Oil Filters, whose is best, and Why?
>Flushing with new oil as suggested would be
>the ultimate but very time consuming and costly.
the same as changing oil every two or three thousand miles?
Also I had an 88 Ranger where I was using the AC oil filter. I didn't realize it at the time that the AC had no drain-back falve. So for years I started the vehicle every morning with very little oil in this very giant filter. Sounded quite ugly but the truck ran fine after 125K when I sold it.
opera_house_wk: no matter how much oil you drain out, you're still going to start out with the same amount of new oil in the engine aren't you? Did I misunderstand you?
On spec sheets you will see a dry fill and a drain and fill capacity for all engines, dry fill is about 1/2 quart more. Dry fill being after dis assembly or when new
That is the setup in our 98 Isuzu Trooper. Is that a sound recommendation-- put a few fluid ounces of oil in the filter when installing it?
I have never seen a late model (last 20 years) oil filter for a automobile gas engine that did not have a check valve. I agree that most check valves are barely working by the time the filter is removed. A very scant few filters are mounted upside down. The check valve was not designed for just those few. Diesel engine manufacturers consider this so important that the check valve is built into the engine. There are pre lube systems sold that pump in oil before the engine is started. The distributors are removed from rebuilt engines and an electric drill is used to pump oil before the engine is started. And, I did an experiment last night that I hadn't done in 30 years as a comparison between oil with STP and without. I stuck a piece of metal in new oil and let it drain vertically in the garage which was only 20 degrees last night. I suggest you all try this to see how much oil can drain off metal over night.
I can't say any measurable damage is done draining the oil overnight. I certainly can't see any good reason it would be the best way. I just did an oil change on my car. I left the filter in and just drained an replaced 4 quarts. I recently got this repo car and it is the third oil change. This filter only has 6 weeks and 3K on it. That old quart of oil doesn't hurt anything. I have yet to hear any reason why draining the oil that long is a good thing to do.
Sorry for the rambling, but I'm just amazed at the number of engines that DON'T have their filters mounted 'gasket up'.
Dave
AC Delco PF47 - This is one of those tiny little filters It had 59 pleats 1.83" X 0.34 for approximately 74 square inches. It had no bypass valve. The sad story is that the check valve had started to flatten out and made a gap which rendered the valve useless. If your valves go clankity clank, you need to change the oil more often. Too bad AC Delco doesn't quite make the grade in this department.
where when how much, etc.
adc100: Uuuuh... did you leave something out?
Now the reason for performing this procedure was that it had added 10,000 more miles to the engine bearings, additionally they pointed out that qick lubes will usually never if ever perform this procedure
I had a tough time, well, I could not separate the paper element from the end or rear end caps, really, really glued on well. Noted no accumulation of much or anything on the paper pleats themselves in terms of particles etc.
I did prefill the new replacement fitler but it is a vertical mount so no big deal. I also use the Mobil 1 and Pure One fitlers but I have never cut one open to date. Next time.
Oil analysis resutls on the oil form this change have not been returned
"Here is another filter survey. I think it was probably posted before."
Uuuuh huh!
4 cyl, 6 cyl two sizes of V8
But, we should be able to get the number down to 20-30 or so. That right there would be a massive improvement over the hundreds (literally) of filters already in use. Honda is already doing something like this. All Hondas & Acuras with just a couple exceptions (their Insight Hybrid for example) use the same size oil filter.
I used to be into paintball BIG TIME and every time a company would come out with a new brand of gun, they'd use a proprietary thread pattern for the barrels. It must have driven the aftermarket barrel producers NUTS!
Every new car that comes off the drafting desks should use a size/style/pattern filter that already exists. There is virtually no reason a new one would have to be made for the latest Hyundai, Dahiatsu, etc ...
--- Bror Jace
You wouldn't believe how many different grades of paper we make. Each different paper type is called a "grade," and this does not refer to quality level, as in Grade A, etc. You could just substitute the word "type" for the word "grade" in our terminology.
Since there are so many filter designs, there are also many, many widths that the paper must be cut into. We call these widths "slit widths," since we must slit our big master rolls of paper into these widths.
There is almost an ifinite number of combinations of paper grade and slit width, so that we must almost always produce our paper to order, rather than inventory paper for the customer.
We carry some inventory in common sizes, but there is almost always some oddball slit width that we would not have anticipated, and this means we have to go back on the paper machine and produce a run of paper in order to cover the order for the unusual size.
tom
you might think the common auto engineers ( Honda Toyota ) would use off the shelf industry standard stuff
while BMW etc try to create an image and have a unique product?
Same with Batteries too
(That's WHICH, FROM, SOONER OR LATER) (:oÞ
see ya
Rando
Magnets I don't believe that in an engine there is a great potential for magnetic particles. You are more likely to see bearing materials that are non magnetic. Automatic transmissions are totally different, lots of steel on steel. There is lots of magnetic material there. I used to put five magnets in the pan of my 92 Explorer and I would have to clean them every 10 months cause they would be loaded. I believe these magnets got me another three years out of that transmission. My 97 Explorer came with a magnet in it and I added another two.
I install a magnet on every engine I build. I use a cow magnet and hose clamp it to the oil pick up tube. Only problem you can't check or clean as it is inside the oil pan. I have taken engines apart later with these magnets and it is surprising how muck metal shavings they attract. I'm not sure but I would think that these metal particals would be trapped in a normal oil filter anyway.
those are awful small.
or
Usual disclaimers...
When the vehicle was new there was some buildup on the plug but now there is barely any debris on them any more. Adding another magnet at the filter might catch some more, but I can't imagine it being very much, and theoretically it would only be the microscopic stuff anyhow, ( but as stated above,,,every bit helps, for all the reasons mentioned already)
Seems like everyone is wearing magnets on bracelets/necklaces/shoes/knee wraps these days,
probably all going to start sticking to manhole covers before long...
I'd say if you have an extra magnet , stick it to the filter, it won't hurt anything
Good morning y'all
Rando
