Visitor Agreement.
Greetings from Australia, I have been reading the stories about the faulty clutches on Tiburons with interest. I have a 2003 V6 6spd and and the reason I am looking at the forum is that my clutch has also failed. My car has travelled 95000km which I think translates to around 60000 miles, I thought that was a ridiculously short life for a clutch.
The trouble started when I couldn't select reverse with the engine running and in a matter of 1000 miles I couldn't select any gears. I took my car to the local Hyundai dealer and they stated to me that the clutch wasn't covered under warranty because it was a consumable like brake pads. The hairs on my neck bristled, I said to the dealer that when a clutch wears out it slips, this clutch wasn't releasing and it was an obvious mechanical failure of some kind and should be covered under warranty, it was as if the pedal free play was too large not letting the clutch release.
My other car is a Mitsubishi Magna V6 ( I think they're called Diamantina in the US) its a 5 speed manual with 185,000km on the clock (I think around 110,000 miles and I still tow my Catalina 22 trail able yacht behind it). No sign of clutch slippage yet. I mentioned this to the dealer then asked them how long do they think a clutch should last. Not much was said.
To their credit Hyundai have accepted liability on this and the car is being repaired (new clutch, pressure plate and flywheel) under warranty (phew). I was told that there were metal quality problems with the dual mass flywheel and it was a known problem ( why didn't he tell me that in the first place and why were they so quick so say it wasn't covered under warranty?). I do feel though that if I hadn't challenged the dealer they would have happily let me pay for the repair.
Don't get me wrong, I love the car and the way it drives but I must admit I'm a little concerned about keeping it and wonder if the problem with clutch and flywheel has been truly resolved.
In 2005 I certainly would accept a clutch failure within the warranty period of a car, if you have the same problem don't accept it. Give the dealer a hard time and see your consumers association or auto club for support. If a manufacturer offers 5 years warranty then that's what it should be, clutch included. The clutch is a very expensive major system in a car, it's not like brake shoes that can be easily exchanged and the manufacturers know this. A press review stating a 60,000mile life span for a Tib clutch with no warranty cover and a $3000+ repair bill (flywheel included) would certainly slow down sales.
I'll get off my soapbox now. Enjoy your Tibbys I know I do.
Joe
You may have a faulty slave cylinder. Have that checked out. I assume that would be covered under warranty.
Loren
That's what I thought the problem was but appearently not. I have had the car back for a fortnight and it runs like a treat, the new clutch is much lighter.
Now a happy camper.
Joe
Thanks again
Dealership has no clue. need to take it back for a while freakin day for them to look at
Is there a trick to this?
BTW, we love the car. This is the 4th Hyundai we have purchased, and we have never had any real problems with any of them ( 2000 Accent/2001 Sonata/2002 Sante Fe). If all goes well, maybe I will pick one up with a manual tranny for myself. Ours stickered for $20,899 and we got it for $17,799. They had one earlier that stickered for $22,154 that we could have got for $18,600 but it was sold by the time we returned.
One remedy I have used in the past is to turn on the A / C, set it on "outside air" and spray a whole can (small size) of "Lysol" into the air intake below the wind shield. This usually will clear the problem at least for awhile. The mould thrives on high humidy and temp (ala Florida) but generally is only a problem during the hottest summer months. I don't know where you live but the problem will eventually clear up. The auto stores also have some sprays just for this purpose but the Lysol has worked pretty well for me and is a lot cheaper too.
Believer
To anyone out there who is having problems with their 2003 tiburon, don't give up hope, the 2005 is a solid car - all the 03's problems have been addressed along with some very welcome aesthetic improvements. Maybe they just needed a year or two to work out the kinks.
hope this helps somebody before their car gets hosed
I can't provide any opinions on an 03 or 04 tiburon but I do concur regarding the quality of the 05 Tiburon. I can't be too over-confident on its reliability because I only have little over 5000kms on the car (I traded in my 00 sonata @ ~150K, which by the way was a solid vehicle) but I am very satisfied with the car. Hopefully, it'll be as reliable as my sonata.
Needless to say, I do have complaints. The car revs too high on the highway. I have a manual for the I4 and at 100km/h, the car is revving at little less than 3000RPM. In general, 120km/h is the norm on the highway but having the car rev at 3400RPM is neither good on the gas nor is it good on the cabin noise. I wonder how the V6 is in regards to RPM on the highway? The other complaint I have is that, and I'm pretty sure that it's the consensus among I4 owners, the car is slow. I know that the I4 has tons of potential in terms of "modding" but the cost associated with all the aftermarket parts, which by the way are mostly from the states or korea, and the potential hassle that you may run into when servicing your vehicle under warranty is just a HUGE deterrent. However, if you're interested in aftermarket stuff, there are lots of communities, both in the US and Korea (I won't name them here because of forum rules).
Other than the two complaints from above, I'm very satisfied with my tib. It's gonna be big test for my tib since I'm in Ottawa now for school, and our nation's capital is known for its frigid and snowy winters.
For prospective tiburon buyers, I sincerely recommend the tiburon. As long as you're not planning on a cross-country trip, I think the Tiburon should be placed among the top of list for those budget-conscious buyers in the sports compact market. If anyone needs anymore convincing, drop me a message and I'll do my best
Steve
Today while on her way to college, 5 blocks from the house, her car went out of control at 40mph (as per witnesses) hit a center median and propelled its self into the air rolling 4 to 5 time landing on the sidewalk on the other side of the street.
I am demanding and investigation of the front end of the car. My daughter sustained moderate injuries.
BUT in defense of the car, it also saved her life. The passenger compartment of this car sustained NO DAMAGE, the side airbags deployed and I believe saved her head from hitting the pavement.
Will I buy another Tiburon NO we have had to many steering problems.
IF THERE IS ANYONE ELSE WHO HAS HAD THIS HAPPEN TO THEM Please I beg of you contact me. My daughter is 18 years old and by the graces of god she could have been taken.... please let me know if you have had these problems. email me at : momofteengirls@aol.com... thanks
Wishing myself and everyone else LUCK....... :lemon:
The car is great but I do have one little gripe. I noticed that there is a rattle that's coming out of my trunk that's sort of annoying. It may be due to the cold weather (Ottawa, Canada) but still, a new car shouldn't be rattling. Previously, I owned a 2000 Sonata with over 150K on it and it didn't have a single rattle. Overall, the Tiburon is an amazing car, though I love the new Sonata too. By the way, the new Sonata and Azera won the AJAC award in their category (Family car under $35K and over $35K)
Steve
SERVICE MANUAL
Applies to: Tiburon 1998-2000
GROUP
Body Electrical System General
TROUBLESHOOTING
ALARM
Symptom
Possible cause
Remedy
The system is not armed
(The siren doesn't sound)
Transmitter faulty
Replace the transmitter
Receiver faulty
Replace the receiver
Damaged or disconnected wiring of door switch input circuit
Repair the harness
ETACS module faulty
Replace the ETACS module
The siren sounds in error when a door or trunk lid is unlocked by using the key while the system is armed
Damaged or disconnected wiring of a door key cylinder and trunk lid key cylinder switch input circuit
Repair the harness or replace a door key cylinder and the trunk lid key cylinder switch
ETACS module faulty
Engine does not start in disarm state
Burglar alarm relay faulty
Replace the burglar alarm relay
Damage or disconnected wiring of burglar alarm relay activation circuit
Repair the harness
Malfunction of the ETACS module
There is no alarm when, as an alarm test, a door is opened without using the key
(The arming and disarming are normal, and the alarm is activated when the trunk lid or hood is opened.)
Damaged or disconnected wiring of door switch (all doors) input circuit
Repair the harness or replace the door switch
Malfunction of the door switch
There is no alarm when, as an alarm test, the trunk lid is opened without using the key.
(The alarm is activated, however, by opening a door or the hood)
Damaged or disconnected wiring of luggage compartment light switch input circuit
Repair the harness or replace the luggage compartment light switch
Malfunction of the luggage compartment light switch
There is no alarm when, as an alarm test the hood is opened from within the vehicle
(The alarm is activated, however, by opening a door or the lid)
Damaged or disconnected wiring of hood switch input circuit
Repair the harness or replace the hood switch
Malfunction of the hood switch
