Buick Rendezvous Accessories and Modifications
That would deprive everyone else here of valuable information!
SUVs and Smart Shopper
James :confuse:
Thanks again for your help. My wife is pregnant and this should help getting in and out of this beast of vehicle.
James
Everyone at Buick and the installer say that it can be done and I'm willing to wait, but I'm suspicious that they are only telling me what I want to hear. I was just looking for a confirmation from another source.
Do you have information as to where this is being sold on E-Bay?
http://cgi.ebay.com/ebaymotors/GM-GMC-Cadillac-escalade-remote-slave-6-disc-cd-p- layer_W0QQitemZ170099632064QQihZ007QQcategoryZ38641QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/GM-GMC-Cadillac-escalade-remote-slave-6-disc-cd-p- layer_W0QQitemZ260103871344QQihZ016QQcategoryZ38641QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/GM-GMC-Cadillac-escalade-remote-slave-6-disc-cd-p- layer_W0QQitemZ140105770823QQihZ004QQcategoryZ38641QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/GM-GMC-Cadillac-Escalade-remote-slave-6-cd-change- r_W0QQitemZ230113292374QQihZ013QQcategoryZ43948QQrdZ1QQcmdZViewItem
I will keep you informed.
Second item...I made a rear storage shelf that clips on the tie down in the rear. I made my shelf 16" deep x the width of the car, about 42". It can be made larger and comes out quite easily. The advantage of the shelf is that smaller, light items can be placed on it the heavier, bulkier bags and boxes can be removed without moving the light stuff. Again I can share the plan/pictures.
Could i get this system to work on my 2005?
Also, I really like the HUD feature. Anyone know where I could pick up this feature, without going to the dealer?
I do not have Onstar or premium bose system.
I have managed to hook up another aftermarket in-dash GPS/DVD player. I am having troubles finding the wires to hook up to the illumination of the aftermarket deck as well using the steering controls with it. The new deck has two wires to connect to the steering wheel controls, I don't seem to figure out, which ones on the factory harness are used for steering wheel controls.
Also, I have got an input for the reverse camera on the aftermarket deck that requires one wire to be hooked on to the reverse switch. Can anyone please shed some light on that as well.
Thanks :sick:
Does anyone make a cold air intake and/or a tuner for the RDV?
For some pictures, surf:
ID Bar: http://www.etrailer.com/pc-light-bars-incandescent~MC94RB.htm
http://i178.photobucket.com/albums/w251/Spike99-Pictures/Misc%20Pictures/Lights-- - - 1.jpg
http://i178.photobucket.com/albums/w251/Spike99-Pictures/Misc%20Pictures/Lights-- - - 2.jpg
If you are thinking of adding more rear lights to your non-trailer hitch RDV unit, this modification can be `cloned` on your RDV as well...
Hope this helps others...
Hey awhile back you were on edmunds and published a picture to help another person who was trying to figure out what all the plugs were in the back of his rendezvous.
He wanted to know what different ones did. Specifically so he could install a wiring harness and/or brake controller. YOu posted a nice picture... no longer hosted by photobucket...
And explained what each one did.
Its gone now and I need that info....
Can you help by sending me the picture and the info?
Here is a link to show you what I was talking about...
pauls02, "Buick Rendezvous Accessories and Modifications" #233, 11 Feb 2006 7:04 am
YOur info was down at message 252 and 254.
Can you do the same for me and email me with that info?
email to trickstandsATaol.com replace the AT with an @. Thanks
I can't seem to find my previous post / reply. Thus, here's the same info about installing a Class III hitch and its wiring for onboard Brake Controller.
For video - to install the Class III hitch: http://www.sutree.com/game.aspx?s=38711
For factory 4 pin Wire connector on RDV vehicle, puchase: http://www.autoaccessconnect.com/re2020trwiki.html
Note: Factory V92 plug under the rear right bumper area. Simply remove its blue plug and "plug in" the new V92 trailer wiring adaptor cable. Surf above URL for a picture. If wondering, I connected the "brown - running / clearance" and "white - ground" wires from this bundle to my customized rear ID bar (3 lights).
For a trailer with onboard electric brakes, puchase a 7-pin connector and mount this connector under the vehicle's rear bumper. Many need to buy its galvanized steel mounting plate as well. For a picture of this 7-pin connector, surf: http://www.etrailer.com/p-30310.htm
Note: Double check the "connector" on your existing trailer (that has its own onboard brakes). It may have a 6 pin connector or a 7-pin connector with round holes. Thus, a slightly different rear connector may have to be bought. For now, let's assume your trailer needs a 7-pin connector with blade contacts (that's shown in the above URL).
Using the 4 pin leads from your factory V92 "pig tail" and installed 7-pin connector (mounted under rear bumper area), connect the available wires together. Use a scratch pad and 12V tester to ensure each wire (and ground) is properly connected. For picture of what wire into 7-pin plug, surf: http://www.etrailer.com/Merchant2/graphics/00000001/faq/wiring_7_pole_500.jpg
The next steps should be done by a 12V auto specialist. For me (on my other vehicle - which is our tow vehicle with Brake Controller), I "pulled in" the 10 guage wiring but got my auto mechanic to connect their ends. Using 2 x 10 guage 12V wiring (one blue and one red - for example), connect to your 7-pin connector and pull these wires to the front of your vehicle. For my other vehicle, I pulled / fastened these wires on the outside (under the vehicle). If you like removing interior panels and such, run these thick 10 guage wires on the inside. If wondering, 1 wire (for example, RED wire) goes from the vehicle's "accessory" fuse to your 7-pin connector - pin #4. When your vehicle's ignition key is ON, this pin #4 is live. If wondering, pin #4 is often used to "trickle charge" a 12V battery inside the attached trailer (assuming the attached trailer has on onboard 12V battery). When the vehicle's key if OFF, there's NO current down this #4 wire. The other 10 guage wire (re: blue wire) that was installed goes from 7-pin connector Pin #2 (electric brakes) to the vehicle's onboard brake controller. For pin assignments within 7 pin connector, surf: http://www.tropictrailer.com/images/wiring/image013.jpg
For more brake controller wiring details, surf 1/3 page down: http://www.etrailer.com/faq_brakecontroller.aspx
Fully test all signals, running / clearance lights, brake controller pin #2 and 12V live pin #4. If necessary, do replace the vehicle's factory default load "flasher unit" with a HD (Heavy Duty) Flasher unit as well. Thus, stopping your flasher from flashing too fast (when towing a trailer). One of those "try it and see how fast it flashes for you" things.
Note: After wiring is fully tested, use "plastic cable loom" to protect the rear wires and use galvanized strapping to secure the wire loom bundle. External silicone the back of the 7-pin connector as well. Thus, keeping crud and rust out of this critical connector. Also... Mount the 7-pin connector on the vehicle's rear bumper. Do NOT drill holes within the installed trailer hitch. Extra holes weaken a hitch.
BTW: To connect a standard 4-pin trailer to your newly installed 7-pin connector (say a small utility trailer without brakes), simply install a 7-4 pin connector. For a picture, surf: http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200336745_200- 336745
Hope this helps...
The V92 plug (for trailer wiring harness) is located under the "left" rear bumper area. For more pictures of how I installed the ID bar, its V92 location, plastic loom and PL Premium (for water protection) coating, surf contents of:
http://s178.photobucket.com/albums/w251/Spike99-Pictures/RDV%20Rear%20Lights/
Note: To enlarge each thumbnail picture, simply click on it.
Hope this correction and more pictures helps as well....
Testing URL...
http://www.carspace.com/spike99/Albums/spike99%27s%20Album/
Hope this works... Good. It works. Thanks for sharing this trick. LOL...
Perhaps you could tell us more clearly if you used the following... DRIVERSIDE or PASSENGERSIDE.
I've looked at the photos and they appear to be passengerside rear bumper area if the tire placement and laying under the car are taken into account.
However, looking under MY rendezvous I see a pigtail just hanging loose under the DRIVER side back of the wheel well area. The other part of this continues up into the back and I assume eventually the rear driverside light.
Please help us to konw what we are looking at in the photos... were they driver or passenger side shots?
I also am unable to tell exactly what you did with the four wire plug that you purchased.
Let me restate it, I'm looking ofr a simple way to plug in and have lights to a four pin camper plug. I'd rather just connect one plug if thats possible.
The V92 outlet is under the rear bumper area - driver's side.
To connect a utility trailer that does NOT have its own onboard electric brakes, simply install a Class III hitch (as shown in the video). Then, buy the V92 to 4-pin Flat connector (which is approx 2.5 ft long). Connect the V92 plug into the vehicle's V92 outlet. Plug the other end of the wire (which is a 4 flat end) to your utility trailer.
If you pull a tent trailer or utility trailer that has its own onboard electric brakes, then install a 7-pin connector instead. Install a Brake Controller in your RDV. And if your trailer has onboard battery (like tent trailers), then install a 12V "live" wire as well.
If only pulling a light weight utility trailer that has Surge Brakes or NO onboard electric brakes, simply purchase the V92 to 4-pin wire.
For factory V92 to 4 pin Wire connector on RDV vehicle, puchase: http://www.autoaccessconnect.com/re2020trwiki.html
Forgot to mention... I do NOT tow anything with my RDV. My mechanic tells me that my 2003 RDV FWD isn't made for towing. Yes. I have a Class II trailer hitch for my RDV (which is hanging in my shed) but did NOT install it. For towing (even light weight utility trailers), I use my other vehicle - which is made for towing. My RDV's V92 to 4-pin 2.5 long wire harness was modified to connect into my vehicle's custom ID "light bar" instead. For this, I simply cut its 4-pin flat connector off and spliced its brown (running lights) and white (ground) wire into its ID light bar. Its green and yellow wire in this wire harness 2.5 long bundle were left "as is".
Hope this helps as well...
For a "light weight" utility trailer of say "1700 lbs gross wt.", your 2005 AWD RDV should easily pull it. And pull it without too much stress. If wondering, my one utility trailer has a 3,200 lbs axle and my other vehicle has a 3,600 lbs axle. Thus, I use a differt vehicle (my non - RDV vehicle) to pull either of my utility trailers. Thus, allowing my RDV to remain a "run about" vehicle. For your 2005 RDV, pulling a utility trailer of "1700 lbs gross wt." is very little stress on it.
If you pull a "loaded" utility trailer WITH rear cargo and/or WITH lots of passengers, I'd recommend installing an Aux Transmission Cooler as well. Thus, keeping its tranmission oil "cool". Cool = longer transmission life. For example: http://www.makcotransmissionparts.com/OC-1678.html
And if the rear of your vehicle has too much rear sag, you might want to investigate Timbrens or Air Bag suspension upgrade as well. re: http://www.timbren.com/timbren-application-guides/application-pdfs/GMRREN.pdf
As long as you pull a light weight utility trailer and don't over "push it" during stop/go traffic, against strong head wind and/or up the steep hills, your 2005 RDV should easily pull a max loaded 1,700 lbs utility trailer.
Not too sure about E3 Plugs myself. Especially E3 design (which might burn hotter) that's being used in a small GM engine - within a heavy weight vehicle like the Rendezvous.
To learn what E3 plug design is, watch video at: http://www.youtube.com/watch?v=sX8TNTT0vGQ
To learn any "high problem" pattern areas, simply google "e3 spark plug problems".
re: http://www.google.ca/search?hl=en&source=hp&q=e3+spark+plug+problems&meta=&aq=4&- oq=e3+spark+plug+
Based on the posts I've read, many folks seems to like the E3 spark plug design.
Hope this helps...
