-June 2024 Special Lease Deals-
Advice or pictures would be appreciated!
We just purchased a used 2004 Pacifica AWD with the DVD player installed, but no rear entertainment. My preference was to have a screen installed in each headrest, but this might be more trouble than it is worth since it appears like the car is prepped from the factory. Too bad that the wiring harness was not already in place.
If I purchased the wiring harness, could I use an OEM screen? Is there something that I need to look for to make sure that I get the correct one? I ask because $900 for the Chrysler product seems pricey.
I guess the only thing is reaching all the way to the mirror to push the call button would be a pain probably. but its gotta look cleaner then the dealer model with the push botton fob on the dash.
mine recently started echoing when calling people. they would hear themselves like 1/2 second later. was very distracting for them. I didnt hear an echo but the caller did. is anyone else having this issue? I tried turning down the volume thinking the speaker is feedback thru the mic. have it at the dealer right now to see if there is a gain adjustment on the mic.
Thanks for any help!
What is the point in Chrysler/Mopar having a labor estimate if the shop can just make this up? Do they do this because most customers simply don't do their homework? The parts department gave me the name of an aftermarket shop that charges less than the $95/hour that the dealer wants, but I need to have some warranty work done and hoped to do all of this at the same time.
Total Package = $402 ouch.
Yup...I know...I think I got ripped!
I am happy that I went with the Mopar vs. a 3rd party. Others are mounted below the bumper which seems too low to me. I like the fact it comes thru the bumber.
Anyone know of a good dealer in the Central CT area?
Todd
thanks, Geo.
I would like to get a real estimate of the level of effort to do this. The instuctions do not look that difficult and part of me wants to purchase the hole saw and just try it myself.
I'm getting ready to do this install also, and have a question about the template.
When you traced the template, did you "Straight-line" the template from the bottom holes to where it is taped at the top, or did you make it follow the contour of the bumper. It seems as though the hole may extend up to the ridge in the bumper.
I'm not sure if I am making myself clear or not, but having done it, hopefully you will understand.
Brian
S
http://www.qaausa.com/index2.ivnu
Just joking ... probably the Edmunds administrator deleted it. They have some kind of policy and if they think you were not polite or something ... they delete it.
Did you, or anybody else having problems because of the battery discharging by itself (when car not driven for a couple of days only)? I saw this on another Pacifica web site. Also the 1st Pacifica I test drove did "click-click" only when I attempted to start it.
You can get just the window trim package if thats what you want. What I got was 'only' the window trim and pillar package (not the bottom moding pakage). If you like I will give you the contact info for it.
