Next I'm thinking the tranny fluid needs to be changed.
PUL-EESE. Seat covers on a leather seat? :confuse:
You might try putting a or in the post for jokes...
I am taking it to the dealer on Saturday to deal with the rear differential problem. But I don't have complete confidence in the service guys to address this and am looking for the right 'words to say.'
Help! Leave the sarcastic comments on your own computer, please.
-why rotate new tires? and if this works, might I re-experience the problem upon next rotation? and doesn't switching front tires, like they did on my car, not follow service direction for tire rotation pattern?
-please read FAQ #17 for background on PTTR (pulls to the right). I mentioned in my message, #4765, that I didn't really understand the distinction between "pulling" and "drifting" and had never heard of this distinction before. Distinction still seems to me to be a matter of degree. Interestingly, the first thing dealer asked me was whether the car pulled or drifted. He wrote up service request as "pulls". Obviously, this didn't really help me.
-TSB's listed in FAQ #17 appear to be for earlier model year CR-V's. I would really like to have info specific to 2006 model when I try to convince service mgr to help
-In hindsight, it looks like my first trip to dealer was a "hail Mary". These visits are extremely inconvenient for me and I want to plan out my next one carefully, so I'm trying to research the problem. So far, I don't know much and don't have a gameplan. Any thoughts?
-Agree with your observation that hitting a bump (or really any change in pavement) can cause the car to PTTR. I also seem to sense force needed to make left turns is a little more than force needed to make right turns. In general, car may go straight for a short bit but the slightest pavement irregularity will make it PTTR. It is definitely not right.
-Please advise me of anything you may learn. Good luck!
chris
I also asked about buying the Honda dual pump fluid & having another mechanic change it for the next time. He didn't have any problems with it.
I sure hope the new 2007 CR-Vs list the correct rear differential fluid change interval.
Mark
May work for a week, or for an hour, then stop again.
My vehicle is a '97, with 150k miles, and has an aftermarket lock/starter system.
Details are: when they don't work, the key fob and the driver door switch both don't work... when they work, they both work.
I believe that something is preventing them from working in error. A sensor might be bad. The door key mechanism seems to have a switch; the rear passenger door will not turn on the dome light anymore; the hatch light sometimes doesn't work.
I have checked the aftermarket lock, and it is always providing a momentary ground on the LOCK and ONLOCK lines going into the driver door. It seems that the B+ is not going to the actuators sometimes. Any help with getting the door panel off? Common failures of switches?
Very frustrating!!!
I saw a two cars with a dealer here. '04-LX CRV with 22000 milage has same kind of vibration issue.. I asked to check other vehicle and the other one (04-LX CRV) also had same kind of vibration. I just came home and searching for this issue online.. I am still thinking again wheather to buy it or not.
Jack
Ok, let's clarify a few things.
1. Did you read the OWNER's MANUAL?
2. Did you read it more than twice?
3. When you get a blast of hot air at your feet, what position is the air flow selector at?
4. What position is the temperature selector at?
The air flow in the "Face/Feet" is designed to send hotter air to the feet and colder air at the Face, as per OWNER's MANUAL, unless the temp selector is the lowest temperature setting.
You should not be getting any air flow out of the heat registers if the flow selector is set to "Face."
"Max Cold" nothing else but a combination of "Recirculation", "A/C", and "Face" locked together.
sbn
sbn
sbn
I just replaced my mirrors with heated ones from SE.
Tilt the mirror up, stick a flat tipped screwdriver from the bottom between the mirror and the housing. You should see the black mirror backing and the white mirror adjstment plate. Release the two hook. Start pulling gently, there is some goo on the back. Pull until you reach a 45 degree angle, then slide the mirror down.
Make sure the replacements are for the correct country of manufacture. There seem to be some minor differences between the UK and Japan made CR-V's.
I am just wondering if anyone else had any of the same issues and what you did about it? We bought the more expensive Honda brand mask so that we wouldn't have any issues!
Thanks for any help or experience you have!
