14814824844864871306
    Could I get a Dodge Dart or a Duster with a 340 and 3X 2V or would I have to build that?
    Yeah, that would be the '68-69 Dart GTS, which came with something like 275 hp with the 340-4bbl, and 290 with the 6-pack. There was also a stripper model called the Swinger 340, which might have also offered the 6-pack.
    The Barracuda offered it, as well.
    I think by '70 though, the 340-6 pack might have been dropped, leaving just the 4-bbl.
  • uplanderguyuplanderguy Member Posts: 17,078
    Mr. Shiftright, not a lot of '60's cars had disk brakes. I remember even most full-size GM's didn't have them 'til '69 I believe...at least not as standard equipment.
    edited December 2011
    I'm in the minority I'm sure...grew up on Chevys but here's a '60's car I'd love to own:
    http://files.conceptcarz.com/img/Studebaker/64-Studebaker-hawk-R2-DV_11-SJ_014.j- - pg
    The emblem at the bottom of the front fenders indicates Avanti power, which also means the car has either a 4-speed or Powershift trans (PRND21) and disk brakes, and full gauges including a tach.
    And only 1,767 built between August and December 20, 1963.
    And from what I've heard, you were actually better off without a lot of those early disc brake systems. Supposedly many of them weren't so hot, went out of adjustment very easily, etc. My '69 Bonneville had pretty good disc brakes, but by that time, I think they pretty much got the formula worked out for them.
    Although in the Studebaker hobby, disks on the '63's and '64's are considered desirable (they were same as used on Jags), they only had a single master cylinder unlike Stude's drum brakes at the time, and a friend who has worked on Studes for fifty years has told me many times to avoid them if I don't want to spend a bunch of money on them.
    The 340 was a classic case of the under rated (power wise) engine.
    HP numbers were simply measured at a lower rpm than a higher rpm would produce.
  • bhill2bhill2 Member Posts: 2,627
    I am somewhat surprised (but gratified) that you listed the '65 Corvair Spyder. That has always been a secret desire of mine, but I assumed it would be not very reliable and would be a nightmare to maintain. Incidentally, you specified a 4-speed. Did they come any other way? I pretty sure you couldn't get an automatic in them.
    I wouldn't want a big block in a 60s compact. The big block cars are very nose heavy and they often completely overpower the chassis. I don't want to be lighting up the tires every time my foot slips a little on the gas and I don't want to be steering the thing with the gas pedal around corners.
    I think you could get an automatic with a '65 Corvair convertible. They wouldn't be too hard to maintain--a few simple tweaks would fix most problems. I think the "Corsa" was the turbo version, and I'd probably pass on that---the turbo system was quite primitive and badly engineered---near useless. I suppose one could tweak that, too, but at what cost to engine life I dunno.
    I don't much like turbo or supercharging on big American V8s, at least not how they did it in the 1960s. Big block V8s should have twin-turbos IMO. Modern S-chargers are pretty slick, though---very compact, intercooled and not fussy at all.
    My current car is SCharged, so I'm no luddite.
    Ah, I see now. When you said '65 Corvair Spyder, the 'Spyder' indicates a convertible. From '62 to '64, Spyder referred to the turbocharged model. You are right that in '65 they went to using the name 'Corsa' for the turbo model. You certainly could get an automatic with the other available engines.
    All '65 turbo Corvairs were Corsa models, but not all Corsas were turbocharged. The base Corsa engine was the four-carb 140 hp engine. Corsas were coupes or convertibles.
    Final "Spyder" models were '64's..the old body style...coupes and convertibles.
    Among the mainstream manufacturers, here are '60's cars I'd like to own:
    1) '62 Tempest LeMans coupe V8 (I know, a mechanical nightmare)
    2) '69 Corvair Monza Coupe, 4-carb 140 hp (I know, Corvair owners will say that a 110 is easier to maintain)
    3) '65 Pontiac Bonneville Sports Coupe, bucket seats and console
    4) '65 Impala SS Coupe--not a bad angle anywhere on the car IMO
    5) '67-70 Eldorado
    6) (and this totally blows out-of-the-water my typical aversion to huge cars)--'65 or '66 Cadillac Fleetwood Brougham. Stunning instrument panel, stunning interior, clean bodysides, those wonderful wide rocker moldings and individual "FLEETWOOD" letters...an awesome, U.S. luxury car of its time.
    I remember reading an old Popular Mechanics, which tested a few engines around 1968 or 1969 to see how much hp they really put out, compared to the claims. The Mopar 340, rated at 275 hp gross, actually put out something like 245 hp, which incidentally is about what it put out once they started rating it in net hp.
    I don't remember much in the way of specifics of the other engines, other than one was a Ford big block and one was an Old big block in a 4-4-2. The Ford engine put out something like 75% of its advertised hp, which is about the rule-of-thumb in the gross-to-net conversion. The Olds was a pretty big liar though, only putting out around 60-65%, as I recall.
    I guess that doesn't mean ALL Olds engines were like that, though. There could have been enough variance in them that Popular mechanics just got ahold of a bad one?
    I also remember reading some Mopar enthusiast magazine that compared three Darts. One had a 340, one had a 383, and one had the 426 Hemi. As I recall, the 383 gave no advantage over the 340, and just made the car harder to handle. IIRC, they mentioned that even the 440 wouldn't be much of an improvement, as the weight would mostly offset the extra power. The Hemi was definitely quicker, but was even more of a pain to drive.
    Just out of curiosity, what would be a bigger chore to deal with...a 1969 Nova with a 396 or a 1969 Dart with a 440? I've heard that the Nova was actually designed from the get-go to be able to handle a big-block fairly easily, while it had to be shoehorned a bit into the Dart. But, IIRC the Chevy big-block is heavier than a Mopar big-block wedge (but not the Hemi)
  • texasestexases Member Posts: 11,183
    I don't know that I'd make much of a distinction between those two big blocks, both would be tight to work on and nose heavy. I'd go with the small block in both (340/350).
    Also, I'd go with a modern front disk brake setup (calipers, booster, plus dual reservoir master cylinder), that's one upgrade that's pretty easy to do.
    And the Dart will rise again!
    Oh I think they'd both be a chore---they are such torque monsters with big bear clutches. It's just very hard to drive them with any kind of finesse, and I like a car that one can drive smoothly...all this clutch slipping and gas-stabbing...and how your head jerks back and forth as you let up or give gas...I don't much like driving them beyond a few hell-raising burnouts and a yee-haw or two. Then I'm done.
    That "corsa/spyder" thing certainly is confusing :) Okay, I want a 1965 CORSA convertible 4-speed non-turbo, white with red upholstery.
    Nice thing about the '65 on up Corvairs, you don't need disc brakes---the drum brakes on that car are about the best ever put on an American automobile.
    Could you get a 440 compact Dart from the factory, or was it one of those custom jobs like Mr. Norm in Chicago? I know that Mr. Norm actually worked with Chrysler in developing some of their muscle car combinations though. I do think that would be handful, especially in wet or winter weather. The GM 396 was a nice engine if you wanted something like that back then.
    I show a GTS 440 Hardtop in the books.
    I think Mr. Norm created the 440 Dart, but later, production was moved elsewhere. However, I don't think it was in-house. I believe they started with a 383 Dart and shipped it off somewhere, to have the 383 removed and the 440 put in, and other mods done. Even though they're both big-blocks, the 440 is a raised deck, so I guess that would make it just wider enough to cause complications.
    I don't think you could get power steering with a 440 Dart, although I have seen later conversions with it, so I guess it's possible with some shoehorning.
    I just found this on google:
    http://musclecars.howstuffworks.com/classic-muscle-cars/1968-dodge-dart-gts-440.- htm
    It says that about 650 1968-69 Darts were converted to 440's. I wonder then, how many had the 383? I've read that either 50 or 75 1968 Darts were equipped with the 426 Hemi.
    Somehow, I have a feeling that there are more Hemi Darts running around now than there were when new!
    Quite a few big block cars in the 60s deleted power steering and AC, and lack of both these would make a 60s hardtop unbearable to drive in some climates today---add to that the massive heat from the engines and transmissions and it's not all that pleasant.
    I remember reading that with the original Dodge Dart Hemi, they even went so far as to make the rear windows stationary (even on the hardtop), and the front windows were raised and lowered like what you'd do on a school bus, to save a few pounds on the lift mechanisms.
    They also used the lighter, cheaper seats out of the A100 van, rather than normal GTS buckets or even a bench.
    IIRC, they also came standard with racing slicks and a sticker on the dashboard that said "Track use only", "Not for street use" or something like that.
    Ah well, that was all good marketing. If it's a street-legal car with lights and bumpers and safety equipment then the "track only" business is hogwash.
    I can't personally compare them, but I had always heard that the 440 wedge was a better driver than a 426 hemi back then because those hemi's could be a bit tempermental?
    Yes, they can be ornery---don't idle well and they overheat.
    Yeah, very temperamental. I've heard they would go out of tune fairly often. They also don't like to just loaf along at low rpms, either, so most cars with them are geared so that they sound like they're screaming, even when they're just idling along. I always notice that at car shows, when I see a Hemi car go by. They usually sound like they're being floored, even when they're not. All that racket is fun in small doses, but I imagine it gets old after awhile.
    i recently drove a '70 Cuda AAR with a 340 3X2V, power steering and disc brakes, and I quite liked it. Very easy to drive around but it could get up on its hind legs when it needed to. Sounded great, too. Only $80,000, so line up. Yeah, yeah, matching numbers, correct color of battery cable harness/holder attached to the right shock absorber bolt--the whole fanatic crazy routine.
  • fintailfintail Member Posts: 58,783
    Yellow Vehicross, 79-83 Z car with amusing period bodykit, headlight covers, etc.
    That "corsa/spyder" thing certainly is confusing Okay, I want a 1965 CORSA convertible 4-speed non-turbo, white with red upholstery.
    Having browsed through an online brochure of the '65 Corvair, I can make it even more confusing. The 140 hp non-turbo engine was standard in the Corsa, with the 180 hp turbo engine optional. The 140 hp engine was optional in the other models.
    Now here is the interesting part; in the Corsa neither engine could be paired with an automatic. However, if the 140 hp engine was specified in another model, you could get an auto.
    My dad bought 2 Corvairs in the 60s. First gen Corvair van for his business and a second gen Corvair Monza for my mom. The Monza had a powerglide automatic with a tiny "T" handle shift lever on the dash and it must have had the 110 hp engine because I remember the 110 emblem. The van was a delivery vehicle which was included with the business dad later sold and the Monza was given to my sister after she got her driver's license. She was still driving it until when she got her first new car....1974 Mazda RX3. The Corvair had been a reliable durable little "sporty" car but the Mazda was a real dud. :lemon: I would never have bet that Japan was preparing to conquer the auto industry. That was back when it seemed German cars were the next big thing after the muscle car era. Japanese superbikes were a hint of things to come.
    RX3s were neat little cars but they were gas hogs par excellence--they had a nasty tendency to backfire and the early rotary engines were not very sturdy.
    A 1 to 2 beer car yarn:
    I had an obscure Mazda---an RX4 wagon--and I really liked that car. It was quite upscale vis a vis a 70s Honda or Toyota. Had trouble with it though, and it was the first rotary engine I ever took apart. Came to find out that they required a very high degree of precision for rebuilding and I wasn't equipped to do that. However, I sold it at a profit anyway. I later heard that local auto racer Jim Smoot parted out the wagon but rebuilt the engine and put it into an MGB, with the Mazda transmission. Rumor had it that that little sucker moved right along!.
  • jljacjljac Member Posts: 649
    My Uncle had a 1960 Corvair and liked it a lot, but it was very cold in the winter. I think it had a gasoline heater which he did not run because it did not work or he did not run it because it killed his gas mileage. Either way, he was scrapping ice off the inside of the glass so he could see out.
    Many friends who owned Corvairs seemed to like them, and the main complaint seemed to be that they leaked oil. BTW, it was strange to hear how quiet the turbocharged Coavairs were at the drag strip even without mufflers. The turbo broke up the exhaust noise.
    The Corsa turbo uses a blow-through system and the stock carburetors really restricted boost (and leaked a lot under pressure). I'll betcha any Corvair at a drag strip has been extensively modified to handle any extra boost. Some people have used side-draft Webers and even SU-type carbs---and 4bbl Rochesters!--successfully.
    If I had a Corsa, I'd certainly put in an extra oil cooler, electronic ignition, and different carburetors. If I had a turbo model, I'd add some kind of knock sensor.
    That '65-69 Corvair styling has stood the test of time IMO, and is pretty roomy inside to boot, all things considered. My aunt had a new navy blue '65 Monza 2-door hardtop, full wheel covers but blackwall tires, Powerglide (no "P" position, just R-N-D-L!) and the 95 hp engine (sigh). Very sharp car though. She bought it right out of nursing school.
    Hard to believe they were down to 6,000 units for the '69 model year. Them's Studebaker numbers!
    yeah, GM cut off the Corvair's blood supply.
    It's a shame the Corvair was left to wither and die, but I'm sure GM never made much money on it. It had to be priced to compete more or less with other compact cars, but I'm sure it was a lot more expensive to develop and produce than something like a Chevy II, Valiant, or Falcon.
    Yes I think the Corvair was Ed Cole's brainchild. Gutsy move at a time when Ford and Chrysler were cheaping out on "compacts" which were just new bodies on very old tech.
    Of course GM was the King of the Hill in 1960, and could afford to be lavish. They still hadn't made their marketing blunders nor entered into the extreme profit-killing deals with the UAW. Ford was still reeling from the Edsel debacle, where they lost a bundle of money, and Chrysler was still the perennial #3 and looking for inspiration. Foreign intervention wasn't a big problem yet, and gas mileage and emissions barely a consideration, if at all.
    Iacocca revived Ford, and Chrysler made a big comeback in the mid/late 60s, and everything was pretty groovy in Detroit until the 1973 gas crunch and the subsequent miscalculations by the Big Three.
    Detroit sure went up and down up and down in the 70s/80s/90s didn't they? But finally their rigid management style and terrible labor relations got the best of them.
    The Corvair was just one more promising Detroit car that was left to die on the vine because of under-development.
    I read on Wikipedia that there was a 3rd-generation Corvair in the works, although it never got beyond a clay mockup stage, and was killed in 1968.
    I wonder what it looked like? I tried searching, but can't find anything. Wikipedia mentioned it looked something like a 1973 Grand Am. Also, supposedly the THM350 transmission had been modified so that it could be used with the Corvair, so that would have finally given the Corvair a 3-speed automatic.
    Still, I wonder if something as big and beefy as a THM350 would have robbed too much power from the small Corvair engine? And, I guess as time went by, it would have been increasingly difficult to meet emissions standards. I think air-cooled engines tend to be "dirtier" and harder to clean up than water-cooled, although I don't know if there's any truth to that.
    Looking back, maybe it's best the Corvair was retired when it was. Had it lasted into the 70's, I'm sure they would have made a mess of it!
    The Corvair platform was shared with no other GM product, so I'm sure it was expensive to produce..especially with volume down those last few years. It was built at Ypsilanti, MI, where Novas were also built, but when the '69 Nova took off, GM moved Corvair production to a tiny corner of the plant. GM didn't even bother to give the '69 Corvair the locking steering column all their other '69's had. All the Corvair got was the square ignition key.
    I'd still really enjoy one though. If I weren't into Studebakers, Corvairs would be the next old car I'd own.
    Yeah, the Corvair probably was at a cost disadvantage vice Mopar and Ford, and that is likely why it was essentially replaced with the Chevy II. However, I'm wondering if the reason GM initially went rear air cooled engine was because at the time the VW Beetle was emerging as a very popular import. It kind of was to the 60's and early 70's as cars like Corolla and Accord became a few decades later.
  • ab348ab348 Member Posts: 20,620
    Sometime in the late 1970s my older brother showed up at our house with a '65 Corvair Corsa. Kind of rough but rust-free. He put it in his garage and there it stayed for about 20 years. Finally, after he retired, he did a backyard resto on it. Rebuilt the engine himself, including the 4 carbs, and did a good job on the mechanicals. He refinished the body himself and that was probably a mistake, because the paint job was the best he could do but in all honesty left a lot to be desired. But it looked fine from 20 feet away. It was white with a black interior, which was in pretty good condition and needed only a few things done to it.
    He finished it, drove it for a little while, and pretty much lost interest. I dunno if it was his age or exactly what that led to that. He kept it for a few years with little use, before finally selling it. The thing with Corvairs is that they don't tend to bring very good money, and he was happy to get what I think was $5K for it. I was in it a couple of times and it seemed like fun to drive.
  • wevkwevk Member Posts: 179
    Still looks good to my eye (and so does the Corvair!:
    http://www.youtube.com/watch?v=59voKreB2j8
    Actually the turbo from the factory is a "draw through" design as can be seen here:
    http://www.corvaircorsa.com/turbo02.html
    Here's couple of nifty ones modified for blow through:
    http://www.corvaircorsa.com/binnie01.html
    http://www.auto-addiction.com/66-Corvair.htm#The%20Power%20Train
    I owned a 1964 Spyder convertible back in the day.
    that's right! I was looking at modified cars I can see now. I never owned a Corvair turbo so never did play with a stock one. Well no wonder the stock turbo didn't wake that engine up very much!
    Seems like with that stock setup you'd need very high rpm to get much boost.
    I always wondered why they dropped the "Spyder" name...plus, I think it looked cooler as a nameplate on the car, than "Corsa". Wonder if they came up against copyright issues?
    They used the Spyder name again as a performance/appearance option package on the Chevy Monza in the 70s. And I don't think anyone ever held a copyright for the automotive use of spyder/spider. Far as I know it's a very old term first used to denote a small, light weight horse drawn carriage.
    I've read that (as was often the case back then), there were functional improvements made to the '66 Corvair compared to the '65, and the Corsa and turbo engine were still available for '66 (Corsa had upgraded trim also, over a Monza). But, those overdone (IMHO) colors of Marina Blue and Butternut Yellow started with '66. In a Corsa, give me an Evening Orchid '65 with white or black interior. OK, some say that color is feminine but I love it and it is a one-year-only color!
    I used to think that my '67 Catalina was butternut, until I saw a '67 Delta 88 convertible in butternut. The difference was extreme enough that it almost made my car look white!
    Here's a pic I took of it, with my car just poking into the lower right corner, as a reference for the color:
    Turns out my Catalina's color is actually called "Montego Cream". Chevy called it "Capri Cream". GM must have been on a Mercury kick that year! FWIW, Olds called it "Cameo Ivory" while Buick just went with "Ivory". I guess the marketing department was running out of ideas by the time they got to Buick!
    I kinda like that evening orchid color, too. To me though, it seems like more of a luxury car color, or an early 60's color, so maybe that's why it didn't last? I Looking through the paint charts, it appears only Chevy and Pontiac offered it? Pontiac called it "Iris Mist". Interesting that Cadillac, Buick, and Olds didn't offer anything like it by that time. I could picture a Cadillac, especially, looking really good in that color.
    A major drawback of a draw through system is that a waste gate cannot be used. The waste gate would have to be downstream of the carburetor and would vent excess pressure in the form of fuel/air.
