Oldsmobile Aurora Maintenance & Repair
1565759616288
  • emertdremertdr Member Posts: 1
    I have a 2003 Aurora and love it. We have the OnStar system active including the Directions and Connections (helpful for my wife's travel for her ailing Mom). I have been given different info from OnStar as to whether it is an anolog system (which is no longer usable after 1/1/08) or digital ready (which can be upgraded). I want to keep the car past that time and want the OnStar capability but do not know who to believe. The dealer has not been much help either. My guess is that with olsdmobile phasing out, they have no interest at GM in this issue so are just ignoring it. All of the early info provided by OnStar on commands to check to see what kind of system you have have now been pulled from their website. My check of those commands told me my system is Digital Ready. Now the OnStar internet info says contact OnStar or your dealer. Has anyone run into this or is am I the only one interested. Bottom line: I want to convert the system to Digital so it will work after 1/1/08. The latest email from OnStar says my system is analog and cannot and will not be converted but I am not sure that is correct based on previous checks. Thanks. DE
  • imidazol97imidazol97 Member Posts: 27,788
    The type of OnStar equipment can be determined by calling the representative from the car and asking them to tell you.
    http://www.onstar.com/us_english/jsp/explore/onstar_basics/helpful_info.jsp?info-view=tech- _equip
    In the past there had been lists of techniques where you can determine if it's analogue only or digital by the response when you said "help" I believe.
    Might check the OnStar discussion here on Edmunds. It's closed but may have info you can use.
  • rjs200240rjs200240 Member Posts: 1,277
    It can be upgraded. It's digital-ready. I believe they will upgrade you if you commit to a long-enough subscription. I'd called about it before. I'm not sure if I'll upgrade my 2002 or just let it slide. I have paid for the continuing service since I've had the car, though.
  • oldswrencholdswrench Member Posts: 5
    my 97 is not blinking on the right side, but will blink on the left. All of the bulbs on the right light up when you select the right turn, but not blinking and it is driving me blinking nuts!!! Anyone else been through this? All of the side marker lights and cornering lights are all good as well.
    Oldswrench
  • mwothemwothe Member Posts: 1
    I had same problem, was one malfunctioning rear light (all appear to work but look at right vs left and the left was brighter). Turned out to be weak connection under the twisty adapter trunk back. Wiggle it around until it works, then stash away and tighten up the panel. Have you been in an accident lately? That's what caused my wiring disruption.
    There're more lights in there than I thought.
    Love my 96 Aurora but have paid more than it's probably worth in the last 2 yrs. the first eight were problem free. If you have a problem try and find a service shop with GM diagnostics, the dealers are notorious selling in the service department. . Especially now since Olds is no longer. Everything is a "special order" but you can find the parts online for just about everything.
    Case in Point: Lupient (formerly Olds) wanted $900+ for radiator replacement. I found new radiator for 200 and paid 70 for mechanic to install. Thanks dealer I bought the car from.
    MW :)
  • bdcq3bdcq3 Member Posts: 1
    Bulletin No.: 67-61-07
    Date: February, 1996
    Subject:
    Oil Leaks from Oil Pan to Lower Crankcase Attaching Bolts (Clean Bolt/Apply Sealant)
    Models:
    1993 Cadillac Allante
    1994-96 Cadillac Concours, DeVille, Eldorado, Seville
    1995-96 Oldsmobile Aurora
    with 4.0L, 4.6L Engine (VINs 9, Y, C - RPOs L37, LD8, L47)
    Condition
    Some engines may exhibit engine oil leaks sourced at oil pan to lower crankcase attaching bolts and bolts attaching the brace between the transaxle and engine oil pan.
    Cause
    This condition may be caused by porosity in the lower crankcase area near the oil pan bolt threads. This type of leak would show oil leaking at or near the head of the fastener affected.
    Correction
    To correct porosity leaks in these areas, use the following procedure:
    1. Remove the bolt which is leaking.
    2. Thoroughly clean the bolt hole with brake clean or suitable equivalent cleaner.
    3. Thoroughly blow out bolt hole with shop air (20 psig maximum pressure).
    4. Thoroughly clean the bolt with brake cleaner or suitable equivalent cleaner.
    5. Apply a moderate amount of Loctite(R), P/N 12345382 (Blue Service removable) threadlocker/sealant to bolt.
    6. Install bolt and torque to 9.5 Nm (85 lb in.).
    Pan Gasket Replacement
    IMPORTANT: The engine oil pan can be replaced either in the vehicle with the transaxle removed or by removing the engine from the vehicle.
    Remove engine and place on stand.
    Drain oil, then remove oil pan retaining bolts and the oil pan.
    Gasket is reusable unless damaged. Do NOT remove gasket from oil pan groove unless replacement is required.
    Install a new oil seal if required by starting the seal into the pan groove in both directions. NOTE: If replacing the gasket do not expose new gasket to oil before inserting gasket into pan groove, gasket will expand when exposed to oil and will not stay in pan groove.
    Position oil pan to crankcase.
    Oil pan bolts and torque in sequence, to 10 Nm (89 in lbs) .
    Transaxle assembly.
    Refill engine oil and check for leaks.
  • wright8wright8 Member Posts: 2
    I have been having my check engine light come on intermittently for about 6 mos. now. I took it to two shops where there could not find the problem. It shows a misfire at first only in cylinder 5 but now 5 & 6. I had the plugs replaced (AC Delco Platinum) and when the 5 plug was taken out it was black. Compression is fine and they wanted to perform a cylinder leak down test but could not garrauntee that this would diagnose the problem. So I took no action.
    I have been driving it since and I have the common problems, rough idle, tough starting, and when it does start the rpms bounce and then settle, poor performance, also I have noticed a decline in gas mileage. Could all this be caused by bad wires or coils, which it seems for so many others was the culprit?
    Or could it be fuel system related? I am afraid that I may have a combination of problems on my hands and don't want to go around throwing away money to try and figure it out.
    If someone could please advise me as to what best cheapest plan of action you think would be suitable, and if you recommend any places to get good prices on parts since I have found that they can range greatly, I would appreciate it tremendously. I have had much luck with sites like this before and hope to have the same again.
    NOte: I am not the most car savvy person here for sure, so try and not be tto technical please. Thank You.!
  • grnhornetgrnhornet Member Posts: 21
    I guess either remove the engine or the transaxle,.
    I have a 95 for 6 years 165000 miles,rough idle,misfire, if you changed your spark plugs thats a good start, but it is probably your fuel press. regulator,this will cause rough idle hard start, and sometimes cause your car to shut off at a stop light. this will cost about 200.00 to 250.00 to have replaced. had the fpr replaced about 4 years ago, plugs changed about 2 years ago , no idle problems since. Hope this will help you out.
    I could change the fuel pressure regulator myself, I know where it is and I don't think that there are any tricky steps to doing so. The piece is only about $75 dollars isn't it? That was one thing I would rather try first before the wires since they are much more expensive. Do you have any special tips regarding do a FPR replacement yourself?
  • blk97aurorablk97aurora Member Posts: 573
    A potential trap is the small o-ring at the bottom of the FPR. It may stay in the "cup" where the FPR resides. If you do not remove it and then install the new FPR with o-ring over the old one, it will not fit right. Also be aware that the fuel rail is under pressure -- you will get some gasoline leakage. Less if the FPR is leaking.
    I replaced my '97's FPR twice. First time in 2002 at 77,000 miles; I had been experiencing the typical hard starting problem, then an underhood fire. Second time in July this year at 122,000 miles. Symproms were different this time; I had been getting P0171 and P0172 codes (rich mixture) and the engine had stalled a couple of times; replacement fixed these problems.
    I would be surprised if a leaking FPR would affect specific cylinders differently, but who knows. I have from time to time observed misfire counts on one or two cylinders using my code scanner. Not enough to set the service engine soon light. Fortunately, the situation has always been of short duration and I have never been able to find the cause.
    As usual, use AC Delco. I paid about $50 each for the two I bought. I recommend GMPartsDirect.com or RockAuto.com; I have no affiliation with either except as a satisfied customer. BTW, I noticed in one parts listing that there are different FPR part numbers for '97 with the original fuel rail vs. recall replacement stainless steel fuel rail; I do not know if this may apply to your '98.
    Les
  • neo8neo8 Member Posts: 1
    hi im new to this never had to ask for help on cars til i bought this aurora i cant figure out this thing.....at a stop light it will stall out only in drive though and when i drive down the road at around 1500rpm it will miss ever so often but only on a pull plz help me out here in ohio thnkx .....
    this sound like a problem with your fpr, you will need to have this replaced. You may experience hard start from time to time, but as long as you are driving above 45 mph you wont have any problems.I have a 95 with 165,000 miles, had this car for 6 years. Replaced fuel press. regulator at around 75,000 miles. Hope this helps.
    thanks for the info on the oil leak.
  • forleeterforleeter Member Posts: 7
    I just had the EXACT same problem. Turned out to be a lose ground on the alternator after i just had it replaced.
    Hello everyone. I just bought a 96' 4.0 Aurora and I thought I could get a "luxury" car cheap............
    Well, I was wrong. Out of the two weeks I had it I drove it for about 3 hours. I think I have everything buttoned down now, but I seem to have some discrepencies with the guages. The temp. gauge shows about 220 F. At normal op. temp. Never over-heats, just seems high compared to my other cars.Is this normal?
    As for the oil, the oil pressure meter on the information center will read about 18 ~ 22 psi. at idle on initial start-up. When up to operating temp. the meter reads about 6 psi. Sometimes it even drops to 5 (never lower) and gives me warning lights. At speed there is also a relative drop in pressure as well. Is my oil pump bad, or is this another case of "when electronics attack"?
    carnut, can you tell me how to get in touch with the mechanic you mentioned a while ago in the Detroit area?
    I spent a few hours researching old posts (there is quite a few) and found what I needed.
    BTW I still love my Aurora, even if it breaks a lot.
    forleeter the 220 temp is normal for the aurora, but not sure about the oil pressure reading. The 96 seemed to have a few more problems than the other years, but I'm not sure why.
    this is a late post, but i had the same problem with my 95, 2or 3 years ago, It was less than 200.00 dollars to repair,but I did not go to a dealer, I go to the same shop in the chicago area all the time. Before you use a shop you should find out if they have worked on aurora's before. Not all shops can work on Auroras.
    My 96' Aurora keeps stalling after running for about ten minutes. I changed the FPR, fuel filter, thermostat and alternator. SES light is on, and d.i.c. says change oil, but I just changed it!? It will start back up but it will stall out again in about a minute. If I leave it sit for an hour it will run for another ten min. Even if I hold the engine speed at 2000 R.P.M. it will stall anyway but will also backfire. I really have no idea what to do and the GM dealers around my house are as lost as I am.
    Also, I took notice of the earlier posts explaining the installation procedure of the FPR and I made sure the O-Rings are out.
    forleeter, these are the exact symptoms of a bad fpr, you must reset the dic if you already changed your oil, it wiil not tell you to change for 6000 miles.
    Forleeter you spent a lot of money, but i had the exact same symptoms, and it was corrected by replacing the fpr.
    I did change the fpr....nothing, also I disconnected the battery for half an hour and it didnt clear the d.i.c. I love this car, but it is no use to me as a lawn ornament. I got the car for an unbelievable price, so I have a little more patience left for this, but now I am at a dead end. I checked the ignition module at my local auto parts store and thats fine as well. I hooked a scanner up to it and there is no codes. Maybe the main computer (i have no idea what it is called) is bad? Would the egr valve cause this? I really cant afford to buy more parts for no reason.Oh yeah I also replaced the return fuel line and upper radiator hose also.$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
  • tjm97tjm97 Member Posts: 27
    "Also, I took notice of the earlier posts explaining the installation procedure of the FPR and I made sure the O-Rings are out. "
    You did make sure to leave in 1 "O" ring right?
    Also - the PCM will not allow the fuel pump to run if the oil pressure is low. I'm assuming you put in about 7½ qts of oil but what does you oil pressure read?
    Next - fuel pump; but what code did you get from the SES light?
    reset oil life by scrolling to the oil life using the "engine" button and then hold "reset" for 10 seconds.
    tjm, the new fpr came with the same o-rings I took out. I am positive the oil is full, pressure varies- greatly. After it warms up the pressure drops to about 6 p.s.i. At speed (55 mph) it averages about 25 p.s.i. When cold it idles with 25 p.s.i. and at speed about 45 p.s.i. As far as the code, there is none.
    I was going to replace the oil pressure sender unit over the weekend but all I could get is an aftermarket unit so I will wait until later in the week. However, it stalls when pressure is high.
    I took the fuel pump out and the strainer was COMPLETELY blocked. The bottom of the tank was COMPLETELY covered in dirt. And the fuel was BLACK!? So I think I found my main problem, what secondary issues this may cause, I dont know. I will be installing the new pump, draining fuel and cleaning tank tomarrow and I will update.
    Has anyone else had something similar happen?
  • e_net_ridere_net_rider Member Posts: 1,380
    I'll jump into the middle of this and pass on what I can remember as I don't remember where I saw it. Turns out that quite a few people are trying to get a class action against GM & Dexcool. Turns out some have had cooling and head gasket problems, of which the 3.1, 3.4, & 3.8 are notably bad. They and their lawyers may be claiming that it is cooling related and somehow tied to Dexcool. Some of the stuff in that lengthy article sounded like bunk and that forum article seemed to point as well in that direction. There was something about air mixing into the Dexcool being bad, but with present design that is unavoidable. Air in reservoir bottle? Unavoidable unless they come up with a sort of bladder system that can expand and contract. Some thoughts ran in the direction that it would be impossible for them to prove no one else had done anything to the car. What can one do?
    Well they pointed out that you should never mix the green and orange. If even a drop of green is put into an orange system, dump and flush before refilling and to always use distilled water for the 50/50. And to use the 50/50 premixed for topping off.
    This gives me some hints as to a problem I saw. 95 Regal 3.1. My wife and I had the car and it had the orange. One of our daughters got the car, and after several months I get a call, Daddy the car is running hot. (by now you should all know the female and that they have more important crap on their mind than to check fluid levels periodically and look for unusual wet spots after the car sits) OK, she was about a half mile from a service station and I told her to drive there at moderate speed. After thought, do not add anything till it cools, but she was no longer answering her phone. So I don't know what really happened there.
    Several months later I'm hearing that the coolant is going down and car is running warm.
    And she wants it fixed yesterday. It was coming up on coolant change I think, but it also looked nasty and a black gunge in the overflow bottle. Water pump was weeping some. I proceed with a flush, heavy duty. But whatever that black stuff was in the bottle, it was next to impossible to remove. My original assumption was that someone added water from a contaminated container, but what was it? To remove this diesel black globuli, after trying several things including oven cleaner, I finally hesitantly used brake cleaner solvent because I was worried about the plastic bottle. I could see that had an effect upon it and more applications of oven cleaner then removed the final portion. However during the flush period, more showed up in the bottle, meaning it was in the engine. Repeat bottle cleaning and another dose of heavy duty flush. Now what appeared to be intermittent and heat related shows up. Fans not coming on and the housing on the temp sensor was cracked so replace. Fans started working, but at a temp higher that what I would normally have seen on the guage. I noted that during the thermostat out final flush, a few miles of driving the guage hardly moved off the bottom. That messed with my thinking and I wasn't cautious by the exhaust manifold heat shield, blistering the fool out of my arm. Dang,(other words really)I won't make that mistake again. But the coolant was relatively cool, right? Well heat soak from the block evidently raised the temp of the thermostat housing significantly. Much harsher words explained my feeling as I grabbed it to reinstall the thermostat.
    Enough comedy. Well one more. Daughter has got to have the car back, even though you explain it isn't done. But you should have showed up at her door step weeks earlier and done all of the preventative maintenance and repairs while she showered and dressed to go with her friends and gave her a $100 for the inconvenience.
    BTW, new thermostat showed no change. She got the car back and boyfriend went to work on it. He measured temp with infrared thermometer and told me some ridiculous temp of like 280 degrees. I have to wonder if he wasn't seeing the exhaust manifold. And that the fans weren't coming on, again, so he hot wires them.
    I know there was more involved as I could not seem to get all the air bled from the radiator and suspect that a head/lower manifold gasket may have been going, again!
    Dexcool? I think not, but am more suspect of them adding coolant to a over heated motor. And that black sludge, maybe a product of someone adding green to the Dexcool. Also in the class action were complaints of plugged radiators.
    If someone gets the real dope on what is going on relative to Dexcool, please post back.
    A shorted diode in the alternator should reveal itself as the alternator not putting out full voltage under load, such as lights, fans, etc. all on, at mid rpm. Also it will slowly drain a battery. An open diode will present without the draining of the battery.
    Either situation can through a lot of noise on the DC power, but the battery acts as a tremendous polarized capacitor and should take care of most of it. The distance from the battery affects the outcome because we are talking time to travel. All components should be designed to withstand reverse polarity, especially of the voltage a shorted diode would produce. There are many components in your vehicle that can through much higher inductive kickback pulses and all should have a diode across the connector of the power lead or internal to prevent this. Relays and motors are excellent sources of this trouble. One such example is the engineering blunder to have a diode across the cooling fan motor and added via service bulletin because it was blowing the traction module if I remember correctly. Something like a $1000 repair. Those spikes can easily run into hundreds or thousands of volts with a very short duration and can easily kill solid state components. They should have no effect on other components such as bulbs or motors.
    Problem started when I went through a wet spot on the road. Not standing water so it was a light spray. Started running rough and throwing multiple misfire code in addition to O2 codes previously there. After looking everything over, I decided to start with the front O2, which helped, but didn't cure. After a week or two of driving and desparation I intentionally drove through a wet spot, something I had been avoiding and it started purring just fine. I drove the six miles home and going through a dip at an intersection, it was back. Which followed the way it had been acting, as possibly something loose. A few days of it coming and going and one morning it is really rough. Starting over, I find one coil has an open, which I replaced with a Rochester. Thought I had it fixed. Runs great for acceleration and idles pretty good, but I notice milage is off at least a MPG. Also noting MPG indicator, mild acceleration seems to suck a lot of fuel, and that there is a slight skip that shows as a mild vibration. Actually most noticeble parked and running into mid rpm, feeling it as a vibration on the steering wheel.
    Plugs looked good and not very old AC platinum.
    Don't know whose wires anymore, red, but supposed to be lifetime as I recall. Not a cheap set, but cheaper than Delco's.
    Is there known problems with aftermarket coils?
    I would like to take another swing at this before delivering into the hands of grease monkeys, so I'm looking for a sensible approach.
    Currently thinking of buying a Delco coil, and do the swap out to see if locates a weak one.
    Possibly then doing wires, but hate to replace $70 wires with $100 wires to not fix it.
    Next on the list would likely be an injector, fuel related problem. Now thinking of it, I might try that before the wires, assuming an injector is relatively cheap. just would take a long time to locate swapping eight times and then running sufficiently to ensure I got it.
    What say you all?
    It just wasn't doing as well as I thought it should. I disassembled most of the dash finding many airleaks on the ducts. Some the foam was misplaced and looked like one poorly hooked up. Got more air moving anyway. Then I get pulled for stupid window tint law. Darned stuff was supposed to be removed before wife took delivery. And I was leaving on to help with weak A/C. An aside, I learned in this interim that those SUV road rage idiots would tend to give me more room when I was in this vehicle. Conclusion is that because they couldn't see me as well that left an uncertainty that made them give me more clearance. So I have to wonder who the police, who got the law for their safety, are really protecting.
    Forced to remove it, the A/C cools much better. I can only guess that it was messing with the window heat sensors causing the system to mix more hot air before reaching the vents.
    But with being all over this car, including replacing front pulleys, in a short time, I now notice a vibration like noise when the pump is running. I hope it isn't going out and that maybe I just disturbed a line enough to cause it or maybe a bolt is loose on the compressor mounting which I've had make that noise.
    When caught up, I'll jump back into the A/C arena, and look further into replacing the orifice tube with the variable one. According to the inventors site, an adaptor is needed with Cadillac type A/C, temp sensing, not pressure. I wrote them, but never heard back as to the availability of it. The variable orifice is widely available.
    I want to do this because of the claims of increased cooling at lower rpm's, less strain on the compressor, and improved fuel efficiency.
    Inventor tests show far less than half as many bad compressors with severe testing. Fixed orifice tube is a compromise via charge amount for best cooling. At idle and low rpm, to get enough liquid for good cooling requires more freon. This also leads to higher head pressures when stuck in hot traffic. But the more freon is also bad when running fast. The obvious would have been the expansion valve which has such a tiny orifice in it that it was deemed to high of maintenance and no longer used most of the time.
  • cplmaccplmac Member Posts: 3
    My '99 Aurora started to leak coolant about 3 months ago. Very slowly at first, would take a couple weeks to trip the Low Engine Coolant indicator. Now it loses a gallon and a half a day, and I can actually hear it hissing out when the car is warmed up. It appears to be leaking from the water pump where it mates to the motor? Anyways, couple questions. First, these water pumps are timing belt driven? Second, has anyone had this problem before and if so should I just replace the water pump altogether or is it just a gasket gone bad? I will replace the timing belt as well if it is driven off the timing belt, and it turns out I need to replace the pump too. If anyone has any experience with this problem or any advice I'm all ears. Much appreciated. I'm no stranger to working on my Aurora. So far I have done the obligatory FPR replacement and done the multi-switch clean out (worked great stopped the lights from blinking).
  • violetbvioletb Member Posts: 1
    Service engine light keeps coming on. It will stay on a few days and then mysteriously go away one day and then come back. Anyone else had this problem. :mad:
    V8 Auroras do not use timing belts; they use two timing chains to drive their four camshafts.
    The coolant pump is driven by a belt that is driven by a pulley on the end of one of the camshafts. Replace the pump. Even if the leak is with a gasket (doubtful, in my opinion), it would be penny wise and pound foolish not to replace the pump at the same time. ACDelco replacements can be bought for $40.
    Les
    Is it leaking right at the pump or the gasket where the crossover manifold carries the coolant? The latter looked to be a major problem as some of the bolts to remove it look next to impossible along with they may be frozen.
    I think on this vehicle, the water pump assembly does a twist lock to get into place. No bolts. I don't know what tool is required.
    I haven't heard any thoughts?
    But I just realized something that may be contributing to poor milage. Torque convertor not locking most of the time.
    I forget how the sensing occurs, but I read that a tight power train when going down a rough road can induce enough change to make the system think there is misfire occuring and it's first reaction is to disengage the torque converter clutch. So even though the misfire is so inperceptible that most of the time you can't notice, sometimes mine runs smooth enough that it engages the clutch. (I knew that the clutch wasn't engaging, but didn't realize it might be related this time until I felt it engaging a few times around 45)
    Has anyone trouble shot a possible injector problem the way i posted earlier?
    What do you think of trying a coil swap?
  • 97andholdingon97andholdingon Member Posts: 5
    a bit of a swerve from the original message train, but my 97 has an interesting problem related to overheating.
    we have determined that there is a partial blown gasket, but one shop contends its not enough to cause my problem.. which is...
    overheating then cooling down then overheating, etc.
    flushed, new thermostat, water pump operable. Most recently, the car will go to the redline in constant driving, and then cool to near normal, creep back towards red, but stop short. It may cycle a couple of more times, perhaps even go into 'dark' red (all alerts) or just medium red ( turn off ac alert only)
    have a new cap so it doesn't boil over, even when I stop. Even dealership seems not to want to touch it, I thought it could be a bad sensor or control board. any thoughts? I was hoping there would be a method to monitor the water temperature outside the system to see if there was agreement with the sensors, is the infrared gun reasonably accurate? Also, ever seen a clear hose 'insert' so I could review the thermostat and pump action? entering the zone of the final straw...
  • mredsmreds Member Posts: 2
    My 95 Aurora was stuck in first, I found an Olds Technical Service Bulletin, No 77-71-73
    dated Jan 1998.
    the bulletin covers information on the service availability of the 1-2 and 2-3 shift solenoids for the 4T80-E transaxle.
    when i pulled the pan and lower controls assembly I found
    the solenoid had separated because the retaining bracket was cracked The repair kit comes with both solenoids and a new retaining bracket.
    Good luck mreds.
    I have a 95 Aurora with 98K miles, it sets a turban speed sensor code but it is not consistent. I have replaced the sensor and the code will still set some times.
    It will clear by its self with out hooking up a scan tool
    any information would be appreciated.
    Thanks mreds
  • teufelhunde93teufelhunde93 Member Posts: 13
    Well, today was the day... the final straw... both the alternator and power steering pump went. The mechanic quoted $1,200+ (parts & labor). I declined. So, if any of you on here need parts, let me know, because I am parting out the car... FYI. My Aurora is a 1995 in good condition other than the problem I mentioned along with a serious oil leak (a quart a week)!!!
    Other than that... farewell and good luck to you all... you'll need it!
  • javidoggjavidogg Member Posts: 366
    Hey e_net_rider about the coil swap, they might be some info about that in the "Other Aurora site".
  • huskerfan_21huskerfan_21 Member Posts: 27
    My aurora has started making noises that you would hear if the brakes were kind of stuck and had small rubbing on the rotors. As the car corners or accelerates the noise matches the speed of the tires. Someone mentioned to me it might be my CV joints?????...it is just annoying, doesnt affect performance of the car. I wondered if anyone has had problems with this and what it might be? The brakes got "checked out" and they are supposedly fine, and had the tires rotated and the noise is still there.
    Thanks-
    Greg
  • HenryHenry Member Posts: 1,106
    I would be interested in a few items. Please email me directly and we can talk.
    Henri
    Which site is that?
    Interesting indeed. I haven't heard of such a problem where it was cycling like that since I was a kid, that is without electric fans entering the picture. And it didn't have a clutch fan. Thermostat didn't get it either. May have been water pump with loose impeller on the shaft.
    Which gasket? Dealer don't want to touch??? Are they aware of some history they aren't telling you? It could be they are afraid of getting dragged into the Dexcool class action. And I'm beginning to see reason for it. It is looking more and more like the crud that the buick got was from mixing some old green with the dexcool. Part of the suit claims it plugs radiators, heater cores. And to the best of my knowledge, I've never seen a stern warning against any mixing of the two and the possible results. It calls for just a flush, but I used the heavy duty drive for like 5 hours stuff. And what i got was more of the near insoluable junk in the overflow bottle. I now think that was just excess in the sytem and the flush obviously did not break it down any. The only question now is what formed that crud. Was it the coolant incompatibility or that and a combination of gas seepage past gaskets?
    This brings concern to me as well. One of the first things I did upon acquiring car was take care of coolant. Basically it looke like water, and had no thermostat. Since working those issues, I've noticed a little cruddy stuff showing up in the reservoir. Since this is one of the vehicles with infamous leak where they add a couple of pellets I thought this was maybe excess working its way back to the high point. I had wondered why the flush didn't remove. I'm going to fish some of this from the bottle and see if it looks like what was in the buick. BTW, used Dexcool as it says on the cap.
    On your issue, do the fans cycle or change speeds with the guage? Infrared are likely accurate to their level of calibration, but make sure it only sees the source of heat you are trying to read.
    All along they've said not to mix the two types of coolant and not to contaminate the DexCool with green stuff. They said not to use the same equipment to check freeze level, e.g.
    The thing they didn't say was that changing the DexCool at 2 years 24000 miles was what should be done! Just like changing the green stuff. The DexCool doesn't survive long use 5 years or 150000 miles for example.
    That's especially true if the system has any air in the radiator with the hot coolant circulating through. Some cars had filler necks that trapped air instead of filling completely like my Buick does. The air with hot coolant being bubbled through it led to breakdown of the coolant. That caused a brown sludge.
    The pellets they put in for stop leak are some organic material (walnut shells someone said). It causes a brown particlate discoloration that shows up in the recovery tank too. But they only put in 5 pellets at most and they're about a teaspoon in size when crumbled.
    Who said? I just looked at a bottle of Dexcool. procedure is drain, flush (quick flush), and fill. It says compatible with other dexcool approved, but nowhere is there anything about the potential catrosphic results if mixed with other. That's why I said stern warning. Can you find one in your manual? At most, I see that like oil. Does it say anywhere that you must use specific oil? Possible weight changes for extreme temp changes and then you must dump immediately when in different clime?
    Something smells about this and it looks like it is going to track back to GM.
    On the air thing, if it is bad to have air with it, then it is next to impossible without creating an expandible bladder system. It sounds like your Buick has an unpressurized recovery bottle, which is exposed to air and at a low temp most of the time. But with the Aurora you have a pressurized bottle and multiple hoses allowing some circulation to bleed air to it. And this high pressure encourages the mixing of air into the fluid, much like making a carbonated beverage. And still it claims good for 100K. Just recently there has been showing up on some shelves a rejuvinator for dexcool. This was part of the defensive side in the class action. It was suggested to be used at the 2 years you mentioned, but you see no info on the 5yr/150K bottle of dexcool. There is certainly more to follow on this story, but my fear is that it is going to drag out so long that most of the affected vehicles will be off the road. Similar to the Firestone 500 radials. By the time it became national knowledge and the lawyers dragged it around and finally Firestone agreed to the recall, average driving would have put 75K on what was then a long life tire of 50K. I had one such set and they were made less than 10K tires after the last one in the recall. Tires were serialized back then. Because the car was only driven about 6K a year, I still had lots of milage left on them. First one separated, the dealer told me sorry charlie. About a month later the other front separated. About 3 months later one of the rear separated. I didn't wait on number 4.
    You mention brown sludge. What the Buick had was black as diesel oil. I'll have to retrieve a couple of globules from the Aurora and determine the color. It looks somewhat grayish in the bottle, but color could easily be distorted against the orange coolant and yellowish plastic bottle.
    Does that organic material show up as small flakes or does it tend to clump?
    Assuming OBDII, 96 & later.
    If you have three successful start cycles, I think it is supposed to go out. That would be cold start through a run at warmed up. The snapshot of parameters at the time of failure are supposed to stay for like 30 cycles. Cheap scanners may not be able to retrieve codes when the light is out. Better should be able to, but it might take the dealer system to pull all the data at time of snapshot.
  • 97olds97olds Member Posts: 1
    Sorry to hear of your misfortune...I would be interesting in some parts if you are parting it out, not certain they are interchangeable with a 97 though. The driver side window switching unit with window lock and woodgrain cover for starters. What would you look to get for this and where are you located to shipor pick up?
    GK
  • sadgirlsadgirl Member Posts: 2
    I know that someone posted a similar message but i would like to tell my problem just in case it is not the same. A few months back i was driving my 1995 Aurora on the highway. I was about to go over an overpass and hit a bump. After i hit the bump i tried to push on the gas because i was loosing speed and the engine just revved up like the car was in neutral. I pulled over cut the car off and then turned it back on, tried to drive and it got up to a 45mph and it stopped accelerating. Has anyone had this problem with their Auroras or does anyone know what might be the problem.
  • hammen2hammen2 Member Posts: 1,284
    My guess is your tranny won't go above second gear. This is a common problem on all '95's and most '96's - search this forum for "shift solenoids" and you'll find a description of the problem, and the fix - a kit from GM. You'll need someone to disassemble and reassemble your tranny to apply this fix, but it should cost you $400-$500, not thousands - to replace the plastic bracket with a metal one...
    --Robert
