Problem is, most of the driving public cares how many airbags the car has (concerned about passive safety over active) and if it has a passenger vanity mirror (first question a few female freiends asked when they saw the car (Protege) for the 1st time - after saying "nice colour").
Dinu
... and you made a good choice in the Protege. The Protege has well designed brakes. 60-0 in 123 feet, and good feel too. I'll take the 5 feet (which was actually closer to 9 feet, but hey - who's counting?).
... and as malt would point out, the difference gets even bigger from even higher speeds. Afterall, who drives 60 on the highway these days?
Ooops, gawkers have traffic stopped ahead, and everyone is slamming on the brakes all of the sudden. Am I going to make it? Bam!!! Oh, man. Just 5(9) feet short. Oh well. Better luck next time. ;-)
But the difference is just about the same you would probably get when you changed tires, brake pad composition, tire wear pattern blah blah...
Under normal driving conditions it won't matter any more than any other variable.
The 6 isn't meant to be a "Beemer killer". It's a sporty alternative to all the plain jane FWD sedans.
They don't because they feel the configuration that they have built is adequate for the vehicle's intended service. Just as those cars with disc/drum confuguration.
What is all this stuff about design, and disks versus drums?
Mark. ?
Seriously, if I had money for a BMW, I would give a kind wave to my Mazda dealer as I passed him or her on the way to buy a BMW.
Actually, strike that. If I had the money for a Gee35 Coupe ... that certainly does beg the question, doesn't it?
If I lived in a hilly area, I'd definitely go with rear discs. You do notice the brake fade during a long downhill grade (even after shifting down for some compression braking from the engine), and it's a little scary.
I think the lower heat-transfer rate of drums is the culprit. Some braking ability is lost to increased gas forming between pad and drum. More loss occurs when the brake fluid is heated to the point that gas bubbles form in the brake lines. This can disable your entire brake system, front discs included (as I think most systems tie diagonally-oriented brakes together).
But for most folks, on mostly flat terrain, rear drums are fine. I'd just prefer rear discs (mostly for easier maintenance). Plus, they look neater.
Why does someone want to compare Mazda6 to Cam/Accord? Dinu is right. These are two different types of cars, and comparison is meaningless. Please drop such topic.
If someone want a nice family sedan, it is a good deal for them to buy a Camry or Accord. However I want something a little more fun for driving and hasing a distinguish style, so I chose Mazda6. I do not want to park my car in a parking lot and find it is difficult to locate it, because so many people drive the same car as I do. Mazda already made it clear that Mazda6 is not a car for everyone, and please do not expect it will be such a popular car as Camry/Accord.
bme
I bought an Accord instead and will use the extra money toward paying off my house.
So get one then.
Sounds like the 05 MPV to me!
Ditto BMW. I prefer FWD for the snow/rain and am willing to accept the understeer trade-off. Besides, BMWs are getting too gadgety for me. I am totally turned off by that iDrive system. Give me dials and big buttons, please (actually, I'm not that fond of the 6's center stack design...controls too far away from the display and the design doesn't look flexible for fitting-in aftermarket stereo equipment).
Also, the difference between disc and drums on the back is usually less than 10ft. stopping distance. But what happens if the thing you are stopping FOR is 8 feet away??
Enough disc/drum for the day. Can we talk about accords some more?
*snickering*
And if the car needed to stop that quick wouldn't it be nice if ABS were included in the package standard also? I mean while we are talking hypotheticals IF you needed to stop that fast ABS and ABD would be a great help. Still leaves the 6 behind the curve it is trying to set.
I would take the previous gen Accord coupe's rear end design 10 times over.
*prerequisite Mazda 6 text* I like the Mazda6
Luckily, all airbags working.
Bruno
Like a 6 isn't walmart Bimmer?
what it has right now simply doesn't look good.
Kumbaya...
- Latka Gravis
Of course you're correct Paul.
http://www.caranddriver.com/xp/Caranddriver/10best/2003/2003_10best_cars_mazda_6.xml
(This link may not work if you are not using Windows XP, in that case go to the Car and Driver home page and the main topic will be the “10 Best” list.
There is text, pictures, and a cool video, check them all out.
Interestingly enough you can also check out the Accord, BMW 3 series and Infiniti G35. The all made it to the “10 Best” list. As you would expect the Accord made to because it's a great family sedan while the other three made it to the list because of their great sport sedan qualities...
Under normal driving conditions it won't matter any more than any other variable. "
Hey, under normal conditions you wouldn't need airbags either, or even seat belts for that matter.
http://www.hwysafety.org/vehicle_ratings/ce/html/summary_midinexp.htm
Just don't buy a Grand Am.
Bruno, wonder more than ever.
