This is the 3.4L pushrod V-6 by the way.
a car can perform great in their road tests and not be recommended if it has sub par reliability (lot of german cars fall in this category).
the new malibu did well in consumer report's road test (the Max will be reviewed next month and it will probably do well too) but it's not recommended because of reliability. the new malibu is no different than other cars in its first year. the accord and camry in their first year also took a hit but not to the point of being below average though.
i like to know where consumer reports states that every toyota in the lineup is superior in its class?
you say their surveys are flawed but don't elaborate on it. fine. their road test evaluations are based on their judgments which you may or may not agree with. but, with exceptions, their road test evaluations pretty much mirrors findings from other publications - GM sedans don't do as well as those from toyota and honda.
i do agree with your premise though. don't dismiss a car because CR doesn't recommend it unless it does really bad reliability wise (like the first years of the ford focus). because for the most part, cars fall in the 98-100% in terms of reliability and it seems silly not to consider a car becuase it may be at the low end of that range.
i believe CR will have a road test of the G6 in addition to the max in the next issue.
Consumer Reports does not assign reliability ratings to vehicles... the people who respond to its surveys do. And for what its worth, the Ford Focus is one of CR's best performing small car models, and recently earned a recommendation because its reliability improved after the first few years.
~alpha
As for their recommendation of a few domestic vehicles, what does it matter? My point is that domestic cars that will run without trouble for years are given low ratings, and the ENTIRE TOYOTA LINEUP is reccomended. Sure most of them may be good cars, but is everything they make superior? I am only saying don't treat the rubbish they spew like it is sacred text. It's not.
And that's only a heads-up for people interested in the G6 or other cars CR has given low ratings.
The Sandman :-)
~alpha
For one thing, I thought the Grand Prix was one of the American models they gave a high rating, along with the Buick Regal. As for whee they get their information, it doesn't matter. It's flawed. As ocmike3 said, a lot of the surveys are filled by people who think CR is the Bible for anyone buying anything. Not only that but the surveys themselves have problems. They ask you if you've experienced a problem, but they don't define a problem as something extremely minor, or as something major. And that's just for starters...
I dont treat CR as sacred text, but it is one source of valid information. If you look at the information published by JD Power for 3 and 5 year long term dependability, you will find that the lists for the most reliable makes and models are the same as those on CR's. The way I see it, both shoot from cuff. When models arent reliable, its reflected in the data. And I dont really see a bias against any make. Check out Nissans recent reliability ratings in CR. They arent nearly what they used to be, especially the Armada, Quest, and Sentra which receive full or partial black dots. Also of note is that in last year's CR Auto Issue, the MOST reliable sedan was the Buick Regal, and this was highlighted.
Personally, I wouldnt NOT purchase a vehicle because it got a low reliability rating. However, on the whole, the fact remains that the domestics still are not at the levels of Toyota/Honda in terms of reliability. And Toyota/Honda are not without fault.
I still recommend reading the explanation of the tables. It doesnt make good sense to go into an argument without having a basis for the debate.
~alpha
Now if we could return to actually discussing the G6, that would be appreciated.
Motor Trend said in their COTY issue that there will eventually be a G6 coupe replacing the Grand Am. Has that been confirmed? Does anyone have an idea of when it's scheduled to debut?
Agreed!! And thanks!
The reasoning I'm posting really, is to say that I saw my first G6 on the road today. It was pretty cool looking, well, what I saw if it was at least. It flew by me pretty fast -- I tried to catch up but didn't feel like flinging the groceries around the back seat. I would like to see more of them on the road, as I think they will help change people's minds about domestic cars.
~alpha
where i still see a significant gap among cars is in their design. IMO, a passat or an accord are clearly a step above the G6 in this regard.
sorry pat, i couldn't resist!
With Nissan the Armada, and Quest had some black dots so I understand how they would mark way bleow average reliablity and on top of that Nissan has had lots of problems with build quality with their new new truck plant in Mississippi.
Getting back to the G6(yes we will talk about the G6 now) I like the look of it for the mid-size class anyway. Its sleek but not boring looking and not overstyled. GM finally styled a winner with Pontiac. As for not seeing any G6's its Christmas time who's buying a car at Christmas time anyway? Most people are shopping for presents for their family members. I have seen at least 7-10 G6's in Jersey.
http://www.thecarconnection.com/index.asp?article=4733
The G6 is a huge step forward for Pontiac. Even though the interior and exterior could be a bit more exciting, I find it very clean and competitive.
Honda Accord LV V6 3.0L 240HP/212PF
Ford 500 3.0L 203HP/207PF
Intrepid SE 2.7L 200HP/190PF
Mazda 6 S 3.0L 220HP/192PF
Its a good car, its just not a GREAT car, IMO.
And while I realize the information isnt perfect, I dont know of any source thats better. JD Power is even less scientific, if you ask me, but nonetheless, the two publications are the only ones besides word of mouth that gauge reliability. And in most cases (I'm talking longer-term, not initial quality) the two ratings are very similar.
dieselg4..... all though torque is listed as "lb-ft" you would say "foot-pounds" in speaking of it, not "pound-feet". Just a tech jargon FYI.
~alpha
I also have seen that the GTP model for 2006 will use a hydraulic power steering system instead of electric power steering system.
CT collects 6% sale tax from full amount, excluding trade-in, but including GM rebates and GM card rebates.
For example, MSRP $31,000, dealer deal $28,000, trade in $2000, makes $26,000. $3500 GM rebates and $3000 GM card rebates reduces price to $19,500 before fees, title, and license plates; however, the sale tax is still $1560 - 6% from $26,000.
My wife and I bought a leftover 2004 Buick Regal GS about 2-3 weeks ago. Loaded demo, with 6,800 miles; however, dealer added 60 months / 60,000 miles GM warranty (Major Guard) essentially for free to compensate for the mileage. The prices and taxes were close to the above amount.
Re: Conumers Reports, I take their suveys with a grain of salt and understand that most is subjective opinion.
However, too boxy shapes also are not attractive. For example, most of 1990-s Volvo.
Any case, I do not think the difference in tastes is between boys and girls. At least, my wife shares my tastes.
BTW, do you own 2004 Gran Prix or 99 Regal LS?
Is there a 4cyl offered-
if not what G6 is considered entry level-
What size is the v6-
anybody know how it places with insurance rating? In the chicago area how much do you think I could get a decently equipped one for? thanks
For insurance rates it is better to call your insurance company: the rate depends very much on your zip code, age, driving history, and in many states even on your credit history. Given this is a new car, I'd expect the insurance rates to be close to GrandAm's ones for the same person.
This dealer also had a lot of Grand Ams too.
I pay about $350 a month including tax (6%). The car is a loaded GT without the panoramic sunroof.
I probably got worked - I think that they could have come down a little more.
BUT - did I say - I love it - had it three months and it is still putting a smile on my face.
Are the grills actually steel mesh?
Also, I can't swing the cast wheels. How do the standard wheel covers look on the car?
#04111
I get a daily on-line update from CarConnection. Today they mentioned the G6 2 door and convertible that will be introduced. But they referred to the G6 as a "compact car", where I thought it was an intermediate.
