Oil Filters, whose is best, and Why?
1101113151649
  • wainwain Member Posts: 479
    "A lot of things that I know are not for public consumption. I would not betray the trust of our customers by posting confidential information on the internet. That would be very unprofessional and unethical."
    Not directed at you, but that philosophy prevents many consumers from getting the info they need to choose the products that meets their wants (economy, efficiency etc).
    As it is now, seems all the filter makers claim theirs is the best,
    same with oils, -Consumer reports in the big taxi tests said all the oils are the same
    Thats possibly true (except for Frams cardboard, and "Bosch" using the german name to increase brand integrity ) for filters too.
  • zr2randozr2rando Member Posts: 391
    Funny how companies use it...
    Tsjay's philosophy probably also holds down on some lawsuits for discussing some proprietary stuff as well....
    All the stuff we DO say on here though is good at making us check some things for ourselves, and also makes us think about points of view we may not have thought of previously. I have started cutting open filters for the last few months now because of what I have read on here, some things we can do ourselves. Some things are not so easy though and we can always benefit from other's experience...I learned a few things about filtration years ago taking Chemical Engineering classes which gives me a couple of viewpoints that another person may not know. Someone else may know construction methods that I do not know and so on.
    Ever notice that dark colors, particularly black signify high quality (Hormel black label ham,black tie affair,castrol plus filter,Bosch(and the aforementioned German name) etc)and light colors (yellow/gray/white) signify average grade (penski/supertech/Castrol std)??? Sometimes the different color may get more $$$ for the exact same,or at least VERY similar filters..
    Point is we all can contribute with whatever background we can contribute with. We all have something to add
  • gasguzzgasguzz Member Posts: 214
    Not at all unusual on Tsjay's work philosophy. When you join a design shop you sign a paper essentially meaning "what goes on here stays here" (they then pay you money and that closes the deal). Unless there is a public safety issue you are obligated to retain company intellectual property within your office.
    I use Mobil 1 filters, unless they aren't available at the time, then I use a Pure One. The reason is because I run full synthetic oil, and I only change my oil and filter every 10K miles, so I want to use the best filter avaialble. The Mobil 1 is worth the $10 to me, knowing I'm getting the best. I don't think a guy could go wrong using either of these filters.
  • adc100adc100 Member Posts: 1,521
    Due to their very high efficiency, I would be concerned with keeping one in more than 5K for instance. I used to use them but I have now switched to K&N because of their claim of 9-13 gpm flow vs the normal 3 for most filters. Their effficiency is advertised at 90%. Also, something else to consider is looking to find oversize filters. I have done this for several vehicles. There is always one available. The classic is replacing the equivalent AC pf-52 for the tiny pf-47. If there's room thats a no brainer. The K&Ns may not be worth the money, but that's my current practice.
    tsjay Do you know anything about the paper in the K&Ns??
  • tsjaytsjay Member Posts: 4,591
    know anything about the K& N oil filters. Gonna have to get our salesmen on the ball and check out that bidness. :) They may use some kind of 100% synthetic media. Aren't their air filters pure synthetic?
    Heck, if someone makes filters for K&N, we might actually have some of the business already. We don't sell directly to K&N, but maybe they buy their filters from someone that we do supply media to.
    tom
    I think the K&N Air filter uses oiled cotton, cotton is actually kinda cool stuff. I have them on my 2 Chevy's, not so much for any extra power or anything but mainly because they flow high air for a long change interval. The adv for the oil filter just says "resin impregnated" filtration media, I,ve never used one of them, so I've never cut open a used one either...I wish that Mopar study fellow had tested one of them though!
    I don't think there's any problem at all running a Mobil 1 or a Pure One for 10 grand. However, I wouldn't try it with an el cheapo Fram! I do like the idea of running a larger filter though. As far as oil filters go, bigger is better! I'm going to find out which one will work on my Honda.
    Like I said before, go to the Purolator Filter book and look on about page 929. compare the diameter, and relief setting and then find one longer than yours.
  • brorjacebrorjace Member Posts: 588
    I had thought that K&N oil filters were made by Champion labs. This is not the case?
    I read on Hastings site that their's are good for 10,000-12,000 miles. I'll have to check and get a firm number.
    tsjay, if someone doubts your credentials, that's their loss. Don't worry about it.
    --- Bror Jace
    No, actually K&N filters are made by K&N. Mobil filters are made by Champion labs.
  • jmsintxjmsintx Member Posts: 41
    Mobil 1 and Bosch Premium are made by Champion Labs. I thought that K&N oil filters were also made by Champion Labs, their construction certainly looks the same. I don't think that K&N actually makes anything that they market.
    Thanks! I figured my Buds would stick up for me.
    I have up til now and will continue to speak what I know for a fact, and if I am just speculating about something, I will say that I am just guessing. And, of course, like everyone else, there will be times that I am just plain wrong about something. I will graciously accept being corrected in those instances.
    But, I don't like being called a blowhard or a liar. :)
    tom
    K&N makes everything they market.
    Bottgers, that's good to know. Thanks.
    Tom, do you frequent many other boards? I get called more names by silly kids that get upset when I say that their choice of oil isn't the best in the world.
    Wear their scorn like a badge of honor. >;^)
    --- Bror Jace
  • ygriegaygriega Member Posts: 18
    The evil Ygriega returns. Perhaps Mr. tsjay could
    show us where I used the words "blowhard" and "liar" in my #597 post. I read "nonsense" and "myth". And this is a "personal attack"?
    In all seriousness and civility, I would really like for anyone to explain the rationale for a filter manufacturer to build three (3) different
    engine oil filters for the same engine. In 2001 I bought two (2) new 2001 Ford Explorers with the
    302 c.i. engine. I also bought an oil filter from the dealer and at the third oil change I bought a Motorcraft FL-820S from Advance autoparts. I removed the factory filter, I removed the dealer filter I installed, and I installed an "aftermarket" Advance filter.
    ALL THREE WERE IDENTICAL. If the process--and it
    was stated as fact, not conjecture--offered by Mr. tsjay is that there are three different classes of filters for the abovementioned application is true, I'd just like to know WHY.
    It makes no sense to me, either from an engineering standpoint nor a marketing one. So
    educate me. (BTW, I'm no kid, Bror Jace. I'm 54.)
    The filters break down as listed above.
    The "Engine Plant" filters, as the name of the category implies, go straight to the engine plants and are the filters that are on the new vehicle when you first buy it.
    The second category of filters, OEM Replacement, are the ones at the service departments at dealerships.
    The third category, after market, would be the Motorcrafts, for example, that can be bought at an auto parts store or a discount store.
    I did not say that there would be a different filter for each of these categories, at least not a difference that you would see when the filters are cut open.
    It's a matter of the degree of testing required and the ease with which a supplier might get a deviation where the "official" performance spec is not being met.
    I won't say which brand of filter it was, but I knew that two different customers of ours were making the same filter, and I knew that the paper we supplied one of these customers was a higher performing sheet than the one we supplied to the other customer. This is when it was explained to me that the one customer had the engine plant business and the other had the after market replacemnent business.
    The filters would probably look identical when cut open, but the performance of one would be higher than that of the other.
    I don't think I am above being challenged, Ygriega, it was just the tone of your post that I took offense to. Maybe you didn't mean it the way it sounded, but it seemed that you were more or less telling me that I either didn't know what I was talking about or that I was lying.
    Oh well, I would like to forget it and just be friends, whatcha think?
    tom
  • vidtechvidtech Member Posts: 212
    how much of a difference in quality would there be between a motorcraft filter installed at the dealer's quick lube and the same filter purchased at k mart?
    In the real world? Not much! Filters are pretty much over-designed and never see the dirt loading that the test stands put on them. Filter manufacturers are just trying to come up with an edge over competition, so they want to advertise a higher performance than the other guy.
    The info below is just a hypothetical example and is not Motorcraft data.
    On the old J806 filter test which I am most familiar with, if the dust add rate is 1.5 grams per hour, then the aftermarket filter might last 10 hours and the OEM might last 12 hours. In either case, the filter would never see that much dirt in the real world.
    tom
    Friends it is. And nothing was intended to be insulting, lack of factual documentation just frustrates me. One final clarification about my anecdote and I'll shut up: All three of the filters on both of the Explorers had the identical Motorcraft FL-820S logo. This is what I don't get. Why shouldn't they all be the same?
    What does Purolater gain by designating three different types or standards depending on where they're going? It's a new Ford 302 and it's under warranty and why would Purolater care? I guess I'm really missing something here. Anyway, you definitely know the filter media business.
    Bye.
    I guess I need to explain a little better, so I will use imaginary companies in a hypothetical example.
    Acme Motors wants their own brand of filters to put on their cars and to sell at their dealerships in the service departments, but they do not make their own filters, so they have to spec them out and get bids from filter companies.
    Filter Companies A, B, and C make prototype filters and submit them to Acme along with a price quote.
    Company A is the first to make an acceptable filter, so Acme awards the contract to them for the engine plant filters and the OEM replacement filters for the dealerships.
    Company B comes along and says we are not quite up to the performance level on your spec, but we will sell you our filters for X amount per filter. If the X amount they are charging is an appreciable savings for Acme, they might say, OK, we will grant you a deviation so that we can accept you filters while you work on improving the performance. Well, Acme would most likely order a good portion of their replacement filters from Company B , but would only buy the engine plant filters from Company A.
    Maybe company C eventually gets in the game and gets some of the business also.
    Here's where I lack an understanding of how it works... the Acme filters that you would buy at a Walmart. Acme lends their name to these filters, but Acme neither makes them nor sells them. It must be just some licensing agreement, I guess. The filter company can put the Acme brand on them, if they meet certain standards, and Walmart can sell them. I suppose Acme gets a percentage of the price of the filter under the licensing agreement. The question is, what are the standards for these filters? Maybe they are officially the same, but in reality, are they up to the specified level, and who is checking them and how often?
    Now, I am just speculating about how it works for the Walmart Acme filters, but what I said makes sense. If someone can provide confirmation or can tell us otherwise, I would appreciate the info.
    So, Ygriega, it isn't the same filter company putting out three different performance levels of the same filter: it is different filter makers all trying to meet the same spec. Company A in the example above could (and probably would love to) have ALL of the business, but they may be unwilling to meet the price of Company B.
    Hope this helps. And I hope I'n not too far off base about how things work for the discount store Acme filters.
    tom
  • vwracervwracer Member Posts: 90
    Don't forget about packaging. Factory filters are not individually packaged (one filter in one box)but are in a bulk container say maybe 200. This would cause a much cheaper price per unit.
    Another thing that might be happening is Acme Motors has a Licensesing agreement with company A to distribute and sell filters in a specific region of the USA (such as the East coast) Company B to distribute and sell filters in a different region of the USA (such as the West coast) , while company C might have a licensesing agreement to sell after market filters in another country (such as Canada). I know this happens with other products.
    tsjay:
    All this is assuming there are actually such things as
    "engine plant filters" vs "OEM filters" vs "aftermarket filters". This is where you--with all due respect--lose me. I just don't see the reason for these three "types" of filters.
    This all makes my head hurt....
    Those are just the "categories" that the filters fall into according to where they go. They aren't actually different filters. Just the strictness of how the filters are held to a spec is the difference.
    The engine plant filters are purchased specifically for use in the engine plant. They are held to the strictest standards.
    In reality, one company could make all the filters for each of the categories, and the performance level would be the same for all of them. That's usually not the case, however.
    tom
    The reason is probably substitutions.
    I used to work in the brake business and when I opened a set of brake pads I would find all sorts of brands and combinations of brands in the same packging. The dozen or so brake pad assembliers I was familiar with at the time would buy friction material from the same 3-4 manufacturers of friction linings and materials. So, direct competitors were selling the exact same product.
    It was worse when the brakes were imported. These things were packaged, stored, repacked sometimes a handful of times. Lots were bought wholesale, with certain numbers missing and those were sourced separately.
    So, it does not surprise me at all that a large company like GM would source something like oil filters from a number of different manufacturers. And it might be impossible to find a set, definitve pattern for where the different filters show up (dealerships, factories, discounters, etc ...). It all depends on which numbers were needed where and which supplier was able to fulfill a last-minute order.
    --- Bror Jace
  • tboner1965tboner1965 Member Posts: 647
    Makes me feel a bit better about choosing K&N. I'm confident I'm getting a consistent, quality filter.
    TB
  • ocelot1ocelot1 Member Posts: 101
    Ijust bought some filters from a web site. Two bosch and two nippon. The nippon looks like they came straight from japan the box says they were made in mayaysia the bosch made in the US, and the construction is quite different from the bosch. I looked in side and counted the pleats and the nippon has 65 the bosch has 40 pleats also the holes in the nippon are about twice as large as the bosch, the holes inside and on the face plate. The nippon is about 1/4inch larger in diameter and the same height. My personal opinion is the nippon is a better filter and was 8cents cheaper yes 8 pennys.One other thing the nippon came with a dust cover platic lid that covers the exposed part and the box was taped shut. Now when I buy filters at the dealer the are usually shrinkrap ? on that spelling. So keeping dust out or maybe air might be somewhat important. Maybe long exposer to the atmosphere may break down the paper used in the filter? Tony
  • csandstecsandste Member Posts: 1,866
    They're supposed to be better than STP, Deutsch, SuperTech, etc. but they look about the same to me when I see them cut open at AutoZone. Better paper quality TSJAY?
  • knapp3knapp3 Member Posts: 112
    etech, I've noticed Bosch filters too. They seem like a good "middle of the road" value to me. I found the parts book at Auto Zone to be pretty good, if you haven't checked it out yet, and it should find you a cross reference for the Mobil 301. One of the counter guys ought to be able to answer your questions too. Interestingly, the Bosch web site does not have any way to contact them as best as I can tell. But the Champion Labs folks have responded to questions I've asked about Bosch filters...as a last resort.
    Chuck
    I assume Bosch filters are not related to be German company?
    but made in us?
    If true, they are riding on the name.
    What if they were called "Smithy Filters" or Freddie Filters, or South Chicago Filters?.
    Would you buy it?
    That plastic cover could be to keep the salt-laden moisture from getting to the metal parts of the filter and causing rust during shipment. They would spend several days in transit on ship to get here.
    The paper would not need protection, since it would be resin-impregnated, and the resin would be cured during the assembly process.
    tom
    That would be a good bet. The filter media could be better in the Bosch. Those you mentioned are all Champion Labs filters, so I would guess a lot of the difference would be just the type of media used.
    tom
  • sinjin_dogsinjin_dog Member Posts: 84
    Yes, Bosh seems like a good "middle of the road" value to me also, readily available at Auto Zone. For the price Mobile1 filter, I can buy two Bosh and change filter at 3500 miles (assuming you are using synthetic oil) rather than say 7000 miles.
    tsjay, I belive I already asked you this question in the past.
    Bosch of Germany. They would be marketed under license with the Bosch name. The specifications would be approved by Bosch.
    I bet they are not - who would know for sure?
    Ygriega, you were talking about buying the filters at 3 diff places and all being the same,
    could be that the Ford filter for that particular application IS the same at all 3 different locations, but another application MAY NOT BE...
    I use the AC pf52 for my 2 Chevys and the AC pf43 for my Nissan truck, they have nothing in common with each other when comparing the Kmart pf52 and the Walmart pf52 for example, the pf43 is also obviously different at each store as well.
    I had some service (replacing a reman engine for another reman engine under the reman engine warranty!!!) done at a Chevy dealer and they used a filter that looks like the Walmart version (I have not cut it open yet, I just looked at it while they were finishing up installing the new engine)..
    So I know from personal experience that at least some filters are identical on the outside (paint color anyway) and totally different on the inside..obviously different manufactures, not just different grades of paper...others could be same manufactures just using different grades of paper only, maybe for a slight cost difference..
    Wal mart sells on low price.
    Thank you, sir. You read and comprehended the point I was trying to make. And you are probably right--it depends on the particular make/model application.
    I have never cut a filter open. I'm pretty anal, but not that anal or inquisitive. Maybe I should be. It just appeared to me that I had a factory,
    a dealer OEM, and a parts house filter and they all
    were the same. And maybe they were, but sometimes it's like Mr. tom says it is.
    Yes, Bosch is the German company. But the filters sold at Auto Zone are made in the good ole USA by Champion. With the exception of the filter element and a different color anti drain valve, they appear to be virtually identical to a Mobil 1 filter. Heck, the two I bought had finger prints from the same assembly line worker. Seriously, give them a close inspection. Both the Bosch and Mobil units I have, have the same letters AAX stamped on the rubber (or silicone) drain valve if you look thru the inlet holes.
    Chuck
    That makes sense.I think I will stick with the nippon filter.I was using Purone ,then I bought 2 ACdelco ultraguard gold I like them but they were 12.00 each. the nippon cost me 3.18 each which is even less than the Purone's.I also bought some air filters from this place 2bosch,2 Full yes Full was the brand name straight from Japan.The filter paper in the full is like wool,dark fussy and thick,the bosch is like every other paper white and thin looking.Why don't american after market parts makers match more closey the products that come from over sea's the ones that usually come on the vehicles that we buy? Tony
    I don't know why, but the Japanese sure like their paper in bright colors! We have to put red or yellow dye in most of the paper grades that we sell to people who make filters for the Japanese brands.
    Sure doesn't add anything to the performance of the filter. Just makes our lives more complicated.
    tom
    I believe they are both made by the same company (Champion). But something is different. The Mobil 1 filters are significantly heavier. I know they have a thicker shell-perhaps they have more/different filter media also?
    I'm sure the Mobil 1 filter would be good for the entire 7000 miles, assuming normal driving conditions, but changing at 3500 with a less expensive filter would be OK too. In comparing cost, don't forget to factor in the cost of the oil you would add to replace what you would lose with the filter change, and if you are talking synthetic oil, which you would be if you are going 7K between changes, a quart of oil would be over $4.00.
    tom
    for the new filter. Still, I would feel better two new Bosh filters than one Mobile1. But in the end, it may be "even money". Oh, my driving is 31 miles at 65 mph and 31 miles of 20mph(stop & go, 70 minutes) five days week. I do feel bad for my cars going home, 5 days a week.
    Thanks again for your meaningful info.
  • alternatoralternator Member Posts: 629
    Where does one access a Purolator Filter book? Is this on-line somewhere?
    Or could you just tell me please, what slightly larger filter would fit my 2002 Mazda Protege 2.0L LX (which has a very tiny OEM filter listed as equivalent to Fram 6607 or Purolator 14622 or Mobil M1-108)?
    My 2001 Sentra cals for a Purolator L14610, and the 2000 Sentra calls for the l14622. Same engine-go figure. Anyway I use the PL14620, or M1-110. My son-in-law's Quest takes the L14622. I have also used the PL14620/M1-110 on that.
    I use the book at Advance Auto Parts and the filter information is on page 929. The 14622 and 14620 are the same except for length. (That's near as I can determine) I recall both bypass valves are set at 14-18 psi. This information is not available online. The equivalent filter for PL14620 is the K&N 1010. Thats what I am using now. Hope that helps.
  • mdq_ntvmdq_ntv Member Posts: 11
    alternator:
    Go to www.pureoil.com and click on e-guide.
    isn't there.
    What is the media of this filter. Someone told me it is not paper. It is "synthetic cotton"--what??
