Across the divided road, on the other side, there was a Trailblazer cop vehicle (I didn't realize the cops started using these) that was pulled up behind a parked car in the 7-Eleven parking lot. And at the Shell station next door (a place that gets robbed on a regular basis) there were two copcars pulled up behind a car at the pumps.
The first one I saw was actually at the Shell station, where I saw lights flashing, and my first thought was that it got robbed...again. But then I saw the other cars.
I wonder what was going on here?
say someone from another lane makes an incursion into your lane, and the vehicle in front of you goes to 0 speed real fast, faster than their brakes can take them there.
no matter how good your situational awareness is, you don't know the condition of the vehicles around you, their reaction times, their visability, their driving skill, their ability to find a way out, etc.
at least you conceed the 2sec will need to be adjusted based on many factors. some you'll recognnize, and surely, some you will not.
Then you disagree with the vast majority of safety experts.
Ok if your using the two second rule and someone makes an incursion into your lane between you and the car you were following then you are no longer following the two second rule. In which case you should slow down until you drop back to two seconds behind them
I would presume you mean they hit something. That being the case unless they hit a brick wall or some other immovable object following 2 seconds behind should give you ample time to stop unless you have bad brakes or tires or bad weather prevents you (in which case you should have given more space).
But really you are being a bit ludicus here. How far apart should cars be? At 80 MPH two seconds is 235 feet, should it be 300 feet? well I can make up situations where that would be to close, or maybe 5 miles? lets be realistic here.
The two second rule is recognized by many as the safest minimal following distance distance.
Exactly. There are always situations that warrant additional distance. As a general rule, 2 seconds is a minimum safe following distance. Should a driver feel the situation warrants additional distance (such as a vehicle ahead on the roadway blocking the driver's view of the roadway beyond), then by all means add the distance.
An basic example of "more distance is better" in terms of sight distance comes to mind when driving a curvy/hilly two-lane road and attempting to pass a tractor-trailer. I will see vehicles close behind the trailer trying to "peek" to the left to see if a pass is safe, while the road is curving to the right! What is the point? The driver is NOT going to see around - not any appreciable distance. Often these drivers will jump out, begin to pass, only to realize that there IS a vehicle approaching and then have to duck in behind again.
I will typically hang a ways back and wait to see, then begin my pass from behind the truck in my lane and, after having a 20 or so differential will pop out, make the pass, and pop back in. The time in the other lane is less and I have greater certainty that there is no traffic approaching because I can see around the truck until just prior to performing the pass.
Most cars stop in well under 200 feet. My car (only 4k miles) stops in about 120-130 feet. My reaction time is less than a second. You do the math. The 2 second timing is sufficient for dry, daylight, good visibility. At night, in the rain or significantly impaired visibility should cause longer following distances. Plus, you will rarely need to bring your car to a complete stop within 234 feet. A good driver anticipates and surveys the conditions ahead (PRIME reason I don't like being behind SUVs) and can anticipate.
Real world example: I brought my car to a stop once from 80 MPH faster than the truck in front of me under "panic" braking conditions. I was following about 1-1.5 seconds behind.
Perhaps our difference of opinion is a matter of driving conditions. Here the roads are almost always flat, straight, bone dry, excellent visibility. Makes you wonder why we only get 55 MPH through the city.
It also has to do with the area surrounding the road. If I am on a road with a real nice shoulder, I can consider that an option if the car in front of me slams on his breaks, but on a road with no shoulder, I need to give more space to allow additional stopping distance.
There are so many variables that I dont think a standard "2 second rule" really applies.
When I was a teenager, I probably needed 5 seconds, because my reaction time when I have friends distracting me was a lot slower.
Commuting now, I take many of the factors that have been mentioned here into consideration. I believe there are times peopl would consider me a 'tailgater', but you cant please everyone.
Yes, excellent point. Rant:
In rush hour traffic I see more and more drivers that use the HOV lane to go 5 or maybe 10 MPH faster than the traffic in the general purpose lanes. In certain areas, when the GP lanes are going 25, you can safely go 65 because there is a 1/2 lane gap and a shoulder.
Not so good point. The 2 second rule is a basis, a starting point. From there, the driver is supposed to factor in the real-world conditions, that is all the 2 second rule means.
Just how do they get to 0 speed before their brakes can take them there? By hitting something? You as a driver should have been aware that a situation like that was coming up or been following further behind. As a driver, concentrating on driving, 2 seconds is plenty for emergencies. If you are distracted by something, like passengers, or shaving or eating then follow further behind.
Hence that is why you keep a 2 second following gap. If the car in front of you can't stop, that doesn't matter as long as you can.
That is the very definition of the 2 second rule. 2 seconds and then adjust to road conditions.
ever see a ladder come off a truck in front of you, a wheel and tire in your lane that came off another car, or a steel folding table come out of a van?
when i said vehicle incursion, say you are in the left lane, something happens in the lane to your right, and vehicle goes in front of the car in front of you hits the cement median perpendicular and bounces back fully into the left lane. car in front of you will t-bone the vehicle and stop in a shorter distance than otherwise with his/her brakes.
i've seen this.
i've seen a vehicle on 75/85 go inverted like in a dukes of hazard episode. at 80MPH, you are very far down the road before they come down dead.
you guys just haven't seen enough evidently to know your limitations on a 7-8 lane highway. you don't know and cannot predict everything that is going to unfold in front of you. of that i am certain.
hoping your 2 seconds and everyone elses 2 seconds is always enough for you.
I also don't bother eliminating all the risk from my life. Especially if I'm not getting a bad 'feeling' from something (like pickup trucks carrying stuff... I've certainly learned not to trust their cargo securing skills).
maybe someone should start a new forum: things i've seen comming off cars. just thought this morning about the scene of a driver loosing 1 of 2 kayaks which i witnessed. now you have to have a noisy big car not to hear and feel the difference when you loose one of these things off your roof. a mile down he finally realized it was gone. why the delay? no idea.
luckily when this went airborne, it came down in the breakdown lane at the side of the road. imagine if windage put it into traffic...
I was driving on the "main road" of the mall, that stretches across the whole mall. The openings throughout the road are to the parking lot. They (the ones coming out of the parking lot) have a STOP sign and not me. So they have to look both ways before entering the road. I came across a stretch where the first one didn't see me, and just went. He at least waved a "sorry sign". The next one was the worst of the three. He didn't even stop, he just went and nearly hit me. It took a 5 second honk to make him realize that I had to slam the brakes and turn the wheel to avoid a collision. On top of that, he started arguing that I was in the wrong! I had to give him a little lesson, on how you're suppose to stop at the STOP sign :sick: . That isn't the end of it though, just about a few feet down. ANOTHER one didn't see me and just went. I had to blow the horn once more. He luckily noticed right away and slammed the brakes.
After these three incidents, I decided to park the car far away :P
The scary thing is, there was a pickup in front of me and a pickup behind me, so it's not like I was just a solitary car that could conceivably be overlooked. I was in a line of cars and she STILL tried to run on through!
Because I was in motion, the impact did some pretty substantial damage. Knocked the front wheel out of alignment, bent the hubcap, smashed the fender, gouged out the door deep enough that the window wouldn't roll all the way down, bent the A-pillar just enough to crack the windshield, and also gouged out the rear quarter panel just below the opera window.
Had it been a newer car it probably would have gotten fixed, but it was 12 model years old and had 192,000 miles on it, so it got totaled out.
Annoyingly, the same chick almost smeared herself up against my '89 Gran Fury about 5 months later, when she was weaving in and out of traffic. That thing was a lot more substantial than the Monte, and this would have been more of a sideswipe instead of battering my car in its "softest" spot with the "hardest" part of her own.
One thing that always pissed me off about that accident was that the Monte, despite being about 700-800 lb heavier than that Tempo, took on considerably more damage than the Tempo, which was not totaled, simply because it was hit in a vulnerable spot.
I always wondered how things would have turned out if the girl had been just a tad quicker, gotten out in front of me, and my Monte had been the whacker instead of the whackee?
Maybe in the long run, things worked out for the best because as it was, nobody really got hurt. Had it been the other way around, I'm sure my Monte would have torn up that Tempo and its occupants pretty seriously.
people come across the center median on highway 169 anyway. when that happens the 2 sec "RULE" doesn't apply they really should consider a concrete divider
The city is refunding the "fines."
Red light camera article
It was a really close call. The expression on the Audi driver's face was priceless, but I guess I'd look funny if I knew I'd be dead if my reflexes were a half-second faster. And the red-light runner was freaking flying -- I'd say he was going at least 70.
Let's be careful out there. Seeing something like that reminds me how nice it can be to not have to drive to work.
if you have a car comming head-on, there is no 2second save.
Yes. And this is why I have been saying that the 2 second rule is a starting point. If you can't get around the vehicle with the poorly loaded cargo, you back off even further. Personally, I have come to distrust the cargo people carry (I've seen too many things fly out, and nearly too many loads almost fall off), so when a hole opens up, I use everything my car can give me to pass them. Also, I had been following someone with a two second gap once and some cargo came off the truck in front of them. Had no problem avoiding it.
That is very possible. So what would you suggest, a five second gap? At 80 MPH, a five second gap will give a "comfortable" amount of room for three people to enter that gap. So in that case, three people could enter and then the person I was following could slam on their brakes, where does that leave me?
When you saw that car go skidding across your lane, you should have been braking, HARD. In fact, if it was in front of you and to the immediately right lane, there is no reason you shouldn't have seen it as soon as it happend, it's called peripheral vision.
Believe me, I've seen plenty. I've avoided a lot of accidents, many of them following with a 1 second gap. I know I can't predict everything, but 2 seconds has always proved plenty under good conditions.
Me too. :shades:
Excuse me but how in the world can the 2 second rule come close to applying with regards to oncoming traffic? You are not following oncoming traffic so there is no following distance.
Its really funny how people are coming up with the most idiotic senerios to say that the 2 second rule is no good. I am almost to the point of expecting someone to say "well if a meteor hits you the two second rule really doesn't apply". :sick:
on the spotlight and instantly the caddy, lol he got over being mad really fast.
If anything, it reinforced why I won't get a sportbike, although sometimes I am very tempted to try one.
Speaking of Audis, I got behind a blonde in an A3 yesterday who made about 5 turns, and didn't signal for a single one.
I insisted on throwing a party for the occasion. :shades:
idiotic scenarios? i think not. expect the idiotic: remember not everyone is as conscientious and skilled as you.
Well, she stayed over in front of me for about a half-mile, but wasn't gaining any ground in the traffic, so she got back over behind the biker. I swear at one point it looked like she was practically BESIDE him, trying to squeeze in between him and the traffic in the right lane!
I don't know if anything ultimately happened, because my turn was coming up. But as I turned off, she was right there on his rear.
At one point in traffic at a light I had actually gotten up a bit ahead of them, and looked over to see who was driving the ES300. I was expecting it to be some little old Clara Peller looking woman who could barely see over the dash and didn't have her wits about her. But it was a fairly young girl, maybe in her 20's or lower 30's, tops. She did have this glazed look on her face though, like there wasn't a whole lot going on in her mind.
I one time on I-80 had a panel truck (not an 18 wheeler) so close to my rear end I couldn't see his bumper. I swear If I could have popped open the rear of my wagon it would have hit him. And this was at around 80 MPH, then it was 79, then 78, then... until he got the message.
Don't Honk. I'm Saving Gas.
I wonder if he'll get the same punishment as a civilian who rear ends a police cruiser...
The ramps have HOV lanes? It says the trooper was on the ramp and drifted out of the HOV lane.
"Stay back at least 200 feet"
This bluff tries to negate the driver from being legally responsible for securing his load. Don't believe these type of signs.
The signs say "Not responsible for objects thrown from the road" and that may be true. But the usual damage to following cars is from objects coming off the top of the truck's load, from the side rails on the bed or the frame and tires under the bed. They are responsible for that damage.
I've even called the state patrol about trucks with a powder blowing out of their beds. That's an unsecured load.
Well the road ends at a 'T' intersection and I make a right, this road has a 35 MPH SL as it goes by some neighborhoods. Well I am doing close to 40 down this road when I notice that the Jeep that was going 35 in a 50 was now closing in on me really quick. I guess he was making up for doing 35 in a 50 by doing 50 in a 35. :confuse:
Did you check to see if he/she was on the phone? That's usually the case...
Nope, just figured it was just another idiot with a drivers license.
I actually thought the guy would gun it when I tried to pass but he didn't. The guy was driving a Cherokee SRT-8, my experience is that they don't like to be passed in such circumstances.
While I didn't check he might have had a bumper sticker that said "Don't Honk. I'm Saving Gas"
Anyway, my choice is "Honk your brains out, it won't take long"
That's a good one. A blonde I assumed?
That could confuse tailgaters..
