Oldsmobile Aurora Maintenance & Repair
1656668707188
  • dlapaduladlapadula Member Posts: 6
    I tried to respond from work but it would not let me post. My Aurora is a 1996. The fans do come on with the AC on. When my mech used his scan tool he could turn on the fans also, so I don't think this is the problem. He seems to think the fans need to come on sooner to prevent damage. The car has always run between 200 and 220. Could a problem with the surge tank cap be causing the excess pressure in the tank. I have replaced the water pump, the thermostat and the radiator. I have not driven since due to the fan problem that my mech sees. After reading your post I am not sure there is a fan problem. Do you think I need to replace the PCM, would that make the fans go on sooner. Thanks for the help, Donna
  • imidazol97imidazol97 Member Posts: 27,791
    I didn't look back for earlier posts.
    Are there airfoils or dams under the front that are broken or missing or not staying in place at speed? These push air through the radiator.
    The heater business sounds like an air bubble reached the heater core. If there's air in the heater core, it might not have been properly purged after a radiator refill. Or there might be air getting into the coolant and some got tot he radiator core and that's why there's little heat being taken from the coolant water. The air might be combustion gases from a head gasket leaking. That also would lead to higher pressure from the gases getting into the coolant and the sounds of boiling coolant as the extra air gurgles its way to the pressure cap and is vented by that cap. Warped head?
  • gm_allthewaygm_alltheway Member Posts: 5
    i have had the heads pressure checked twice now and both times they held the pressure so could it still be a warped head? im not having any major coolant loss
  • blk97aurorablk97aurora Member Posts: 573
    Donna,
    If you have a problem, it is not clear to me what it is. All Classics run between 200 and 220 (maybe a bit of overstatement). The fans are designed to come on at 227 degrees if the a/c is not running and the coolant level is OK. Changing the PCM is not going to change that.
    I worried about my '97 running over 200 degrees for quite a few years. Now I just accept it. If your mechanic is telling you that you have a problem because your Classic runs between 200 and 220 and that is the only symptom, then I suggest he just doen't know Auroras.
    I agree with your mechanic that the fans should come on sooner, but I have not seen any evidence of damage. I have owned my Aurora for 7 years and 93,000 miles. It still has the original radiator hoses.
    If you want the fans to run all the time, have your mechanic disconnect the coolant level switch in the surge tank. Or install a switch so you can control the fans remotely. The side effect will be a DIC message telling you that your coolant is low.
    Les
    You could have a cracked head, wherein the coolant is heated by exhaust gases, like a tea pot, but there is no water/oil mix and possibly no pressure loss. You can have the coolant checked for exhaust gases, this is a pretty simple test.
    Overheating can be a real bear to diagnose and cure, since there are many possible causes.
  • mbmoorembmoore Member Posts: 6
    My 01 Aurora is in a tranny shop as I am typing this reply. I wrote earlier about having the exact same problem. But, some tran codes did pop up in my case. Code #1 - Turbine speed sensor and Code #2 - Trans range fault after shift. Apparently, this has to do with the fact that the computer realizes that it is in OD, but it also recognizes that the RPM's are too high to actually be in OD. They pulled my trans pan and said that there was excessive metal shavings on the magnet and there were some very small metal slivers in the filter. Of course I looked in the pan, but I don't know what excessive really is, it seems kind of subjective. They said that those combined with the codes lead them to pulling the transmission to see what is wrong. They say that OD is one of the first things that goes in these transmissions. I will let you know what they find out and how much it costs me, initial estimate $1,200 - 2,400, ouch, there goes the bonus.
    I am having another problem. After running fine for a few days. My surge tank was spewing out all of the coolant after I stopped again. The thermostat is new and has been checked. The temp guage in the car said the temp was 200 degrees. What could be causing this problem. I just replaced the water pump and the radiator. Help! Donna
    Surge tank cap?
    I was already planning to buy a new one tomorrow. What has me baffled is the temp guage in the car never indicates that the car is overheating. I am also going to check tomorrow and make sure the cooling fans are coming on when the a/c is turned on. They were working a few days ago when I checked. It they are not turning on with the a/c is this a PCM needing to be replaced. At this point I am okay with replacing the PCM but only if that is the problem. Thanks for all of your help, Donna
  • smooth1971smooth1971 Member Posts: 1
    I flushed my readiator because the car kept overheating. After I finished the fluse the car will not start. All of the lights, radio will come on but no sound out of the car. I also get a message "Service Vehicle Soon". When I look at the readings there is no trans life, oil life they all say -----. The funny thing is when I try to start this morning it shows me the date and oil life and no Service Soon light then I try to start and nothing and the Service soon light comes back. Any idea?
  • whitey1121whitey1121 Member Posts: 1
    All of a sudden the instrument panel, climate control, and trip/computer system stopped working. Spedometer, tachometer don't work. When the lights are on though the instrument panel is illuminated. The climate control and computer lights do not illuminate at all. Is this just a fuse problem or something bigger? Thanks for your help.
  • medictexmedictex Member Posts: 2
    I've got a bad starter and need to replace it. I have not worked on this car very much (it's my wifes car) and I am curious if it's a job I should tackle myself. Most parts changes on this vehicle are a little more complicated than normal, so I wanted to ask before I get in over my head. Anyone here changed one out themselves? Any cautions or tricks?
  • phil95phil95 Member Posts: 30
    I bought a used 95 (nice clean car) Aurora there was no RKE with it. So I sent for one.
    still waiting. I'm convinced it has remote keyless. I could be wrong. the car came a 1996 manual. And progrmming theater lighting is done with a transmitter which I still need to get and get programmed. In the meantime when I get the car the light go off instantly. same getting out. What am I doing wrong.
    phil95
    Maybe you can help me. I'm sorry I don't know anything about starter replacement. But I bought a used 95 (nice clean car) Aurora there was no RKE with it. So I sent for one.
    still waiting. I'm convinced it has remote keyless. I could be wrong. the car came a 1996 manual. And progrmming theater lighting is done with a transmitter which I still need to get and get programmed. In the meantime when I get in the car the light go off instantly. same getting out. What am I doing wrong.
    phil95
  • kiehlkiehl Member Posts: 5
    Let me know how that goes. Ironically, mine went into the dealer on Friday, 7/14 also. It just rolled 80K and I noticed it now has a delayed shift from 2nd to 3rd and now they are telling me that it won't go into 4th gear??? The dealer said they think that there may be a rod stripped or something. It will cost me $800 to know for sure to drop the tranny to investigate further. I am just so skeptical with this car anymore. I am picking it up tonight without the additional work. In the last 3 months I have put a new drivers side axle, wheel bearing, water pump totaling $700+. Now the transmission could be $2800. It also has an Air Bag Malfunction message in the message center ($425), Check Engine light 0410 - Secondary Air Pump ($410), intermittent messages about Service Stability System all yet to be fixed. I really like the car but enough is enough. To top it off, it has been rusting/oxidizing above the headlights for a few years and the dealer wouldn't do anything with it because it's not rusted through. It will never rust through because the hood isn't steel. I am looking at trading in ASAP! Please let me know what your ends up costing as it may help keep me out of 5 years of payments on a new vehicle.
  • oldsmoneypitoldsmoneypit Member Posts: 6
    I recently changed mine out in a 98...do not be fooled into thinking this is very difficult, it really is easier than changing one in a regular car. it is located under the intake manifold, there are detailed instructions on this site just do a subject search. The only advice i will give you is that in my case, i did not need to remove the fuel rail. I simply removed the bolts holding down the manifold and bungee corded it up out of my way and then removed the starter, two bolts and the power wire and it comes right out. The manual says to replace the intake manifold, i ignored that as well, no need to. good luck!
  • coreyg1coreyg1 Member Posts: 34
    I am having an issue with the VENTS in 98 Aurora. AC or just regular fan will blow then stop periodically. AC is still cold(not freezing. It doesn't matter where i have the fan or temp set. They will all blow then they decide to shut off. HMM what to do????
    I dont know what to do about this any advice would be greatly appreciated!!
    To further my issue with the vents. Now they blow absolutlely no air at all. It doesn't matter what the climate control is set at. AC or no AC there is no airflow through the vents... HMM what could I expect is wrong.
    I am supposed to be picking it up today. I didn't want to do it, but it will end up costing me $2,400 and some change. I could have had it done for $2,100 with a 12/12,000 warranty on parts and labor, but the additional $300 replaced more electrical components, such as; solenoid valves and boosted the warranty to 24/24,000. So I decided that paying a little more now was worth it, since they already had it apart, than pay a lot more later if they had to go back in to replace those components or replacing the car. I know what you mean about liking the car, but... Fortunately, the last major repair that I had, approximately $1,800 was covered under an extended warranty. I currently have about 108,000 miles, no more warranty, on the vehicle and am looking for ways to help ensure prolonged engine life, any suggestions would be appreciated. Also, to let you know what was wrong, they found out that it was 4th gear itself that was bad, it is a spline gear and it was striped down to where there were no teeth left on the gear, smooth. Which obviously meant that there were metal shavings in a bunch of components in the transmission that should be replaced, such as the torque converter...?
    The blower fan motor itself could have gone bad. That can be checked by applying power through a fused wire directly to it and making sure the ground is grounded.
    It could be the blower motor control module. I am assuming the car has an automatic temperature/fan speed control like Buicks have of the same era. There is an electronic circuit board that replaces the resistor sets that used to give different speeds on manual fan control systems. The control module is in the air box right next to the blower--that air movement keeps it cool so it doesn't burn up. The electronic control module is about 4 inches x 6 inches but only the top end sticks out for the electrical connections. It will be on the airpath box in the engine compartment. I do not know the layout of Auroras.
    The failures in Buicks of the same era are that the module can stay on with key turned off so the blower keeps running until battery gives out or they can vary in speed sometimes while being used or they may cut in and out or they fail completely.
    The part is dealer or can be bought at Advance Auto store, e.g. People says it's about $100 at Advanced, if I recall correctly.
    The part can be tested to see if it's getting power from control inside the car without removing it. Testing to determine what is wrong is necessary to avoid replacing module or blower motor if they're not bad.
  • HenryHenry Member Posts: 1,106
    Has anyone had to replace the furl lines under the car due to rusting or pitting of the lines?? I have a 95, so I guess I am talking to other Classic owners.
  • caseybrcaseybr Member Posts: 1
    I'm having the exact same issue with a 1995 aurora, i've checked a good deal of the fuses in the fusebox on the dash, but i've not found anything amiss with those. My best guess is that the computer has gone haywire. Can't afford to find out right now. :(
  • mbalsamombalsamo Member Posts: 3
    their was a recall on the fuel lines and fuel rails located up on top of the engine, take it to a cadilac dealer and they will fix it for fre..
    their was recall on the fuel lines and fuel rails, go to a cadillac dealer and have them replace the fuel lines and fuel rail :shades:
  • aurorafreakaurorafreak Member Posts: 2
    My 96 just got both (I beleive their are two, not certain) solenoids replaced on the transmission. Apparently this is a very common problem with the transmission in the Aurora. It cost me about $600. They are external to the tranny and do not require any massive amount of labor.
    Ask them if they are certain it is not just a switch/solenoid. My car was basically fine in first and second gear. As soon as the car reached the RPM level that would switch it into third, it would just slip right out of gear and the engine would rev real high.
    The tranny shop that worked on my car is called Danny's Transmissions in Columbia, SC. They apparently have worked on a lot of these cars and were familiar with this behavior. She told me she has never seen an Aurora that had a bad tranny, just bad solenoids/switches.
    Computer going haywire - it does happen. Unfortunately (I have a 96 by the way) the Aurora has a very complex wiring and electrical system. this is one of the major negatives about the car. That system has to be in almost perfect mechanical order to function properly. When sensors begin going out, such as the one on the coolant resevoir, oil pressure sensors, etc., the onboard computer starts sending all these false readings like service engine soon, coolant low, etc.
    I learned a few years ago when I had the batteries replaced that one of the benefits of disconnecting the batteries was that it reset the computer and cleared alarms and other false readings, etc.
    Try that by lifting the back seat and disconnecting the battery power wire for about 30 seconds.
    Well, the damage is already done, so to speak. They took the tranny apart and showed me what they said was my 4th gear. It was stripped smooth, I didn't see them take it apart so I cannot say whether it was actually mine. So, go or bad, I have a rebuilt transmission with a 24/24,000 parts and labor warranty that cost me $2,400. I would have liked to get a second opinion, but I had already given them permission to remove and inspect the transmission and it would have cost me $500-600 to have them put it back together without doing anything to it. I was stuck between a rock and a hard place.
    could you please tell me the part number for the ignition switch you replaced??
    Re: ABS LIGHT & TRACTION CONTROL LIGHT REMAINS ON '98 AURORA [hammen2] by pizza442 Dec 19, 2005 (11:10 am)
    Had this problem a while ago; ended up being the ignition switch in the column. Dealer tech was able to test the switch after testing the security-key deal. He had a good used switch laying around which he hooked up while everything was apart and new for sure it was the ign. switch. Ordered the new part.
    My early trouble sign for this was a slight delay in starting when you turned the key.
    Jay
    I am talking about the fuel lines UNDER the car. I already replaced the ones under the hood per the recall.
    Has anyone here looked under their cars (Classic owners) at the fuel rails? Are they rusted or pitted???
    The part number I got from GM PArts Direct is the one below. Is this the part I am looking for guys? The last time I discussed this, someone commented that it was not the lock cylinder. I just want to make sure I spend the money on the right part.
    Thanks in advance.
    Henri
    26030594 ignition lock cylinder switch.
    :):D
  • dr_turbodr_turbo Member Posts: 60
    Any ideas on this: while turning the wheel either right/left and moving forward slowly I hear a growling noise almost like something is shuddering or grabbing. I know nothing is rubbing in the wheel wells since I checked that.
    It steers nice otherwise and I only hear while going slow and turning from center position to halve radius.
    I will be replacing rotors/pads soon so I can look into your suggestions on this. Thanks
    paul
    My 95 started ruining rough and is getting worse is stumbles with the air on. It's got 97,000. do you thinks it's plugs and wires or worse like the thottle body. it's running about 250 degrees as well. it's been extra hot here in Illinois. But before I start throwing good money after bad. I was hopeing somebody straighten it out with plugs and wires. And did I read not to use the platnium tips again? My mileage fell from 14.7 with the air on to 9.0 mpg. can somebody help?
  • mshuda1mshuda1 Member Posts: 6
    Phil,
    You may try a throttle body electronic control module.
    Its about a $19.95 at a discount auto parts store (as opposed to $80 at a dealer).
    Also it is about a 10 minute repair, if someone (most shade tree mechanics) knows what they are doing.
    You should check plugs and wires....are you getting any error codes? I think autozone will read your codes for free if you don't have a reader.
    I don't have a reader but for 20 bucks I'll give it a try. I build hotrods mostly normally asperated 350 Chevys. But I think I can firgure this out. I had a hunch it might be that complicated delivery system. Plugs and wires I guess are just a given at such high milage. Just hate get rip off for wires. But there is such a temperature swing in Illinois. I'm sure it takes it's toll.
  • sbelksbelk Member Posts: 1
    I own a 2001 Olds Aurora and had to have the motor replaced with a new one (block was cracked). Since it was replaced 3 days ago, the check engine light, the low coolant light, and the low tire pressure light keeps comming on every time I start the car. My husband and I bought this car used from a used dealer. They put a new motor in it from GM.
    My husband has disconnected the battery and it didn't clear anything. The same messages come up and the engine light is still lit up. I brought the car back to the dealer and they said they had reset the engine light but later that day it reappeared. What am I to do?? What is causing this?
    Any advice would be great!!! :confuse:
  • bondsman22bondsman22 Member Posts: 1
    I have a '98 Aurora and in the past month I have had a new compressor, condenser, orifice, and inline filters put on it by a Chevrolet dealership that is supposed to be a certified GM service shop. I send $1,500 and about for trips to the dealership to have the car do the same thing that it was originally doing when I first took it to the shop, the A/C gets super cold at night and super hot during the day. Should I have taken my car to a Buick dealership since it shares the same a/c system as the Riveria (and dealer's repair manual) or should I have taken the car to an independent a/c shop? Can someone tell me what is going on?
    I would take it back to the Chevship that worked on it and let them contact the Buick dealership to find out what they did wrong and make it right for you. Before that I'd contact a Buick shop and ask what was wrong--so you go in with prior knowledge so Chevship can't cover their rear with a lie or less than truth.
    I've see people mention Cadillac dealers because of the Northstar motor in Auroras. Have you considered that?
    My A/C turned off last week in 117 degree heat. I took it to the shop and was told it was a high pressure switch that automatically turns the ac off when the car is running hot. They had to reset it with the computer. My question is, is there a way to reset the a/c without taking it to the shop, if this should happen again? Thanks.
    The left hand side map light works fine with the switch out. To fade switch in I need to tap the switch. So the light bulb is fine. Question is how does that unit come out of ceiling. It has to be just a small bend in the switch to repair but I hate to start prying trim out that may be fasten some other way. Looks like a fiction fit anybody been in theirs.
  • red_headred_head Member Posts: 1
    Did a search for my problem and thought I had it solved. Headlights flicker on and off, accompanied by a clicking noise in the steering column/dashboard area, even when the car isn't running. Followed thumpin455's directions to clean out the multi-function switch but it didn't work :cry: On top of it, now the left turn signal won't work and I've even replaced all the rear bulbs. I am a poor college student and don't have the $500 to fork over right now. Any other suggestions?
  • danee05danee05 Member Posts: 1
    Is the battery located under the back seat? :confuse: I just brought a 95 and I had pulled the back seat to get to the seatbelt buckle and when I popped the seat back in everything in the car flashed off then back on. However once this happened I wasnt able to start the car. Dont have an owners guide. :mad:
    I could not locate the battery anywhere under the hood and I started to freak out. Surfing oldsmobile's sites have not helped me at all....... :(
    My computer keeps flashing things about the transmission fluid and coolant but they are both just fine. Do I have to go to the dealer to get it reset?
    thanks in advance :blush:
  • 99dodge99dodge Member Posts: 15
    Did you find out what the problem was and which motor you had to replace.
  • pegasusthunderpegasusthunder Member Posts: 13
    Hey there.
    Yes, the battery is located under the back seat. I don't like it there, but oh well. I didn't know it was there until after I bought it. I have a 95 also. Didn't think to check. There is lots of wires and stuff associated with the Aurora. It's a pain. I had problems with mine starting. I posted before about the security problem, like the key and stuff. Well, it turns out there was a problem with the ignition switch and some wires under the stearing column.
    I've had this car in the shop most of the time since I got it, which was in January, but now I think what they last did might be the trick. *knock knock on wood* I haven't yet had a problem starting it. So my previous posts did not answer the problem.
    As for your problem. I have heard that if you unhook the battery for a bit and hook it back up again, the computer will reset. Try that. It may help. If not, it may be a wire problem.
    If you have to take it in, tell them to check the back seat first, since that is when the problem started when you lifted the seat and put it back. It may be a pinched wire or a wire got pulled loose, or a grounded wire problem.
    I wish you luck. I love this car, but it can be a headache. It gets better when they find the problem. Of course, no car is perfect!!! I've had my share. :sick:
  • akwebb81akwebb81 Member Posts: 15
    I just purchased a an '01 w/ 68K miles on it 2 weeks ago. The other day when I was scrolling thru the Driver info center, I noticed that the oil pressure was extremely high, 76psi at idle and 115-130psi at highway speed(it was 30-60psi when I bought it). I know that the most likely causes are a stuck pressure release valve or the sending unit. Which would be more likely of the two to be wrong? The sending unit is the cheapest fix and it sounds like to replace the valve you have to replace the oil pump(not cheap), just wondering if anyone has had a similar experience.
    Funny, I have an '01 with the 3.5L and it is reading 131 psi. It has been reading that for as long as I can remember, but it has only recently become a problem, actually 130 psi. The display is now reading low oil pressure, which I don't understand. When it read 130 psi the low oil pressure indicator never went on, now this it displays 131 psi, on comes the indicator. I don't think that it is actually low oil pressure as it has been running like this for as long as I can remember. So I would guess that it is the sending unit. Do you know where the sending unit is, I don't. And do you need special tools or is it extremely difficult to change it out yourself?
    I'm taking it into the shop tomorrow to find out exactly what it is. As far as the sending unit, typically they are located next to the oil filter and just screw in and out. I believe you need a special socket to remove them, but it is usually a simple procedure. Autozone sells the sending unit for $45, so a cheap fix if that is what it really is. The problem for you, and what I'm worried about, is that if the pressure is actually 131psi, and not just a malfunctioning sending unit, then you run the risk of blowing out seals and gaskets inside the engine, which could result in oil leaking out of the system and causing low oil pressure. I would recommend having someone look at it who has an oil pressure gauge they can hook up directly to the engine. If it is the sending unit, it should take them about 20 mins and an oil change. If you actually have low oil pressure you could be causing your engine some really serious problems.
    I just read a message but didn't see an answer. I would like to drain the radiator and refill with dex-cool. but I don't want a power flush (97k) I'm not looking for trouble. I. do have to remove the air low cover to get at the radiator petcock? and 2. is there enough room for what? 3 gallons of mix. and would you run it hot with a garden hose stuck in the overflow of just empty the radiator. Been a long time since I did a flush. I'm only good too -10 I live in Illinois should -30 of -40 to cool properly. and it has Zerex in it. I'm retired and haven't done a flush since my teens.I'm retired. I have newer cars and bought this autobahn as a hobby. I have always loved them and found this an older gent local who wanted a flexfuel car.This car is like new. when I bought it the only things wrong where a cup holder flapper (junk yard) and I had to re-dye the shifter. But I noticed it had carquest radiator hoses and the wrong coolant. The old man had a fast oil change place fix it. Winter comes up fast here. And I still want to put a new battery in it. Otherwish I had my mecanic go over the whole car and knock on wood he can't find any problems or error codes.
    I'm a streetrodder I have '40 Ford Deluxe 350 chevy ,305 turbo hydro ,mustang front end. It has electric windows ,air, all shaved, all eletric doors and trunk. Took many trophys. the reason I mention this is it's normally aspirated and doestn't have 100 miles of wires in it like the Olds. It's a striaght forward custom. that I can't drive in the winter. so I took on the Olds figuring it's halfway to a hotrod with some luxrury I can tool around in. The Olds is Champaige no matter how much I buffed it , it 's still not what you call striking. Plenty of high grade wax but........well it's Champaigne. Anyway it's needs coolant and a battery. and you guys know the tricks.
    I'd be really careful to get all the other type coolant out. The DexCool doesn't mix right with any of the other coolant present. I would find out if there's a flush chemical to put in to counteract the old style coolant in the system. I believe they said only a little bit will cancel the qualities of the DexCool.
    Don't forget to add a few of the GM pellet sealer to the radiator when you're ready to take a drive after the system's been filled and checked out.
    Phil,
    Welcome to the wonderful world of Auroras!
    On my '97 there is a round opening (~1.5") to access the radiator petcock. Mine is not aligned closely with the petcock, which makes it difficult to reach. I have used a 19mm socket to turn the petcock. Draining is messy because of the misalignment.
    If you google for dex-cool, you will find more than you ever wanted to know. There is a lot of disagreement and misinformation. So far, I believe Havoline and GM. There are others on this board who disagree with me.
    Following is my experience: I bought my '97 in 1999 with 37,000 miles. In 2002 at 78,000 I flushed the cooling system with a Prestone cleaner and a tee that claims to reverse flush the system using a water hose. I do not know if Prestone still sells these tees; I've been using mine since 1970s.
    Cooling system holds 13 quarts. It's impossible to drain all liquid. After draining the radiator and removing, cleaning, and reconnecting the surge tank, I added 7 qts of Havoline Dex-Cool. I completed the fill with distilled water.
    Completely draining the cooling system is a chore I never want to do again. Every year since I have drained about 1 gallon of coolant and replaced with a 55/45 mixture of Dex-Cool and distilled water. My reasoning is that instead of waiting the recommended 5 years and completely draining the system, I am replacing 20+% each year.
    I am being conservative by using >50% Dex-Cool, using distilled water, and replacing >20% each year. The incremental cost is quite small and I keep my vehicles for a long time. My odometer is now at 133,000 miles. I'm still running the original pump (I do have a spare in the basement).
    Minimum percent Dex-Cool should be 50%. Not just for freeze or boilover protection, but for the additives. Corrosion in an aluminum engine and aluminum radiator can be a serious problem. The information on the side of my Havoline container shows freeze and boiling temps as -34 and 265 degrees F with 15 psi cap for 50% mixture. At 66%, the temps are -84 and 270.
    You have the additional problem of green anti-freeze. All the info I have seen is that even a small amount of the green stuff will negate the long-life properties of Dex-Cool. The thing I have not been able to determine is how small is small. I think my procedure of replacing 20+% every year will mitigate this problem.
    As someone else posted, be sure to use the walnut shell pellets. They are cylinders about 1.5" in diameter and 0.75" long, tan color. GM sells them as does Bars-Leak (I'd guess Bars-Leak makes both). The fibers seal leaks in the engine. There have been reports that they can clog the heater core, but I do not believe.
    I replaced my battery in 2001. The only correct replacement battery I could find was an ACDelco; original battery was 681, replacement 76-84. The battery needs to be vented because of its location under the rear seat. I think that ACDelco no longer makes the 76-84, so I do not know what I will do for next replacement. I have read that some people have used Optima gel electrolyte batteries as replacements.
    Hope this helps.
    Les
  • e_net_ridere_net_rider Member Posts: 1,380
    Les, sorry about my lengthy absence.
    That sticking ring thing should not have been a problem unless you were using 10W40, more specifically Valvoline, and I would have hoped they fixed whatever the problem was.
    It is probably the same procedure they used back when this was a prevalent problem for GM and it was a hit and miss thing which if it didn't work required a tear down and new rings.
