Oil Filters, whose is best, and Why?
1282931333449
  • malachy72malachy72 Member Posts: 325
    those are the filters for my 2 hondas. I'll have to check them out at wally's. The filters are an SOB to get at compared to my wife's Sport Trac and my sister's '01 camry which is right on top.
    I hope the kids appreciate the forward thinking your doing on their behalf. I've been telling my friends that I'm going to tape a sign on my '89 accord in the rear window:
    " NOT FOR SALE,
    EAT YOUR HEART OUT"
    And looking at the odometer and checking my spreadsheet I've put 2.5k on in about 5 weeks.
    Can't figure out where the hell I drove. But fleetwood,I do have that Chevron Supreme 10-30 in stock calling me from the garage to pamper the old crankcase with it.
  • mike1qazmike1qaz Member Posts: 93
    Yeah, you do have to lay under the Accord to get to the oil filter. But this is nothing compared to changing one on a Nissan Frontier 2.4L 4cyl.
    I'm wondering what the odometer reads on your '89 accord.
  • armtdmarmtdm Member Posts: 2,057
    The oil enters the oil filter under pressure through the holes on the perimeter of the base plate.
    The "dirty" oil then passes through the filter media where it is "cleaned". It then flows to the central tube and back into the engine through the usually threaded hollow center mounting stud.
    The Bypass Valve
    Under ideal conditions, the bypass valve will never open. When it opens, the oil by passes the filter and goes on through to the motor, obviously unfiltered. It is a safety valve. However, in real operation, it opens often.
    One example is when you start the motor when cold. The oil is thick and does not pass easily through the filtration medium, thus building up to a high pressure drop. So, the bypass valve opens to prevent oil-starvation of the motor. How long it stays open is dependent on how cold the oil is and how long it takes to get near operating temperature. When the pressure drop across the filtration medium drops below the bypass valve setting.
    Another example can occur when the motor is fully warmed. At idle, the oil pressure is about 15 to 20 psi, and the pressure drop across the filter is about 1 or 2 psi. You take off towards the redline, and quickly build oil pressure. During that full-throttle acceleration the pressure drop across the filter will exceed the bypass setting, and send unfiltered oil to the motor, until the pressure across the filter has time to equalize. During a drag race, shifting through the gears, the bypass will open several times.
    A third example, which you should never experience with frequent oil and filter changes, is when a filter becomes clogged. A spin-on filter can commonly hold 10 to 20 grams of trash before it becomes fully clogged. The bypass valve opening is the only way to keep the motor from becoming oil-starved if the filter becomes clogged.
    If you do lots of racing, you're probably better off with a higher bypass setting.
    If you do lots of *cold* starting, especially in the winter, or seldom change your filter, I think you're better off with a lower bypass setting. However, with few exceptions, bypass pressures for spin-on filters run in the 8 to 17 psi range, and any of them should work acceptably.
    it reads 220k but the cable was out for about 7k miles.
    My in laws gave me an '88 civic wagon w/AWD last year. I put about $ 1200 into which was paid for with a rebate on my Citibank drivers edge card.(Had my pop in law give me a bill of sale for 1k and I paid the sales tax). I'm looking for 200k from this car , it has 110k on it. Some rust on rear wheel wells, a project to address soon. It mostly a winter car as a/c malfunctions. It is a quick little SOB with f.inj. 1.6L
  • fleetwoodsimcafleetwoodsimca Member Posts: 1,518
    Confidence in the Wix and Champion companies is precisely why I choose to use their oil filters. I know I am getting absolutely adequate filtration to maximize the miles I might choose to run my vehicles. If I were to own a car capable of going out to, say, 300K, I would be confident that these filters would NOT shorten that figure. I am very comfortable with the pricing of the Kmart and Walmart house branded Wix and Champion filters, and that leads me lately to restock my (vast!) cache of filters from those stores. There are other makers producing perfectly acceptable filters, as well. Yes, I own a batch of those, too! (:o]
    just how long are you set up for oil and filter changes? I've been keeping a couple of filters around, enough for 2 changes, but only enough oil for the next change on each car.
    ...concerning both oil and filters. Kmart may/may not stay in business-- but we presume they will. If so, they may make major changes which could include no more Wix, or whatever. In the oil arena, SL oil is under threat to be redefined in the next year, or not long after, and that threatens to be undesirable for many consumers that place barrier protection above mileage, etc.
    Let me put it this way: I can hold out for at least two years without any more purchases.>:oÞ
  • zr2randozr2rando Member Posts: 391
    Hopefully the following will show easy to read, I have compared a few filters, I use the comparable filters to the Ac PF52 for a Chevy 4.3 V6:
    Filter Cartridge Length Pleat Depth Pleat Number Area Notes
    Chevy S10 4.3 V6
    Castrol Plus CMP3980 3 11/16 10/16 47 217 box says synth mix, paper obviously thicker (lrg int holes)
    Penske Maxpro CM3980 3 11/16 10/16 50 230 std paper lrg int holes
    Penske PN3980 3 11/16 10/16 50 230 std paper lrg int holes
    PureOne PL24011 3 12/16 8/16 63 236 box says "micronic", no string around cart.
    Kmart AC PF52 4 3/16 13/16 36 244 std paper lrg int holes
    Walmart AC PF52 4 8/16 61 244 std paper
    Supertech St3980 3 12/16 8/16 55 206 box says synthetic enhanced media
    Well it is easy enough to read I guess but I would rather it be able to be 1 line per record...
    Basically the Supertech looks like it is made by Champion, (same construction as the Walmart version of the AC PF52) but with a few noticeable differences.
    The anti-backflow valve is the same.
    Center tube on both is the same
    The Supertech cartridge is shorter (AC is 4in, ST is 3.75)
    The Supertech cannister is visually thinner than the AC, Not flimsy, but is thinner.
    The Supertech has visually thicker media than the AC, which looks like is the reason that it contains less square inches,(about 15% less), the cartridge is still well filled with media (evenly and closely spaced)..box says it is synthetic enhanced, but visually you can see it is thicker.
    I would say that the filter is very well made, and definitely worth the money (I paid $1 for them, but normal price is $2). They do have a limitation though, at least in this application, they have less filtration area (and using synthetic enhanced media) would decrease total flow faster than some other brands would.
    I change oil at 3k miles, sometimes even less, so the lack of media area is probably not a show stopper, but I would NOT recommend the filter for extended drains (unless you change filters during the oil change interval)
    Hope this info is usefull to anyone using the Supertechs!!
    Rando
    Like you, I usually change oil and filter in each of my family's cars/trucks at 3K. Where we might differ some is in length-of-service for Supertech filters. I would let one go 5K without worry, but I won't, because I'd worry about the oil instead! >:o]
    I'm just big on the 3k thing myself, it looked good enough to go longer,,,(poured some used oil in the center to see how fast it settled out through the paper, and it settled pretty fast)
    I definitely don't have any reason to NOT use them.
  • fwatsonfwatson Member Posts: 639
    Quote:"Well it is easy enough to read I guess but I would rather it be able to be 1 line per record..."
    I use dashes to keep things seperated. This site ignores spaces and closes the gap, which screws up your spacing.
    but I thought some might find this thread interesting asto how an oil filter and its components operate:
    http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=6;t=000048
    post 1510-- I'm sure you're right on the Supertechs being (apparently) Champion made, and also the AC Delcos at Walmart appear to be Champion. I bought 4 AC Delco filters for my Geo Prizm when they were on close out at Kmart, here. Have you noted that a "trade mark" of Wix made filters is the spiral twist appearance in the central return tube?
    Walmart AC filters were the Champions, the ST at Walmart now are too. The Kmart Ac filters I think were made by Delphi, And the Kmart others (Penski/Castrol) are Wix clones, at least for the time being, I think Fram is making at least a temporary comback at the moment,,,I won't use them though. I am using the ST filters, I have about 8 on the shelf at the moment, they were on sale for a buck each.
    Good morning,
    Rando
  • jc1973jc1973 Member Posts: 63
    hi all i was was wondering if the motorcraft oil filters were good i use themon my 1990 ford van but i use the supertech,s on my 94 sunbirdv6 are those good also
    I have had good service from Motorcraft filters, and do not hesitate to buy them when I find them at competitive prices. I do not pay a premium for Motorcraft or AC Delco filters, but use them readily when they are "cheap." I fully trust Supertech filters from Walmart, and would not hesitate to buy them with full service expectancy. You might want to look at the Kmart filters made by Wix, as well. They are under the Penske and Castrol names. I have a slight preference at present for those over the other modestly priced, but fully capable filters mentioned above.
  • alternatoralternator Member Posts: 629
    now carry only Fram oil and air filters, no others!
    That's bad news, but thanks for giving us all a heads up on what we may all expect in the near future. I'll check here, when I can. It's not a short trip to Kmart for me. I have about a dozen Castrol and Penske filters to hold me a while on my two Nissan 3.2L V6's-- I may be back in the fire on those, in the future. You see, I do not like the shorty filter offered by Supertech at Walmart for that Nissan engine. AutoZone wants double the money to buy a Bosch for it. My dilemma is wanting a long filter, and a bargain price at the same time!
    I rode my Valkyrie over to Big Kmart yesterday, and investigated the filter stock there. They had some of everything-- Fram, Penske, Castrol, AC Delco. There were no sale prices on any of it. I get the idea that some of the merchandising and marketing going on is store by store. When I get by a different store location, I'll check again.
    #1521
    Yes, I also get the feeling the marketing and merchandizing is going on store by store. I have to admit that it is a good feeling getting a 8 dollar retail filter AC Delco PF-44 for 2 bucks and below. I do miss that loud orange color however! :)
    I JUST HAD MY OIL CHANGED 3 DAYS AGO ON MY 90 FORD VAN THEY PUT ON A MIGHTY OIL FILTER ARE THESE GOOD FILTERS
  • raimondi1raimondi1 Member Posts: 9
    Hi any1 out there try the new FRAM SURE DRAIN oilpan drain plug kits? They look like a good idea since they would save some wear and tear on the drain plug threads and leaks from frequent removal (especially on aluminum oilpans!)
    accord, Drained oil out last week for the first time. It worked well. Upon installation, you really have to tighten it more than you would your oil drain plug to 'crack' the gasket it the base of the setup to seal it tightly. Had to raise the car a second time when I spotted oil coming from around the plug. This fixed it.
    I have five of the valves but they are the Fumoto valves not the Fram. Fram did not make them when I made my purchases Fumotos are about twice a smuch as fram, very well constructed though and I would purchase again. Defintiely easier and better then pulling that plug out
    Yes, I have them on my '95 Olds, and my '01 Millenia.
    I will never again be without them.
    Their construction is excellent, and they making all but changing the filter much easier. Not to mention you will never have to worry about stripping the drain plug threads.
    In your opinion, is there any chance (no matter how remote) that the valve on the Fram drain device could vibrate open and spill the oil?
    Also, does the oil drain out nearly as fast with the drain device installed as without it?
    I see no way for the oil to be lost. In addition to a spring loaded valve that only opens when pushed open by the drain hose, there is an o-ring cap that is apparently intended primarily as a dirt/dust shield. It is heavy brass with an o-ring that seals as well as any seal on your car.
    Draining is slowed by the valve, but the hose allows you to direct the oil into a milk jug or other such container for disposal. I cut both of my hoses to about four inches to make them easier to handle. They are still plenty long enough to go well into the drain jug.
    My only concern would be if the drain plug is directly on the bottom of the oil pan and hangs down to where it can be easily hit going over something. In that case, you might damage or knock the valve off more easily than you would knock the original drain plug off. It only protrudes about 3/4 of an inch, but that is farther than the original plug does.
    I have decided to stay with the ol' drain plug from the factory on all my vehicles, for the time being. The reason is that it is conceivable that road hazards might cause you to lose your oil through a Fumoto or Fram valve, under circumstances that might not cause oil loss if one had kept using an original equipment style plug.
    #1530
    I agree with you.
    I change my oil and oil filter once a year or 15k miles.
    The hardest part of the oil change is getting the vehicle lifted to its proper position and the clean up!!! If you look at the % time you do the task , (wrenching the oil drain plug) It is almost so low as to be negligible.
    Besides for what those plugs cost I can buy 4-5 oil filters.
    If half the price of a Quicky Lube oil change is too much for you, that is certainly your prerogative. They make the job much easier, as well as far cleaner. No hot oil on your hands is a bonus. I have done hundreds of oil changes including in a filling station as part of my job. Florida quick lube installs this type device on fleet vehicles, and they are standing underneath the vehicle looking the plug in the face. I have never seen one damaged or leaking.
    $13 for this kind of convenience is worth far more to me than a few cokes, beers or Big Macs. If you haven't used one of these you do not know what you are missing. Brand name is of no importance on these.
    As far as damaging the drain valve. On both of my cars, the plug is on the back side above the bottom edge of the oil pan. If anything hits one of them, I hope I am not in the car at that time.
    I think it will be worth it to me --- not to have to transfer hot oil from catch container to disposable container.
    #1532
    In addition to changing the oil one a year (100's of times to me would 1.5m miles) My drain plug already has less than 3.5 in road clearance. It also faces foward at almost the lowest point on the underbody. If in the unlikely case it would fit between the notched out cross member it would be even lower!!! I have to agree with you even more than you state.
    "As far as damaging the drain valve. On both of my cars, the plug is on the back side above the bottom edge of the oil pan. If anything hits one of them, I hope I am not in the car at that time."
  • adc100adc100 Member Posts: 1,521
    The two issues for me were: Not as good a flush when draining. This could be minimumized by following the drain with a few ounces of kerosene. I average an oil drain every 9 months. I like the really positive method of torquing the plug. I guess you have to have one to appreciate it.
    Al, I know you do drains on more than one car. I'm sure you must use ramps to lift the front end for drains. This grading assures that as much of the oil will drain as with any pulling of a plug, save perhaps half a tear drop. What would really be of interest to you is the ease in which the sampling for oil in the middle of the pour which I understand is most desirable as procedures go.
    Just my 2 cents. I'm not the Pontiff on the topic.
    (:oÞruking1 Right on!
    (:oÞfwatson Hey, Cokes and beers are one thing, but a Big Mac? I couldn't give THAT up!
    Good point. I use a sample bottle which collapses and the tubing goes right down the dipstick tube. I'm not saying the plug isn't a good idea. Just not ready for it right now.
    what's up with that special sauce? It's just too tough to keep that big mac stacked through the devouring process. Thumbs up to those new fajitas though.
    Ronnie Mac dropped the 99 cent rotating specials here, so I dropped going in to buy! I'm out of the loop. Lost a battery in their parking lot about a month ago. Bad experience. Had to call an auto shop to come jump me. I bought a new AC Delco battery at that shop, about 10 blocks from Ronnies.
  • striker13striker13 Member Posts: 1
    i own a 1990 honda civic wagon with 190k, and change oil at 4k intervals. i use oem oil filters and the engine still pulls as strong as the day i purchased the car. i offer this info only to inform.
    Now maybe , someone knows off hand who makes OEM for Honda? BTW, striker, this is with regular dino oil? And your engine is still running at 190k? Someone call the Guinness Book Of World Records! LOL
    I have a friend who continues to drive his 1981 Chevette 4 cylinder daily. It has almost 207K miles, accumulated with 7500 mile change intervals on NAPA petroleum oil (Valvoline in disguise) and NAPA (WIX} filters. This rig thinks it's a Timex-- It takes a licking and keeps on ticking!
  • tntitantntitan Member Posts: 306
    often discussed topic. The American made OEM filters are usually made by Filtech (it will say so on the outside of the filter) and the Canadian filters are made by Fram (I think - don't recall for sure). I don't believe that the Japanese filters can be purchased here.
    I use the Wallyworld $2 SuperTechs (Champion) on my Hondas.
    Routine servicing of the 2002 Mazda Protege (for example) calls for replacing the oil and oil filter every 6 months or 7,500 miles (4 months or 5,000 miles if severe service applies).
    Many of us like to be more conservative, so we choose 3,000 miles for our oil and oil filter change. Now, if that seems overly expensive or inconvenient, consider the following:
    The most-modern of motor cars in its own time (and a wonderful technological marvel it truly was) --- the 1930-1932 Model L29 Cord --- had the following manufacturer's service recommendations:
    Engine: Every 500 miles, change oil (8 quarts)
    Engine: Every 8,000 to 10,000 miles, change oil filter (WOW !!!)
    Chassis: Daily, or every 100 miles, depress lubricator pedal
    Generator: Every 1,000 miles, add 8/10drops of oil to front and rear cap oilers
    Starter: Every 1,000 miles, add 8/10drops of oil to oiler
    Distributor: Every 1,000 miles, oil breaker arm pivots, give grease cup one turn, lube cam with vaseline
    Wheel universals: Every 2,000 miles, lube
    Drag link: Every 500 miles, add grease
    Front tie rod: Every 500 miles, add grease
    Rear wheel bearings: Every 3 to 6 months, clean and repack
    Front wheel bearings: Every 3 to 6 months, clean and repack
    Steering gear: Every 500 miles, top off oil
    We really have it easy today don't we?
  • csandstecsandste Member Posts: 1,866
    I think there's been discussion, both here and on Bobistheoilguy stating that the SuperTech (Wal-Mart/Champion Labs) filters are better not only than the Canadian Frams but the FilTechs as well. Frankly I think that SL oils are good enough, especially with 4K oil changes, that most cars could last that long-- even with Fram filters.
    sounds like a NASCAR maintenance. 4 or 5 hundred miles and rebuild.
  • pluto5pluto5 Member Posts: 618
    Returned my stock of Fram filters and got a full refund, no receipts required--bought Super-Tech filters for 2 bucks apiece. If more people did that Fram would have to make a better filter.
    I guess they remain #1 in the market, so that would take a lot of returns!
