http://www-odi.nhtsa.dot.gov/cars/problems/tsb/
I have the same problem- all 3 outlets not working and the fuse is OK. I checked the fuse with a meter. I used an LG charger for a long time with no problems and also a Garmin charger from time to time. Any advice is much appreciated.
I have an 06 SL AWD that is 14 1/2 months old and has close to 10,000 miles. I'll have them check it at next oil, unless someone thinks it should be checked right away.
Anybody else have this problem?
Otherwise, no problems in the year since my mystery roof leakage was finally fixed (that was a saga!)
Is my transmission failing? also had one engine mount replaced a few months ago, coud they have messed up something?
Dealership says part should begin with a NI?!
Also, can someone show me how to remove the front door panel. I'm going to try and go in there!!
Sorry - don't know on the Hankooks.
Michaelscai - can you tell us in more detail what the problem actually was?...
Also anytime I put any packages or items inside the car, they tend to rattle like crazy no matter how I secure them. Is the ride that stiff? With no packages in the car there are very few, if any, rattles or other noises. It sure is annoying.
thanks.
Jim
where I bought it. Ya know, the same prople who told me to contact Nissan directly. Oh well, Guess I'm stuck driving with this normal abnormality.
Stacy
I HAVE HAD THE TRANSMISSION IN MY 2004 AWD REPLACED TWO TIMES IN 34000 MILES---STARTING TO ACT UP AGAIN--SURGING WHEN YOU ACCELERATE FROM STOP OR PASSING ANOTHER VEHICLE--DEALER TELLS ME THAT THEY HAVE NOT HEARD OF ANY OTHER PROBLEMS WITH THE TRANSMISSION IN THIS TYPE AUTO--WOULD ANYONE WITH THE SAME TYPE PLEASE SEND ME A RESPONSE
I never took it back to the dealer cause I knew there was'nt much they could do. I had read the complaints about the Murano and the brake noise prior to buying one. The 06 I rented for a long trip last year was REAL bad with the brake noise but I loved the car so much I had to buy the 07 regardless of the noise.
Hopefully with time the noise will stop with your Murano as it did with mine.
I have a 2007 with the same problem, I just left the dealership a few minutes ago after having my first service done. They looked into the brake squeal issue and there is a technical service bulletin issued by Nissan for the problem. They have to order some type of shim kit from Nissan which they advise will take care of the issue. They didn't stock it so I am waiting for it to come in later this week. But it appears that the dealer and Nissan were aware of the issue.
I agree the squeal is very loud.
:shades:
