Visitor Agreement.
The skull-crushing argument against additives in cars (for me, anyway), is that modern cars rack up incredibly long mileages without a whisper of an additive added beyond that from the fuel and the regular engine oil. That observable fact sort of stopped me in my tracks years ago from advising the use of additives anymore.
Does anyone know where this is reported? I feel better since I've avoided the alcohol-based fuels as much as I can at stations.
I thought I posted something about it a long time ago, but can't find it.
This affected mostly californian vehicles, since California uses reformulated fuels quite a bit.
I'll try and see if I can find the information again, but that was a few years ago and my memory isn't that great.
Shifty the host
Later on GM's issued a report and conclusion was it was caused by sulfur compounds depositing on the injectors. This supposedly happened more-per local newspaper investigation-to people who bought Citgo brand gas.
I haven't read anything since a few weeks ago, and our Ford Taurus and Dodge Caravan both swallowed the Citgo and any other brands we bought during that period without a whimper, so it didn't affect me.
I use straight additives, no gas, car runs like greased lightening, till the motor burns up. shoots flames outta tailpipes, scratches with each gear shift, leaves great clouds of mosquito spray everywhere I go!!!
Ok, enough story telling. Just wanted to change the pace a little.
Greased with oil of snake. ;-)
Best Regards,
Shipo
Still chuckling(not choking) on that one.
Andy
I *think* they make a stronger version of techron that is quite a bit more expensive (as is BGK44). You get what you pay for in other words.
They can:
keep injectors from clogging(maybe)
clean a clogged injector (maybe)
take water out of gas
stabilize fuel
lubricate upper cylinder area
kill algae in diesel tanks
things like that are possible, though really bad cases of the above probably cannot be cured from a "dose".
What the CAN'T do is:
improve gas mileage
extend engine life
repair a defective engine
raise compression
All of the above three claims have fallen down under strict laboratory scrutiny.
I suppose you could say that if the fuel additive unstuck a sticking injector then it "improved fuel mileage" in a weird kind of way, but only because a dead cylinder was re-activated.
It fixed up my Benz diesel pronto, which was idling badly due to one clogged up injector.
You have to differentiate between fuel additives that are for "maintenance" (to keep clean things clean) and for "correction" (to make dirty things clean. Those are two separate animals.
You aren't going to get anything "corrective" for $2.99.
Does it work, don't know but I do not like the way it is marketed, it smacks of snake oil. Ask them what nationally recognized lab did the testing that they talk about, Any reputable lab would love to have it s name thrown around maybe results are confidential but the name of the lab, let's have them?
My Corolla 5 speed was having problems shifting at high RPM and on downshifts. It would grind lightly as if the synchros were slightly out but was getting worse. I had 3 shops check and all pretty much said that they'd have to rip it apart to find whats wrong which would be big $$. My neighbor who is an A mechanic at a BMW dealer recommended BG Synchro Shift. They used it at the dealer for the cars that were exhibiting the same type of issues and noticed huge improvements. I had changed my GL-5 gear lube every year any way before that. I figured $50 bucks in gear fluid couldn't hurt as a last try. I contacted BG with questions and the rep said that their fluid was a 75w-80 synthetic GL-5 instead of the 75W-90 and gave me the local rep# as well as sending info on that and the 44K. He said that I could find it at many of the local dealers. I had my shop put it in expecting nothing, hoping for a miracle. Left the shop and noticed ZERO difference and was like, oh well and drove the mile back to my house. Next day I went to work (23 miles away) and downshifted as I always do and SURPRISE, NO GRIND!!! I started from the light and went to 5500 rpm in 1st, 2nd, and 3rd all with zero grind. With a big ear to ear grin I get back ion the highway and try some more higher speed downshifts all smooth. Would Amsoil, Redline, Royal Purple, Mobil 1 gear lube all have done the same thing? Maybe, but 4 years and at least 50k later I still have no grind so I'm sticking with it. Next I had bought some of the 44K just because of positive experience from the fluid. One tankful later my mileage went up, definitely more power, and ran smoother (I fill up and write down miles and gallons and maintenance every time for all my cars so checking is real easy, dad's fault). This was after at least semi annual Techron treatments with no noticeable difference, I figured it was already clean and I was just maintaining which I was ok with, wrong! Bought more for me and family/friends who had same results. When I drive on a trip or concentrate on "normal" driving I still get excellent mileage (33+ mpg on my almost 190K, 1993 Corolla) Unfortunately my mileage is normally less as I'm in traffic some, either that or it's the full throttle, 5500 rpm, 1-2-3 very smooth shifts, hmmm I wonder.
I've only seen one dealer by me advertising the BG products in their flyers. All the rest you have to ask if they have it and then they volunteer the info and you see the BG equipment in their shop. I've NEVER seen a sales flyer, TV ad, or magazine info on the stuff, or found it in any "chain" auto stores. The prices at my dealer are the same as all the rest of the local shops for tranny and other fluid flushes as well as Fuel Injection cleanings. Granted just my experience but since I never saw ANY marketing it would be hard to say it was marketed as the cure all.
I had asked the mechanic who fixed the Exploder if he had ever heard of BG and what his thoughts were if he did. His reply was "what do you think I used on your Explorer with a big smile"
right.
I'll post the website later.
I just took over the car from the wife, and put Mobil 1 in right away. And now I want to give it some "supplements". To boost the health and such.
I will also use this experience to judge whether or not to buy some, as gifts, to some favorite family members.
do you add it to the gas tank or engine ?
should it be put into new cars ? or just cars with problems ?
thanks...
And let us know if the car improves.
Shifty the Host
I will update as we go along. Does seem a little peppier. Course, my car wasn't a basket case goin in...so...we'll see.
With tax, cost me @18 clams.
Still runnin on the 1st tank with BG44K mixed in. With my work schedule and overall lack of useless driving, be later next week before I refuel.
I all ready like the fact it starts quicker in the cold.
