I've checked the seat to make sure there is nothing blocking the seats movement, and everything is clear. I've looked at the fuses but nothing indicates which fuse is for the seat, but again everything else in the seat works, so I'm reluctant to start pulling fuses randomly.
If anyone can offer any advise it will be much appreciated.
James
Nothing unusual or difficult about it beyond how its done on most cars?
How do you feel about places like Jiffy Lube and such doing this, versus the dealer?
Also, I sometimes hear creaking sound from chassis (or suspension i am not sure)when i go slow on bumpily road, and also from the chair when i move around. Is that normal for a 03 G35? or should I bring it to infiniti for repair since I still have warranty covered.
Did you fix it with warranty?
I bought the car used when it was a year old (a year ago) and they repainted the hood of the car and front fenders of the car last year at no charge when I bought it because it was such a mess. I'm just worried about more rust. Or should I just get touch up paint and touch up all the spots? I worried about being able to see touch up spots all over the car though. I didn't know what the warranty covers on these cars as far as paint goes. Thanks.
Red paint "issues" are a known problem, at least by some of us. If it's not red, then it's just the standard latex paint (green-friendly) stuff that we all have to deal with these days.
You may not remember when factory paint stuck like glue & lasted forever. Sadly, I do.
Also, you can find a bunch of do it yourself videos for the g35 here: http://g35driver.com/forums/showthread.php?t=183421
I found the problem a week ago. When I had my brakes done in June, Infinite service had to remove the bottom shield to the engine. When they put it back, did left 2 retaining clips uninstall. The sheild vibrated when the car reached a certain speed.
Great car!!
Today while driving to work my slip light has come on and stayed on. I have pressed the button a few times to deactivate and avtivate it again but no luck.
Has anyone else had this problem?
Greg
"Fog may temporarily form inside the lens of the exterior lights in the rain or in a car wash. A temperature difference between the inside and the outside of the lens causes the fog. This is not a malfunction. If large drops of water collect inside the lens, contact an Infiniti dealer."
Not sure if the 2003 uses the same headlamps?
Reference: Date:
ITB08-001 January 12, 2008
VOLUNTARY SERVICE CAMPAIGN
2007 G35 6-MT CLUTCH SLAVE CYLINDER
CAMPAIGN ID #: P7253
APPLIED VEHICLES: 2007 G35 Sedan (V36) with 6 speed manual transmission
APPLIED VINs: JNKBV61E*7M 700138 to 727518
NOTE: Use Infiniti Net to confirm campaign eligibility
INTRODUCTION
Infiniti has determined that on some 2007 G35 sedan vehicles equipped with the 6-speed manual transmission, the clutch slave cylinder assembly may not have been manufactured properly. This could result in the operating force of the clutch pedal becoming light, and in some cases, could result in improper clutch operation. Infiniti is conducting a Voluntary Service Campaign to replace the clutch slave cylinder assembly with a new improved part free of charge for parts or labor.
IDENTIFICATION NUMBER
Infiniti has assigned identification number P7253 to this campaign. This number must appear on all communications and documentation of any nature dealing with this campaign.
OWNER’S LETTER
Dear Infiniti G35 Owner:
Infiniti is committed to providing the highest levels of product quality and customer satisfaction. With that in mind, we want to bring to your attention important information regarding the clutch hydraulic system in your 2007 G35.
REASON FOR SERVICE ACTION
Infiniti has discovered that on certain 2007 G35 vehicles equipped with the 6-speed manual transmission, the clutch slave cylinder assembly may not have been manufactured properly. This could result in the operating force of the clutch pedal becoming light, and in some cases, could result in improper clutch operation.
WHAT INFINITI WILL DO
To assure your continued satisfaction in your G35, your Infiniti retailer can replace the clutch slave cylinder assembly with a new improved part free of charge for parts or labor.
WHAT YOU SHOULD DO
Please contact your Infiniti retailer at your earliest convenience in order to arrange an appointment. This free service should take about three hours to complete, but your Infiniti retailer may require your vehicle for a longer period of time based upon the workshop schedule. To ensure the least inconvenience for you, it is important that you have an appointment before bringing your vehicle to the dealer for service.
Please bring this notice with you when you keep your service appointment. Instructions have been sent to your Infiniti retailer.
If the retailer fails, or is unable to complete the modifications free of charge, you may contact the National Consumer Affairs Office, Infiniti Division, Nissan North America, Inc. at P.O Box 685003 Franklin, TN 37068-5003. The toll free number is 1-800-662-6200.
Thank you for providing us this opportunity to ensure your on-going satisfaction with your Infiniti G35.
Verification of contact information can be found by going to http://www.infiniti.com/iapps/contactus
Verification of the TSB can be had by calling the 800 number above and pressing the menu option for Infiniti Recall / Service Campaigns.
I started getting an error occasionally - when starting the car, the display screen in the car would indicate "Private Caller," the on-screen buttons (e.g., Hang Up) would appear but not do anything (as if they were disabled or locked), the car would "ring," but there would be no incoming call (the phone was silent). After about 20-30 seconds, this error would go away on its own (except for one time when it did not, and I had to turn the car off and then back on - like rebooting my car).
The dealer replaced the radio unit, which changed, but did not eliminate the problem.
Now, when the problem occurs, I get the same screen (Private Caller, with buttons that don't do anything), but the car doesn't ring, the phone is still silent, and the problem fixes itself in about 10 seconds. The times when this error occurs seem to be "grouped" together - last week, this error occured 5 times in one day (each time I started the car that day), but has not occurred since.
Thanks in advance for your suggestions!
They replaced three parts and the brake fluid:
CYL ASSY - Concentri - 306A1 - JK40C
CYL ASSY - Concentri - 206A1 - JK40A
Insulator & Bolt Kit - 34115 - CD026
Brake Flui 320Z - 999MP - A4132P
Twice during discussions with the salesperson I asked what the breakin period was. He said 500 miles each time. The car now has 1500 miles on it, however since the 500 mile mark, the engine has been briefly (i.e. 5 - 7 seconds at a time) spun to 5000 three or four times.
I purchased the car on 12/31/2008 and have been reading the owners manual from day one, but just got to the section that talks about not revving the engine past 4000 rpm until after 1200 miles. A stupid oversight in retrospect. I should have hunted this info down first, instead of relying on the salesperson.
Now I wonder what the consequences might be? The car still seems to be running fine, but I have the sense that I could spend the next 5 years figuratively "looking over my shoulder".
The fact is that I am VERY careful with my car most of the time. I am generally a "5 mph over the speed limit" driver on the road. I hate to admit it but, in town but I accelerate in a "elderly" fashion (1) because it swills premium unleaded at about 18 mpg and (2) because it's been nearly 20 years since I owned a performance car and I want to keep it forever.
If anyone can tell me candidly what the potential consequences are for having accelerated above the recommended 4000 rpm ceiling prior to the 1200 mile mark, I'd be appreciative.
.. and as several people have mentioned, I don't know how your test drive was, but my salesperson had me take the car to red-line. Yes, red-line, while demonstrating the manual shift mode. This on a new car right off the lot (not mine ) with about 30 miles on it.
And lastly, they test every G35 out at the factory when it comes off the line. There should have been a card in your glove box signed by the person who did the testing and how many miles the engine had on it. Mine had 5 miles, but word has it they could be up to 10 miles, and I guarantee you that the engineer drove the car hard during testing.
A few briefs seconds at only 5k RPMs is, in my opinion, absolutely nothing to worry about. If you had said you were driving around town bouncing the engine off the rev-limiter all the time, then yeah, maybe I might think about being worried. My former S2000 had a break-in period of 600miles and then it was 9000 RPM!!
kc
I have also had my touch screen replaced due to a blackout type situation that wouldn't allow the entire control center to work...After they replaced it, no problems.
Any info would be great...
So far owning the car has been a remarkable experience. After years of reading car magazines and dreaming of owning a high-performance sports sedan, it is gratifying to find the reality is living up to my dream.
Powerful, agile, sophistocated, and luxurious, it has provided a out-of-this-world experience, this driver of a 2001 Subaru Forester could not have imagined.
kc
I did some searching online and saw nothing that looked exactly like the problem described and relatively few bluetooth problems specific to the Q9M in general. I did find it interesting that Verizon (don't know or did not see who your carrier / wireless service provider is) , does not show "navigation" equipped Infiniti models in their list of supported bluetooth car kits .
There were some posts in various forums indicating problems that Acura's were experiencing with the Q9M. See the web sites listed below (hope I used the forum's URL formatting tool correctly):
Hello Moto Q forum
Everything Q forum
Q Users forum
If I interpreted their postings and replies correctly, the problems they observed might be in phone handset's software itself.
***** The waters from here on are bordered with "Enter At Your Own Risk" signs.*****
That said, if I'd exhausted all the settings and configuration avenues I'd check with the wireless service provider to determine if there is a software update available for the phone. It might fix the problem you are having. If you take it to their store, they will often update it for you. You could also find this information (and if it exist, the update itself) at the web site of the wireless service provider or Motorola. Be forewarned that though such updates fix problems (and sometimes add features), they can change the behavior of existing functions. This can potentially create new problems, or at least requiring learning how the updated function works. Lastly, updates sometimes erase the handset's user preferences and data. Better designed ones, back up this data as part of the upgrade process, but there are others which do not.
In case the URL links fail, the actual URLs are listed below. Good luck:
http://www.infiniti.com/bluetooth/
http://support.vzw.com/pdf/bluetooth_car_kit/Motorola_Q9m.pdf
http://www.hellomotoq.com/forums/built-applications-motorola-q/476-bluetooth-blu- es.html
http://www.everythingq.com/forum/moto-q-9m/acura-tl-handsfree-w-q9m-13024.html
http://www.qusers.com/forum/viewtopic.php?t=11439&sid=2d1ec8438e14d304e8323b2458- dbcebd
I have a premium and nav package equipped '08 G35x. I use a Sprint Treo 700p phone (which is not on Infiniti's compatible / tested phone list) and have had minimal problems with bluetooth functionality, so far. Of course, it should be noted I have only had the car for a month.
Also, I had to get the rear window molding repaired due to a problem they said they are seeing more of...the clips that hold the molding in the door are breaking...fyi
If you interrupt the movement, it's all screwy the next time you the in the car.
I've noticed this as well.
I have it set to raise the wheel and move the seat back.
Sometimes I have my 4yr old with me in the back seat and I don't wanna crush her little feet... so when I open the driver's door to exit, I quickly tap the seat adjustment knob to stop the backward movement.
When I get back into the car, the seats move around, and don't reset back to my programmed position once the car is started.
This ONLY happens when I interrupt the seat movement upon exiting.
Check and confirm if your issues only occur when interrupting the seat's automatic movement.
Are you sure it's the car that's the issue here? Try a different phone and see what happens, maybe.
