Also, if turning on the A/C creates so much cold air on the windshiled that outside air condenses, then have you tried changing the vents to blow out the dash and under the dash (instead of above the dash).
What I don't have as an option in my 6 is to have defog without A/C which sometimes is an adequate(and most economical) solution. Do all new cars force A/C when in defog mode? All my other cars had the option.
No, warped rotors won't damage the car.
I have almost 3,000 hard miles on my 6s with no warping.
Mark. : )
Also, should I assume that the dealer put a layer of wax on this car? It still beads and has a beautiful shine.
Are you washing it regularly in cold water after a spirited Zoom-Zoom-ing trip? If not - I'd hope its just a faulty set and the dealer should replace it.
I just washed and applied the wax. Then, a few days later, did the same thing. Then, a week later, did the same thing. Then, a month later, did the same thing. Looks better each time.
Mark.
And 8900 for a 2001 Pro ES - wow, that's crazy depreciation. Just to try and sell it yourself, you may want to modify the deal (if they lied about the brake thing and you have the right to!)
Think about it!
I would much rather sell my own Pro myself, as and when (soon, I hope!) I buy a new car.
Thanks for ANY advice
Bob LaPadura
Sometimes an auto glass shop can polish them out. I had a similar problem a while back. As a rough test, they said if you can catch a fingernail on it they probably can't take it out. I'd take the car to an auto glass shop and have them look at it. By the way you described it, they should be able to fix it. I wouldn't mess with it yourself, as you might make it worse.
RAIN-X, here I come (I understand that's helped, or should help, right?)
An easy way to find out is to swap the front wheel from the side that it pulls to with another wheel.
Thank you for the suggestion, however I have already been down that road ! I started out with Enkei after market rims , and went back to the factory 17 inch wheels with stock Michelin tires. Then I upgraded to a better tire Michelin Pilot A/S sport 225/45/ directional tire . I have not , however rotated the tires front to back, and now I am curious if this could solve the problem. It is worth a try before I head back to the dealer. I am still curious to see if shortbuskid got his issue resolved, because as I said before , my problem is identical to his, except I have to correct to the left to compensate for a right hand pull. I hope to get a straight answer soon !
My nightmare continues...I took it to an independent alignment shop where they proceeded to make only minor adjustments within the specifications set forth by Mazda. Sixty bucks later and several tire rotations and I was right back to where I started. The car still pulls right and I have to hold a left correction...the drift is severe. I marched straight back to the dealer where I bought the car and they got there top technician with 15 years Mazda experience to ride with me and now they are revisiting the problem...it may have to be written up and referred to the engineers at Mazda....I am not looking forward to the next few days...right now I am in standby mode, just waiting to have the pleasure of driving my otherwise perfect Mazda 6s 5speed again someday...hopefully...this could be their last chance as far as I am concerned....one possible idea is your head warranty guy could contact my dealer as well and maybe collaborate to solve both our problems...I did hear of another person that is experiencing the same problem at my dealership, along with the new guy who added his comments today...I am thinking it might be chronic in some vehicles...hopefully not an epidemic !!!
1. I start the car.
2. Put the clutch in.
3. Shift into reverse.
4. Apply gas/release clutch.
5. Car moves backwards.
6. Reapply clutch to better control backward movement.
Upon reapplying the clutch, theres a very muted scritchy sound that lasts for a split-second. The best way to describe it would be that it's similar to the sound your tranny would make if you shifted without pressing in the clutch, only 100 times softer and nowhere near as abrupt. Indeed, one would hardly notice it at all unless they had the radio off and extremely acute hearing.
So has anyone expereienced this too? It's no big deal (I hope!) but it happens every time I do it and wanted to know if it was happening to anyone else.
Now a question about the software upgrade for the check engine light. After I had the update my 6s would occasionally rev very high after starting for the first time in the morning and then bottom out and even stall. Back to the dealer they couldn’t recreate this, even after letting it set over night, but said that it might be due to the type of gas (premium) that I was using. I’ve been using regular but still have this happen once in a while.
This has not been a BIG problem and I love driving the car, especially on long drives from GA and through WV. It loves the winding country roads!
Has anyone had false alarms on their M6s? I've got the 6s with the perimeter upgrade on the alarm but no motion sensor. Unlocking with the remote kills the alarm but I'm going to start annoying the neighbors.
Other than that, I love the car. I've put 2000 miles on it in the last 10 days since I got it and have had no other problems. On highway trips I'm now getting 27.4 mpg @ 75 mph.
Also in the headlight structure what is the purpose of the light next to the high beam. It seems not to light up at all. Is it the fog light? thanks
Mark.
1.) Headlights... Does the "top" of the light halo hang a bit low on your cars? I did not know
this about these cars when I test drove them, but I think the headlights can be improved. Is there a height adjustment on these so they can shine further down the road? I don't want to have to use my brights all the time...
2.) Locking/unlocking. Why does this car not have automatic locking? Even a Ford Focus has that. Is there a setting I'm missing? I have yet to read my owners manual cover to cover. Is this a feature on the more expensive "S" model?
3.) The readout on the center console (near the amb temperature readout. I can see there are other indicators near that light (eco, a fan "scale", etc. Do they light up on the "S" model? I can only get the indicators "AC" and the recirculation symbol to light. Maybe that is the only indicators that light up with manual a/c?
4.) I seem to have a slight pull to the right when in the right lane due to slope of the road (I think). It does not happen in the left lane. Is this a common thing in the Mazda 6?
