If not, can anyone recommend an after market solution?
1. BMW Flashlight Socket:
Part no. 61-13-8-352-336 - $10.50
2. BMW Aux Power Adapter
Part no. 82-11-0-004-073 - $8.25
The power cord is behind a plastic panel on the left hand side of the glove box. Pull out the panel with a small screw-driver or finger-nail, if you don't have the hook tool.
Connect the power cord to the Flashlight Socket and push it back into the slot. You have your power outlet.
You can connect the Aux Power Adapter to power your portable devices in the glove-box; or get the rechargeable flashlight (@ $24) for emergencies.
I just called up the service centre and he told me that I can use the button to close the visor but need to manually pull back the sliding shade!
This sounds bizarre. Is this true? If not can you guy splease post how you use your panaroma roof, particularly how you simultaneously close both an open glass roof and the sliding shade.
When your shade and roof are in the complete open position make an extended click (like your one-click power windows) and the roof should retract. Another click should retract the shade.
When you go back to the dealer, try this out on the Demo X3.
One other thing you might look into...the one-touch power windows are a programmable feature. You can de-program the one-touch feature for a particular door. Check if there is any programming option for the roof & shade. The only thing is that they have to hook your truck to the computer. If you have not got your complimentary programming, use that opportunity.
Best of luck!
What a pain!
I am considering an X3 along with a few other SUVs. Does anyone have any comments on its off road capabilites ?
I am looking to do a little beach and light woods use along with everyday driving.
I have search and really can't find much on this and the dealer is not a source I would trust.
Lou
As for 06 engine, it would seem likely the horsepower upgrade to both the 2.5 and 3.0 in the 325 will also be in the x3.
Someone in the car review section mentioned not finding non ammonia cleaner (recommended to her, maybe by a dealer) to work well on the leatherette. I think the manual suggests a mild soap solution, so I use ivory bar soap watered down and followed up with clear water and it seems to work fine on my black leatherette (Ivory flakes at my stores are a detergent base, which is why I'm using the bar)
-Paul
I've read my BMW magazine and read the sections about accidents and survival and just curious as to how the X3 has done in testing.
If I didn't pick a BMW, what other cars would you recommend (side impact airbags required).
-Paul
I found when I drive more than 70 MPH, I can hear the wind!
It's that common or I should call dealer?
I usually hear nothing below this speed.
The fix is a simple warranty matter, where the dealer uses a product to clean the door seal, then applies a kind of lubricant. This has solved the problem on my X3.
But how about Wind Noise, it's normal that I can hear the wind at 70MPH without open moonroof?
I believe that the A/C system its the same on the 2.5 or 3.0. Mine it's the 3.0 and I live in Puerto Rico, where we know a little bit about hot and the A/C systems up to date works excellents also in Auto mode.
X33.0, White/Gray Montana/Automatic
I was surprised to find that no two tires had the same pressure. I was about to fill the pressure based on the door post numbers...then I thought that they seemed a little high. I consulted my manual and realized that there was a 6psi diff between what it should have been and the door post. And I thought that there must be quite a few people who must have made the same oversight.
The door post has 32psi (front)and 38psi (rear)- This is the recommended psi for 5 adults with baggage, it is 29psi (front) and 32psi (rear) for 4 adults.
The lower psi made the ride much, much smoother.
One question, though....is it not normal (due to the weight of the engine) to have slightly higher psi in the front than the rear? Why is this opposite for the X3??
I too have the howl that sounds like blowing on a coke bottle - but only at 82 mph. It doesn't bother me yet because I never go that fast around the city.
Almost every BMW recommends higher pressures in the rear... My 325i is recommended at 30F/35R.
It is easy to see the controls, features and power before leasing.
Not sure what the advantage you have in leasing unless the real resale value ends up being less than the lease company projected as the future residual value.
However, it's a fun ride, I kinda like the clean lines and simplicity inside, but after i see my friend's RX330 i feel like he got more for his money.
The 2005 3.0s will be much cheaper because of lots of new standard or no cost options.
Given that, comparing overall the BMW X3 vs RX is apples to oranges, if you prefer an SUV that rides/handles like a sedan, the lexus is better, however, I chose the X3 because it has the SUV size I wanted without comprising the driving performance of a BMW...
The 745 interior does not compare to the interior of the LS430. But the 745 is a much sportier drive. I prefer the 745, even though it is not as plush.
The X3 is average in interiors, but it's all very functional. It's a SAV...needs to have easily cleanable surfaces since BMW designed it for weekend sport enthusiasts who would not have to think twice packing their dirty bikes or shoes in the truck. I frankly think that the interior is not plush but it all goes together.
Also, people buy BMW's for the drive, not for their interiors. If you've ever sat in a base 325i, you'll realize just how un-thoughtful BMW is....they don't even have an arm rest or cupholders or any basic storage for the passengers....it is probably very disliked by passengers.....but ask the drivers what they feel? It truly is a driver's machine.
The X3 is a little less powered than most would like, but it does well within the city and is ok for those weekend trips. The handling of the X3 compensates for all the extra power that the MDX, RX and FX have. They can't seem to handle the 40 mile turns that the X3 can.
Lexus RX 330 vs BMW X3
It hasn't been very active - seems like most people compare the RX 330 to the X5.
