March 29th production launch & unveiling at the New York Auto Show.
Changes - 3 distinct models to cover a broader spectrum of the customer base - "Base" will have 2 rows of seating (5 passenger), AWD & FWD - "Touring" will have 3rd row seating (6 passenger), AWD & FWD - "Limited" will have 3-rows/6 passenger, AWD only, wood interior accents, unique leather seating, and 19" chrome wheels.
Engine changes - Base will have current 3.5L/250 hp - Touring & Limited will have "upgraded" 3.5L High Output ("255+" hp).
That's it for now.
Thanks again for the post.
It fits perfect and has all the bolts for existing holes. The 7-pin connector bracket is already on the hitch and nothing shows except 2" square opening and chain brackets. They give you a rubber hitch cover but I installed on the forward end of the opening to keep the rain/dirt out of it and bought a standard black one for show. Looks great.
2004 CHRYSLER Pacifica SUV 3.5L V6 F/I
All 33-2283 Air Filter
FYI dont know who carries them but its listed on K&N Website
Thanks for any advice.
Todd
To remove, simply get some monofilimant fishing line, wrap it around a couple of sticks, or whatever (to make a garrote), and run it between the vent shade and the door. Once you have it off, simply use some Goof Off or whatever your local hardware store sells to remove tape residue to remove it.
A friend of mine runs a printing shop (where they do a lot of vehicle graphics), and he supplied me with this tip about a year ago. Works great!
Todd
Have any of your put a Thule or Yakima cargo box on your Pacifica roof rack, how did your mount it?
Anyway, I was concerned that I wouldn't have the disk from the car which has the current revision numbers on it when I applied for the update. The lady at Alpine told me to get in my request IMMEDIATELY, as there is a new update going out THIS WEEK! She wasn't concerned about the current rev level as long as I had the coupon that came with it! So for all you folks that are due an upgrade... go get 'em!
If you have any questions, you can contact Alpine at 866-733-5492.
Paul
Jeannine Fallon
PR Director
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
Does this make sense to you? Any suggestions?
Can someone help with this?
if you have an aftermarket one and no DVD remote controller then sorry dont know ...
I have noticed with my Pac that when I do a scan or seek it does not find many stations. If, however, I dial in the station I want, it does seem to lock onto it and I get ok reception. So now that I have found all the stations I want to listen to and have saved them in memory, I have not had too many problems.
Yes, the FM reception is worse in my Pac than it was in my Envoy for the same stations.
Sorry you are having problems!
Any idea how big your Thule box is and how much additional weight might be in it when you haul?
This year for our vacation we ended up taking two cars, so we packed the minivan and the new Pac rather then put the case on top of the Honda.
I would worry more about wind catching underneath the box and sheering the supports then I would rollover.
Thanks for the update!
