Oil Filters, whose is best, and Why?
Anyone else cutting up filters?
Its easy, cut the case off with a hacksaw, then use a knife to cut out a 1 inch band all around - then measure that length.
The sizes I got were;
Camry 4 cyl
Purolater: 50.25 long x 1 7/8 high = 94.2 square inches
SuperTech : 40.5 x 1 3/4 high = 70.8 square inches
WIX 39.5 long x 1 5/8 high = 64.2 square inches
Nissan OE 42.25 x 2 3/8 = 100.3 square inches ????
This was a longer/taller filter but only had about the same area as the smaller Purolater
(for Maxima V 6) the antidrain back valve in the Nissan filter was very thin and did not have a lot of "body". Made in USA but I have never seen a relief valve like this one had
So far I have cut up 4 versions of the filter my Chevy truck uses (AC-pf52), they are definitely NOT the same quality among the 4,,,
interesting huh?
see ya
Rando
WHY don't the mfg post on the filter what the internal area is????
Number one answer - they would lose sales!!!!!!!
I am a lifetime Enquirer subscriber - with home delivery.
I hold it in a vice with holes up and cut with a hacksaw,,,not too bad.
but I stand in front of it looking stupid when the wife drives up...I'm so proud of my experiment...and she's like....."you're so weird..."...she's in there screaming right now because NCSU just scored...she's a BIG sports fan...cool huh?
We don't need the HAZMAT people....we have wives!
Manufacturer Champion Labs
Single Pass 98%
Multipass 94%
SAE HS808
Note: Newer Versions of Supertech advertise 99%/98% (I believe)
Inlet Holes- 6- 1/4" -- Area .296 sq. in.
Filter Media Yellow Resin??
Pleats- 43
Area - Approx 47 sq. in.
Cannister Thickness .017"
Filter Support-104 1/8"(approx) holes- approx 1.25 sq inches
Bypass valve metal-neoprene coated
Spring- Leaf
Anti-drainback valve- Black neoprene
Conclusions- I would have no problem using this filter. Everything appeared to be first rate. I especially liked the idea of the heavy wall of .017" vs .011" for the Pure One. As I said earlier-I won't use a filter with such a thin wall.
on the area are you sure you measured right?
the 4 filters I cut open (and they were small short filters) had areas of 60 to 100 inches. Yours has only 47 - what car is it for?Maybe check the math - how long was the filter paper and how high (wide) ?
43 x 2 x 1.25" x.44 = 47 sq. in.
Correct me if I'm wrong. Probably a little larger cause I didn't add a little extra at the top and bottom of the pleat.
measure the heigth-
then cut out all around with a knife a piece of the filter paper and pull it off and measure it
a little more exact
either way probably close
that ST does not have much area tho at 47 inches. what car does it fit?
Bosch- 3323
K&N (my favorite)- HP-1010
Pure One- PL-14620
Mobil- M1-110
Fram- 7317
These filters give twice the filtering area.
If you need additional information-email me.
Al
Be sure to look at all five pages therein.
I will be waiting with interest for feedback regarding the above from this discussion group.
adc100: to add to your "larger filter options for Purolator PL14622" list, take a look at Castrol equivalent which appears to be noticeably longer even than the Purolator PL14620.
i think the only way to tell is to cut them open.
the Nissan original equipment i cut open was longer than the Purolator but only had about 10% more area.
They fool you - short element in a tall can -
the nissan OEM was made by wix i think who also makes the penske ones at Kmart that were short on filter area. but then they are cheaper and "made to K mart specs"
link would not open - can non members view it?
Here is an interesting comparison about Nissan filters against "you know who":
http://www.motorvate.ca/auto/maxima/oil_filter/oil_filter.htm
Adc100, just curious, why are K&N your favorites?
Chuck
the post you gave also says made in usa.
That red anti drain back valve is TOO flexible in my opinion - it is weak and will not push firmly against the base can (my opinion)
why do you think they mahle makes them?
http://shoclub.com/lubrication-oil/lubrication-oilpart5.htm
Perhaps Mobil 1 is still an O.K. Choice.
Pure One- PL-14620
Mobil- M1-110
Fram- 7317
I used the Fram, and then learned that some other brands would make excellent alternatives. I have found the Bosch filter to be very good. I got concerned about the Purolator 14620, because of finding a discrepancy on that number versus another Purolator number that some Purolator sources claim to be the right one! I have avoided using any Purolator filters on the Nissan 3.3 liter engine because of that.
The disappointment was that the wall thickness was only .012" vs .017 for the Tech. Also the epoxy holding the pleats in the Bosch was sloppy.
Efficiency for the Bosch was 98%/93%.
SuperTech appeared to be the winner here. Unfortunately I will not be able to use it for my Nissan because it only comes in the shorter version.
It is made by Champion.It has a little unusual build.The center tube has circumferential "ridges"or corrugations.There are 12 circumferential rows of small holes(top to bottom),in groups of 3(x4).The stamp on the end plate is even identical.
Seems to add more credence to the multi-supplier theory since I have another PF59 that is totally different.
The only caveat is that I haven't cut them apart.But I'd be shocked it they are not identical!
Most posts,however,seem to think the quality of the Champion Labs filters are good.Probably the thing we won't know about ALL the various ACDelcos,concerns the filtering medium.What it is and what the ability to filter the smaller particles is.I'm not sure I trust the "data" on the Frams,Castrols,Champions,etc.concerning their ability to filter small particles at high multi-pass efficiencies(i.e. in these $2-$5 versions).And since it appears beneficial to get a high % of 15-20 micron particles,maybe the Mobil 1 and Amsoils are worth their higher prices?
I think theyare cheating pople.
My Honda Civic currently had a Hastings (#LF-402) on it and I'm thinking of replacing just the filter (oil change not due til May or June) so I can chop it apart.
--- Bror Jace
Oh, and Fleetwood, I wasn't saying Fram = cheap (as in price), I was talking about their lack of quality. I know they are usually at least $1 more than say, a Super-Tech filter produced by Champion Labs.
I think Fram filters are priced higher because Allied Signal markets so aggressively. That marketing is very expensive and they need to pay for it all.
Plus, there is a perceived quality with a higher-priced product. If Fram sold their filters at the price it cost to produce them plus the usual mark-up, people would see what junk they really are. Currently, too many people think they are actually buying a quality filter because the brand name is so powerful.
armtdm, I'll bet you a dollar that the only difference between a Hastings (or Baldwin) filter and the Amsoil filter is the media used. Amsoil probably uses a slightly higher efficiency filter media. What say ye?
--- Bror Jace
"Avalanche
2002 - Avalanche V8-327 (5.3L) SFI
Parts Information
Part Prompt Notes PartNo Qty
Lube SDF64 1
Air TS123/AF1052 1
Air Cabiin AF1114 1
Fuel GF111 1
Oil Vapor N/R 1
Fuel Vapor N/R 1
PCV 1
Transmission Filter No. 4L60E S. Pan TF113 1 Transmission Filter No. 4L60E D. Pan TF156 1 Transmission Filter No. 4L80E TF144 1
The SDF64 is the only option we offer for this application. It does however have a larger capacity than most oem or aftermarket filters. The SDF64 element is rated at 5 to 7 microns".
So,I assume the media is different.They say there is fiberglass in it.
Another thing I'd like to do is use a larger filter. I haven't looked at it yet, but there has to be room... the filter (fram 7313) is tiny!! Where can I find a larger size that will work with my car?
The oil filter numbers I have for the Hyundai '02 4 & 6 cyl engines are as follows:
Mann...............: W 811/80
STP.................: S2808
Bosch..............: 3312
Mobil 1.............: M1-104
Amsoil..............: SDF-20
AC Delco..........: PF-1127, SPF-1127, UPF-1127
Fleetguard.........: LF-3462
Purolator...........: L-14459
Fram.................: PH-3593A
KFO (Korean)....: 00301
Hyundai part #...: 26300-35500
You milage may vary. =;-)
I'm not sure I have seen ANY efficiency figures for these filters.Judging from how few filters have synthetic media,I suspect these are very good.
They now have a new box that says made by Champion Labs,in USA.It also gives the Single pass at 98% and multi-pass at 99%.AND it says "synthetic fiber-enhanced filter media...."No micron rating is mentioned.
So are these efficiencies at all meaningful(since it doesn't give particle size)?It does say SAE tests #HS806 and J1858.Looks to be an excellent product(esp with some synth media).
I am new to this forum... and seems like Champion Labs makes good filters, and I read that they also make filter under other brands... can someone tell me those names? Thank you
