Any 1999 F-250 owners?
--MikeF150
congrats and good luck - maybe you should change that screen name though
THANKS FOR THE INFORMATION. IT SEEMED TO BE A GOOD SITE IF ONLY IT WORKED. I WILL CHECKING IT OUT OFTEN TO SEE IF THEY HAVE FIXED THEIR PROBLEM.
AGAIN THANKS. CW
P.S. IF ANYONE ELSE HAS ANY OTHER PLACES I HAVE AN OPEN EAR.
Dodge 4x4's are also very high but none of the 5th wheel dealers said the dodge has a problem working.
I would like to hear from anyone with a '99 4x4 Superduty who has been able to fit under a 5th wheel. Are some modifications needed or not?
I'm going to email Fleetwood and see if there is an industry standard for pickup bed height to fit under a 5th wheel. Will let you know if I get any additional information.
Has anyone else gotten closer than $400 difference in invoice and what the dealer wants?
BTW, I know that Isbell Ford will do it for $99 under. I factored the cost of airfare, fuel, time, and mileage (1700 miles) and thought a dealer would have to come down to $28,000 to balance out Isbell. So far, the dealer is $400 over the difference.
Any thoughts?
Ryan
I believe you might have to do some modifications. There is something that will lower the rear of the Superduty and there is also something you can do to the springs of the trailer to raise it up. A good source of info can be found at www.happycampers.com. They have a chat area. You can scroll through previous responses to see if they have already discussed the issue and/or you can post your own questions. I've found that site to be very helpful with my camper purchasing decision. I found out about the site from people on this site.
I bought an F250 XLT Supercab, LWB, V10, 4x4, Offroad pkg, keyless entry, dual pwr mirrors, captains chairs, 6way pwr drivers seat, trailer towing pkg, 265/75 tires and spare, passenger air bag, 5 speed, privacy glass,CD & Cassette, Trailer hitch, & Sliding rear window. It invoiced for $26,100 and they sold it to me for $26,600. The holdback is built into the invoice so you should not allow for it. They usually sell for $49 over invoice, but on the 99's they want $500 over invoice. I bought it from Turnpike Ford in Marmet WV.
I have been pulling a 28' 5th wheel with the original truck without any problems. It's basically the same truck except it is a short bed. The only towing problem I had was having to mount the the hitch a little further back than I wanted because of where the frame brackets bolted.
The long bed will solve that problem - I can mount it a little bit forward. I couldn't do it with the sort bed for clearance reasons.
I am using a Reese 14K hitch that bolts through the bed to the frame.
but they didn't say a word, not one, about the height---though the Main Office of Ford knew of the problem, proven by their own admission of having to poll the leading RV Mfgs. Point----do your homework!!!!!!
also, what other warranty problems seem to be cropping up?
My gas gauge will read incorrectly when the tank is not full. For example, if the tank is 3/4 full and I park facing downhill, then when I start the truck, the gauge will say it is at 1/2 full. If I park facing uphill, then it will say it is Full. It will not correct itself shortly after running on level ground. Most of my trips around town are not long enough for the gauge to adjust and give a correct reading. My guess is that placement of the sensor in the tank is in the back of the tank, but I don't know why it won't correct itself after a few minutes.
I have the V10, and it has never bogged down on me yet. I have hauled a couple of loads around 2500 lbs and it still had plenty of power.
thanks,
Ryan
motor has plenty of power, it just has that rattling sound of detonation. knocking like with poor gas, you know?
anybody else out there hearing what i'm hearing?
also, did anyone ACTUALLY get a 3.73 ratio with limited slip on their v10, or did they all come with 4.30? how about with the v8 and limited slip? i was told 4.10 was the only combo...
Speaker placement in the new trucks is slightly better, although rear speakers in the CC are still poorly placed. The extra space behind the CC back seat will be welcome, though. I've got a Kenwood PDC9000 with 4 a/d/s 325is mid/highs, 4 JL 10W1 subwoofers, and a McIntosh amplifier right now (all hidden). I'm going to get one of the (prob. Alpine) in dash LCD screen setups for the new truck, though. If it ever gets here...
not until September. I didn't want to lose my place in line, so I'll go with the original order
and stay in South Texas all winter.
No wty problems/issues at all. This is the first new vehicle that I've purchased that I couldn't nit pick about!
checksix,
I have ordered and received my F-250 SD with the 3.73 axle, limited slip. In California we had no other choice due to CARB.
all,
I just returned from the Pittsburgh, PA area. (Funeral) I rented a Hertz, Nissan Sentra. My F-250 SD is smoother and less noisy! It may have been their poor freeways but I was never so glad to get back into my F-250.
Rich
Now I am really confused: Ford(salesman?) tells
me the production line will not start producing
this option until September.
Obviously, he is misinformed (or worse).
The dilema is :Who can you believe: a car salesman or a person who has already taken delivery of one? (HA)
I am going to confront him tomorrow. Since I have not received a VIN #, I may be able to slip the
change in. Thanks for the timely info.
What does CARB stand for?
FYI: I have lived in the Pittsburgh area most
of my life. We have a procedure here for the
construction of new freeways: When the road is
finished, they have to create artificial potholes
until they form naturally.
California
Air
Resources
Board
The governing board that since the 60's has mandated cars meet stricter requirements than federal air standards allow. In fact, California was the first state to introduce air standards.
Cheers,
Ryan
On your vibration. I would ask the service manager to get the Ford factory representative involved. If the dealer refuses, contact Ford directly. (They have a toll free customer service number.)
I've posted this elsewhere but; According to my dealer the Ford quality team goes through three build phases.
1 - Prototype the vehicle itself. (Do the parts fit?)
2 - Prototype the assembly line. (Can the vehicle be assembled by the production line.)
3 - Final production test. (Were the problems in 1 & 2 fixed.)
Note that phase 3 may be included in the actual production run. i.e. It may not be separate.
Rich
you didn't say which engine you have. Is it the
Powerstroke or V-10 gas engine?
it took 15 weeks for delivery. i think it was well worth it. i got the lariat with everything and glad i did. truck performs like a dream. plenty of power. 2200 miles now and avg slightly over 12 mpg overall. esof works great with no problems. only complaint is the overhead monitor that registers temperature, mpg, miles to mty, etc., is awkward and hard to read. a little thing i can live with. this is a truck!
Good luck!!
I am purchasing an F250 SD 4X4 because I launch and retrieve a sailboat that weighs 7000lbs. The part of the boat ramp that is under water is often very slippery and the rear wheels will spin while trying to pull the boat out of the water, especially without a 4X4. With the 4X4 the two front wheels give me the extra pull I need to get the two back tires out of the water and onto dry pavement. I am not planning to get the limited slip because I didn't think it would offer me much. What are your opinions?
I got the power stroke! (Third diesel.)
sselker,
I went with the TT mirrors, electric adjustable. They are a dream! The cost was something like $154. Over which I'm not sure. My dealer ordered my truck twice; once with and once w/o the electrics. He got them both!
There is one complaint with the electric TT mirrors. The blind spot mirrors aren't adjustable. There's nothing really wrong with that but my preference would be less truck in the right and less sky in the left. Go with the electric adjustable TT mirrors. You'll be glad after every trip to the car wash.
dmscms,
If it were me, I would go with the limited slip. It is only like $300. I know with my '92 F-250 going over Deadwood Summit in sleet and snow I was glad I had it. I was able to get out of the Oakhurst valley with ease. I've also been half on a very soft shoulder and pulled right out with the LS rear end.
You'll hear from some people that a LS will put into the ditch on slippery roads. That could be true BUT what they don't tell you is that you have to be doing something stupid too. If you are in a situation where only one wheel has traction. If you apply full throttle as you are driving out of this situation funny things can happen. With full throttle, one wheel is getting significantly more power than the other. To correct for this situation the driver has the front wheels turned into the direction of the power. When the other rear wheel gains traction two things happen. First the power to the wheel with the original traction is reduced which cause the front wheel steering angle to have more effect. Second the rear wheel that just gained traction starts pushing, also in the direction of the front wheel angle. So the vehicle has a tendency to go towards the side where the wheel had traction.
I did it once coming off of a gravel shoulder to see what would happen. I was doing maybe 25 MPH when both wheels got full traction. The truck jumped 3", maybe 6" to the left. I came to the conclusion that, yeah you could wind up in the ditch; but you'ld really have to try hard.
Rich
I would have went with the limited slip on my 250 if it was available. I hear that by Sept., it will be available. Shift on the fly can help in some cases if you don't have limited slip, but don't shift into 4x4 and stomp on the gas if you have a back wheel slipping. Give it the gas slowly, because it won't engauge the 4x4 instantly with SOF. I have had limited slip for the past 12 years and have NEVER had it to cause me any problems, not even the slightest. It has kept me going in a lot of situations that would have required me to lock in the hubs and go to 4x4 if I didn't have limited slip.
Another example is the heavy duty automatic transmission on a Chevy pickup is only available with the 8600 GVWR 3/4 ton truck. Read the fine print on the options list and you should be able to find out what combinations are available.
I doubt if the salesmen pay much attention to these things unless they have been selling Ford trucks for quite a while. I'm afraid you will have to print out the options list and figure out on your own what you can and can't order. I wouldn't depend on a salesman, who might be wrong, with as long a wait as there is on these trucks.
spells it out in three or more places:
No lim slip 3.73 with the 99S V-10 Engine.
When I did my research back in January,
Edmunds did not have any information published
on the 1999 SD's. I got my info from some other
net source, and It showed the L/s as available.
Today, I was told by the Ford dealer that it is
available next week. See my post on Topic#158
response#349.
As far as a 4wd without limited slip being essentially a 2wd, that may be true on a technical point. I don't claim to have a lot of technical knowledge in that area. However, the difference would still be huge when it comes to traction in a 4wd over a 2wd, regardless of whether you have limited slip. It's the pull vs push argument. In 4wd, you have the front end pulling you up the steep inclines, in addition to getting some push from the rear. That makes a lot of difference on a slippery sloping surface, regardless of whether you have limited slip. Of course, having limited slip is better than not having it, but 4wd without it will still provide better traction on slippery slopes than a 2wd with it.
F-250 3.73 with Traction Loc 99-s V-10 Gas engine.
Since the news bulletin came out, you could
"ORDER" this option.
The problem is Ford isnt going to "PRODUCE" it
until Sept.
JB
Ryan
JB
Electronic Shift On the Fly
Thanks for the info. If you hear anything else, please let me know. I guess that the source book is where most order from, so if I want the 3.73, where would I tell them to look?
Nolan1,
That is a beautiful paint job --- for about 5 months. If you look back in this echo (or the next F250 one) you'll see that Ford discontinued that paint for the same reason Dodge did last year: Extreme rapid fading, paint peeling, and poor overall longevity of the paint on the truck. If you have problems, make sure to have Ford repaint it under warranty.
Good luck,
Ryan
