Visitor Agreement.
I'd say your friend is pretty smart.... great products. I've been very impressed with their paint sealant... waxing will have to be done every 3 months or so. The paint sealant lasts much longer.
Any info is much apprecated.
if you want it to look GOOD, then you gotta go with a full replacement. The guy's insurance paid for it to be fully replaced, didn't they?
I know a guy that had this happen to him once. He was able to find a license plate bracket, and mounted it over the hole in his bumper, and then put a decorative license plate in the bracket. Just a suggestion depending on where the hole is located.
Thank You
what the heck was it doing on a hoist?? Does it get transported by sea to get service?? (that last part is a little joke)
I'd say chances of damage beyond the value of the vehicle are pretty good.
Thanks...
:sick:
Do you want the engine bay and door jambs and trunk repainted?
Do you want all the trim and glass removed, or just taped?
How much body work is involved?
What part of the country are you in?
Some Ideas: When you see or hear about cars painted for $500--$1,500, this is generally done quickly, sloppily and with inferior materials. It looks okay from 20 feet away and might last a year or two. But quality work costs quite a bit of money because a) really good paint and primer is very expensive and b) the labor involved is very extensive.
So just guessing I'd say $5,000 minimum and then up from there, depending on all the factors I mentioned above--tape work is cheaper, and not doing engine bay and door jamps is cheaper and single colors are cheaper than two-tones.
But whatever method you choose, you have to face the reality that the paint job will cost more than your car is worth (in dollar terms I mean) and that even all painted up and pretty your car won't be worth the cost of the job.
And that's perfectly fine as long as you know that going in.
But shop around. If you get a very attractive price be sure to ask about warranties and ask to see their work and look at their facilities.
The $5,000.00 is somewhat accurate for a complete exterior paint job. The cost increases if you want more obviously. Also Ive run into a number of problems when working on older cars, in particular Mercedes-Benz. Most likely you'll have to replace all of the weather strips and seals, because if the seals are original they are probably worthless. Many times they will still serve their purpose however when you take them off to paint the car they usually fall apart. I would warn you to be ready for a number of problems, when a car that old is taken apart completely there are bound to be a lot of things that break, fall apart, or get lost throughout the process.
The paint job will definately cost more than what the car is worth. If you dont know, you should have Glasurit paint put on the car. Glasurit paint is some of the best paint in the world, and it is what Mercedes-Benz uses at the factory. Glasurit paint also comes with a life-time warranty. I would check around the local shops in town and then do some research on each shop and then make your decision.
that is helpful, especially in regards to all the extra old bits that might fall apart. Wouldn't have thought much about that. What I'm working on is of a more artistic nature and if I get anywhere with it I'll be sure to repost. Thanks again,
Divenport
You can still make a car look very nice without taking out all the glass, window seals and trim...if it's not for "show" a "tape job" is good enough and a lot cheaper.
Bottom line for a decent=looking paint job IMO is a) the prep work prior to painting and b) the quality of the paint you use.
Joshua
There was another answer to my question but I wasn't able to find the reply. Thanks to that individual too.
Well you should get an estimate of what it would cost for a shop to fix and paint the damage, I would think they should repair and paint the fender and bumper, and blend the hood and door, and if the estimate costs more than the kit and the material you ordered then you might want to try to fix it yourself. If the estimate is less than the kit and materials you ordered then you should consider letting the shop do it that way it will save you some money and more importantly time and aggravation. I hope you get it all sorted out either way. Good luck!
Not sure where I heard the name Langka but the product sounds like it will work. I ordered the paint to match the color of my 1999 Camry from www.automotivetouchup.com. I also ordered 1/2 oz of primer (for use of adhesion to metal and plastic. Primer also helps to fill the scratches).
Back to the story, the damage was to his back left side/corner of the bumper. The side panel was pushed in and had a lot of our cars paint on it. I am kinda concerned about the top left panel (circled in green in the picture), it looks like the paint is chipping away. The back tail light had a very small crack in it and was a slightly scraped on the bottom edge. I got down and looked under the car and from what I could tell there no damage to the car frame.
So is there anyone with body shop experience that could give me a figure for the damage. My friends dad may be able to help get the dent out and order parts for cheap... Does anything needa be replaced?
I appreciate everyones help and input...
Here are some photos on photobucket:
http://i51.photobucket.com/albums/f365/shanecbx3/PIC-0081.jpg
http://i51.photobucket.com/albums/f365/shanecbx3/PIC-0080.jpg
http://i51.photobucket.com/albums/f365/shanecbx3/PIC-00810.jpg
Would I do it again? Yes. The first paint color was wrong. I ordered it for a 99 Camray and the second time looked on the door and ordered the correct color because the car was manufactured in 1989 and sold the first time in 99. Live and learn they say.
So you have to price out the bumper skin + painting it plus repair of that upper panel + tail light lens.
I'm just guessing here but I'd say to do a nice job on a nice car it would be $500 to paint and match the skin and install it + parts price of the skin ($300? $500?) plus refinish the upper panel and blend the paint ($600)....so you're probably looking at $1,500--$2,000 damage.
Yeah, dealers and such get people to come in and patch up and repaint bumpers, but it's not the best quality and as an owner of a nice shiny car, I wouldn't let you fix my car that way.
You may wish to claim this on your insurance. Usually if your claim is over $1,500, it's worth making a claim vs. the rise in rates you'll get.
Now if it were my OWN car, I'd do it your way, for sure.
Thanks much,
Ken
If this happened during the claying process, you must have picked up a small grain of something and then never reworked the clay. Otherwise, you got the scratches another way. From the cloth used to wipe of the clay lubricant perhaps.
Some sort of very unskilled person repainted one side of my car, and there is overspay on everything, particularily on the data plates on the inside of the drivers doorjamb, and some more on the rear bumper rubber. Anywho, knowing what clay bar is, and the basics on using it would be great.
Thanks in advance
-Ryan
You can learn more about it in several places. One option is here: Detailer's Handbook
I am located in Baltimore. I dent and scratch my car (passenager door) and is interested to have the scracth repaired. I thought of body shop and is lost with the internet search. Does anyone know how much the repair cost will be?
Anyway, the problem is this---a properly repaired clipped car might be "as good as new"---after all, many of those $1 million dollar classic cars you see being sold on TV are pieced together, and beautifully done as you can see; however, these classics don't have to worry about DE-preciation....as they are AP-preciating. But a Volvo S60 is a depreciation vehicle and will always be one.
Here's one route you can take---since it was a third party that hit your car, you CAN sue the other insurance company for "Diminution of Value" (you can't generally sue your own company for this). The DMV is in fact, the difference in value between a nice untouched S60 and your clipped one (regardless of how well it is repaired--we are talking about the divulgence of the accident affecting the value).
Insurance companies fight DMV but you can win. This requires an appraiser that you have to hire for this process.
As for preventing YOUR insurance company from clipping the car, you'd best call your State Insurance Board and see what Fair Settlement Practices are in place to protect (or screw) you. You have to read your policy and see what you signed regarding what the insurance company is allowed or not allowed to do. It varies a lot state to state.
I have to say I'm puzzled that a car with only $4,800 would have to be clipped. I don't see why you can't pull it--but I haven't seen the damage, so can't say more...
It's a mess. Just remember next time how little your insurance company helped you out here.
Here's an interesting web site. I'm not presuming that your insurance company is practicing bad faith (some companies are very good once you talk to the right person), but just in case...
http://www.badfaithinsurance.org/
