Most other cars have 12-volt outlets. I don't understand electric this good, can someone explain me the advantage of it?
Also, does anybody know how many watts the audio system of the new Sienna will offer? Especially the one with 10-speaker surround sound? The new Mercury Monterey will have 140 watts, but Toyota Avalon XLS offers 250 watts!
Also on the Avalon, for 2003 they offer a DVD nav system with a remote controller. Will that be available on the Sienna?
Now one point, maybe some of you will not like it, maybe not agree, but it's a matter of fact. I have now a Ford Windstar, which has excellent traction in the snow. I live in upstate NY, and came last night (4:00 am) (what a weather! almost 20 inches of snow!) from Brooklyn to my house, with no problems, and 2 friends came along with 01/03 Toyota Siennas, and had many traction problems. I also have 3 friends with Honda Odysseys, and they have a big problem with snowy weathers, they're spinning around like no tomorrow...
It's a fact that in terms of traction, the Windstar beats the imported models. One of my above friends with the 2003 Sienna had a 2000 Windstar before, and due to many problems he switched to Toyota Sienna which he loves, but he told me: When the snow start to fall, I need back my Windstar, it performed much better than my new Sienna!
So bottom line, if you're buying a new Sienna, my opinion is, go with AWD. at least go with snow tires! My Windstar I came home this night is a front-wheel drive and regular all-season tires, and no problem!
> What do you mean to say, it has a regular plug, so I could use, for example, my vaccum cleaner? or small heater?
Make sure you check the manual about any power/wattage limitations. For small current draw appliances such as a VCR, charging up your cell phone, a camcorder etc are definitely OK. But for things like heater, vacuums, hair dryer etc, they require very high current; so make very sure the manual is read very carefully or you will blow the fuse.
I can't find any detailed info on this on any brochure released so far.
"For small current draw appliances such as a VCR, charging up your cell phone, a camcorder, etc. are definitely OK"...
Just asking, these things are definitely OK with a 12-volt outlet, too. So again, what's the advantage of the 115 volts over the 12v?
But if you already have the car adapter(s) for your devices, then no advantage.
I would say Toyota put in the 115V outlet specifically to enhance the entertainment system along with its other uses for other people.
Too bad they can't call them anything but minivan.
If anyone finds out more on why we can/can't get this combo, I would love to hear it- JK
1355: LE packages 8 (BY), 9 (BZ), and 11 (CM) include DVD amongst other options.
> Thanks. A bit disappointing. More cost effective for Toyota compared to some form of LSD, I suppose. Not exactly leading edge safety technology, though.
I see it differently. This is the same AWD system used in X5, 3 series AWD, Mercedes M class, and all the 4 matic system. If done correctly, it is a very effective system. Well, at least they believe it's good enough for S-Class!
Sienna AWD will have 50/50 torque split in normal driving, and that's good. It is a real full time AWD, unlike for example, Acura MDX's VTM-4 or Volvo XC90's Haldex II which have 100/0 and 95/5 split in normal driving - more like a part-time automatically engaging AWD in all practical purposes.
Also, is it unrealistic to expect invoice pricing available at this time, on ANY site?
Just wondering - very interested in the 04 Sienna - thanks - JK
they have the prices on that web site.
Base model CE is $22,900, nothing on it. AWD top of the line with DVD & Navigation will be $42,000. So there's a $20,000 gap that the vehicle you want can fall into. The AWD will start at $36,000 for the limited model.
Also, does anyone have a figure for ground clearance on the AWD Sienna?
So, if all diffs are open, then yes it will get stuck more easily. More easily, I should say, than a system like that used by Subaru, or VW-Audi (which can transfer power (torque) "from the wheels that slip to the wheels that grip" (sound familiar?). It'll be better than 2wd, though, so its a plus in that sense and that is a key point to remember. I wouldn't spin it as a plus relative to one of the more sophisticated systems, though.
It should be noted that some systems with LSDs center have open diffs front and rear (I think many Subies are this way). So they'd be just as stuck if only one wheel has traction. Also, some LSDs require at least some traction at the "loose" wheel to work, and they furthermore limit the largest possible torque bias to considerably less than 100/0. All of this technology helps, but it can't work miracles.
On a related note: $36k and up for an AWD model? Ouch. That's out of my league, so I guess what type of center diff it has is academic as far as I'm concerned.
This is essentially what traction control can do automatically for you - brakes can be applied to limit wheel spin and, as a by-product, the max available torque is raised making more torque available to the opposite wheel with traction. So traction control will mitigate some of the down side to the use of open diffs. It won't act as fast as an LSD since most traction control systems pull back power first, then apply brakes. I'm not sure how the Sienna system works, and furthermore don't know if it optional or standard on AWD models. I'm guessing it is standard because it would make the system work so much better.
BTW, I'm not an expert on this stuff, so don't go taking it as gospel. Like I said, it's all academic to me at this point. ;-)
And yes, it can distribute to one wheel if necessary.
Also, has anyone bought an extended warranty over the internet and used it without a problem? I know that more affordable warranties are available for the Hondas on the net, but wasn't sure about Toyotas-
If anyone can pass along any info I'd really appreciate it, thanks - JK
Sienna Ground Clearance: 6.9"
> From what I understand, the AWD system on the Mercedes ML cannot send power to only one wheel, rather it reduces power to other wheels to avoid wheelspin/skidding.
Actually, ML, similar to Sienna, *CAN* direct most of the power to one wheel. You probably have misunderstood that it cannot send 100% torque to one wheel. But using traction control and put brakes on other slipping three wheels, torque will be directed by the three open differentials to the remaing non-slipping wheel. Not 100%, but enough to get the car moving.
I always had a problem with a 38k Town and Country with AWD because the base Voyager can be had for like 20k.
I realize the engine is different as are size of wheels and trim upgrades. My problem is that the platform and drive train are the same. Now that makes the ce and le one hell of a deal, but the Limited a option layden profit center. Maybe I need to consider the XLE and keep the price down.
Im not dissing the Sienna, in fact I think it will be a very good value, so long as you keep the sonar and other silly thing in the parts bin.
I like silly toys, but there are limits. Seems like a very General Motors thing to do. They once used a Cavalier as the platform for a Caddilac, the Cimmeron it was called. Loaded with options, they passed it off as a Cadilac.
The limited is very nice, but does not offer enough structural or performance enhancements.
Maybe at invoice, but hold the DVD and NAV. at 34 or 35k its Ok. But 42k?
Thanks for all the details about differentials. It sounds like even with open diff(s), the Sienna AWD should have decent traction if equipped with traction control. Not all traction control systems utilize the brakes, but I'll assume the Sienna's does.
Yes, there is lots of profit in options, which is why I'm surprised options have fallen out of favor at most car manufacturers which instead now offer only a small number of "packages", if that. I sure miss the days when you could pick and choose from a menu of 30 options and there weren't all sorts of restrictions as to what could be ordered with what.
I'm also not sure some of the Limited toys are all that necessary. I'd happily trade the laser-guided cruise control and power side doors for driver's seat memory, cornering lights, oil and voltage gauges, and a multi-adjustable front passenger seat.
I found a comment form at toyota.com. I relayed my thoughts, likes & dislikes. My comment may end up in a bit bucket, but I'm hoping someone will read it.
http://toyota.custhelp.com/cgi-bin/toyota.cfg/php/enduser/ask.php- - - ?p_sid=c-PKHdCg&p_lva=&p_sp=cF9zcmNoPSZwX2dyaWRzb3J0PSZwX- - - 3Jvd19jbnQ9MTU5JnBfcGFnZT0x&p_li=
I recall on Sienna #1 my son almost took the head off our daughter, he closed the door with out looking. Scared me half to death! I like power doors. The power tailgate is neat, Im not sure its worth 400, but I'll cross that bridge if I get to it.
Sienna CE 7-passenger $23,465
Sienna CE 8-passenger $24,085
Sienna LE 7-passenger $24,770
Sienna LE 8-passenger $24,920
Sienna XLE 7-passenger $28,770
Sienna Limited 7-passenger $34,990
Sienna AWD CE 7-passenger $28,385
Sienna AWD LE 7-passenger $31,975
Sienna AWD XLE 7-passenger $37,440
Sienna AWD LE 7-passenger $28,385
Sienna AWD XLE 7-passenger $31,975
Sienna AWD Limited 7-passenger $37,440
Am I missing some features but it looks like prvacy glass is the only tangible item. You can get that for $300 post sale.
Any insight is appreciated. FYI, local dealer in Oregon said mid-March for delivery.
Peace, Becky
Peace, Becky
Jnr1? Well.... I'm dying to know!
Any recommendations for dealerships in the Omaha/Des Moines area offering deals like those found in Oregon? Thanks, Greg
Sienna FWD MSRP and Dealer Invoice price(includes shipping, holdback, etc..)
CE 7 Passenger $22,955 $21,602
CE 8 Passenger $23,575 $22,172
LE 7 Passenger $24,260 $22,801
LE 8 Passenger $24,410 $22,940
XLE 7 Passenger $28,260 $26,188
Limited 7 Passenger $34,480 $31,839
Sienna AWD MSRP and Dealer Invoice price(includes shipping, holdback, etc..)
LE 7 Passenger $27,875 $26,123
XLE 7 Passenger $31,465 $29,100
Limited 7 Passenger $36,930 $34,066
#3373 of 3373 Bought my Odyssey last night!! by smartyboy Feb 20, 2003 (3:19 pm)
I was driving through Crystal Lake last night (suburb of Chicago) and saw that the local dealer and recieved a Sandstone Odyssey with leather. It did not have the DVD however. The salesperson came out and said that they are putting in the Honda aftermarket in most of the vans and would do the same with this. I told him about the $2000 discount offered at the other dealer to see if they would match. Secondly, I told them what I was looking for on my trade. 15 minutes later I had my new van. The dealer called a few minutes ago and said the DVD can be installed tomorrow.
While I noticed that they have put several accessories on some of the vans, they do not push them and will sell you a van without all the little add ons. However it was nice to see what a few looked like with some of the touches.
I am happy with the deal and very happy with the dealer. If in the Chicago area, call over to Crystal Lake Honda in Crystal Lake Illinois.
