Visitor Agreement.
Fully loaded I'm carrying 8,000 lbs. My 1997 Yukon just will not do the job(burned up the clutches in the rear end) I will let my wife drive the truck to and rom work( 2 miles) and only use the truck when I go fishing. I'll probably tow the boat 25 times per year. I really like the 4-door which means Ford is the one. I'm thinking v-10 since it is quieter and most of the driving will be only 2-4 miles/day in town(so I'm not too concerned about gas mileage)The 3.73 with the limited slip seems right for my application since this really isn't a work truck and most the ramps I use are pretty good. Im also thinking automatic with the v-10, just for the convience. Finally, the F-250 seems adequate for my needs. Can someone help this fishing fool out on his truck needs? F-250 vs f-350/ V-10 vs diesel( anyone know of any problems with the v-10), rear end??/ any help would be appreciated. Ask about info on Ponce Inlet fishing, Cedar Key, Jupiter Inlet, I'll be glad to share w/ you
Skipper of " The End of The Line "
Good Luck...
I think the Ford is a more stable towing platform than the Chevy: 10 years newer chassis.
hope this helps
Eric G
If the numbers you quote are accurate (14,000 pounds, 4.56 gears, 10mpg), your dad gets better mpg than the Ford V-10. With my camper on, my 99 SD V-10 weighs 12,000 pounds. With the 4.30, I get 8.5-9 at 60-65. I just made a 450 mile round trip this weekend, including a climb through a good size mountain pass, and averaged 8.7. I could probably get right around 10 on flat roads at 55 mph.
From what you indicate, the 454 gets better mpg carrying more weight with a lower axle ratio. I'll admit, that's pretty impressive.
Before I bought the truck, I expected 10-12 empty and 8-10 with a load. Those estimates were right on. I will admit that the numbers I've been hearing with the 3.73 are higher than I expected. Then again, I'm not sure I believe all of those numbers. One guy said he was getting 16mpg. I'll buy 14, but not much higher. Regardless, because of the load I haul, anything taller than the 4.+ was never really an option.
I had the 351 in my 92 F-250HD 4x4 with the 3.55. I had friends that had similar year Chevys with the 350. They always got a litte better mpg than I did. The best I ever did was close to 15 on the hwy. I think I had a tail wind. My average hwy was a little over 14.
well the numbers are pretty much what I quoted. He does a lot of long highway, flat land driving in South Texas. In overdrive at 70 mph, I think its turning about 2200 rpm (don't quote me). If he does a bunch of shorter trips (5-30 mile variety), then he gets about 8-9 mpg. But most of his driving is the long stuff. I know he's pulled a couple of big trailers that pushed the total combination weight over 20K, but i never asked him if he checked mileage.
The 454 is an old engine platform (like Dodge), but its got the newest combustion technology working for it (unlike Dodge). It has an incredible powerband. This thing will outrun a powerstroke in the same weight truck from a dead stop. the 454 doesn't have the diesel's torque below 2000 rpms, but its not in that range very long anyway. Its got a great torque and hp curve from 2000-4500, and I kid you not, this 14000# truck will push you into your seat once the engine revs past 2500. The Ford V10 has a great curve also, its just not "quite" as wide as the Chevy's. But most definitely a workhorse, too, as it puts out the same hp and torque as the 454. I couldn't really advise or say anything bad against either engine. Like you said, for a long long time, the Chevys and Fords have had similar power, and the Chevy's always got a little better mileage. Seems to still hold true today.
I do think the cummins is a great engine But I also think the ford is as good. The new psd has more power in 99 & with the six speed & the new auto they have it will tow about any combination you want.
Mike
clinton
Remember, your Cummins was rated at just 160 hp and 400 lb-ft of torque. A Cummins with stick is now 235/460, and a Powerstroke is 235/500. That extra 75 horses will make a HUGE difference for you when you're at the top of the powerband, and the extra torque will get your trailer moving much better. It will come down to your own comfort and personal tastes as to which brand you pick.
Your biggest choice will actually be transmission, not engine or truck. If you don't mind clutching, both the ZF 6-speed in the Ford and the NVG5600 6-speed in the Dodge are overkill - they will handle any situation, and have excellent gear spacing.
kcram
Community Leader/Smart Shopper Conference
Chris
Couple questions: What kind of real world difference is the 24 valve going to make? are they going to need adjusted more often than the previous models? is it really that much more efficient (having problems finding EPs on these)
Second, the warranty. Cummins backs this for 100k. Thats all good, but the dealer I came from said that they'll take a 500k motor and recycle it. Now those arent rebuilt and put back into the lineup, are they?...Naw, they wouldnt do that, right?
The only dilemma in my buying decision is, of course, the Ford. The 2 guys I know that have them are leasing...and really dont care about warranties because they plan on throwing the fish back after 3 years...Would that V-8 Eat itself alive after 3 years of tuggin? probably not. How about after a 72 month adventure in Payments?!!!
Sounds like you've got the truck I'm leaning towards buying. I've done most of the research and ready to test drive the Dodge and Ford this weekend. I drive 10 miles to/from work 4 days a week and on weekends load up the 10'6" Bigfoot Camper and head up to fish the lakes - as high as 7500' elevation at times. In the winter, 2 1/2 months of duck hunting sometimes driving in muck, but no snow. My first choice (I think) - Y2K 350 SD V10, Supercab, 4X4, 4.1 LS. Any comments? Have you had any regrets about your choice in truck or options? What options would you recommend?
I would definitely give the duallys serious consideration with that camper. In addition to adding 1,000+ pounds in payload capacity, it also eliminates alot of the sway. I'm very satisified with the ride with the camper on, but I still think I will put some Rancho adjustable shocks on next Spring.
The camper package is a must, as are the trailer tow mirrors. I'd also get the trailer tow package. Although I got the Class IV hitch option, I haven't done any towing with the camper on yet. It's my understanding that I will need to get a Class V hitch since my camper sticks out the back of my truck by about three feet. If you plan to tow with the camper on, you might check with a place that puts hitches on before you fork out any money to get the Class IV hitch option.
If you decide to consider the diesel, it's always worth giving the Dodge a good test drive. The guys with the Cummins swear by them. If you're definitely going with a gas engine, it wouldn't hurt to test drive a Chevy. I believe they are coming out with their redesigned 3/4 and 1 ton models. They've always made some good gas engines that tend to get a little better mpg than the comparable Ford models.
It's best to approach the purchase with an open mind. I openly admit to a Ford bias based on previous experience with Ford, so I haven't really given Dodge or Chevy serious consideration in the past. Ford likely has me as a customer until they sell me a bad truck or until one of the competitors clearly proves an advantage over Ford in the model truck I am looking at buying.
I get 20 empty. I hall a 30 ft fifth wheel with atip-out .at 75 i avereage 12 per gal see if a power stroke can do that.
5.2L (or 5.9L) Quad Cab 61/2 ft bed or the F150 Extended Cab (both 1999). Any info or other suggestions?
It is on the newsstand; I actually bought it last week. TL's usually objective, reliable reporting had one really bad flaw right in the beginning of the Ram test. They mentioned very early that the NVG5600 was the "first 6 speed manual in a standard pickup". Hmmmm. I guess the ZF 6 speed that Ford has used in the Super Duty line behind the Powerstroke since January of 1998 doesn't count, right?
kcram
By the way, congrats on the Community Leadership. You're not just a moderator, you actually drive one of these things!
Thanks - this is actually the most fun part-time job I could ask for
The most objective mag right now is Open Road, by the few truck freaks at Road & Track. It's strictly for vehicles with a driveshafft at both axles, but they are not the least bit afraid to say something is bad. They tested a Ram 2500 Cummins and a Ford F250SD Powerstroke last year, and it was the best comparison I've read in ages. Now if only they published it more than 4 times a year and offered subscriptions.
kcram
Only two choices folks.....
Ford or Dodge?
GM is lost in never never land...out to lunch I say...the big sleep...cheap, cheap, cheap.......
we could argue Ford or Dodge all day long, but Chevy? Why bother? Not in the same class!
Of course that's just MY OPINION, you all are entitled to it!
The Dakota Quad Cab (full 4 door crew cab body style) will begin production in just a few months. Click here for more info. I happen to like the Dak over the Frontier in this configuration simply because the Dak has some bed space between the Cab and the wheelwell - if you look at the Frontier, the cab cut actually interrupts the body flare of the rear wheelwell.
kcram
I have a 99 QC 4x4 w/Cummins Auto 3.54LS. I tow a 6K# trailer through the mountains of KY on a regular basis. Things to consider when deciding between the Cummins Diesel and the V10...
I got 14mpg towing on the interstate and with a 35gal tank, I can go 490 miles before fillup. I'm "guess-timating" that the V10 would only get around 7mpg towing. That's only 245 miles per tank full.
Not every gas station sell diesel and most of the ones that do, locate their diesel pumps off to the side. It seems like I'm always "positioned" the wrong way (with my trailer behind me) to get to the pump. The plus side to this... I've become a pro at backing a trailer around corners!!!
If you drive the truck for every day use, will the "rattle" of the diesel bother you? I can't go through the fast food drive thru anymore because they can't hear me!!!
I've been told in these postings that it's not good to turn a diesel on and off a lot (e.g. quick run to the carry-out).
All-in-all, I like the truck. The diesel takes some getting used to, but I still prefer it over the V10. My only two complaints... I wish I had the 4:10 diff instead of the 3:54 and the Auto Trans. needs a 5 speed auto instead of the current 4 speed that was designed for the V10 and not the Cummins.
Good luck...
Brett
If your ride is more for pleasure than work go gas. Believe me I've tried both and the noise of a rattling diesel is something you can't hide.
I personaly agonized over my last purchase for quite awhile. I needed a truck with space(quad cab)that I could drive every day to work in comfort. But I also own a 5th wheel that weighs in at 95k loaded. I eliminated the Ford based on engine noise and cost. This left me with Dodge(I considered Chevy/GMC but just didn't like em.)which wasn't to hard of a choice seeing as I had previously owned a 94' RAM 1500 w/5.9L 2WD that served me well. When I factored in the average miles per year I would put on the truck would not exceed 10K, I figured the extra 4K for the diesel would be hard to justify. I finally bought a 99' 2500 quad cab 4WD w/5.9L SB automatic. I have pulled the camper four times and have found the engine/tranny do very well at about 60 mph. The gas mileage locally is about 12, towing is about 9.5 mpg. It's a matter of individual choice and how much you want to spend. I specd. mine with a special request 3.73 gears. Most sales people dont know what is available but service managers do. I've had mine for 9 months now with no problems and a whole lot of enjoyment. And I can still use the drive thru's.
good things to think about however when the dealership told me they would give me 19k on trade (for my 98 no door dings polished every weekend, synthetic oil only snug topped, everything but leather SLT 4x4 with only 11,400 miles) I burnt all bridges and told them to kiss my @%#. I plan to swap my gears to 4.56 and take my beating at the gas pump, what two less mpg's when your only getting 11...
we'll also look at Dodge but am concerned about the lack of "real" beef of chassis, drive train components. we will, however, have-a-look. don't know what happened to Chevy... but we've a '92 2500 and had nothing but problems (just after the 3 year warranty decided to expire... those engineer's are truly amazing... the "plastic" parts last JUST long enough!). Chevy's really got to do something BIG to pique our interest. they seem to have completely missed it in regards to serving the larger RV rig requirements of towing that have come to pass these past few years. we also personally don't believe that any new design ought to be purchased in the 1st model year of availablity (& especially at these rather ludicrous price levels)... sorry GM.
Ford owned less than 10% of Cummins between 1993 and 1997. It was strictly to solidify their relationship with Cummins because Ford used Cummins engines in their heavy trucks. When they sold that line to Freightliner, they also sold back their stock to Cummins. They have never, nor do they have any intention of owning 51% of the company. Cummins has no intention of selling 51% of their company. Whoever told you this has lied to you. Click here for the CORRECT information.
kcram
(who is just dying to know where this rumor came from, as it has been around for YEARS, and really wishes it would go away...)
T.
Also remember you have to make your own mind up, people will tell you both trucks are great / crap / not worth the sheet metal they're made with / worth their weight in gold etc.
That said you will get a lot of info, but if you can tell us a little more specifically why you want / need a truck we can target the info to those reasons.
For instance I have no problems with the dodge front end - but I'm 6'2".
Like Andy said, if you give a little more info, you will probably get more useful information, especially in regards to engine size and axle ratios. Both of those impact mpg, power and towing ability.
The question is which axle? is the 4:10 that much worse on fuel than the 3:54?
Most of our trailer towing is 50/50.
Also, we're confused as to the "little" items to request from the dealer that are NOT in the brochure.
Is the ford SD PS basically the same fuel consumption?
Should we wait for the new GM?
email:mclennan@compusmart.ab.ca
