--Robert
1) Use a machine that hooks up in-line with the fuel system, and run a special fluid through the injectors
2) Use a gas supplement like Chevron's Techron (the link to the additive must have moved, here's more info from a link talking about their gas with the Techron additive already in it. I can't get that here in Wisconsin - no Chevron stations :-(
http://www.chevron.com/products/prodserv/fuels/techrongas/advantage.shtml
If you've never had it done, and/or you're having injector problems, I recommend option 1). If you've got a fairly new car, and/or you're not having any problems, I would go with option 2) (I do that on my wife's Envoy every 8k miles or so, and will do the same on my GTO - had #1 done on my Aurora last spring, and also put in the Techron).
From http://www.americascarshow.com/glossary/Welcome.html?index=E
"The EGR Valve is an intricate part of a car’s exhaust emission control system. Here’s what it does: the valve is used to introduce exhaust gases into the intake manifold air stream. By using this procedure of readmitting a small amount of exhaust stream into the engine’s combustion chamber, peak combustion chambers are reduced and so are engine emissions. EGR Valves are very touchy because of the very nature of their design and function, feeding exhaust gas back into the engine and are therefore susceptible to clogging up from carbon deposit buildup. This is why it’s so important to keep your engine in tiptop operating condition so that the engine runs clean resulting in a clean EGR Valve and system."
May be time to try to clean up the intake/throttle body (butterfly valve)/EGR valve with some intake cleaner (don't use carburator cleaner) and see if things are any better...
--Robert
Any puddles under the car? (I had a water pump leak intermittently until it seized - thankfully under warranty).
--Robert
However I was told that the EGR would bring up a code and it has not yet, so I'll go and have this guy look it over.
paul
The symptoms you are describing point exactly to the fuel pressure regulator. I also had this problem about 2 years ago on my 95. It starts hard, and mine did actually stall on me once before I was able to replace the part. It's a very easy job, you just have to remove the plastic cover over the engine. The new regulator was around 50$ (if I remember correctly ) and takes a total of 10 minutes to change yourself.
If you need more details just ask.
good luck
Pete
Les
Thanks Again
paul
Given my history with this car, fuel problems and the Holland Tunnel, Iwas not a happy camper. Well as soon as I got about a 10th of a mile into the tunnel the car's rpms drop. I am like I dont believe it -- INSTANT REPLAY.
I looked again and the car had not shut-off, it had just stopped surging. For the rest of the trip on the highway the car seemed fine and I got it home with the SES light going on and off.
From what I have researched on this board, the surgeing may be a dirty throttle body, faulty FPR or fuel pump.
The overheating is of more concern, When I checked the coolant it was clear like there was not collant in it just water. I got the car home by turning on the heat to help cool the engine down. But now I am concerned as to why the car was overheating in the first place. It never actually got into the red, but when I opened the reserve tank the water boiled over the top. I am thinking it may be a simple thing like I need a new thermostat??
Comments, answers, questions are appreciated.
Henri
--Robert
Possible clue is that this happened (or was noticed) after a detailing that included an under-the-hood wash!
About a year ago my '97's mirror mount dropped off the windshield. It was quite difficult to separate the wedge from the mirror bracket, but I was finally able to do it by prying with a screwdriver. I glued the wedge back in place with one of those two-part adhesive kits. Then it was time to attached the mirror bracket back onto the wedge. My service manual said to align it at the top and pull down. I was certain that the wedge would break free from the windshield again, but it held even though I had to apply considerable force, and the mirror bracket snapped into place.
With the difficulty I had in separating the wedge from the bracket, I cannot imagine how yours came apart. If yours is built like mine, then just pull down on it to snap the bracket onto the wedge. Good luck.
Les
Re: overheating
Your '95's coolant being clear like water is really puzzling. Have you been running orange Dex-Cool or green coolant? Could someone have flushed your cooling system and left only water? That would result in lower boiling point (212 degrees vs. 260 or so).
Thermostat could be the problem, although I think they usually fail open and not closed. How's your water pump? Is the air path through the radiator unobstructed? Plastic bags sucked into the bottom-feeding air opening can severely restrict air flow. Another possibility is leaking head gasket.
Les
My problem... Today I fixed I think 4 wires between the driver door and car, the wires and problems I fixed:
A small orange wire controling memory seats and lumbar.
A larger orange wire controling power seat.
A large green wire but didnt notice anything.
A purple wire controling the rear passenger door window.
After this was all done, the following do not work, keyless entry, instrument panel speed etc. the DIC, the temp etc. Also door lock does not work but unlock does.
Other things is that at first the lumbar did work, and now it beeps when I press the lumbar button,...
I have an appointment scheduled with dealer but hoping to fix... Again, I have searched and searched but came up with no solution to this,
All i can say is get that part checked, it may save you thousands. We have a 95 Aurora.
Welcome to the Aurora board!
I don't understand this. How did dirt and water get into the fuel tank because the retaining ring corroded? Was the fuel pump replaced? If so, the mechanic who replaced it should have cleaned the area around the tank opening before removing the ring and pump. No matter what the material of the ring, there will be some dirt, sand, etc. from the road. Where did the water come from? Why didn't the fuel filter catch the dirt? The sock on the fuel pickup should have blocked water. Something dosn't add up here.
Les
http://www.howardm.net/dred98/underhood.php
Since I have had the cooling system flushed and new coolant put in, do I now need to go and get the walnut shell tablets? Or do you only do the tablets when you change the radiator??
How did you crack the intake manifold? Is Brooklyn that bad? Was that the cause of your overheating, too?
I think the walnut shell tablets are more for block, heads, etc. than radiator. I would add them. Did you use Dex-Cool?
Les
Since our auto symptoms seem so similar, I would like to know what you like was actually causing the problem rather than try to fit it by trial and error, as I don't have much money. Your last message suggested that new spark plug wires fixed the problem. Your input would be greatly appreciated.
Javi
Member
"Aurora Club Of North America"
I am back. I wrote some time ago about my 95 Aurora V8 and I still have not been able to get this resolved. The issue is cannot keep car running at all. It will crank but will not stay running. We have replaced the fuel pump, fpr, sensors, put on computer thru no codes, changed the computer still nothing any ideas anyone. We even found a crack in the intake valve and fixed that still won't stay running. Checked for spark its there. It has been a month we are completely saddened gave the car to son he had it 5 days and has paid for insurance without a car now for a month going on the second month now any ideas would be great.
Sorry to hear about the luck you're having with your '95. Don't give up, these cars are fantastic to own and drive. Would you be able to email me on my America Online account? You can find my address in my Edmunds profile. I would post it right here but I would get hit with more junk email.
I would like to know the details about your situation and exactly what has been done in an attempt to fix the problem. I work on engines quite frequently on the side, and have also worked on several Auroras (including my own). I have a few ideas in mind which would help diagnose your troubles.
Are you located anywhere near Buffalo New York?
I can't stand the thought of an Aurora just sitting on the sidelines.......
Pete
