Oil Filters, whose is best, and Why?
Whats Amsoil's efficiency??
A permanent filter with a disposable cartridge?
Also, does anyone know who makes these filters?
It is so hard to get any objective and uniform information about oil filters that you really have to rely on your own common sense. It reminds me of what an old boss told me when I first started a sales job, "Confuse the customer, and sell them the best." Unfortunately with oil filters, its often a case of "Confuse the customer and sell them the worst!"
I'm no expert on oil filters, but from what I've been able to piece together, the Nissan filters appear to be of good quality, and designed to filter out partical sizes ( >20 micron) that Nissan feels are harmful to their engine tolerances. They also seem to be made in mind for the longer oil drain internvals that Nissan calls for with normal service. Unfortunately I've never found my local Nissan parts dealer to be very knowledgeable of their parts. Other Nissan dealers however put out some fairly factual information on the web. If you search "nissan filters" on various search engines, you'll find those dealers and their data. I like the www.google.com search site myself. I've never tried looking for Infinity filters, but considering that is the high end Nissan car, I'd hope you might find even more detailed info.
Good luck. Chuck
PS. Don't spend so much time on the internet checking out filters that you forget to enjoy these great Nissan cars. As my wife keeps reminding me, "It's ONLY an oil fitler!"
i switched to pure one and no more clatter .
I started taking pure one filters in to the dealer - I got the impression they had heard the problem before.
who knows - maybe dealer bought a lot of the Nissan filters and stored them in a hot warehouse.
pure one advertises a silicone anti drain back valve.
tom
TB
Paul, thanks so much for entry to that very entertaining Mazda web site. I had been searching all over the web for just the torque specs listed there. Do you know who is behind that web site? They are very opinionated on some points, so I wonder about their credentials.
I think the bypass valve was opening practically all the time and pressure was not building properly until the oil warmed up and could start going through the filter properly...oil was still flowing but not at a high enough pressure to properly lube the top area on the engine,,the valve train area. That truck has 190k miles on it now so at least the filter flowed oil,,,probably just not very well filtered!!! I change oil every 3k anyway so probably didn't really push filtration as bad as if I tried extended changes.
But I don't use Frams anymore.
See y'all
Good Morning!
Rando
Later,
Al
When I add new oil, it is getting poured in thru the top of the valve cover. I assume there is enough left in the valve area to prevent the noise when I first start the engine.
Thereafter, I think it due to better antidrain valve designs that other filters have than Fram. On a Fram filter it looks to me like the rubber anti-drainback valve seals the metal backplate to a cardboard end cap, not metal, and easily leaks, causing dirty oil to drain back into the pan. I've noticed noisy valve train at startup on several of my vehicles, and figured this filter is likely the cause after reading about it at this post. The other telling item I've noticed is that the Fram filter was virtually empty of oil whenever I pulled it off the engine. All I know for sure is that the noise stopped when I used another brand.
One web site I found even makes a point of providing some data on Nissan oem filter anti drain performance: http://www.nissanhawaii.com/Owners/Genuine/GP_page7.asp
I know that it would make the oil start circulating a few seconds faster the first time the engine was started after the filter change, but is that all that important, since it only happens once?
tom
Also, to the post that used Fram for 200,000+ miles.
If you change your oil every 3000-4000 miles you can use the cheapest SL rated oil and piece of crap filter (fram) and still get great durability. Hassle is the key.
camrys have plenty of room for a longer filter.
Anyone know?
tom
any filter (air/fuel/oil..) starts out as least restrictive as it will ever be, (least efficient and highest flowrate). As time goes by and the filter collects debris it becomes more restrictive as the filter material gradually holds more debris in the passages that the fluid is moving through. It gets more restrictive (more efficient and has a lower flowrate). Eventually it gets clogged and the efficiency is at a maximum and flowrate is at a minimum. Different filter materials would change the efficiency/flowrate curves when compared with time so some would last longer and some would fill up quicker.
You ever watched the air filter in your house? At first it doesn't change much and then it starts looking dirty, and then it REALLY starts looking dirty, and then if you don't change it the airflow is basically stopped at the filter..that is an example of increasing efficiency, at first it only catches the big stuff, after it gets a little dirty, it even starts catching the small stuff, thats shows how the efficiency changes. You've seen the pleated air filters? They start out more efficient, so they have to add more material (pleats) so it will still work for the estimated 30 day period like the cheaper air filter, it just catches more dirt even starting at the beginning?
Tsjay, I miss anything?
Good mornin
Rando
As to being politically correct and calling Fram "value engineered" should we also call Castrol Syntec by the same name for their FULL SYNTHETIC label on hydrocracked oil. Creative Marketing !!
I feel we need to be explicit if we ever want to get back to honest and fair marketing and manufacturing processes. CRAP IS CRAP value engineered is a KMart Term and I wish Castrol the same fate as KMart!
Would love Consumer Reports to do a true independent test on oil filters and oil but I doubt that we will ever see it. Too many products, combinatiions and normal day to day driving would make the test take 10 years to complete if it were a true to life test.
Their answer was:
"The L14476 and the L14477 oil filtes are tied to different original equipment part numbers where they are cataloged. While the filters are similar except for length, Purolator must catalog them as the original equipment requires in order to meet warranty concerns. "
Sounds like he is saying they are the same???
"quality challenged".All you fram users have to do is cut one open.I'll bet you never use them again.
Rando
Lee said that it was and it should be . When one gorund up Filet Mignon it had to be a great burger.
Same goes for a quality filter. Ingredients make a huge difference! A cruise missle only has to be fired once and a value engineered engine can do the job. Of course if my life depended on that thing hitting its target I would not want Fram making the engine!!!!!.
The problem is that it becomes more and more restrictive to flow, and if left on too long, will by-pass a good bit of the time.
The media doesn't really absorb dirt, if you mean the fibers actually take in some dirt. The media traps and holds dirt between the fibers, in the void areas, or "pores."
tom
Good morning
Rando
Guess I'm gonna have to recommend that we hire your butt, since you know quite a bit about filtration!
tom
Some women say married the first for love and the 2nd for money,,,,well I worked the first for money and will end up working the 2nd for fun/interest. back to subject..
Filters are cool
see y'all
Rando
