I also own an American Jeep Grand Cherokee and have had typical SUV issues with it due to its weight. But my family is shrinking (going off to college) so I really don't need the SUV any more. My BMW 325xi has AWD and actually handles the snow I have to deal with very well.
As for reliability, kdshapiro is right - the latest BMW's, in general, are VERY reliable, and I've only been to my dealer for one problem, and they bent over backwards to help me and they fixed it immediately. The 5 is just as, if not more reliable than the 3. The new 5 may be a different story with all the electronics involved: active steering, adaptive lighting, active role stabilization, i-Drive... we'll see.
Until the 2004 5 Series is available, which my wife really likes, I'm not deciding one way or the other. I have told her I want to drive the G35 sedan (we want 4 doors) before we commit to any car. My short list includes sport luxury sedans from several vendors: Infiniti, BMW, and Lincoln. All are excellent cars. The price range varies a bit I agree, and I am very much a fan of BMW's inline 6's. There are very few engines smoother.
Is there a premium attached to BMW's? Yep. It is up to each individual buyer to decide if that premium is worth it to them. When I bought my 3er, I paid less for it (with AWD) than I would have for a G35. The bigger premiums will be found on the higher end BMW's, though the 330 will have a bigger premium attached than the 325.
This is not totally uncommon or unique to BMW. Look at the new RX-8. You will pay more for the 247 HP version than you will for the lower HP version. You also get more standard, as do you with the 330. I'm not sure how Infiniti does it with the G35c auto vs the 6MT, but the 6MT does come with more sport tuning standard.
I'm not knocking the G in any way, especially since it is an excellent car that I may be adding to my garage in the next 6 months or so.
-Paul
However, I would never consider these cars directly comparable. The G35 sedan, with all of it's virtues, is closer to my Maxima in interior fit, finish and materials than it is to the 5-series.
As far as resale value - that may not mean much to me given that I have 9 years / 143k miles under the belt of my Maxima. However, anyone with a 3 year old Q45 that is worth about 30% less than an initially less expensive 3 year old 5 series knows that you buy Infiniti for life or get crushed on resale. I made that call when I bought my Maxima and haven't regretted it.
My point is that a 2004 530i is likely to be $10k +/- more expensive than a 2004 G35 sedan for good reason. Given the opportunity to get a 5-series for under US invoice through European Delivery, I consider BMW to be a pretty good deal. The "premium" attached to BMW over Infiniti is directly propotional to what you get, in my opinion. The same cannot be said for the E-class pemium over the 5-series. That's probably where I would draw the line.
At any rate, used G35's have, so far, been going for strong money according to some of the people here that know about this kind of stuff. I don't see anything about the G to indicate that this situation is going to change substantially in the near future.
His only complaint is that dealer maintenance and repairs run 50% higher than for similar services at Nissan. Example, a 30,000 mile interval "B" service on the I30 is $330. On my mechanically idential Maxima it's $220. But the amount he saved in depreciation buying a 2001 Q45 Touring for $24,000 this spring over a 2001 $40,000 E430 more than makes up for a little extra service.
Thanks in advance for saving me a trip to my local Infiniti dealer!
supra880
PS -- Looking forward to owning the car if I do get it!
Best Fuel Economy: 15.9 mpg
Worst Fuel Economy: 19.9 mpg
the G35C doesn't have rear air vents in any form. The only G35 that does is the auto sedan with premium package. HTH.
First my questions:
1 – RPM - I do not see the final drive ratio listed in the brochure - if it is also 3.357, the RPM at 60 seemed rather higher than I expected in 5th – I seem to recall ~ 2,400 or so???? I expected something closer to 2,100 . . . Thanks to rx8zoomster for posting the gearing information (below) – and now I clearly need to try this again, as the Coupe, with the same 5th gear and final drive ought to be turning 2,100 according to what I have seen. . .
2 – MPG – owners out there – what do you see for gas mileage in extended highway cruise mode – say 65 – 75 mph? For example, if one fills the tank and drives a couple of hundred interstate miles with only a brief (coffee / bathroom type) stop or 2, can you exceed the EPA highway rating of 26 mpg?
3 – Engagement of 5th gear in manual mode – I had some trouble understanding the algorithm here. I tried to upshift into 5th at 40 – 45 mph several times. Sometimes it took 2 or 3 tries, then it engaged. At the (roughly) same vehicle speed. What am I missing here? I believe that I was above a (road) speed that would have allowed over 1500 rpm (engine) speed in 5th each time . . .
4 – Automatic upshifting in man-u-matic mode. I believe that I read somewhere that the trans. will stay in a gear and bounce off the rev limiter – as opposed to upshifting at the redline if one forgets (?) to tap the shifter in manual mode – true?
Thanks for any information anyone can provide!
Brief background: I had driven a couple of G35 sedans shortly after their introduction. I decided to buy a different car partly because I did not like the way the man-u-matic feature of the automatic trans. worked. Not in line with my expectations. I recently read somewhere (here?) that the coupe worked differently – and more in line with my preferences. And it now does perform much more to my liking.
Overall, my impression is that Infiniti has done a terrific job on the coupe.
I certainly enjoyed the responsive engine and the exhaust note at lower (below 3000 rpm or so) is nicely aggressive, yet fades at highway rpm. Well done. Not the deep, heterodyne beat of a V8, but enjoyable.
I did not test the cornering limits, but the feel is natural and comfortable for me. OTOH, the OEM Goodyear RS-As are clearly NOT ultra high performance tires . . .
The sun / moonroof takes a critical few inches of headroom for me – but I think it would be worth it to me to have both the glass and additional light as well as the ventilation / fresh air – but I am still debating that one. . .
The front seats are an improvement for me – I am one that objected to the placement of the seat adjustment controls on the sedan. And they are very comfortable. And the adjustment control positioning is much less intrusive.
Again – it is a fun car to drive. It behaves in a generally refined and sporty manner - and performs very well. I think that Infiniti did an excellent job here.
Just my $0.02 worth
Cheers,
- Ray
Looking at coupes seriously for the first time in many years . . .
from rx8zoomster . . .
---------5 A/T----6 M/T
1st------3.540----3.794
2nd------2.264----2.324
3rd------1.471----2.324
4th------1.000----1.271
5th------0.834----1.000
6th---------------0.794
reverse--2.370----3.446
Final----3.357----3.538
g35 coupe ratios
a/t 6 spd
final 3.357 3.538
top gear 0.834 0.794
overall: 2.799738 2.809172
1.rpm, try to turn the vdc off it lower the
rpm a bit
2.mpg, well full tank highway cruise speed around 80, the best i can do is about 400 but i heard it will improve after 5k
3.never drove the manual so...
4.Automatic upshifting in man-u-matic mode; yes it does bounce off the rev limiter when it reach about 7000rpm
supra880
- Almost none of the coupe owners are meeting or exceeding the EPA mileage estimates. Usually 2 mpg under that.
- As for the "sunroof or not" question, I decided against the sunroof due to headroom issues. I've been very glad that I did. I miss having a sunroof, but I really like the extra 2 inches of headroom. I'm pretty sure that the "crowded" feeling would have really put a damper on my love of the coupe.
Good luck with your decision.
FWIW, I was in negotiations with a dealer over an '04 G35 C w/PP, and he said that the '04 price lists at $450 more than the '03. I guess that would make a coupe with PP run $35,445 MSRP.
I've put my purchase decision on hold until I can get the price I want. I'm in MA, where there are about 4 to 5 Infiniti dealers within 40 miles, all of whom say "This car's going at right around sticker. There's no room to work on the price." The fact is that there's plenty of room to work on the price; it's simply a question of whether the dealer wants to.
The '03 MSRP on the aforementioned configuration is $31,641, which still leaves a decent $2,000 profit if they were to sell it to you for $33,641, which they won't (ethan777 notwithstanding. BTW, I'd like to talk to HIS dealer). Admittedly, they don't need to give you that price because the demand is high enough for them to justify waiting until the next guy walks in and pays sticker or above. Can't blame 'em if they can get it, but I wonder how much longer it will last.
I'd be interested in hearing any anecdotal evidence on recent pricing trends from those of you who have purchased recently or know of others who have. Thanks in advance!
The others have fairly negative reputations.
As far as price trends are concerned, I've seen and heard the same thing as you, pretty much nationwide if evidence from other boards is to be believed.
My guess is that the automatics, which seem to be pretty plentiful, will start to discount well before the manuals which still sell as they hit the lots ... I have an appointment for (another) test drive in one when it arrives (!!!) next week ... the drive will be fun and a refresher but it is mostly an excuse to keep the dealer on his toes should I decide to buy a 6MT this winter.
Best in your search. Please update here on your Boston experiences! JW
But obviously, that is a personal decision! JW
I find the seat control module a little annoying, and I plan to have the Infiniti TSB fix for that done during my upcoming 3750 mile service (they remove a brace and a plate to allow the seat control module to "give" more.
The idea of waiting to the end of the year is a good one, I think, for purchase. Prices are just beginning to flex and in winter sales soften so the best discounts should be available then. Obviously, I have no inside info, just a feeling. I'm waiting for Feb. myself. JW
What do you all think??
Anyone bought coupe 6MT recently in VA/DC/MD area? any recommendation? sales person from Passport/Alexandria said that there might be negotiation room for 03 model, but MSRP for 04. Is that true?
I am welling to drive up and down the coast (200 miles radius).
Shiftright the Host
get a quote for 550 below MSRP. Anyone has a better offer than this? dimond graphite, willow, coupe, 6MT, premium.
Could I get opinions from those who have the auto,
on the g35c, about their brakes.
Just climbing down from cloud nine for a second to make a post. I just bought my G35 Coupe and am loving life. This is my first sports car and I never knew that driving could be so darn fun. I am asking the option of other owners as to their thoughts on the protective bra for the front of the vehicle. I do a lot of highway driving and I want to protect the car from debris. Has anyone out there already got the bra on and can you share your thoughts? Pros and Cons of purchasing one? Also, does anyone know of after market racing pedals for the G35? I can't believe that they would sell the FX with them and not the G35's??? Well, I am back to the road, any input would be appreciated.
In my test drives, the coupe had a little less nose dive than the sedan. Both had brake pedals that were more sensitive than most other cars.
My take on all the posts: two of the options stand out, and cost about the same. One, get the clear bra. It does exactly what it's supposed to do. The vast majority who have them, swear by them. Two, live with the chips until you can't take it, then get the front bumper repainted by a very good shop. A lot of people who did this report that the paints used aftermarket DON'T chip, so after the repainting the chipping problem goes away.
I don't have the clear bra. I've decided to live with the chips (8 of them in 4000 miles, mostly city). I'll go with a repaint if it gets too bad.
For what it's worth, this exact same problem is a major topic on several Acura and Mercedes forums. Really sad.
The dealer suggested that I also purchase mud guards, protective trim, lojack, and glass etching (anti-theft). I am considering adding these to the deal and was wondering what others thought of these, particularly the protective trim. Any thoughts would be appreciated.
Let me know.
I believe that MSRP for a 2004 coupe 6MT with premium and aero (the cheaper one) packages is $35,795 exclusive of the destination charge ($545 here in NJ). Again, my "take it out the door cost" (that is, all costs included) was $36,282.
Could you email me the sale person you had worked with and the dealership number? Thanks again for helping us saving some money!
My email is fruto123@yahoo.com
