Visitor Agreement.
A soon as I get 5K miles on the Chevron SL I'm currently running, I will do an analysis and post the results. This should give us a good idea just how long this stuff is good for.
Wain
Jiffylube's 3K oil change recommendation is based on one thing; making money!
70s?
80s?
I really think the filter does a lot, even when used only 3K. I remember several old cars that had no filter, and I recall overhauling some engines in my garage. Times change, and engines as well as oil are so different we cannot make direct comparisons. Yet, I guess I prefer to think that yeoman grade filters by the top providers do help increase engine life--
Cost $10 $2
Type HP-2001 ST 3980
Element Length 3.375 3.375
# Pleats 59 53
Quality Thinner Thicker
Spring Single Leaf Double Leaf
Inlet Holes 6 8 Larger Holes
Shell Thickness .019"-.022" .013"-.016"
AntiDrainback Both similar material, slightly different design
Bypass valves None None
These filters are the equivalent of PF-52
Conclusions: I would Buy either. The element on the Supertech was more uniform spacing. Both are champion Labs. I basically like the heavier construction of the K&N-which is probably overkill.
You are no doubt right on that. Nowhere in any of the online oil filter comparisons I have read, have they had a canister of any brand rupture. There was a seam leakage problem with one (can't remember the brand), but no canister failure due to thickness of the steel used.
By the way, your unbiased, give-the-information approach on this comparo is excellent.
I have never used Fram (I usually use Purolator). The reason I am asking is it appears that some Honda filters are made by Fram. Why would Honda use substandard filters for OEM if other good, cheap options were available (like the Champion Supertech)? If Honda is using them can we assume they will perform well?
I am not looking to pick a fight (seems some people really hate Fram). I own a Honda (actually two) and I am wondering if I should use the OEM filter on one of them.
I am not sure if the Fram filter was bypassing 100% and not allowing pressure buildup, or if it was NOT bypassing and obstructing flow, but either way it was definitely causing a noise that other brand filters never caused again.I use the supertech filters now, they seem to be the same as the Walmart version of the AC filters used to be.
Anyone else have similar experience with the Fram filters?
see y'all
Rando
when and why did that happen.
hard to believe a filteris "full" at 3000 miles?????
For two or three dollars you are willing to leave a pint to a quart of dirty, and chemically (acid) damaged oil in your car when you put in three or four quarts of new clean oil? Not I.
then Consumer reports says ok to go long distances say 7.5k so whats so important about a filter every time. where is the data that says thats needed. it used to be every other. And that was when filters were bigger.
I know this is a repeat, but can someone remind me who manufactures the Castrol Max Pro (white box) filters. I believe it's Champion Labs or Wix, but I can't remember which. I picked up 4 filters that fit our 98 Isuzu Trooper today at KMart for $2.50 each. I'm sure they were on clearance for less at the going-out-of-business locations, but I think I missed my chance on that.
Anyone else notice from referencing the NTPOG oil filter survey that most of the substitute filters didn't come close to the inlet area and filter media area of the 3 honda oem filters. I wonder if Honda is trying to emphasize oil flow rates?
Keeping this in mind, whenever the dealer is out of the Filtech oem filter, I use the oversize wallyworld st3950 which comes close to the honda specs.
And the link he referred to:
http://www.ntpog.org/reviews/filters/filters.shtml
It's too bad we can't get the Japanese honda oem filter here. The Hamp looks good, but is expensive and hard to find.
Also, I use mobil1 10w30 and don't replace oil and filter until 6k.
Like I said, I do use the supertech oversize filter when the dealer only has the canadian oem (Fram) in stock.
