Oil Filters, whose is best, and Why?
Lessen learned when I was ten and bought my first (Shakespeare) rod and reel. The better real had a stainless steel spool the "good" reel had a plastic spool. I bought the "good" one. The plastic spool came off and the stainless steel one was underneath. Sometimes things are done for marketing reasons. This example is almost a half a century old, but I think the same thing holds true today. The only difference (witness the datasheets and box) between the Penske and low end Castrol is a paint job, the price, and marketing.
http://www.theautochannel.com/news/press/date/19990419/press021970.html
Filters for Kmart
Kmart Corp. has selected Dana to supply air and oil filters. Marketed under the Castrol® and Kmart Penske CarCare™ brands, the filters will be available in nearly 2,200 Kmart retail stores beginning in May.
I would consider it a good filter for $5.
It sounds like it breaks down into 3 levels;
Penske- base quantity and quality of media
Castrol White- higher quality media
Castrol Black- more quality AND higher quantity
Like Knapp3 said, the Penske says 20% more filtering area, the Castrol White says 20% more dirt, and the Castrol Black says 50% more dirt..
I will eventually have all 3 cut up after they get used and check em out...
I'm just glad they did away with the old Fram clones they used to have....can you imagine a "low cost" version of Fram?
see y'all
Rando
if there are three levels, Penske, Cast white and Cast Black
1. what is the MP Plus several people mentioned?
2. Will the average K Mart stock a popular filter in all three?
Does sound good tho - wix is probably better than wal marts Fram or Filtech
Canister thickness needs a mic to check - maybe not a problem - I do not hear of many on cars breaking - boats another matter - they rust quick - mercruiser advertises extra coating to prrevent that.
For my truck, Chevy 4.3 v6, When I go to Kmart, they usually do have all 3 , it is the 3980 in that case. Not sure about all the versions, and now with Kmart thinning out in some locals, they may start getting low on general stock as well maybe.
Only thing I have really noticed on can thickness is that the Walmart AC filter was obviously tougher to cut than the Kmart version of the AC filter (pf52 in that case), Walmart AC made by Champion, Kmart version made by ????
The Walmart supertech looks like it is changing, for the better, box says higher efficiency now and made with synthetic mix, painted black on new stock on shelves.
"Wix manufactures the Penske/Castrol brand of filters to their
specifications. They are not the same as the premium Wix brand. Thank you for your inquiry."
intersetingly the application manual at K mart listed two filters for my Camry 4 cyl, one larger than the other.
what is the premium wix called?
is the supertech a wal mart only brand???/ If yes, it would be suspect to me.
MaxPro(R) and Castrol(R) MaxPro(R) Plus oil and air filters, which are also manufactured by Dana."
Wix may be a slightly better filter than Champion Labs but IMHO they're awfully close. Certainly both are infinitely better than Fram.
BTW--If you don't like Wal-Mart, Car&Driver filters at Target are also Champion Labs.
A more important design criteria than filtering is how the filter will act when the oil is thick at startup. All filters go into bypass at this time. The first one to exit bypass mode is the better filter long term.
I could not find info on Bosch or the champion lab filters or Hard driver.
What I got was:
WIX web site: SAE J806 tests prove that WIX oil filters hold 45% more dirt than the leading national brand – (note - the AMSOIL charts show WIX as next to worst in capacty between Fram and NAPA.)
PUREONE web site: SAE tests prove the PureONE oil filter is #1 among ALL leading brands when it comes to protecting your car's engine against potentially damaging contaminants. With its exclusive Micronic ® filtration system, PureONE captures 96% of all contaminants.
For the Plus (not PureOne) they say: PremiumPLUS Filtering Media removes 10-20 micron-sized particles under actual driving conditions.
AC DELCO web site: UltraGold filters 4 GPM of cold oil compare that to Wix Sport Truck Brand which filters only 2.3 gallons at this pressure And "with an Efficiency rating of 98% at 8-10 microns, it traps particles 4 times smaller than conventional filters."
FRAM web site:
The SPE Test is one of the industry standards for evaluating and comparing oil filter performance, and measures a filter's ability to remove less than 20 micron-sized particles of dirt the first time through.
The FRAM Extra Guard filter performs at 96.2% efficiency in the single-pass efficiency
Tough Guard filter has even more synthetic glass and cellulose than Extra Guard® filter for an even greater life and efficiency with a SPE of 98%.
PENNZOIL site – 94% target efficiency on oil filters, thicker than conventional media, designed to catch 10-20micron particles. April 99
Quaker State Site – no data
AMSOIL site: The AMSOIL SDF Oil Filter provides up to 100 percent more capacity and up to 20 percent greater efficiency than other filters provide. It is ideal for use with extended oil drain intervals.
They have a good comparison at http://www.amsoil.com/products/sdf.html
Showing Mobil 1 as very good (expensive) and AC and Pure one as close. FRAM, WIX and NAPA on bottom.
OF course, filter capacity may not be important if you change every so often. And the filtration eff chart numbers are all in the 75-94 range – that may not make much difference either – anyone know?.
I was surprised that WIX scored so low in the AMSOIL tests.
Maybe the answer is anything but Fram (their web site shows the "cardboard" ends.
Using the can opener on these side seam cases is only marginally better than making a small hole with a chisel and prying off pieces of metal. Its a lot of work but this method does not introduce any foreign metal if your purpose is to inspect for foreign objects in the filter.
Professional cutters have a metal plate you hold the filter against. A cutting wheel cuts the body just above the metal backing plate. Two wheels press on the opposite side of the filter while you twist the filter.
I bought a Purolater Premium plus L14476 ($2.48) from Advance, a Supertech 4967 from WaldoMart for $1.97, and a Castrol MaxPro cm4967 from K Mart for $3.49. This is really Donald Trump level finances – what ---$8?????
What I saw:
Overall height of the outside, and diameters were all the same, though the filter media size inside varied surprisingly. Weights were about the same.
The WIX and Supertech had the same and biggest 8 holes on the base plate– Pureolater had 8 smaller inlet holes – I don’t know if that’s good or bad.
All the media looked about the same. Purolater and WIX were same color, ST was a little lighter. Non of the media was "fuzzy".
ST had AA stamped on base like some AC filters.
1. Center Tube Holes – WIX has the spiral tube and the others have a rolled and crimped tube, but the WIX has only a small number of flow holes, even though their holes are bigger. The SuperTech and the Purolater had both the same looking type tubes and lots of small holes, which I think is better for even and more flow distribution to the pleats of the filter media. The WIX had room for more holes. Winner? Purolater and ST
2. Bypass relief valve springs – Wix has a nice coil spring with the "range" you get with coil springs, the other two have the flat leaf type spring. I am not sure which is best. This feature may never be used unless you are starting in very cold climates or get the filter real dirty. Winner: ?????
3. Antidrain back valve – important to me as the Camry filter is mounted upside down. I think the winner was the Purolater as the surface it sits on is a rolled ring on the hidden (inside side) side of the baseplate that gives lots of places for the drain back valve lip (a piece of rubber) to seal. The base plate outside is flat and Purolater must have added this ring for a seating surface. The ST and WIX filters have the valve lip just sit on the flat baseplate steel, and the sealing surface is "reduced’ on the inside side by the flow holes and on the outside side by the spot weld dimples, leaving only a small sealing area.
Winner: Purolater in my opinion.
4. Filter Size. Even though the filters were the same height, the media area was not. The Pure and the ST were about the same height, the WIX media was shorter visually compared to the Purolater. The WIX media glue job on ends looked a little better than other two, that were about the same as each other.
Number of pleats: Purolater 52 ST 42 WIX 38. Are more pleats better? It may not matter.
I cut the media out and measured it. The media is not very stretchy even though someone said that earlier. If a piece is say 40 inches long when pulled out, you may get only another 1/2 inch out of it by really pulling on it.
The sizes I got were;
Purolater: 50.25 long x 1 7/8 high = 94.2 square inches $2.48 sale price
SuperTech : 40.5 x 1 3/4 high = 70.8 square inches $1.97 everyday
WIX 39.5 long x 1 5/8 high = 64.2 square inches $3.49
I was surprised the WIX was smaller by such a big number cause the box says it holds 20% more dirt than "the leading filter". Wish we could find out who that is.
But the Purolater has 46 % more filter media than the WIX. Either Purolater is throwing away lots of filter media nationally, or the WIX is too small or will fill up quicker.
Based on the anti drain back valve and the bigger media I would choose the Purolater.
Related - I do not see how there is room in a PUREONE for more media – these I looked at were all full now. The minimopar study said the same about PUREONE. The above filter measured is the Premium Plus, not the Pureone.
they seemed about the same from trying to flex the pieces.
Maybe the Purolater was thinner than the other two but it could have been an illusion as the ST and the Castrol (WIX) had fancy/thick paint jobs and the Purolater had a "thin" looking and feeling paint.
The new Vector (plastic "B") filter wrench I bought was too small to fit over the top of the Protege OEM filter. Space being so limited, I haven't figured out yet how to remove the OEM filter, which is reachable only from the end. However, the Vector wrench seems exactly made to fit the replacement Purolator filter (L14622 or L14620).
The WIX/NAPA (metal #6) wrench I have always used on the Cavalier Fram filter (PH3387A) was very slightly too small to fit the replacement Purolator filter (L10111). But a Vector (plastic "J") wrench seems to exactly fit.
I didn't realize that replacement oil filters (of apparently the same diameter) are made in an assortment of slightly different sizes and/or profiles!
Did you notice a different construction on the unit, like it was possibly made by a different manufacturer. Since Wal-Mart owns the brand they could rejigger suppliers.
I'm pulling for them so far
Rando
http://www.lislecorp.com/tools/catalog/filters/index.htm
but now I will all the time. I think those AC's are on CLOSEOUT, the Walmart near me also has a few left and they are $2 as well (RED TAG!) They still have some Motorcraft so far and they mainly have Fram and ST.
Good Morning
Rando
Some years ago, and I do not remember the circumstances, I came up with a device for removing stubborn filters from impossible locations. It has spikes on it and a socket wrench drive cavity on the other end. I suspect you could puncture a canister and twist it out with this. I know that the real intent of it was for removing filter bases after a disaster left you with only a base plate needing removal. The spikes will fit into the holes that let oil pass into the filter. I've never seen a broken off filter canister on any vehicle, but I reckon it is possible. I have removed a few with screw drivers-- you know, where you puncture the can and use the screw driver as a lever handle. This technique requires lateral room. The spike device is for no-room jobs!
<http://www.bobstools.net/Store/LS63600.html>
Usual disclaimers.
These filters seemed to run about $10 - $11 online. I found a AC Delco jobber here (Greenville, SC) that sells them for $6.30. I go in every several months and buy them out in my size. I still have 12 sitting in my garage. I think $6.30 is a great price for such a well made filter.
Check out the AC Delco website for info on the filter at http://www.acdelco.com/html/pi_filt_oil_gold_main.htm
I used their web sites parts locator system to find the jobber. Don't wast your time at AutoZone, PepBoys, etc. Look for something like jobber or parts warehouse.
Happy Motoring
most of the others say "leading filter"
wonder who makes the AC filter or do they?
the pureone scores good too in the flow test answering the minimopar concern about flow rate, and is sometimes on sale.
I heard somewhere that they much-vaunted "Ultra Guard" filter was being phased out because they found it difficult to market such a premium filter. Anyone here any more on this?
--- Bror Jace
No AC
Can you spell P U R E O N E.
course I never saw one for sale anywhere.
I bought a case of 12 from gmpartsdirect about two months ago so I would have them for awhile. For anyone who still wants these, try there as they may still have a stock of them.
It seems to me that there is so much area up inside the engine for the old oil to cling to that it would be more reasonable to wait until the engine is almost cold to allow time for more of the oil to collect in the oil pan before draining. Then, it might be prudent to pour a fresh quart of oil through the engine to flush the pan itself more thoroughly.
Has anyone seen any scientifically proven evidence that oil should only be drained while hot? Hot oil is certainly messy, and also a real safety hazard.
