Visitor Agreement.
I have no problems changing the oil myself. Thanks for the help...
Ford hasn't purchased any Honda engines. In fact, I have an electronic copy of a memo where they recommend 5W20 as the oil to use for engines going back to 1992 or 1993.
I don't think Honda makes the 5.0L V8 for Ford now do they?
I'm pretty sure Ford would like to put the blame for all of those 3.8L V6 head gaskets on someone else...
Now Ford does work hand in hand with Mazda. The new 2.3L I4 engine is pretty sweet and is already in the Focus found in CA, and a couple of other east coast low emissions required states. I guess when production ramps up, the same engine will be available nationwide for the 2004 model year cars.
(BTW, this is the same 2.3L you get as the base engine in the Mazda 6)
FWIW,
TB
Pennzoil
Vis@ 82F (D445) 48.0 cSt
Vis@ 212F (D445) 8.6 cSt
Pour-point (D97) -49 F
Vis. Index (D2270) 158
Flash point (D92) 445 F
Quaker State
Vis@ 82F (D445) 45.5 cSt
Vis@ 212F (D445) 8.1 cSt
Pour-point (D97) -27 F
Vis. Index (D2270) 151
compared to:
Mobil 1 Synthetic 5W-30
Vis@ 82F (D445) 56.0 cSt
Vis@ 212F (D445) 10.0 cSt
Vis. Index (D2270) 167
Flash point (D92) 430 F
Actually, the 5W-20 Pennzoil is fairly close to the Mobil 1 5W-30 full synthetic in specific characteristics, even though the Viscosity Index is a little lower. It looks like the Pennzoil starts with a slightly lower viscosity base stock, but that is to be expected for a oil in that temperature range.
The API Gravity (D287)specification for the Pennzoil is 35, and not listed for the Mobil 1. The Mobil 1 has a High Temperature/High Shear (D4683) of 3.08 @ 150 degrees centigrade, but this isn't listed for the Pennzoil.
You probably can't go wrong with the 5W-20 unless your driving in the summer time in the southwestern US.
Dusty
Dusty
From every aspect, USA is the biggest market for most goods regardless of it's either a car or oil.
Before entering US market, every item is well tested and used in actual life 'for a long time' from where it's manufactured.
5w 20 or 0w 20 has been throughly tested and used from late 90's in places where people regard what you call 'the severe driving conditions' in USA is just a dream.
Just imagine what it would be like driving in the far East.
After extensive usage from 'tens of thousand real life results' without any major problem, some Japanese makers even considering using 0w 10 for some of their hybrid models.
Don't make fool of yourself! and use whatever oil the manual says or whatever you want without any concern!
a guy from the far east.
I use Honda 5W20 in my '02 CRV to satisfy the warranty. This oil was made by Mobil.
When I purchased the new bottles they are made by Exxon apparantly Honda switched to Exxon. My observations from a chemists point of view: Oil is a few shades darker {no big deal}, oils seems much more viscous [now thats a big deal] To check I compared a part bottle of Mobil versus the Exxon 5W20. I used Gardner Holt bubble tubes. You fill the tubes with the testing media to a certain point cork the top to a specified line and compare the bubbles by turning the tubes against known samples of stable liquids at a specific temp. I used 77 degrees F. I do not have the sample liquids so I checked the two samples against each other. The Exxon is about two and a half bubbles slower which means the oil is more viscous. Two and a half bubbles is considerable so I don't believe its a + or - QC spec. Did Honda change the specs. to a heavier oil? Did some problems occur with the thinner viscosity made by Mobil? I am wondering.... but, I will definitely check the next lot I purchase.
It seems highly unusual that the two samples would have different viscosities if they have the same API rating...
It seems almost IMPOSSIBLE that they would change the oil in the bottle to something that is NOT what the LABEL says it is.
Even more unlikely is that ANY change was due to problems -- what are the odds that there are problems and none of the Honda/Acura forums here or on the wider WWW haven't noted anything unusual???
You might check over at bobistheoilguy.com as they've got some "oil geeks" who can probably explain it to ya, but I'm pretty sure that how fast they drip at 77F doesn't mean anything.
Besides 2.5 bubbles slower out of how many 10, 100, 1000? I have to admit, I'm am not familiar with your test method.
However it is possible that two "room temp" samples behave very differently than they will at operating temps.
TB
yes, ExxonMobil Corporation is merged as it gets. they may have decided to cut down bottle designs. I doubt it means they have decided to cut down formulations, they probably have four times as many SKUs now as when they were two different companies
The standard for the upper range is 212 degrees F.
The lone exception is any oil that is "0W" (zero-W). Obviously oil cannot be zero weight (no viscosity). Even water has viscosity. In the case of "0W" motor oils, the lower limit is actually that of 5W, but the pour point is considerably lower.
Dusty
I believe any synth 30w product would be able to duplicate these figures. But, M1 is very available over the counter.
