A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Good to hear there is something going on about replacement of the defective hoses. The oil I use is SAE 5W-40 Rotella made for/by Shell. I strongly believe we all share the same oil bases since major oil companies are implanted worldwide.
Concerning cracked engine cylinder sleeves or castings, this was true 35 years ago in the glorious days of Castrol HD-W40 castor-oil
I think the risk of using 0W-40 is to loose the oil film in areas where gravity applies. Some engines had oil retention pockets in the past. I'm not shure this is the case today.
The 2.5L CRD did not have the emissions control system. I have a 2003 2.8L CRD that doesn't have this feature and only uses 10 OBDII codes out of 33 like the recent vehicles (numbers came from the dealership).
You can disconnect the vacuum line going to your egr valve and your ECU will not see it. This will also stop the black smoke coming out of your tailpipe. It's quite simple to remove your egr valve and clean it. It's fixed by two 13mm nuts onto the top of the exhaust manifold and two more 13mm nuts to the 'concentric' water cooler (on mine).
http://www.tweddle.com/techinfo-europubs/
I didn't buy from them, 250USD for a CD is plain madness :lemon:
Are you saying that you can disconnect the EGR by disconnecting the vacum hose and the car will not notice? If so, will it impact performance positively or negatively? Can anyone else out there support this? If this is true then it sounds like the answer to the EGR problem.
Then again, maybe I misunderstood. Sounds too simple to me.
:confuse:
Farout
I really like having a special unique Jeep, but I am really anoid that we were and are a test market, and we paid a price to be a test market. I think DCX owes us a rebate or something to use as a down payment on our next DCX vehicle. Are you old enough to remember the Chevy Vaga, or the Ford Pinto? There were others also I just can't remember them just now, but a discount to be used on the next vehicle was given out to compensate for the problems. I feel if enough CRD owners started barking it just might happen to us, maybe, perhaps, at least I think they should.
Farout
As for ULSD, I do not see any advantages in using ULSD other than extended oil life (less corrosive) and higher cetane. ULSD will have less BTUs (=lower fuel mileage) and cost a few cents more per gallon.
Regards
Dzlmyster
Yes in my case, no in yours. My engine is the prototype of yours and I don't have lambda sensors or air-massflow metering. My egr valve is located on the exhaust side of the engine and the vacuum line that drives it is used for setting the vriable pitch vanes of the turbo on yours. I have a fixed turbo.
By getting rid of my egr valve all my shifting hesitations went away and mileage is back to normal, like when the truck was new. But, there is a but, there are variations in the low sulfur diesel I buy here. I usually get between 20 and 25 mpg driving in the same region, same traffic, and I can't yet explain what is making so much difference.
Friends of mine have TDIs, DCIs, HDIs and I also own an older type of diesel. I seem to be more subject to mileage variation, but again, the ECU in our Jeeps works differently than others. Our ECU tries to regulate the fuel in such a way that for a given sollicitation it "must" meet a given performance and thus injects more fuel than it should. This may be the factor that makes bad fuel even worse when compared to the factory 'achievement' that is memorised in the computer's map.
It's like running the 100 yards when you're 20 and having to do the same when you're 60 just because you are still the same person. It doesn't always work :sick:
Farout
If this CRD was going to be used any longer I would not be as reluctant to try different things. But because we were only a test market for DCX, I expect warranty issues to become SOP for DCX to question anything that goes wrong with the CRD. I also expect to see DCX contact the first time buyers of these CRD's and make some kind of offer as a discount on buying a new DCX vehicle. I am really burnt to a crisp that I was used as test without my knowledge! The more I talk with a few others who bought this CRD they too are feeling the same way. Time will tell, if DCX will own up to this false marketing. I hope so.
Farout
I read that the new VW bug Diesel is being used as a rental car at LA airport. They have a slug of them and they meet the 207 emissions standards.
I think DCX is missing the boat big time by not having a Liberty that will pass the emission standards for 2007.
By what the tec's say about the best thing to use for oil is the 0-40 and if that's true, than maybe we do need super oil......hope not.
Farout
I agree with many of your feelings. Let me first say that I'm conscious of the warranty issues with B20, but having read up on biodiesel I believe that any problem caused by B20 will be due to a defect in its refining, not an inherent problem. The local oil companies that sell B20 are good, local companies in farming areas, selling mostly to long-time customers and I expect they will stand up if they sell bad fuel. Having said that, I'm not encouraging anyone to use higher than B5, only saying it works well in my CRD.
I have not seen the 0W40 anywhere except one single online store I found using Froogle. The only safe oil I can find in stores is Rotella-T 5W40. I consider this fair game as it is effectively identical to Mobil 1 5W40, which is listed in the owner's manual as OK.
I too am concerned about DCX support and potential issues down the line. I wonder whether I will have EGR valve problems at some point, reading everything on here. I also want the shudder to go away forever. I am generally very happy with my CRD but already debating whether to drop it while it's still in great shape and get something better supported, such as a diesel or gas pickup, instead.
OFF with no weight on passenger seat
ON with approximately 10lbs or more on passenger seat (my briefcase when it's full)
OFF with an adult in the passenger seat (the lightest adult I've had in that seat is about 150lbs, so I don't know the cutoff weight)
Twocycle2
Today, I put Amsoil Synthetic 15W-40 into the crankcase. It specs out very closely to Mobil 1 5W-40 oil. The Amsoil has a slightly lower cold pour point and the Noack vaporization rate is 50% less than the Mobil 5W-40.
How does it run? Nicely. The engine is quieter and smoother at idle and the turbo spools up quite quickly thank you, and with a little less lag than before. Wish I had a real oil pressure gauge to see if there is any difference in the reading.
I will be traveling to NYC and New England in early June so I will let you know how this oil impacts on my fuel economy.
Mileage before mods w/5k boat in tow 15hwy now 16. w/o tow was 26-28hwy now getting 30-32 at 60mph, before 23-24 now 26-27 at 70mph.
- Balance the fresh air with the exhaust to limit the oxygen content before and after your catalyser measured by the lambda sensors. Post injection is used here not to bring more power to the piston but just to keep the catalyser at the proper working temperature. This is why there are two sensors. The second sensor after the catalyser tells the ECU that the corrective action (post injection) was sufficient or not.
- Protect the engine from burning it's own oil in case of a turbo bearing failure (leak) by closing the duct. The ECU always expects a maximum rpm value and will close the flap in case of overrun.
- Bonus is to stop the engine in a more pleasant way, but it was not put there to do so.
This thing really has a brain
Tom.
Just turned 3000 "troublefree" miles on my CRD. I thank the man upstairs each day after reading all the posts on here.
I am contemplating when to change my oil the second time. First time was at 500 miles. Currenly running Rotella T 15W-40 and have not used any oil in 2500 miles. I am going to run one more change with Rotella T 15W-40 then switch to Rotella T Synthetic 5W-40. I am curious if fuel mileage will improve with synthetic oil. Current fuel mileage is 27-28 mpg highway (corrected). I did find out my speedometer is reading about 3 mph fast and the odometer is reading about 6% low. At least the errors are good for preventing speeding tickets and keeping the miles low on my CRD.
Finally got around to checking motor mounts for tightness. Yup! I tightened the left upper motor mount nut and the clunk is gone.
Thanks Europasusan.
Tom.
I'll go first
05 Sport 16k, no trouble so far! Build date July 05
I hope there are alot of us out there!
Trouble is, I only have about $6,000 to spend. What used vehicle could I buy that seats at least five, can tow a 2,000-pound GVWR trailer and may come that cheap? Suggestions welcome, and thanks.
Tom.
Also no matter how I drive it, highway or around town, only get 20 to 22 mpg. See some on this forum getting higher, 27-29???
Now have 12,200 miles, changed oil at 3,600 and 11,989, Rotella 5-40.
