CR-V vs Escape
13334363839167
    The lack of antilock brakes was the reason why the pre 99 CR-V wiring harnes and recent ignition switch recalls were made recalls (rather than simply TSB corrections). I'm curious as to how/why Ford is addressing a similar issue with only a TSB. I can certainly understand them wanting to avoid the stigma of yet another recall, but the NHTSA is typically the one to issue it. We'd have to ask them.
  • baggs32baggs32 Member Posts: 3,229
    I'm wondering if it is because the CR-V had a specific part fail, and that same part can/will fail in all of them. With the Escape they may not have enough proof that all vehicles are affected and they can't break it down to a single bad batch because it is such a random occurance in both model years.
    Now that it seems they have it fixed (at least to me anyway), maybe they can move forward with whatever it is they need to do or are forced to do by the NHTSA. I don't imagine you can issue a recall without a proper fix.
    The random occurance doesn't much matter. The CR-V had a very unlikely situation which involved a very specific set of circumstances leading to the CEL coming on. Two people could drive down the same road at the same speed and not get the same results. It had to do with a false positive reading in the emissions software and Honda fixed it with a TSB. Had it been safety-related, they would have been forced to issue a recall.
    Ford does have a TSB issued with a specific fix for reprogramming or replacement (in cases where a reprogram is not possible).
    I speculate that the NHTSA simply doesn't have the resources to investigate every single issue. They've been busy as of late. They may eventually catch up with this, or not.
    As for fixes, I am told by reputable posters on these boards, that the NHTSA can issue a recall even though a fix hasn't been developed. That would be extremely bad news for the manufacturer as they would have to issue a stop sales order and vehicles would wait on the lots until the problem is resolved and undsold units are modified.
    In other recall news... Ford is back at it with tires.
    http://www.usatoday.com/money/autos/2002-08-19-tire-recall_x.htm
  • whothemanwhotheman Member Posts: 169
    On what planet did an Auto CR-V beat an Escape V6 head-to-head?
    CR-V 8.91
    Escape 9.0
    Just for kicks: the 5 speed RAV4 beat them both at 8.90.
    What month?
  • soccermum02soccermum02 Member Posts: 47
    I was referring to the towing of motorized things (e.g. jet skis, snowmobiles) none of which I own. A canoe can fit quite nicely, though, - we put a (now considered heavy) kevlar mad dog rental canoe on a 88 Mazda 323-GTX, 2-door hatchback (our previous wheels) and it had no problems. If you can portage it, surely you can throw it on a roof -yes???? That is all we want out of a SUV, plus reliability.
  • bessbess Member Posts: 972
    yes, the inital Escape launch did have some recalls. That was over 2 years ago. There are no recalls for 2002 Escapes and this model year is about to end..
    Your nit picking on the slight advantage in statistical initial quality and blowning it out of proportion.
    Your also indicating that initial product quality is the same as long term reliability, which is clearly not the case.
    Neither the Escape nor the CRV leave its drivers stranded on the roadside. Both vehicles are reliable. Both vehicles will go several hundred thousand miles with just normal maintenance. You constantly imply that Fords are not capable of this when thousands upon thousands of Ford owners have vehicles well over the 120k mark.
    I believe it and have personally experienced it many times.
    Can Ford improve it's quality, absolutely.. Honda is also far from perfect.
    I wonder why are you are so concerned about reliability when you don't even own the vehicle long enough to take advantage of such reliability?
    (trading in 01 CRV for 02).
    I don't deny that most reports show that Honda has a slight edge in reliability. You use Ford's own statements that they should improve as additional justification for your position.. However when Honda tries to hide problem data with its vehilces from Honda owners (TSB info), you don't even question why they would do this.
    You bring up other Honda models. Why is it when 'professional' reviewers write about Honda products, they dismiss the 6 times they had to have the vehicle in the shop for work to be done, but if a Ford has this many problems, its front page press..(See Edmunds review of Odessey).
    The first 2 years of Escape sales, there were no incentives and it outsold every vehicle in its class. I would hope that the new Honda model could sell without incentives.
  • scape2scape2 Member Posts: 4,123
    Stalling, I visit about 6 other chat rooms around the net. Edmunds by far has the most postings and repeat postings from the same people about this issue. I feel very confident this is VERY, VERY rare. I have had my Escape towing, hauling, climbing up/down hills, long trips.. and it has proven to be very reliable.
    Don't forget, Honda hides TSB's, or shoult I link you there again? Still waiting for my recall notice for my wifes 2000 Accord?? Remember? the huge recall of all 99-2001 Honda's noone seems to know about?
    I bet the new 2.3 is going to show up in the Escape/Trib in mid 03 or so. Mazda is putting into their new 6 sedan.
    Ran into yet another Escape owner at a soccer practice. Hers has been ok too. That is a total of 9 Escape/Trib owners I have run into that have not had any problems... I take that back, one person did have some squeaks..
  • daveghhdaveghh Member Posts: 495
    Scape,
    Visit http://www.carreview.com and check out the comments regarding the stalling Escape issue. Extremely frequent postings!
    I am sure most of the Escapes are fine, and more people with problems go to the internet then those without problems. So I will give you that. :)
    The Escape will out tow, out haul, out pull, out pass, out merge, more payload, better braking, more GVWR, More max payload, more ground clearance, More of an SUV! than the CRV.
    Varmit, don't you get it?? when your CRV reaches its MAX, meaning you have NO MORE, torque of 160ft/lbs, the Escape has 40 MORE, meaning it has more, ft/lbs of torque to give... and 40 MORE HP???
    Scape,
    Now you are just being annoying... respond to my post (Post #1726)above, if you dare.
    Whotheman -
    January/February of 2002 Special 5th Anniversary Issue, Page 28
    Bess - According to the latest information from CR, the Escape is 40% less reliable than the industry average. At last rating, the CR-V was about 80% more reliable than the industry average. You may call that slight if you like, but I don't see it that way.
    Scape2 - I understand that the Escape has more power. Once again you are putting words in my mouth. I've never said that the CR-V was "more powerful". So, here we go again...
    What I don't understand is why the Escape can't use that power to accelerate. Imagine that, a V6 with an extra 40 hp and 40 lb-ft can't outrun a little four banger. By every measure, the Escape should dust the CR-V. But it fails.
    Looks like Ford can't get the job done without a V8. Slurp, slurp, slurp, slurp... stall... slurp, slurp... =)
  • landru2landru2 Member Posts: 638
    0-60 times are to compact SUV drivers.
    Anybody have any acceleration figures for loaded vehicles from 50-70 mph?
    Landru2 - 0-60 times are not especially relevant. That is a point we generally accept around here. However, it is the industry standard and few reviewers publish any other measurement. That is, unless you think comparing 1/4 mile times would be more productive?
    To the best of my knowledge, no one has published 50-70 times with loaded vehicles.
    Scape2 - As long as I'm at, I decided to take another look at the 40hp/40lb-ft differences you are so fond of quoting.
    First of all, you are talking about a measurement taken at the flywheel. Neither vehicle delivers peak output once it makes it way through the drivetrain. Generally speaking, it is estimated that a vehicle loses 15-20% of its power before it reaches the wheels.
    Although it is often rounded off to 200 for simplicity, the Escape's true torque output is 196 lb-ft. The CR-V is rated at 162, making the actual difference 34 lb-ft. If we knock of 15-20% from both vehicles (for the drivetrain) and do the math again, the difference becomes 27-29 lb-ft. The Ford still has a significant edge, but not as much as published numbers would have us believe.
    That's with automatic transmissions. Manual transmission are generally more efficient than automatics, which is why we see the manual CR-V beating the Escape in those 0-60 tests. If we take that into account, the real-world torque difference between the auto Escape and manual CR-V is more like 21 lb-ft. Now, we're talking about half the difference you like to quote. Add to that the fact that the manual CR-V is about 170lbs lighter than the Escape, and we've got a more competitive match.
  • hondaman02hondaman02 Member Posts: 250
    Bess, reliability is not always measured on recalls it can also be judged on how many times you go to the garage to have something fixed!
    I hope this will be the last time I say this but I change cars often due to the high mileage I put on them. I usually put about 40000km's a year or more depending. I have put over 200000km's on my wifes Accord and have gone in once for a minor door squeek. Plus, with the company, we rent as well, so I have put very many miles on almost every Honda make. That is the reason I ended up buying Honda in the first place after all the bad experiences we have had with previous models including all domestics.
    As for being stranded, well I disagree as the Tribute I had did leave me twice! I don't want to go there because I do believe that this is an isolated incident. My main concern is long-term reliability and that is where Honda has alway shined! This has been proven so many times that we don't have to discuss this anymore.
    Scape we know it is more powerful dream up something else please!!!!!!! What we are saying is that for a 4 cyl. it is very close and for an engineer (!!???) you should understand this. Also your tourque statement s don't make sense. If the Honda develops 90% of it's tourque immediately and the Escape higher up and then drops off, that should explain the acceleration run Motor Trend experienced along with the technology of vtec. I am really starting to wonder about you.
    After having my new baby for a week, I can say that there is quite a nice little engine under the hood. It seems to be very good at almost all it does BUT after the Tribute, I would not say it is more powerful but very close.
    varmint,
    "0-60 times are not especially relevant."
    I agree with you there. However, I was corrected on this once by someone, and it did make some sense to me. 0-60 times can be relevant in situations like highway merging. A second or two could mean the difference between getting smashed by a semi, or being a safe distance ahead of it.
    This of course only pertains to those that do stop on the on-ramps which is often times just as dangerous as not timing your merge right.
    There are parts of the country where they have stop lights at the beginning of the acceleration lane. These are found mostly on the freeways of the West Coast. You have to go from a standstill to merging speed with only the straight section of acceleration lane to work with.
    However, I've been able to make those merges while driving rental Focuses and other "underpowered" cars. Neither the CR-V nor the Escape should have any significant trouble. Besides, sometimes a good merge means hitting brakes, not the accelerator.
    Ford trades green reality for "green marketing".
    http://www.msnbc.com/news/796496.asp
  • np1908np1908 Member Posts: 39
    Honda has built a very good reputation with their line of Accords and Civics: the fact is - they have been around for a long time, refined all long during that time and on an average, have less problems over similar models.
    But, people seem to be EXTRAPOLATING this Accord/Civic reliability to ANY Model from Honda stable. The fact is: even Honda has had issues with other Models atleast initially. Honda Odyssey trannys and power door have had terrible problems during their teething years (some of them still even today). Mind you, I am not saying that they are inferior models - infact, most of the Honda models can stand well with their peers. But we cannot always conclude that ALL Models from Honda is ALWAYS good.
  • bpraxisbpraxis Member Posts: 292
    Hello everyone and I hope that you are having a great day.
    My girlfriend purchased a 98 CRV new and has had no mechanical problems in 65,000 miles. We have driven the Honda across country and it was terrific. And lets not forget the gas milage advantage with the Honda.
    In addition my cousin has a 99 CRV with 180,000 miles and has had no mechanical problems.
    Consumer Reports has rated the CRV as the most reliable sport utility made.
    And of couse the Honda Resale value is amazing. You can drive the vehicle for a couple of years and recieve a few thousand less than you paid for it.
    Now if you need more power than the CRV why not consider the new Pilot, or some other quality Japenese SUV that will have great resale value.
    I wish Ford had a better reputation for quality but we all know the reality here. Ford still does stand for ( Found on the road Dead ).
    As I remain you motoring enthusiast.
    Ford could have a mission statement that would say: Yesterdays quality and engineering today. Recalls everyday
    "people seem to be EXTRAPOLATING this Accord/Civic reliability to ANY Model from Honda stable." - np1908
    That may be true of some models, but not in this case. The CR-V has been MORE reliable than the Accord and Civic for the past several years.
    MPG.. the 2-3 mile advantage the CRV offers is not that big of a deal.. Kind of like 4 feet worth of stopping distance :-}
    Those small 15" tires sure make the CRV look even funnier. I don't think you could fit anything larger under the wheel wells. It almost looks like the CRV has 14" wheels.
    we all have stories of vehicle longevity. My moms 92 Escort, 135,000 miles, my mother and father in laws 95 Taurus, 110,000 miles.. I have owned multiple Fords with high miles... YAWN....
    Reliability.. The CRV has more history than the Escape. I admit the Escape started off with bad news and Ford/Mazda fumbled bad. However, if you would actually read the recalls you will see they are for early 2001 models and NOT for every single Escape/Tribute built, only certain lots and dates. The fact is my late 01 Escape has been flawless and I would be willing to bet the vast majority of Tributes/Escapes are the same.
    I own a 2000 Accord, back to the shop 3x.. Also own a 98 Ranger, back to the shop 0x, Escape back to the shop 0x... Hmmm...
  • bascottbascott Member Posts: 27
    But how much did they get for them at trade-in. Not as much as a 92 Civic or 95 Accord I'll bet ;-)
    Take my word for it scape.........your 2000 Accord will outlive and outsell your Ford!
    I need some advice here, now that I think about it.......the woman I work with that owns a Tribute asked me this morning about her check engine light. She informed me that her husband was towing a couple of 4 wheelers when it came on and has never turned off since. Does anybody know what I should tell her? Is this a common problem? The Ford dealer did not seem to really know what to tell her and she was worried. I would appreciate a comment from those that own this vehicle please so I could let her know if it is something that you have had happen before.
    hondaman,
    The check engine light staying on does not come up all that often and can be caused by one of many many things.
    One thing that immediately came to my mind was the 4X4. Do you know if they were using it on dry pavement to tow the 4 wheelers? Just a shot in the dark, but that would be a bad thing to do.
    No baggs, the 4X4 was not used. I do know that they towed these items for quite a considerable distance......around 400 miles! Probably around 1500 pounds but it was not a problem at that weight for power.
    "You are generalizing and making up, guessing, percentages about the loss of HP/Torque at the flywheels!" - Scape2
    Yes. Or maybe I should say, "DUH!"
    However, it is a fact that transmissions suck power from the engine. It is generally accepted that the percentage lost is between 15-20% for automatics and less for manuals. I used the same numbers for both vehicles, so comparison is as we good as we can get without the actual percentages.
    "Once again... try and try to make your 4cyl every bit as good as the V6!! LOL!@"
    I don't need to try for "as good as". The 4 cyl is "better" for everyday use. =)
    "The 4 cyl is "better" for everyday use."
    If you care about things like fuel mileage and emissions. Not every one does you know.
    Even then, the difference in fuel mileage is still less than ten mpg. The emissions might present a greater difference, but since I don't hug trees on a regular basis I tend to ignore those numbers.
    "but since I don't hug trees on a regular basis I tend to ignore those numbers".
    I agree baggs, the bark may be a little rough!
    Not everyone cares about towing either.
    According to an article I read, the Escape's demographic is 52% female with an average age of 41. (The CR-V is similar.) Do you think they care much about stump pulling?
  • muckyduckmuckyduck Member Posts: 219
    If the terrorists don't kill several millon people, this "don't hug trees" concept will certainly. We are just seeing the tip of the iceberg (literally and symbollically) with what governments, industries and humans in general have done to our enivironment. I think it is too late already to avert major events (like the European floods) that will be occuring over the next several years, killing thousands, if not millions, and destroying centuries of history.
    There now, don't we all feel better that I did not bring up reliability issues with the escape??
    varmint,
    Which one is the better daily driver is all up to the buyer. All we cared about is which one would better pull us up hills and around town with a load of crap (not that crap, get your mind out of the gutter) in the back or on top. Towing had no part in our decision process. I didn't even want the tow package but I didn't have a choice.
    Each vehicle holds clear advantages in a couple of "daily driver" categories (mpg, hp/torque, emissions, etc.) that can, and most likely do send the dollars of some people to one side or the other. But they shouldn't be used to measure which one is the better "daily driver".
    "Do you think they care much about stump pulling?"
    Not at all. They do need something to carry those heavy shopping bags home from the mall though. Maybe they figured they could use the extra power to tow a small UHaul trailer when the back fills up.
    Muckyduck - Let's not get overly melodramatic, here. =) While I agree that we need to pay much more attention to our natural environment, there's only so much that lowering car emissions can do toward that goal.
    I think it's more realistic to point to indicators like the CARB proposals. It may not happen today, but, as those ideas gather momentum, they will get passed. Can you imagine what would happen to Ford if they were no longer able to sell their big trucks in California? How long would it take before Massachusetts follows? We already follow the same regulations. So do several other states.
    People certainly do care about the environment and (despite pressure from Detroit) it's starting to take effect. Toyota and Honda understand that and they've done something about it. Other manufacturers are trying to catch up. Ford understands that fact, but their bottom line is still sore from the pounding it has taken in recent years. They've announced that they will not introduce any new "green" ideas until they get financially stable. That means sell the gas guzzlers as long as they can. And they know that time is limited.
    Baggs - The CR-V does get around town with plenty of authority. Several reviewers have stated that the I4 feels like a V6. If you don't believe them, take a look at the sales figures. Americans vote with their wallets. Sure, the Escape may be better able to tackle steep hills when fully loaded, but how many people do that everyday? Do you really think that ordinary people need a U-haul to get home from the mall? Do you really need 200hp to get up hills while loaded, or carry Christmas packages, or commute to work with 4 people in the car?
    Guess again.
    It's like using a sledge hammer to drive in a roofing nail. Sure, it's nice to have that kind of power, but it isn't necessary. And I, for one, would not want to spend the day lugging around a sledge on the roof!
    Thank you for more of your opinions varmint. Better emissions and fuel mileage are not necessary either. You just have to understand that some people like the feel of the extra power, and therefore want the extra power. You don't seem to have a hard time understanding why people might want better fuel mileage and/or emissions.
    The better daily driver is not something that is measured. Everyone has to figure that one out on their own because they are the one's who will be driving it. Look at Pepsi and Coke, or McDonalds and Burger King.
    It is just not car emissions but all the industries built using fossil fuel and support of automobiles.
    Anyway, back to the unreliable escape topic.
    The most common cause for the check engine light, is the gas cap was not put on tight.
    Unfortunatly, it takes alot (I'm not sure of the exact number) of on/off cycles after the cause is remedied for the light to go off.
    This happened to my Escape and the light was on for 2 days even after I put the cap on properly (yep, it was loose). Rather than wait for enough off/run cycles I just disconnected the battery for 10minutes to reset the computer (which resets the light as well).
  • crvdudecrvdude Member Posts: 2
    I selected the CR-V in part due to the higher gas mileage and lower emissions the CR-V offers. I also bought a 1998 Accord when it was one of the first (if not the first) to meet ULEV standards. I see it as a way to promote corporate responsibility.
    The mileage I get in the CR-V is similar to the EPA ratings, never got close to it in a Ford (Mustang, Ranger, F-150 owned by me or my family)
    That being said, I'm a little surprised Ford will beat Honda to the market with a hybrid powertrain, especially since Honda has one that works in the Civic.
    Maybe the hybrids will make the Escape more reliable since newer technology is involved. Based on their history and admitting their quality needs improvement, I have my doubts.
    Thanks bess, I appreciate it. You know, that might be it......I will let you know.
    come on people, there is a 2-3 miles per gallon difference between these two vehicles. Honda owners make it sound like the Escape gets 10MPG and the CRV gets 50!
    Varmit, as I have said, keep trying to make believe in your own mind and world the 4cyl 2.4 is everybit as powerful as the 3.0 V6 in the Escape...
    Sales.. Its already been shown the Escape/Tribute OUTSOLD the CRV.. yep, people speak with their wallets..
  • diploiddiploid Member Posts: 2,286
    scape, use your engineering abilities to figure out how much more beneficial an additional 2-3 mpg can be on a long trip.
    "Sales.. Its already been shown the Escape/Tribute OUTSOLD the CRV.. yep, people speak with their wallets.." (scape)
    Yup scape....and you keep on praying that after your warranty wears out in 3 years you won't need to open that wallet of yours!!!!
    Obviously a 6 cyl has more power than a 4 cyl. But the point a lot of people are making is the CRV 4 cyl has more than enough power for day to day driving and as I have said I have had no issues with my CRV fully loaded going uphill or otherwise. As for your sales numbers it seems to me that from what your saying it takes two vehicles to get higher sales numbers than one CRV.
    Touché bascott! The CRV outsold the Escape/Tribute in July!
  • warren19warren19 Member Posts: 28
    I guess we can add the Element totals to the CRV too when they go on sale. Ford has a significant advantge bcos they have a dealership on every block and they still haven't manage to outsell the CRV.
    warren19.....the Element may be built on the same platform but it is a totally different vehicle. It is not intended for the same group of people. They are using this platform as it is proven and nothing is really new except the look and utility. I really don't like the look of it but maybe it will grow on me!
    "Ford has a significant advantge bcos they have a dealership on every block and they still haven't manage to outsell the CRV."
    Yes but they only produce about 250,000 Escapes/Tributes combined at the KC plant each year. Honda produces about the same amount (I think) of CR-V's in both of its plants each year. It is quite possible that fewer Escapes are produced than CR-V's. No matter how big you are, you can only sell as many as you produce.
    As I posted a little while back, Ford will be producing the HEV, some 40,000-50,000 "regular" Escapes, and the upcoming Mercury version in its Avon Lake plant starting next year. If they can sell all of them, Honda won't be able to keep up unless they somehow increase production too.
    It seems that the woman I work with that owns the Tribute had a minor problem with an oxygen sensor that led to the check engine light problem. No big deal and now it is fixed.
    Ya see scape......all that hooplaaaa for nothing »LOL!!!!!! Have faith my friend! We Honda guys are not all that bad!
    What exactly does an oxygen sensor do anyway, and is it necessary to make the check engine light (a.k.a. the holy crap my car is going to explode light) come on when it goes bad?
