know my Honda will be there - NO QUESTIONS ASKED!!
  • 77hchbck77hchbck Member Posts: 24
    quality is that Honda has built a reputation of long-lived drivetrains, if given normal maintenance. However, their current issues with automatic transmissions in the 6th Gen Accord, Ody, and recently their recall of the 5spd autos in the Ody, Pilot and MDX have many questioning their reliable longevity.
    Some buy new cars every 3-4 years or 50K-75K miles and don't worry about longterm durability, other longhaulers, like myself, buy new and hope to reach 200K before major drivetrain failures. To me, this is where the Accord historically has excelled and is currently suspect. My LX had a bout of 6th Genititus and I'm currently on my 2nd autotrans.
    Squeaks, rattles and vibration noises may upset many after buying a new car, for my part, I wish Honda would address the drivetrain longevity issues that are appearing more regularly on multiple Honda forums.
    And extended warranties are nice piece of mind gestures for the aforementioned short haulers, but do little for us longhaulers.
    There seem to be some folks just as quick to only praise Honda as well as those who would damn Honda. This is my first Honda out of many cars over 40+ years. I am disappointed in the problems I have had (delivered with toe so out of alignment it cupped the tires, driver's seat frame replaced to keep it from shifting, front brake pads replaced-rotors turned at 10K for judder, center dash compartment replaced 3 times for rattle and several screws and fasteners stripped or deformed when I put on mud guards). The car runs great, is a hoot to drive, comfortable, well equipped and fast ('03 V6). Expected better quality from Honda on build, but I am not as leery as I have been with other manufacturer's. A good car, not yet a great car, hopefully not living on reputation.
    I would hope that in some future redesign that Honda would go back to their traditional low cowl/large greenhouse Accord styling. But this may be unattainable given the safety considerations for pedestrian injuries when hit by these vehicles.
  • h0udinih0udini Member Posts: 118
    buying an Accord and have been following this board for a while. When I went to look at the Accords, I did notice criticisms mentioned in this forum. For the heck of it, I paid particular attention to the headliner where it joins with the windshield. The headliner's edge is just hanging there, and I was able to put my finger between it and the roof. Now, on my '98 Toyota truck, the headliner is clearly attached and "buttoned down," or sealed, against the roof/windshield using a piece of plastic molding. It does seem to me that the headliner's edge should be secured somehow, and not simply cut to shape and left hanging with no molding or such securing it.
    I've also read numerous raves about Honda's quality and fit and finish, but did notice that the interior plastics did not fit together properly. No, I didn't use measuring calipers to determine gaps, but the uneven gaps were plainly visible to the naked eye. On the coupe I looked at, the flip/flop cover for the storage bin was not aligned, and the plastic panels forming the center console, especially at the rear of the console, fit poorly indeed.
    I've read about the brake and rotor problems and am reminded that I have 65K miles on my Tacoma and haven't even replaced the pads yet. My truck is also rattle free. I don't know if my truck uses something else besides clips to hold the dash assembly together, which is what others have said holds the Accords dash together.
    I was very interested in buying an V6 coupe 6MT but changed my mind. My impression was that it was a nice car on the surface but upon closer inspecion, appeared to be hastily put together. When I started thinking about the power seats, power sunroof (which doesn't fully retract into the roof - again, another odd detail), 6 disk changer, etc.,etc., all I could think about was how much there was to go wrong.
    In my humble opinion, it appears (to me, at least) Toyota builds a tighter car. Maybe the fact Toyota stands behind their product with a better warranty helps reinforce my opinion a little. All I can say is I was looking forward to buying the coupe I mentioned but walked away a little disappointed.
    These forums tend to give a somewhat skewed perception regarding problems... it's easy to come to the conclusion that reported problems are more widespread than they actually may be. And as been mentioned several times, there are comparable forums for reporting problems for other brands, and one can come to similar conclusions regarding how widespread their problems are. If you draw conclusions from "issues" forums such as this, you'd have to end up believing that there's no such thing as a reliable car from ANY manufacturer.
    There's no denying it, Honda has had some problems of late, probably more problems than they would like, but they still manage to come out near the top of reliability studies, so they still must be doing enough things right to continue to earn such praise.
    I'm saying this because I've had a 2003 Accord EX V6 sedan for just over a year, and it's been everything that I'd expect in a Honda, based on their reputation. Excellent fit and finish, no sagging headliner, no misaligned interior pieces, no rattles. I can't imagine a "tighter" car in this price class. I've driven Camrys and they're tight cars, but certainly no more so than my Accord. And I'll take my Accord's more involving drive over the Camry's more isolated drive any day.
    To this point, it's required no warranty work whatsoever (knock on wood). Have I just been lucky? I'd like to think not... I know two other owners of Gen 7 Accords who are just as happy with their cars as I am with mine. As with any car, YMMV.
    But at the end of the day, the most important thing is that I still look forward to the drive every time I turn the key.
    If someone is more comfortable with another brand, such as Toyota, more power to them... they make some great cars. But based on my experience, most people wouldn't go wrong with a Honda either. And I'm probably one of the fussiest people I know... ;)
    Just my opinion...
    YES, but it would look like "HELL"!
    Up to the 2003 Honda Accord all my vehicles had a "key cylinder" on both front doors. I don't remember "Honda" sending me a "Fax", or a "Memo" or a "Letter" or "leaving a message on my answering machine" asking me if it would be "ok" if they eliminated the cylinder on the front passanger door of my new EXPENSIVE vehicle.---- They just did it! I like to be able to open the front passanger door with a key. It is that simple. (In the event that the "remote doesn't operate", and the drivers door is blocked by another vehicle in a tight mall parking space, with two cylinders the owner has options). Other vehicles have a key cylinder on both doors! ------The mirror issue is another story. QUESTION: ----What is the purpose of a mirror? Tractor Trailer Drivers use mirrors all the time to control the operation of their vehicles. The 2003 Honda Acord has a "dangerous blind spot" on the drivers side, because the mirror is not large enough! The passing vehicle is lost in the mirror, long before it is picked up by the driver in "peripheral vision". In an emergency situation, the driver will not have enough time to look over his / her shoulder. The driver should not have to "look over their shoulder" when changing lanes. This is a "design problem" and an accident looking for a place to happen! To minimize this issue and put the responsibility on the owner is ludicrous. Honda needs to come up with a "fix" for this problem, possibly a replacement lense for this mirror that would expand the "field of vision".
  • rda27nerda27ne Member Posts: 8
    I'm glad to hear you have not had any problems with your 03 Accord. Mine was just the opposite. I had the following problems with it:
    Misaligned hood, doors and trunk lid
    Flaws in the finish
    Numerous rattles
    Transmission whine
    Out of alignment from the factory
    Strut replacement
    Rubber gasket pulled away from window
    Center Console broke
    Occasional hard to start issue
    Warped Rotors
    I haven't even had this car a year yet. I spent so much time at the dealer that they all knew who I was. The best thing I ever did was get rid of the piece of junk. In my opinion Honda SUCKS! I would never buy a foreign car ever again based on the experience.
    Did CR comment on the mirrors and the blind spot in their review of the new body style? I recall in 95 or so they ripped the GM H bodies (LeSabre, Bonneville, Olds 88) for the mirrors being small and not adequate. They also criticized the same cars for the vertical vent (psuedo) wing obstructing visition and the same year the early Odyssey had the same vent wing pattern.
    I have to agree also about the keyed right door. My car does not have it either. Didn't miss it until after I owned it. In the bitter north I picture having to park outside, ice storm, and battery dead. Bitter cold and no way to get into the car without pouring hot water over the left door to thaw the iced-up innards so the key lock will work after you've chipped through the ice to get to the key lock. The right door was on the leeward side of the freezing rain while you were at work, so a key would have allowed entry so the AAA truck could jump your battery.
    I know. That's a stretch. But I'd feel better with two keys also. Eight years from now the auto lock system doesn't work and you don't want to repair it at your own expense. The left door links stop working. You use the right door to get in to unlock everytime you've locked the car because the left key cylinder doesn't work. OOOPs. No right door lock.
    I saw a lady crawling out of right side of her car the other day because the left door locks didn't work. Then she unlocked the right side and crawled back in.
    "In an emergency situation, the driver will not have enough time to look over his / her shoulder."
    Given that most drivers use the outdated mirror adjustment method that virtually insures a major blind spot on both sides of the car and, assuming that it's true, this statement is chilling. Talk about accidents looking for a place to happen.
    "The passing vehicle is lost in the mirror, long before it is picked up by the driver in "peripheral vision"."
    Not in my experience. My 2003 Accord has no more problems with blind spots than my 2000 Accord had. In other words, no problems at all.
    "I know. That's a stretch."
    I'll give you that... ;)
    Especially given that with the near universal application of remote keyless entry in cars of this class, the keyed locks have been essentially reduced to little more than a backup system. The likelihood of both primary and backup systems failing simultaneously is so small as to be a complete non-issue, IMO.
    IMHO anyone depending solely on mirrors is an accident waiting to happen. The "blind spot" on any car is dependent upon how the mirrors are positioned. About 90% of all drivers improperly position their mirrors.
    I have never even considered my Accord to have the slightest problem with the mirrors. In fact it is much better than several vehicles I have owned. I know that everyone is different and I am not trying to offend anyone, but I find it ludicrous that the Accord is thought to have anything close to a potential safety issue regarding the side mirrors.
    I often wonder about the driving experience of some of the Honda critics. If the Hondas are so bad then I would encourage you to try another brand. If based on your experience Honda does not meet your prior experiences....then why did you quit buying brand X anyway? I can understand people that have transmission or other serious problems not being happy but those that have the minor annoyances will probably end getting rid of a vehicle that someone else will get years of value from.
    I have my flame suit on.....
    First the driver would only experience the "mirror problem" after they have driven the vehicle for a period of time on the highway. QUESTION: ----Why is it always the "drivers issue" and NEVER a "poor design problem" from the manufacturer. Whenever there is a problem with a vehicle, the manfacturer is sure to come up with a "special solution" that puts the responsibility on the owner / operator.---- People have been driving vehicles for years with both "ouside" and "inside mirrors", and they have been adjusting these mirrors without a problem. NOW, all of a sudden, we have to take a "college course" titled "Mirror Adjusting 101" in order to get the process right! Lets face it, there is a problem with the driver's mirror on the 2003 four door Honda Accord that needs to be resolved. I have been driving since I was 17 years old, and I have never driven a vehicle that had a "Blind Spot" like this Honda! ----------Question: ---Are you employed by Honda or a Honda dealership? The reason why I ask this question is that you seem to be VERY defensive about a negative comment about Honda. Honda is a VERY fine product, but the designers and engineers need to pay attention to "detail"! This problem can be solved.
    The only question I have is, has anyone else actually complained of the same "issue" you experience? People tend to really complain on this board I have not run across this one. I know several people who have these cars and not one eluded to this.
  • badgerfanbadgerfan Member Posts: 1,565
    I don't own an Accord, but fact is that most people do indeed adjust their drivers outside rearview mirror wrong. If you can see the side of the car in your outside mirror, you simply have it adjusted wrong.
    I drive a 2000 Taurus, which has fairly small outside mirrors, but if I adjust the outside mirror outward so that it picks up a car passing me just as it leaves the field of view of the inside mirror, then I eliminate the blind spot. Just as the passing car leaves the outside mirror range of view, I pick the car up in my peripheral vision. I would virtually guarantee if you adjusted your mirrors properly, you would eliminate all your blind spots, and you would barely have to ever turn your head to the left to cover your blind spot.
    My Taurus, by the way still has mechanical key locks on both sides, though I have yet to use either mechanical lock to date after 4 years of driving it. The remote has worked every time, and still has at least 50 foot range, with the original remote battery. In a pinch, I suppose I could even try to crawl into the passenger space from the trunk, but doubt if I ever will have to.
    I adjust my mirrors IAW safety guidlines and have no issue with the accords mirrors. Would love to have them heated though.
    "People have been driving vehicles for years with both "ouside" and "inside mirrors", and they have been adjusting these mirrors without a problem. NOW, all of a sudden, we have to take a "college course" titled "Mirror Adjusting 101" in order to get the process right!"
    Only if they consider having a major blind spot (that could be corrected by an simple improved adjustment method) as being "without a problem". This is a major problem with the "tried and true" method, and that's a commonly known fact among automotive experts, not to mention most drivers.
    This is one of many demonstrations that you can easily find on the internet of the shortcomings of the "old school" method and the advantages of the "college course", in case you doubt me. Clearly they find many problems with the "old school" method and recommend the "college course" method very highly.
    http://www.nifc.gov/safety_study/annual-refresh/hot_topics/drivin- - - - - - g_mirror-adj.html
    Every car that I've ever driven using the "old school" method that they taught in high school driver's ed resulted in a major blind spot on both sides. The Gen 7 Accord is absolutely NO different, nor was the Gen 6. Nor the Toyotas, Eagles and VWs that I've owned in the past. Nor the Pontiacs, Buicks and Mercurys, etc., etc., etc., that I've driven.
    I would personally not like to see another "Honda emmployee" comment in the forum. I think it is too aggressive for gentlemanly conversation.
    Of course, if you reall ARE a Honda employee, that's for you to announce, not somebody else.
    thank you
    Shifty the Host
    If you read Edmunds enough you would swear Honda has a larger payroll than the federal government.
