Acura TSX
1505153555699
  • robertsmxrobertsmx Member Posts: 5,525
    Why doesn't Honda use the Honda S2000 engine for the TSX Type S engine??? That car will fly..... tell me what you think...
    It is possible that the anticipated TSX Type-S could share engine with the next Honda S-car (note that I did not say S2000, since a rumor that there will be a bump in displacement to 2.2 liter, which would mean S2200). Sooner or later, F20C (S2000 engine) is going to be replaced by an I-VTEC variation. It could be a variation of the current K-series engine.
    As already pointed out (Varmint), the sportiest version of Accord today (Accord Euro-R sold in Japan only) shares the high revving engine with the current Integra Type-R (2.0 liter, 220 HP @ 8000 rpm, 152 lb.-ft @ 6000 rpm), while the lower performance but more comfort oriented models (24T, 24S and 24TL) use the same engine as TSX.
    A good comparison would be that between couple of Japanese Accord trims (a lot of people think TSX is European Accord, but in fact, there is no sport packaged Accord in Europe at this time),
    24S: Sport Suspension probably similar to TSX, 2.4 liter, 200 HP/171 lb.-ft. Not offered with manual transmission though. Weighs almost as much as TSX (slightly less due to less standard features).
    Euro-R: Sport Suspension, screaming engine (K20A) with 8500 rpm redline, offered with 6-speed manual transmission only (also shared with ITR, and closer in-between ratios compared to TSX). Euro-R is about 250 lb. lighter, but surprisingly, well equipped (nearly all conveniences are standard, unlike a Type-R).
    I will not be surprised if K24A was de-stroked (or K20A was slightly bored and stroked) to develop a new engine (let us call it K22A) capable of revving to 8000 rpm and beyond to potentially deliver 240-260 HP.
    That said, I may be one of the few who feels that it is time to make use of electric assist to get more power along with the use of either K20A or K24A in the TSX.
    IMA would be another way to get more from the K24 (in lieu of forced induction). However, an IMA system would also add more weight, which would hurt acceleration. Thanks to the extra torque, the vehicle might feel stronger off the line, but outright acceleration might be a break even deal.
    Weight gain is guaranteed, but if IMA is used in AWD layout, as showcased in Acura RDX (which used K24A as the base engine), it eliminates the need for an AWD system which would also add as much weight or possibly more.
    As far as acceleration is concerned, it will not be a break-even deal. For instance, current TSX has a (top end) weight-power ratio of 16.3:1. Even if hybrid powertrain added only 25 HP at the top end, a weight gain of over 400 lb. would be required to make it a breakeven deal. And even if it does, the output characteristics of an electric motor (strongest in the low-mid range) will still improve the weight to power ratio in low-mid range.
    And if TSX-S could get the AWD 240 HP IMA-K24A unit (as in RDX), and Acura manages to keep the weight around 3500 lb. or less (better than Audi Quattro or BMW 325ix, with way more power and torque), things can get very interesting.
    Speaking of the RDX, Motor Trend is reporting a 2007 release with some cheesy sketches. Basically, it's a rehash of the same stuff that we saw back when the concept was shown. They cite 250 horses for the combined drivetrain.
    They also report that this would be second hybrid in the Acura lineup after the 2005 RL. I doubt any of this is truly accurate, but that makes it sound like a hybrid TSX is not in the works. Makes sense, given the (relatively) low production numbers.
  • himilerhimiler Member Posts: 1,209
    The Accord will have to go with IMA before the TSX will. Economics of scale, and such.
    Economies of scale is a non-issue in this case. TSX and Accord share the basics anyway. Volume production/sales of one car helps the other.
    varmint,
    I feel positioning of next TL will probably give us a better idea of any additional possibilities with the TSX. If TL Type-S goes into mid-30s, there will be enough room for TSX Type-S. Now, whether it will be using IMA or a high revving K-series (like) engine remains to be seen.
    It is possible, however, that all future Acura Type-S model could have IMA, and RL w/IMA could be a Type-S as well. I doubt base RL will make use of IMA.
    This assumption is based on the premise that I read somewhere a while ago, Acura supposedly getting a hybrid performance sedan, and a hybrid light truck (CRV? Odyssey? Pilot?) for Honda. I believe this was from an article in TOV several months ago.
    Sport Compact Car dynoed TSX to get: 179 HP / 156 lb.-ft (nearly all of the peak torque appears between 2500 and 5000 rpm before tapering off).
    That is quite good for an engine rated at only 200 HP/166 lb.-ft, unless the drivetrain losses are that low (only 6% loss for max torque).
  • nowinonowino Member Posts: 1
    Saw a red one this am. Looks good to me. Smallish, like the Integra, but classy. After reading about the car only two negatives come to mind. Lack of low end torque and wide (40') turning circle. Wife has an Infiniti I35, about the same turning diameter. It's a pain to maneuver in cramped quarters. Has anyone driven this and can comment from personal experience?
    Nowino - Can't speak from personal experience, but I would have to agree. Such a wide turning circle can be a problem.
  • heymistaheymista Member Posts: 22
    I've noticed Hondas tend to have a wider turning radius in general compared to Toyotas. I think it may due to the fact that the suspension is more tuned for performance. The TLS has 40ft turning radius, and I've driven it the past 2 years without much of a problem. I noticed the TLS has a wider turning radius than the TL by a couple of feet. I'm getting a TSX next week. I think since the car is relatively short, it be pretty easy to maneuver.
  • damorminodamormino Member Posts: 82
    When the TSX was first announced, Acura said that a DVD rear seat entertainment system would be available as a Dealer-installed accessory. Has anyone heard anything about this recently? Every time I ask, they put it out a few months. While on the subject, they also said there would be a hands-free cellular phone kit for the TSX. (They did this for the 2003 MDX too and still haven't delivered.). Incidentally, the cell-phone kit and DVD Entertainment systems we both announced for the 2003 Honda Accord as well - then similarly delayed or withdrawn. Anyone have information on these items?
  • parker19parker19 Member Posts: 59
    I am waiting for a tsx I ordered. It's been 3 weeks and they said it would be about 4 when I ordered it though lately they are being less sure about the arrival date and my current car has died.
    Meanwhile, another dealership has the same car in and will knock off $200.
    Would you back out of the other deal? Would I still be able to get my deposit back?
  • anonymouspostsanonymousposts Member Posts: 3,802
    We had a similar situation with our 03 Accord EX-L coupe. Put a deposit down at one dealer who promised a delivery date of December 14th. Then it was going to be early January. By then Honda had 3.4% on the Accord and if we tried to get that the dealer wanted MSRP. So we took our deposit back and bought elsewhere. They should let you out of it if the car isn't built by the date they promised.
  • blueguydotcomblueguydotcom Member Posts: 6,249
    Unless you signed something saying you're taking the car no matter what, then just demand your cash back and buy the cheaper car.
    Simple...
    You don't owe the dealer anything, but $200 is not much of a difference. If you think it is more convenient to get the car serviced at the 1st dealer, you may want to stick with the deal. You may want to call the first dealer and tell him you have been patiently waiting, and someone else offered you the exact car for less. You may get him to match the price. I've noticed there is a big difference between service departments in Acura dealerships. I've noticed that the quality and the prices of service work vary greatly between Acura dealerships. I had an 2002 TLS and a 1992 Acura Vigor. My wife had a Lexus, and I found Lexus to be much more consistent as far as providing great customer service. Also the dealer has some control over giving out loaner cars. Since the only other Acura dealer was 70 miles away, I did not really have the choice of using different dealers. I've watched others have difficulty getting loaner cars, while it has never been a problem for me after buying my 3rd Acura with the dealer. They have even given me a car they were trying to sell that the sales manager was using for his personal car when they did not have any service loaners.
  • tomskilvtomskilv Member Posts: 4
    Someone asked about DVD in back seat. I test drove one in Las Vegas this week that had it installed.
  • bwoolley1bwoolley1 Member Posts: 4
    Definitly buy from the dealer you do your service at if the difference is only 200 bucks. Its worth it to see a smiling sales person who knows you and a GM that knows you bought from their store.
    At our Acura the sales people will wash your car whenever you want if you bought from them. Just a nice little bonus.
    As for the TSX-S, expect a super charger
    LOL. As if you ever see the GM or salesperson when you take a car in for servicing. Drop the car off, hop into a shuttle/courtesy car/friend's car and then return later that day or the next day to get your car.
    Most car nuts would vehemently disagree with a dealership carwash as a perk. In fact everyone I know who truly cares for his/her car will not allow a dealership to wash the vehicle. Check out Freshalloy or Bimmerfest and see how many carlovers allow the dealership lot guy to make swirl marks in the paint of a luxury car.
  • kdshapirokdshapiro Member Posts: 5,751
    YTD - car wash bill $0.
    YTD car wash bill if I brought it to my dealer to have it washed. $0 + inconvenience.
    Maybe its different where you live, but I always see the sales guys at Acura and they are friendly and helpful.
    As for the car wash, its automated, obviously it will never be as good as a personal handwash but its better then nothing.
    I guess I'm just lucky to live near a decent Acura dealership, but I get the same great service with my BMW too.
    I'm against auto car washes with the brushes. A touchless car wash won't hurt anything though. Won't get it very clean either but it won't be as dirty as it was when you left it.
    When we had the drought restrictions, heavily restricted water usage. That year I brought my car to the car wash, no damage. While I am a clean car fanatic I can only do what I can do with my car. If it gets swirls in the car wash so be it.
    Life is too short to worry about a couple of swirl marks on my car.
  • fedlawmanfedlawman Member Posts: 3,118
    I can't remember the last time I hand washed a car...
    I've had my Acura dealer wash my TSX three times already this summer, and it looks just fine.
    In a couple more weeks, I'll put a coat of "Klasse All-In-One" on it. That'll remove the swirls and give it a high gloss finish.
    I used "Klasse" on my Buick almost two years ago and the finish is still slick and glossy. I guess if I was really picky, I could wax more often, but I just don't see the need.
    I'm all for automatic car washes, just not the ones that use the brushes. Swirl marks can be buffed out but those brushes can leave little scratches all over the car.
    So my saga to buy a tsx continues ... i put down a deposit .. dealer said 4 weeks give or take ... its been a bit over four weeks ... just got an email from the dealer saying it will probably be at least another month .... reasonably can i expect to get or ask for something for the extra wait ... there's no point in walkking cause i would just have to wait all over again ... is this a case of sucking it up and waiting
    With a supercharger? I seriously doubt it. Forced induction has never been a strong suit for Honda (except in a couple of JDM sub-liter engines). IMA is far more likely, but I'm not sure if that really fits the performance mold, either.
    IF there is a Type-S, the changes probably won't amount to much more than a 20-30hp bump (from a higher compression ratio, forged internals, and a higher redline), sticky tires and bigger brakes.
  • stretchsjestretchsje Member Posts: 700
    They can't make the engine rev higher, since it's already a very long-stroke engine. The pistons would be moving too fast.
    A V6 won't fit.
    So, they can either bore out the current design and try to make it larger displacement (costly), or they can supercharge it.
    Or, my going theory is that Acura has no interest in a Type-S for the US.
    Or, as I mentioned earlier, destroke the engine to displace 2.2 liters, and have it rev higher. A typical Honda 2.2 liter engine, at 8000 rpm can develop 240 HP which won't be bad for a Type-S. A rumor has been floating around that S2000 will become S2200, and I wonder if the engine could be shared with TSX.
    There's a blurb on the the S2200 in this month's C&D. Looks like the S2000 will become the S2200 this Fall, complete with more torque (same HP) at lower revs, new ratios in the tranny, and a more-comfortable suspension tuning (which has me worried).
    That would absolutely be a killer engine in a TSX-S.
    Stretch - I think boring it out would bring in another set of problems. The 2.4L is already fairly big for a four banger (not huge, but big enough). With that much mass pumping that fast...
    OTOH, I would never bet against Honda being able to make an engine rev faster. The piston speeds are an issue, but it's also something Honda is very familiar with. I don't expect they would go that route, but I wouldn't take it off the table, either.
  • gee35coupegee35coupe Member Posts: 3,387
    There's only so much revving and displacement a 4 cylinder can have. I know Honda hasn't done it here, but it may be time for it to start.
  • id888id888 Member Posts: 12
    I think I read somewhere (here?) that the designer of the K24 engine in the TSX has the pistons moving at 22 m/s (F1 levels).
    Regarding a higher performance TSX, the folks at Honda are slowly dropping the Type S designation. The 2004 TL will have a 6sp "HPT" variant with some extra bang for the buck. It's unclear to me right now what that will be... I think IMA is unlikely.
    That would be a quick switch. Less than 2 years ago, Acura marketing was keen on making the Type S designation the equivalent of M power or AMG. They figured Type R cars were too "unrefined" for the Acura nameplate. Type S badges were fairly popular with the aftermarket crowd (I've seen them on MDXs of all things), so I thought the plan was working.
    Yeah, I thought Type S was a pretty cool idea, and I was looking forward to switching into a Type S TSX in a few years. I think Acura is a nameplate in search of an identity right now.
    The thing that gets me is that the new TL will be released in a few short months, right? Well, very little data is available about this machine on the net. However, I did hear about dropping the Type S line while I was looking for TL info, though. It's unclear to me whether changing the name from Type S to HPT is going to have the impact that Acura may be looking for. I would just stick with a brand some people know (Type S), and run with it.
  • midnightcowboymidnightcowboy Member Posts: 1,978
    is the current rumor. The 2004 TL coming out the end of August is supposed to have all the new features the TSX has plus some. 6-speed or 5-auto with 280 HP. Supposed to be $33-35K
    Hadn't head of the "HPT" designation until now.
    I also wish for a Type S or Type R TSX but haven't heard any rumors yet. However, the european version of the Accord is still stouter than the USA version "tart" Accord.
  • xplorx4xplorx4 Member Posts: 621
    What's the difference between a "Type R"-designated car and a "Type S" model?
    When I hear "Type R", the first thing that comes to mind is "coffee-can" muffler.
    Type-R: Track tuned chassis with performance brakes/rubber etc. Considerable trimming of fat (weight), minimum convenience features. Ride comfort is not the priority. Extremely limited volume (in the past, Type-R engines have had some manual labor involved).
    Type-S: Sport tuned chassis (usually) with additional power over regular (usually 'touring' trim), but ride and comfort is still a priority.
    Xplorx4 - You might think of it this way.
    Type S - Take a nice with all trimmings and add some sporty flavor to it.
    Type R - Take a nice car, toss out everything but the seats and make it a purpose-built racing machine.
    If only it really worked out as well as it sounds...
  • li_sailorli_sailor Member Posts: 1,081
    The type R assessment is right on (which is why I would never consider one in the RSX or TSX, both of which I am considering).
    However, the "more sporty flavor", I think, understates type S a bit. A more powerful engine is the primary meaning to me...the RSX-S has 25% more HP (200 v 160) then the RSX.
    Now...if only the TSX was a hatchback, I'd long since be driving one. Oh, and a bit off the price, too ;-)
    It kills me that I'd have to pay $5k more to get all the "nice stuff" that the TSX has and the RSX doesn't...and I'd have to give up the hatchback, too. And get 2 doors I don't need.
    BTW...I notice that sales for the TSX are 2,275 so far this year (through May). I had heard that they planned on 15,000 for 2003. Seems like they are well under target...what month did it hit the market?
  • talon95talon95 Member Posts: 1,110
    The TSX hit the market in April. The 2,275 units were sales FOR May, not through May. Sales through May were 4,111. Sales through June were 6,032.
    Projected sales is 15K for the year. So, Acura needs to move out atleast 1250 units per month. In three months, they have managed 6032 units, which is 60% better than the required pace, not under.
    My apologies...I must have columnar dyslexia...read the wrong column.
    So, the first 3 months are:
    2,275
    1,836
    1,921
    6,032
    That projects out to just over 18,000 for the year, so it looks like they'll be close to their estimate.
    Well, they only have 9 selling months, so that's 1,667 a month to hit 15,000, not 1,250.
    They're still over, but by 21%, not 60%.
    Of course, if the TL steals sales, that could change come September.
    9 months by calendar year, not by model year. I don't see why Acura would project sales by calendar year, nobody does.
    Launch of TL may affect some sales of TSX, and at that point it may actually even out to estimated pace. However, TL will also be, atleast 3K more expensive (for the base, model), while not being a touring sedan (unlike TSX which is a sport sedan). When (and if) the 'sport' version of TL arrives (TL Type-S) a few months down the road, it would be even more expensive to start with, putting it in a completely different marketing class.
  • kyfdxkyfdx Moderator Posts: 271,621
    In this case, I don't think they are estimating 15000 just for the 2004 model year. My guess is that you won't see a 2005 TSX until September or October of next year. I believe they are estimating 15000 units every 12 months, regardless of model year.
    regards,
    kyfdx
    Ok, I see...I thought it was calendar year.
    What I'm really thinking about is whether there's any reason to think that they might start selling the TSX below sticker anytime soon...if they were to raise production or for any other reason.
    At this point, it doesn't seem likely. Any thoughts?
    Good grief, it IS selling below sticker in southern california. if you want a tsx below msrp just call a socal dealer.
    So CA? Good grief, that's a long drive for me from NY :-)
    How much below sticker? Is this a recent change?
    To my knowledge (not vast on this subject, I asked one dealer and I've read several ref's here and TMV), it's pretty much going for sticker around here.
    They may not be able to send too many more. You know there is an import quota from there. That's why they make the higher selling models here.
    Acura could make TSX right here as well. But then, that possibility also depends on demand of Accord and TL (whose production line is probably getting revamped for the 2004 TL). However, CL is gone, so there must be some additional room in there.
