Changing the oil this way gets 'most' of the oil out and about 1 quart is left if you have a 1.8T engine. The 6 takes more, that detail is also in the manual.
An early change should not be needed at all as the initial 5,000 should be fine.
JR
Since you have a manual 05+, I'm pretty sure that you have the 2.0t engine. While I can't recall exactly what the manual said about oil capacity, I believe that it is around 4.5 quarts.
As JR mentioned above the 5 k interval should be fine. On my previous A4 my first change was at 5 k and the car never ever needed any oil between changes... this suggests that the engine had healthy piston rings. But a big part of that is driving smoothly, avoiding WOT, high rpms, varying rpms during that critical 1000 k break in period. I also gradually (and gently) let the rpms occasionally move further up the rpm band.
Byron
JenP
I think it is ridiculous that it has such a problem at this point.
everytime you stand in front of the question what to buy - a hard to find answer.
I consider the Audi A4 2T and Toyota Avalon Limited.
Well, 2 excellent cars and manufactures. However best results you hear from consumers they have experience with one or even both cars.
Any suggestions... any problems I should pay attention when purchasing one of these two cars? Tell me what it was like for you... Good experiences and bad..
From a dealership to the car itself....
Any comments appreatiated.
I read so many reviews now, but still want to know more... the more the better and the better I can feel when I go for the deal.
as a long term audi owner I never had this problem.
could be there is something wrong with your AC. ( moisture getting into the system)I USE my AC to clear condensation and it works very well. AC dries the sir so it clears condenstaion at any temperature hot or cold.
I have a 5 yr old Audi A4 with 2.4 V6, SE.
good luck
I have owned an A4- V6 2.4 L. for 3 years, and I check the forums regulary. I see a lot of reported problems re the 2 l turbo. I think its to do with the higer temperatures under the bonnet causes problems after a while.
I find the Audi a very good car but it is not cheap to run- running costs and servicing is expensive, especially compared to my previous Toyota's. But I do prefer the Audi.
Please call the Audi Customer service at 1-800-822-2834 option 3 and let them know that you are also having this problem. i had called them last year and also today about this situation.
Just wondering...
Byron
My 1999 A4...timing belt bust at 65,000 miles...still battling with Audi on the matter.
I was wondering if any other 2.8 owners with timing belt failures out there if so, whether there's anything happening from Audi to help them.
Graci
pej 1
http://www.boston.com/business/globe/articles/2005/07/17/class_action_can_be_engine_of_cha- nge/
Byron
Alex
At 51K the fuel pump died 3 hrs from home costing me $700 P&L.
At 56K the oil and engine lights came on and right then the entire engine blew out and needed to be replaced - again 3hrs from home. I got that back and it was surging during acceleration so I brought it back and the dealer cleaned dirty valves and vacuum lines. 2 days later, 3hrs from home, the main pully on the crank shaft fell out of the front of the engine. The dealer that has it now says this engine needs to be replaced. This will be the 3rd one.
I have not been charged for anything but I'm making payments and have not had my car either. They gave me a corolla though.
In my talks with the dealer I have been told that the oil suldge is from not using synthetic oil but I always brought it to the dealer every 10K miles as advised. When I asked "why 10K?" they said because they use synthetic. Now they say they used regular oil but that synthetic will solve the problem.
The problem has been identified as a defective engine and not a dealer workmanship problem. It seems Audi cannot even build a decent engine.
Has anyone else dealt with this type of situation?
My new 2.0t engine came with synthetic oil and after an initial 5k change, calls for 10k changes. You can bet that I will stick with the 5k/6 month change. This has kept my previous two Audi engines very happy and hopefully this will work with my current ride.
Tummydummy, I see maybe a new Lexus or Infiniti in your future Very sorry about your crummy Audi experience.
Byron
I have 2003 A4 1.8T
The CVT transmission needed to be replaced at 52,000 miles! just 2,000 miles after the warranty!! The dealer claimed that it happens every so often but there was no recall from the manufacturer. I am not confident about this CVT transmission and I cannot wait to get this car replaced! If it goes out on me again that would be $10,000 to replace it. (I heard that this Audi transmission is one of the most expensive transmissions)
(2002.5 Audi A4 1.8T Quattro)
Thanks in advance.
Most new stations in my area use this nozzle and as older stations replace nozzles they install the OPW 12VW. The places I can get gas are slowly disappearing. I know some other A4's have had this problem. Anyone know of a fix? My dealer is unable and unwilling to help.
Please respond if you have experienced the same problem and what I can do about it. Or what you think my problem is.
Is this something I will get used to or is something wrong with my Audi
Anybody have any thoughts?
I used to drive a 1999 323CI BMW.
Either way my friends think its rediculous but the bottom line is I have been driving the car for one week and seriously concerned about the ride comfort. I am imagining it is that I am not used to the ride of the car since it is such a contrast I feel from my previous ride of 6 years.
Thanks for comments and corrections I hope everyone understands what I am trying to convey, sorry for sounding so stupid.
Please let me know if you have any thoughts
Byron
I want to say that I purchased my car from a dealer that is 2 miles away from Audi of America. From the moment I stepped in the showroom to every visit to the repair shop, the service is phenomenal. Even though one of the service guys is a bit of an [non-permissible content removed] the rest of them make up for his rudeness. Also, everytime I request a car when mine is in repair/service, they always give me another A4 with about 5,000 miles on it.
Here are my problems I've had with my 2003 A4 1.8T:
1. At 9,000 miles, the glovebox door started to rattle. No problem, dealer fixed it. Now it requires applied downforce in order to be opened.
2. In the blistering cold here in Michigan, at about 25,000 miles the fuel pump went out. No problem. Germany sent over a new one and 4 days later I had my car back.
3. Here is the kicker....at 39,000 miles, driving on a beautiful sunny Saturday, the car starts to make funny howling noises....I'd shift gears and the noise would go away. This happened a few times and when I slowed down to about 25MPH, it went bezerks, did this weird high speed winding noise as if something was grinding and it stalled. It would not crank or nothing. Had it towed to my dealer within an hour. Luckily I caught the manager there and even though they were "CLOSED" he managed to go inside and give me a brand new loaner A4.
I called about a week later to inquire as to what happened. The manager told me that the water pump turbine has been getting worse and worse. Because of that, the water pump seal had slowly leaked coolant into the timing-belt cover which caused the timing belt to gradually loose its grip/function and simply snapped. Because it snapped, one of the piston heads collided with 2 valves. Both the piston shaft and valve shaft were bent. The good thing: no cylinder wall damage. yay!!! They fixed it without asking me any questions. I did ask them how much it would have cost if I were to pay for it. Their answer: $5,000.
When I got my car back, the MPG were a bit worse then normal, but after a while it got back to normal and now it drives like a champ.
4. Now I have 48,000 miles and the front suspension makes funny squeaking noises whenever I go down/up a driveway or over a speed bump (of course, I drive over them slowly).
One thing I have come to realize is that you need to have lots of $$$$$ if you want to drive a performance vehicle. Audi cars are made to perform. And just like anything high performance, it works wonderful, however it has a short life span. In the case of Audi, they are using LeMans technology in their cars. LeMans cars are built to perform for only 24 hrs, not 5 yrs. Once the Audi engineers figure a way to incorporate reliability with performance, they will manage to win over BMW & Lexus buyers.
Ohh and another thing I've learned is to "NEVER BUY A CAR THE FIRST YEAR IT COMES OUT". As an engineer, I've worked on a few vehicle launches here in Detroit and let me tell you, they are not pretty. Managers cut timing drastically, thus not giving us engineers the proper time to do our job properly.
One thing I know for sure is that Audi will have problems with their FSI technology in 2006...its too new. Come 2007, the 2.0T engine be flawless....just in time for the A3 quattro.
Thanks for reading my novel and feel free to post any comments.
I,ve released one screw on the inside of the boot and have a little bit of movement but still can't get the light cluster free!! I can't see any other obvious screws. can you help??
If you don't need quattro and like to shift yourself the mileage is pretty good I think.
I hope none of you reading this will have one of these "unique experiences". I have had German cars for years and they get testy, but if the company and dealer stand behind the product then life is good. With Audi I have a total of 150 days at the dealers, one was 45 in a row. For those about to ask, yes, I pursued them with Lemon law (due to intermittent failures they avoided taking the car back) and got a large settlement. What is odd about Audi is the fact that all they had to do was fix the car, they once offered me 1 month lease payment in return for not having the car for weeks. That check never came, even after repeated calls to them, they just said they were looking into it....for 4 months? So that 1 month they offered me ballooned into much more in court and with all the warranty work, loaner cars and their own experts they have spent triple the cars value - yet they can't fix it and won’t give up. Is this putting the customer first?
As much as I wanted to like and believe in Audi I am giving up. They are not ready and they do not have the customer service attitude. I am frustrated with all the smoke blowing and I just found out my issues were known about 2 years ago...the dealers, plus Audi, chose to ignore or were incapable of understanding their own service bulletins. My advice is stay away, if you get a bad one you are in for a battle. One of their employees told me they only sell cars, seems to be true.
Sorry to ramble, but, it has been quite a wild ride. It is all documented.
It is a shame because one can see the attention to detail in the car, but any product without support is worthless.
