Dodge Ram: Problems & Solutions
kcram - Pickups Host
The ABS indicator lamp is illuminated anytime the Anti-lock Brake Controller (CAB) sends a fault message to the instrument cluster. The CAB will declare a fault when it detects a malfunction or the anti-lock braking system is inoperative. The Brake indicator lamp will be illuminated when the CAB records a fault.
There are two versions of anti-lock brakes found on Dodge trucks: a rear wheel anti-lock system that operates the rear wheels only, and a full anti-lock system that operates all four wheels. In both systems there is a rear wheel speed sensor mounted to the rear differential. In addition, in a full system there are two sensors mounted to each front steering knuckle.
An ABS fault can be declared by a defective speed sensor, a defective hydraulic control unit, low brake fluid, a defective CAB, or an bad electrical connection in the CAB system. If the system is inoperative (ie: an open ABS controller fuse), a fault will also be declared. Ensure that there is adequate brake fluid in the master cylinder reservoir and check all electrical connections in the ABS system.
The rear wheel speed sensor mounted on the rear differential housing also sends a signal to the Powertrain Control Module (PCM) to determine road speed. The fact that your speedometer isn't working tells me that this sensor may be causing both problems.
Best regards,
Dusty
well after three weks they have determined the rod is not bent and so it looks like this new truck will be fixed under warranty. they are now looking at injectors or another mechanical failure of some kind. it sure took a lot of fighting to get them to actually check it out correctly. they are waiting on the proper tools to do a compression check. how can they service their own vehicles if they do not have the knowledge with tech to know what to do or the tools to properly check for problems.
i will keep you all posted. a lot more to add, but will wait to make sure they warranty this new truck.
The links have provided some fantastic information. This weekend I'll start with a bit of cleaning of the brake area and the Sensors. From there . . . who knows.
Seeing this problem at MANY sites and with many vehicles has put me a bit at ease regarding the running of the truck, as it all seems to be a faulty indication of trouble rather than actually an ABS problem.
Now, the only other problem that lies is I have no clue what Im looking for when I look for the sensor and all that. Where is it located, or where can I find out? Thanks.
I have the same problem with a 98 2500. I figure since the breaks work I'll drive it. Now my speedometer doesn't work until drive awhile at 70 MPH. It will work a little sooner if I run 70 and back off on the throttle. Now my A/C quit. Probably the orifice at the evaporator plugged.
This thing is nickel and dimming me to death. I bought this thing for the Cummins engine. I wish Ford or Chevrolet used Cummins.
Best regards,
Dusty
John
The "black box" you refer to has steel brake lines going to it, it is the hydraulic control unit. If one of the internal pressure releif valves have stuck in one position, then yes it could cause an ABS fault.
Dusty
Any suggestions.
John
Thanks in advance.
If this can't be done for whatever reason, at the very least make sure the t-case is in its Neutral position.
..............and that the main transmission is in Park.
Dusty
It is designed to open at 600 psi.
Dusty
*Clutch petal interlock switch (manual transmission only)
*Starter relay (located in the power distribution center or fuse box. The underside of the cover should list the relay position)
*Starter solenoid
*Ignition switch
*starter cable and other electrical connections
Dusty
Loss of coolant.
I've no idea of the labor costs for that job, but getting several estimates from local shops should give you a idea of what's fair.
Remove the screw just above the bag holder, the one between the center console and the glove box. Open the ashtray and the cupholder. Pull straight out on the plastic center console (the one that goes around the radio and has the cubby hole in it. It will seem like it is going to break, but if you pull directly out it will not. Disconnect the electrical connectors from the cigar lighter and A/C Panel. There are four screws that hold the radio in, two on both sides. Remove the screws and pull the radio out (it will be in snugly). The antennae is the tricky part. You must push the antennae wire in, then pull the outer collar back, then pull out the antennae wire. (It is a locking device).
Also no codes came up stated there was no problems encounter.
Help!
