Jeep Liberty: Problems & Solutions
Montsue--As to the power steering fluid leak, you may have the same problem I had. The power steering fluid pump was bad and had to be replaced.
Both of the above problems occurred within a couple of months of each other and had me wondering for a while if this vehicle was going to be a service nightmare. Luckily I haven't had any problems since and am now sitting at about 26,000 miles.
By the way, I'm driving a 2002 Liberty Limited Edition.
Jon
www.theptking.com
Bug and tar remover does work best.
After a good cleaning apply a premium wax.
Has anyone else experinced this problem or heard of it?
hope this helps
My advice...call their bluff and demand the vehicle now or else you are going someplace else.
I purchased a set of the 16" chrome rims and am having slight corrosion problems myself. In the warranty book, Chrysler states that they are not responsible for corrosion that happens from salt, chemicals or other environmental factors. As a result, I have been fighting with the factory myself.
Thank God it came with a free bicycle.
my 02 liberty has a jerking in the rear end when I slow down. happens as the speedometer is about 20mph upon slowing. was this your problem?
My dealership stood up for me and said no dice. They fought to get chrysler to buy my lovely lemon back and I am now in the midst of a 5 day test drive with the '03 freedom edition. Which was out 2 months after I purchased mine and a constant pinch when I walked past it in the show room while my original sport was having all of it's issues. So in the end I am very pleased with the second chance at a dream jeep. I am sad about loosing my FIRST JEEP:(
If anyone is having this or a similar problem with their transmission in the '03 liberty they should take it in to the dealership right away. Mine started at 2000 miles and was a light shudder when turning and stopping. This progressed into a shudder when stopping at lights. It would happen right before the car came to a complete stop. As time went on it began shifting hard and shuddering at 45-50mph. The last time I drove it it had a new metal on metal grinding at this speed to accompany the shudder. The problem would happen after driving for 45 minutes plus. I hope this helps anyone out there who is feeling this same thing and not getting the necessary answers from their dealer mechanic. The memo from chrysler to the dealers came out on Thursday 7/31/03 if that helps them locate the e-mail.
My only concern now is getting to 2000 miles with the new freedom edition. I have my fingers crossed that the same problem doesn't show it's ugly head again. I am loving the tough look of the Freedom ED.
Mine makes noises when I back up and when I'm slowing down, kind of like a grinding noise. Does that sound like your symptoms? I don't get that noise when I make turns. At least not yet
My problem was not a sound in the beginning but a feeling. It felt as if the breaks were grabbing and letting go repeatedly. It was actually the transmission not the breaks. My dealership said it was the transmission slipping when going into gear. They talked with the engineer at DC and was told to replace the pump first. This didn't work and now they are waiting on the program upgrade from DC. This program won't be out until the end of august. The service department won't be able to find the problem with any computer programs run and it won't show up on the diagnostic tests. I wish it did. I would demand to have your mechanic call the engineer at DC and talk to them about it. They should have the same info from the head office that my dealership received. I hope they can find the problem, it took having the head mechanic drive my jeep home and to work for a week to feel what I was talking about. Best of luck!
Issue 1: The cloth upholstery is not impregnated so it absorbs all liquids immidiately. This something strange for a car like this. Our dealer and the importer are looking into the matter at the moment. If we can get more people with the same issue, we can try to get it solved by DaimlerChrysler.
Issue 2: The lock of the trunck gets stuck regularly. A dog in the trunck that won't open , is not very pleasant. Every time we take the car to the dealer, it works perfectly. It's hard to convince them that the problem is real. Does anyone recognize thise?
Greetings from Holland
Thanks from a Chicago area liberty owner.
Anyone have anything similar to this??
Other than this repeating woooooooo problem, I love my jeep, despite its thirst for gas and would not give it up for anything in the world.
JeepSpaz!
Thanks in advance for the help.
We've had a vibration problem from day 1 with our 03 sport v6/auto/4wd. At first it was at about 50mph and decelerating, vibration from the rear that resonated very loudly inside, more resonance than actual vibration actually. Give the gas just a tiny touch and it would go away (taking up slack in the pinion?) At 800mi they put a whole new rear end assembly in the Lib. That was good for about 2000mi, then it started the same vibration but on acceleration at the same speeds. They put ANOTHER rear in, that one was bad from the start. They also balance/rotated the tires and put 3 set of drive shafts in (driveshafts for 04 models are different to fix _something_, but will not work in an 03)
They just replaced the ring and pinion after trying to set the differential up on the ends of the spec ranges, in the middle, etc. Through that adjusting they were able to move the vibration from acel to decel and back, but not stop it. The new ring and pinion has not completely solved it, but seems to have made it some better. It also seems the longer you drive, the worse it'll get.
Before we bought the Lib we almost bought a 99-01 Chero, and it seemed to me on those trucks that they all vibrated at about 45mph when accelling up to highway speeds. Is this a common Jeep problem with the venerable 8 1/4 rear end?
bearing. Two days later it started a thumping noise. Now the dealer is replacing the
rear axle. My jeep has 34,000 mile on it. I will be trading after this repair
Frank
