I have a 00 EX with just over 42,000 miles ever since new I am only getting 17-19 miles per gallon. Even tankfuls that are only highway miles will give me only 20-21 mpg at the most. I have only run regular gas in my Ody but am wondering if premium gas would increase my mileage enough to warrant paying the extra 20 cents. Or are most other owners getting similar mileage?
I have not posted in a while, but still enjoy this site! My 99 OdyEX has been great, except for a carbon build-up on the manifold which was fully covered by warranty. The dealer told me to use at least the middle octane gas (not the 89, the one above that) and also to always use brand-name gasoline. Don't know if that was just a line or not. My problem is that just 2 days ago, I noticed that my clock is not lit up when the headlights are on. It still keeps excellent time, I just cannot see it at night. All other dash backlights are fine. It is just the clock that is completely dark. Any ideas?
I have posted here a few times regarding the numerous problems my sister had with her 00 Ody EX. I'm happy to report that after fighting with Honda for nearly a year, they decided to take back her van and give her an 01 EX without actually going to court over it. It took a lot of frustration on my sister's part, but all her complaining finally paid off. Just as a recap, here are all the things that went wrong on her van in 16k miles:
The AC compressor was replaced to get rid of a clunk on startup. Both front struts were replaced to get rid of a squeek over every bump. All front suspension bushings were replaced twice, as well as lubricated, trying to alleviate a clunk that was felt and heard in the steering. The entire steering rack was replaced for the same problem (still didnt fix the problem and was the reason for Honda taking the van back). Both power door latches were replaced, as well as sensors that set off the door open alarm. One power door motor was replaced because the door would not fully close. All four doors required realignment due to rubbing and sticking problems. The battery died after only 12k.
As you can see, this van did not live up to the Honda name. It wouldn't have even lived up to the Kia name. She had to take the van to the dealer at least 25 times and was constantly stuck in a rental car. The van spent about a month in the shop in a year's time. I just hope the second one proves that Honda can still make a quality car. So far she is happy with it. One thing is for sure, she is one lucky person to get Honda to do what they did. She was told it's unheard of.
hi there rrr54,pls let me know if you have any luck later with this problem,i brought mine to the dealer 1 week ago, during road test they heard the clicking, but can't seem to find where it's coming from. thanks
I also have similar clicking sound when accelerate from stop, stop quick and making a turn on my 01 EX. It feels coming from the back of van. Among all the rattles, this is the most annoying one and drive me nuts too.
I also have other rattles, most coming from dash area, steering column, sun visor on driver side, passenger side front door when driving on modest rough road or small bumps.
I believe harsh ride of odyssey contribute to most of these rattles. My tires are 35 psi, all driving are done at San Francisco Bay Area. Maybe 2002 modified suspension will take harshes out of the odyssey.
Had this problem in January of 2001. Problem occurred three times over a weekend, w/3 different drivers (the last being the tow truck driver). When the van got to the dealer, they could find nothing wrong (it started right up). Last week went on a trip to Maine, returned to NJ after a week, that night went to get pizza - van would crank fine, but would not start. This time the dealer at first could not start the van, then it started after a second try a few hours later. A mechanic remembered a Honda bulletin about a wiring harnes problem with the 1999 and 2000 Odyssey's. The lead to the #11 fuse under the driver's side dash gets loose and causes the problem. In subsequent models they installed a fuse box cover (H/C 6536338, P/N 382-S3V-A01) to protect this fuse. According to Honda "The fuse box cover was added to the 2001 and 2002 mdels and was never installed on the 199 and 2000 models." The odd thing about it was that a third technician who remembered this bulletin overheard two others discussing this problem with my van and said "Hey there is this bulletin..." If this stuff was online and searchable I would have orderd the damn part myself and saved Honda a tow charge of at least $100.
Went driving yesterday with my 2000 Odyssey EX with 3800miles on the odometer and after car was warmed throughly I put it in park and the engine started surging between 1100-1900 RPM. Even did this while in neutral. Would put in drive and surging would stop. But as soon as put back in park and neutral surging would start again. Any ideas?
Has anyone had trouble with the electric motors going out on the sliding doors? I have a 2000 EX, with 33K miles on it. The driver's side sliding door closes but does not latch at the rear of the door. The dealer said there is a small motor that seats the back of the door into the latch and that this has been a common problem.
Sister had the same problem on her 00 EX. They had to replace the power door motor because the back of the door would not pull in. The motor would just sit there and run constantly and set off the alarm.
I have just been thru all this with my '99 Ody. My CEL came on five times at 25K,25K,36K,36K,37k.In every case the cause was "low flow at EGR".
Apparently this is not a wide-spread problem with Odys, but it spread to me for sure.
The first time Honda fixed it by performing the work called for by TSB 00-009 which calls for re-routing the PCV flow by doing some work on the intake. On the second occasion they simply cleaned the EGR port. These two visits were done under warranty.
The third occasion was after my warranty expired, at 36,700 miles. I took the car to my local mechanic who reset the code and charged me $35 and told me that if it recurred he would have to replace the EGR valve. Three days later it came on again and I replaced the EGR for $228.
Three days after my local mechanic fixed the problem, the light came on again. This time I took it to Honda and they removed the intake manifold and cleaned the port and charged me $152.
At that time I requested that they fix it under warranty since the problem was a recurring one starting while my car was still under warranty. I asked if they knew about the TSB's listed at the NHTSA site. They knew about the TSB 00-009. I asked about one numbered 157 or 161000 that referred to the EGR. They claimed no knowledge of any such TSB.
ALLDATA did not have the TSB's at that time (July 2000).I asked NHTSA for more information by submitting a request for a search. After I sent the request, they advised that I would have to agree in advance to pay a "search fee" based upon a $25-$25 per hour rate for the info. I told them to forget it. I then called my congressmans office and told them about my problem. In about a week I got a free reply from NHTSA. It seems that the TSB 157 is actually a "Service Engineering Survey" dated 10/16/00 ( this is where the number 161000 comes from in Governtmentese). This survey is an internal Honda document to their dealers which states that TSB 00-009 adresses the problem of cars which haven't had a blocked EGR but doesn't address cars which already had a blocked EGR. In these cases, the dealers are supposed to "use the 1998-99 Accord V6 Bulletin 99-085 procedure B to restore EGR flow". I have never been able to determine what this procedure is.
Armed with this information I returned to my dealer and asked for an adjustment. I also wrote Honda's home in CA and asked for a refund.
When I showed the service manager the "Service Engineering Survey" he offered to refund the $152 he collected the week before. I told him that wasn't good enough. I asked for at least $200 (I did get a new EGR valve). He finally agreed to refund the $152 and gave me a service credit of $48 to use when I wanted. I took this offer. I figured that was the best I could do.
Of course the service manager said if I had brought it to him when the light went on the 3rd time, he would have done it "no charge". This sort of flies in the face of the fact that when he did see the car a week later, he charged me $152 and refused to honor my warranty which had only expired 1000 miles before.
Since someone here posted the suggested method for cleaning it yourself, I am indebted. I will follow this procedure myself the next time the light comes on. I really think I'm probably good for another 10-12K.
By the way, ALLDATA now has the TSB's listed again (Sept.2001), but they are hardly any more informative than the stuff at NHTSA. They don't have any reference to the "Service Engineering Survey" I referred to.
Also, after the service manager and I settled the matter between us, Honda home office called me and said they had decided not to give me a refund. I simply said "OK" and hung up.
Thanks for the detailed explanation of your journey through the labyrinth.
I think I was the first to post this problem quite some time back. I've never taken it to the dealer because of the general ineptitude of their Service Department.
I have my own temporary fix which has been described here, but it's lasting for shorter and shorter periods of time between the need to do it again. I'll try to get my hands on TSB 99-085 and see how it works on my vehicle. Regards!
Thanks for the post on the temporary fix you posted previously. I don't have the manual and this is a big help.
FWIW the service manager told me it wasnt enough to clean the port on the EGR alone, but that there was another port "downstream" that had to be cleaned also. I presume its the port just below the EGR valve in the intake and removing and cleaning the intake should do the trick. Incidentally, are there any gasket replacments needed when you remove either the EGR valve or the intake manifold?
I'd appreciate it if and when you ever see TSB 99-085 if you will post the contents here.
If your solution is working less and less, you may actually need to replace the EGR valve. But be aware that my local mechanic charged me $166 for the part alone. It is the genuine Honda part and I'm sure he took a profit, but I bet your looking at $125 at least.
Here is one for you "heavy van affecting gas mileagers." Have a 2000EX with approximately 7700 miles on it. For the first 6 months, spring into fall, city mileage was 16-18 mpg. For the last year, Fall 2000 to Fall of 2001, the city mileage has dropped to 11-12 mpg consistently. Have had engine checked by Honda service who say that nothing is wrong.
At the last scheduled maintenance, I asked again that the engine be checked because of increased gas consumption. After the maintenance, I was again told that nothing was wrong with the engine. Then I got the zinger: the service manager told me to use regular gas instead of the premium that I have been using. When I protested that the 2000 Odyssey was designed to produce 210 HP on premium, his response was that the 205 hp on regular gas was adequate enough. He also said that premium gas causes excessive carbon build up in the engine, requiring maintenance to remove it.
I have had no other problems with the van, other than a computer glitch where the van cut off once and all the indicators can on at the same time. I re started and that has never happened again. I have noticed slightly more resistance when accelerating, along with the increased city gas consumption. Highway mileage has remained at 22-24 mpg depending on cruising at 75 to 85 mph or below. Something is malfunctioning, either in the engine, computer or transmission; does anyone have a clue about this problem?
I already replaced the EGR valve as the first attempt to fix the problem. It comes with a gasket; and, if you're careful when you remove the valve, the gasket is just fine. I don't remember how much I paid, but it was significatly less than Honda's MSRP. In addition to accessories, H and A Accessories also will quote and sell any replacement parts you might need, and the discounted price is well worth the wait from CA (where they are located) to GA, where I live. They can be found at:
Since having my transmission replaced in July (00 LX, 15k miles), my mileage seems to have dropped off as well. While my local mileage was always awful (12-15 MPG), I was getting close to the mid-20's on mostly highway driving. Since the new tranny, it's been high teens at best. Otherwise, it's been fine, but it does seem to have a slightly different shift pattern. Will mention it at next service visit.
On another topic, it's getting close to the two year anniversary and I want to extend my warranty. Unfortunately, I can't seem to find any of my bookmarks for dealers who discounted HondaCare. If anyone could re-post or e-mail me, it would be much appreciated.
I'll be curious about your success in purchasing the extended warranty after 1 year of ownership. I have always heard that 1 yr was the cutoff date to purchase any extension.
Extended warranties can be bought up to the 3/36 of the original warranty. Sometimes they do get more expensive the longer you wait, only because as time goes by the prices rise. I do whole heartedly agree that everyone should go with the extended warranty only because of a mech. problem I had this past week with my Tracker.Going on 4 yrs. old and only have 22,000+ miles on it. Have all maintainance done at dealer and it looks brand new. Out of the 22+ miles I would guess 6 thou of it is towed behind my motorhome. Anyway it wouldn't shift into reverse Friday morning.(5 sp. manual). Well $650 to take out the trans as the transfer case is hooked to it and now I find it needs 350 bucks in linkage parts that I could hold in the palm of my hand. Anyway 1100 bucks to fix. I could have bought an extended warranty with money left over. The prices dealers get now days for fixing cars just one breakdown could buy a couple of warranties. I learned my lesson.
you can purchase an Ody extended warranty up until you exceed the terms of the base warranty (3 yrs or 36K miles). I believe the price goes up after 1 yr. of ownership, then it stays the same until terms eexpire.
As others have said, you can purchase a Honda Care extended warranty any time (and from ANY Honda dealer) until the 3 yr/ 36 mo factory warranty is up. I bought a 7yr/75,000/$0 ded Honda Care warranty for my 2000 EX NAV when it was 21 months old and had about 20,000 miles on it. There was NO surcharge at that time, although they said after 2 years/24,000 mi they did think there was an additional charge.
If you start on the Edmunds home page, click the "Finance, Insurance & Warranties" link, and then on "Extended Warranties: Extending the Joys of Ownership" you will find an article discussing extended warranties in general, and HondaCare specifically. The article does mention a surcharge after 2yrs/24,000.
I just bought a 2002 EX and within 150 miles of basically highway and a little city driving the EGR valve was faulty. The car would stall while in park and would hesitate often at stops. The tech started the vehicle which was also difficult and new what the problem was right away and said it is a common problem.
We just got our new 2002 EX on Monday. A few minutes test driving doesn't really tell the story. But my wife is having difficulty getting the drivers seat positioned to her liking. She's tall to begin with, about 5'8" tall. If she positions the seat for her legs, she feels like she has to stretch to reach the steering wheel. If she repositions the seat so she can reach the steering wheel more comfortably, then she bangs her knees on the tilt steering wheel handle getting out of the van. I guess she needs longer arms. Has anyone else had this problem?
Yes, I had the same problem. I'm 6'1". I had a real tough time trying to find a comfortable seating position that didn't bang my knees (or hit the key fob) yet kept the steering wheel within easy reach. The solution for me was to lower the seat, move it comfortably close to the pedals, then bring the seat back forward until I could reach the steering wheel properly. The more upright seating position was a bit uncomfortable to begin with, but I actually prefer it now (it's much easier on my back). I've modified my seating position on my 2001 Pathfinder so it's similar. You may want to try this.
My 2000 van has been in twice for a clunking noise in the front end over series of small sharp road bumps- after replacing the struts and 'loose' calipers, the noise is still there. PLEASE, if anyone has a solution I can pass on to the service dept. I would appreciate it as taking it in constantly is a pain! The noise is in the front, sounds like a wood on wood noise, with metal clank over especially sharp bumps. Am worried this problem will escalate if not attended to and my van just rolled over 36,000. I should be ok for awhile since its been in twice while under warranty though.
The van had the shimmy, the transmission replaced, squeeky rear windows, and wore through the firestones by 26,000 miles- I solved all of those alone but need input from others as I am tired and desperate! Thank you!
Does anyone know what Honda's toll free customer service number is? I think I may need it. We discovered two days after we picked up our new van a bump on the front bumper down near the drivers side wheel well, and a large paint chip on the underneath side of the bumper. Of course the salesperson is already setting us up saying that we must have hit something. No way we hit anything.
Here is the section on Ext. Warranties from my old web page... I know it may be out of date. "Sources for HondaCare warrantys ...beside your dealer! Pacific Honda - 619-694-1000 Steve(finance person) Hoehn Honda, San Diego - 760-438-1818 RobertLennick Burns Honda, Marlton,NJ - 609-983-0600 Perry -- Finance Manager *** I called, price is 835.00 **** Union Park Honda - Greg Allen (302) 573-5222 *** I called, price is 835.00 Frank is gone, but Greg will honor!**** "
I DON'T KNOW IF IT'S THE SAME PROBLEM, BUT MINE SOUNDS MORE LIKE CLICKING/CREAKING OVER BUMPS ON BOTH SIDES,IT REALLY SOUNDED LIKE IT'S COMING FROM THE DASH, NOT TOO LOUD BUT REALLY ANNOYING. ANYWAY, FIRST COUPLE OF TIMES DEALER TOLD ME IT'S NORMAL,TOLD THEM I'M NOT A MECHANIC BUT I KNOW IT'S NOT NORMAL. I KEEP ON BUGGING THEM TO FIX IT, FINALLY THE 4TH ATTEMPT THEY FIX IT.
Hi Tan4, What did the dealer do to fix that subtle,but annoying noise? I'm experiencing the noise problem and the dealership shrugging their shoulders as to what to do. Your input would be greatly appreciated.
The dealer used a listening device to pinpoint the location of the source. The culprit is the strut tower. They removed the black plastic trim to access the strut tower, drilled a couple of holes, used bolts and nuts temporarily. I test drove it with the service manager and that annoying clicking/ticking noise is gone. They remove the bolts and did some welding on it. I am really glad that it was fix, cause it really is annoying. Insist that it is not normal, keep bugging the dealer, that's what i did Keep me posted, goodluck.
The saga continues....After two weeks and $600 to replace the torque converter solenoids, I think I'm back to square one...The check engine light is back on....I now suspect I'll join the ranks of replaced transmission crowd....I too will keep you all up to date regarding the dealer response and any interaction with Honda North America.
With all the problems everyone is having with these junkers, why is anyone buying them? My advise is to sell them now!
By the way, I have a 2000 LX with 21,000 miles and it seems fine for now. But I am seriously considering selling it because of a ton of little problems (terrible gas mileage, rattles, sliding door sticks, front brakes replaced already, etc.). The fit and finish simply isn't there.
I have a 2000 LX with keyless entry. This weekend, I went to open the van's back hatch and it was locked. I went into the house to get the keys, and unlocked the door with the keyless entry (standing in the doorway from the garage to the house, I heard the locks unlock). I left the keys in the house and went out to the car. As I approached the rear of the van (maybe a foot away), I heard the sound of the locks locking. Mysteriously, the car had locked up. As I said, the keys were still in the house at the time, so it wasn't accidentally depressed in my pocket. Has anyone experienced this before?
Go to another Honda forum and you will find most people are very happy with their vans... not "everyone" is having problems as you suggest. No car is perfect. There will be issues here and there. It all depends on how many there are, how serious they are, and how the company treats you as a customer when you do have a problem. Go ahead and sell your van. I think you will be very pleased at how quickly it gets snatched up and how much money you get for it.
My 2001 Ody has 10,800 miles. Just in the past month or so, I have on occasion had the van refuse to start on the first try. This is not a consistent problem, but seems to be worsening--maybe once out of every 15 tries or so. The van cranks and all the lights come on, but I can't get it to kick over. Thus far, I have waited for a minute, and the van starts fine on the second try. There doesn't seem to be any relation to cold or hot weather, rain or shine, or any other factor.
Any suggestions before I head for the dealer?
BTW, I had an ongoing battle with my dealer earlier over the "popping" paint on the hood of the car (silver). He said I was hitting rocks. I insisted it was a poor paint job. I am convinced, rightly or wrongly, that the problem was the result of the plastic wrapping bring put on the van before the paint had seasoned. Solution achieved, however--the result of being hit by some kid in a baseball cap to the tune of over $2800 in damage. His insurance took care of the new paint job.
Have the dealer check the EGR valve, mine acted the same way, and when the tech went to start it he had trouble and knew what the problem was right away, I overheard him say that the EGR was a common problem.
...so that's what it is! I've had that problem about a half dozen times in the past year (not during the summer though) with my 2001 EX. If it happens again, I'll know where to start. Thanks.
Found a 99 EX with 34850 miles today that looked in to be in excellent condition. It looks nearly brand new inside and out. Bought the CarFax report on it and nothing came up. I can have it for $23700...what are the problems I can expect to encounter (I don't have time to digest the 1200+ postings. Should I get the Extended Warranty? Consumer Reports recommends staying away from the 99 Honda. Reliability being a big concern.
My '99 LX has 39800 miles on it now. The '99EX had automatic door problems and thats what got Consumers Report excited. Common '99 problems were groaning brakes and some transmission problems. There were also recalls to re-route the PCV valve; Fix some door latches; wiring harness problems;rear vent motors whining. The Honda dealer can check which of these have been fixed. I have had problems with the EGR valve but Honda fixed it under warranty after a little fighting because I was out of warranty the last two times I took it in. The problems with the '99 might be more than the '00 or '01, but way less than competing makes. All things considered, this is one real fine van. I don't think you need to worry too much about quality. The extended warranty might be worth considering before the original warranty runs out.
$23700 seems high to me. What does Edmunds say for this car? Seems like it ought to be under $20k. Mine is listed at about $18k wholesale I think. At $23700, I'd be looking at the '02 LX for a few more bucks.
Lots of cranking but no starting is also what happens when the "immobilizer" system and the ignition key don't quite get along. Look for the green flashing light the next time it does it...if the light is on while you're cranking you've found the problem.
kondor: That seems a little high for a '99 to me. Its not my money but if you're going to spend that much already, my advise would be to get a new EX for $3000 more. (or as bigjim said.. get a LX for the same $$) If you are finanacing, you will get a better rate anyway. Based on all the posts I have read, odds are you will have more troubles with the '99 than a '01 or '02. I guess it just depends how much a gambler you are. For the record, I bought a '01 EX in April and I love it. Good luck.
At the dealer, everything worked when we drove the EXL off the lot. On the way home, the fog lights stopped working. The dealer was very helpful over the phone and I spent 15 minutes unsuccessfully searching for the fuse. Did you know there are 4 fuse boxes, 2 inside the cabin? The fog light fuse is not in any box but is a separate inline fuse. I told the dealer I'd wait for my first service to get this fixed.
Yesterday I got a call (2 weeks later) and was told they figured out that the wiring harness needs replacement. Apparently the fog lights and seat heaters share the same circuit and putting them together was too much. I don't know if this is a general problem or one having only to do with this dealer's installation.
One thing Honda need to do is include some information in the owners manual on fog lights. There is nothing in the book.
Since this is a dealer option I doubt you will ever see it in the owners manual. Even on cars I have had with the fog lights it only tells what size fuse is needed and if you are lucky where it's at.
Has any one had a problem with the rubber strip (seal?/gasket?) located under the lip of the rear spoiler? The rubber strip sags out from under the spoiler onto the rear windshield in hot weather. I took the van into the dealer and they replaced the entire spoiler (seemed to be overkill for fixing an errant rubber strip). This worked for awhile, but the problem is now happening again.
Again, has anyone had this problem? Is there any PERMANENT fix?
TIA. SCMelvin
did you bring it to the dealer yet for that annoying clicking noise?
Good Luck
http://www.handa-accessories.com/
Tell Trevor that I sent you.
hope it helps.
Hope all is well with you and yours.
is annoying.
IMHO, the logic is that you might inadverdently unlock the vehicle if you put the remote in a pocket/bag. Thus the van relocks itself.
With my EX I open one of the sliders and then mosey on out. With your LX, you better run!!
