Chrysler Pacifica: Problems & Solutions
I bought mine through eBay, from a person who re sells expired leased vehicles. This vehicle had over 21,000 in one year, so I guess they wanted out. The only problem I have ever had was with the gas gauge. That is really Mopar's fault, not Chrysler, other than that's where they get their parts. The replacements were defective, as you can research through Google. The dealership I use in Phoenix has been nothing short of exceptional.
Personally, I would own no other car! The automobile rides excellent, with the exception of the Gas issue, (that happen in the desert I might add) I have had no problems. Everybody loves the ride, the car has everything but 4 wheel drive. I really didn't want that anyway, as I was not going to take it places the frugal person would not take a $37,000.00 auto, and I don't get snow. (Something else to go wrong, on something used very little) I have fixed my mirrors, so I don't have any blinds pots. If I had it to do over, no questions, I buy the car!
If I had it to do again, though, I'd just get the FWD. Far better gas mileage and acceleration.
There are other vehicles I would get instead, personally, but my wife wanted 3 rows and not a minivan, so that restricts the choices quite a bit.
In my experience, Chrysler gets on the ball when you bring up safety.
Which vehicles were you considering along with the Pacifica and which did your wife prefer? I was considering the Toyota Sienna and Honda Odyssey but... it's a minivan, not that cool. I also considered the Chevy trailblazer and GMC Envoy but the appearance of the dash electronics sucks incredibly compared to the Pacifica. I also didn't want to sit high up in vehicle, yet wanted something more than my current mercury sable wagon.
For the last few weeks I've been going between the Pacifica and the Sienna. No the clunking and engine/motor issues I read a heardd about on the Pacifica are forcing me to reconsider again, and the I hear the Sienna's safety isn't great at all (I need to do some research on that) plus I don't want to spend over $25k on a minivan. I'd rather spend that on a Pacifica.
I don't know what to do. I might just go with a Toyota Camry and keep my wagon. I'm tired.
08-012-06A 6-Apr ELECTRICAL - MEMORY STEATS/PEDALS ERRATIC/INOPERATIVE
21-008-06 6-Apr A/T - DIAGNOSTIC TEAR-DOWN PROCEDURE
23-014-06 6-Mar WIPERS/WASHERS - WIPERS SMEAR OR STREAK WINDSHIELD
18-004-06A 6-Mar ENGINE CONTROLS - NO START OR HARD START CONDITION
09-005-05 5-Dec ENGINE - ROUGH IDLE/ MULTIPLE CYLINDER MISFIRE
22-001-05 5-Dec WHEELS - CARING FOR CHROME WHEELS
19-008-05A 5-Nov STEERING - REVISED POWER STEERING BLEEDING
18-037-05 5-Oct ENGINE CONTROLS - FLASH PROGRAMMING FAILURE RECOVERY
21-020-05 5-Oct DRIVETRAIN - POWER TRANSFER UNIT (PTU) POP/CLICK SOUND
24-013-05 5-Aug A/C- MUSTY ODORS WHEN HOT OR HUMID
18-029-05 5-Jun ENGINE CONTROLS - CO PILOT SUPPORT & CORRECT CABLE USAGE
23-032-05 5-Jun BODY - FRONT DOOR CLASS SERVICE PROCEDURE REVISION
02-004-05 5-May SUSPENSION - FRONT STRUT SQUEAKING/SQUAKING SOUND
07-001-05 5-May ENGINE - ACCESSORY DRIVE BELT SHEILD MISSING
08-024-05 5-May ELECTRICAL - RADIO EQUIPMENT INSTALLATION RECOMMENDATION
23-014-05 5-Mar INTERIOR - DIP/SAG IN CENTER OF INSTRUMENT PANEL
08.015.05 5-Mar ENGINE CONTROLS - PCM INITIALIZATION AFTER REPLACEMENT
02.001.05 5-Feb SUSPENSION - FRONT SUSPENSION RATTLING NOISE
08.014.05 5-Feb ACCESSORIES - MOPAR® REMOTE STARTER INOPERATIVE
19.001.05 5-Jan STEERING - STEERING WHEEL TILT MECHANISM INOPERATIVE
21.004.05 5-Jan A/T - DELAYED GEAR ENGAGEMENT/POSSIBLE DTC'S
D39 5-Jan CAMPAIGN - SEAT CONTROL MODULE/DRIVERS DOOR HANDLE
24.007.04 4-Dec A/C - INTERMITTENT LOSS OF A/C/HEATER DISPLAY
08.038.04 4-Dec ELECTRICAL - DRIVER DOOR SWITCHES INOPERATIVE
19.010.04 4-Nov POWER STEERING - ADDITIVE PROHIBITION
23.045.04 4-Nov BODY - RATTLE NOISE FROM FRONT/REAR
02.007.04 4-Oct SUSPENSION - LOW SPEED RATTLE/CLUNK NOISE
19.008.04 4-Oct STEERING - IN AND OUT STEERING COLUMN MOVEMENT
09.004.04B 4-Sep ENGINE - ACCESSORY DRIVE BELT CHIRPING/SQUEAKING NOISE
23.035.04 4-Sep BODY/FRAME - WATER LEAKS INTO PASSENGER COMPARTMENT
18.006.04B 4-Sep ENGINE CONTROL - GENERIC PCM PROGRAMMING PROCEDURE
23.010.04A 4-Sep A/C - WATER LEAKS ONTO PASSENGER FRONT FLOOR
18.032.04 4-Aug ENGINE CONTROLS - MIL ON/DTC P2066 SET
08.029.04 4-Aug INTERIOR - SEAT HEATER CONTROL MODULE AVAILABILITY
08.027.04 4-Jul SAFETY SYSTEMS - INADVERTENT DAMAGE/DISABLING
23.026.04A 4-Jul INTERIOR - FRONT SEAT BELTS EMIT FOUL ODORS
03.005.04 4-Jul DRIVETRAIN - REAR AXEL OIL SEEPAGE DIAGNOSIS
02.004.04 4-Jun SUSPENSION - TOWING/LIFTING DAMAGE PRECAUTIONS
08.022.04 4-May ENTERTAINMENT SYSTEM - CRACKLING NOISE FROM HEADPHONES
09.012.04 4-May ENGINE - MIL ON/MISFIRE/STUMBLE
18.011.04 4-Mar ENGINE CONTROL - MIL ON, P2097 & EVAP MONITOR DEFECT
08.010.04 4-Mar ENTERTAINMENT DEVICES - CRACLING NOISE FROM TWEETERS
NHTSA04V113000 4-Mar RECALL 04V113000: ENGINE STALLING HAZARD
D15 4-Mar RECALL - PCM REPROGRAMMING FOR ENGINE STALLING
21.001.04 4-Feb A/T/ENGINE CONTROLS - FALSE SOLENOID DTC'S SET
09.002.04 4-Jan ENGINE - COLD START TICKING NOISE
22.001.04 4-Jan INSTRUMENTS - ERRONEOUS TIRE PRESSURE WARNING LAMP
C30 3-Nov CAMPAIGN - PCM CONNECTOR SEALS
NHTSA03V41000 3-Nov RECALL 03V471000: FUEL LINE RETENTION CLIP INSTALLATION
23.024.03 3-Oct INTERIOR - HOLE IN BACK OF SEAT TRIM PANEL
03.001.03A 3-Sep DRIVETRAIN - FONT HUB/HALF SHAFT POP/CLICK NOISE
05.005.03 3-Sep BRAKES - BRAKE PEDAL SQUEAKING/CREAKING SOUND
18.026.03A 3-Sep ENGINE CONTROLS - LONG CRANK/NO START/MIL ON/DTC'S
23.021.03 3-Aug BODY - DOOR BELT MODLING MISALIGNED
09.005.03 3-Aug STEERING - POWER STEERING FLUID USAGE
21.006.03A 3-Aug A/T - HARSH 4TH TO 3RD GEAR DOWNSHIFTS
05.002.03 3-Jun BRAKES - SQUEAL/SQUEAK DRIVING IN REVERSE
22.002.03 3-May TIRES - VIBRATION/SHAKE AT HIGHWAY SPEEDS
24.003.03 3-May A/C - SYSTEM SEALER USAGE PROHIBITION
18.020.03 3-May ENGINE COTROLS - PREMATURE A/T OVERDRIVE CLUTCH WEAR
08.009.03 3-Apr ELECTRICAL -IOD FUSE AND ELECTRICAL SYSTEM INFORMATION
:mad:
08.012.06A 6-Apr ELECTRICAL - MEMORY SEATS/PEDALS ERRATIC/INOPERATIVE
21.008.06 6-Apr A/T DIAGNOSTIC TEAR/DOWN PROCEDURE
18.010.06 6-Mar ENGINE CONTROLS - OBD IMPROVEMENT FOR I/M TESTING
23.014.06 6-Mar WIPERS/WASHERS - WIPERS SMEAR OR STREAK WINSHIELD
18.004.06A 6-Mar ENGINE CONTROLS - NO START OR HARD START CONDITION
14.001.06 6-Jan FUEL SYSTEM - MIL ON/DTC P0457 SET
22.002.05 5-Dec TIRE MONITOR SYSTEM - SYSTEM INFORMATION
18.039.05 5-Dec ENGINE CONTROLS - IDLE FLUCTUATION/ENGINE ROUGHNESS
09.005.05 5-Dec ENGINE - ROUGH IDLE/MULTIPLE CYLINDER MISFIRE
22.001.05 5-Dec WHEELS - CARING FOR CHROME WHEELS
23.054.05 5-Nov INTERIOR - 2ND ROW BENCH SEAT LATCH WON'T RELEASE
19.008.05A 5-Nov STEERING - REVISED POWER STEERING BLEEDING
18.037.05 5-Oct ENGINE CONTROLS - FLASH PROGRAMMING FAILURE RECOVERY
08.055.05 5-Oct AUDIO SYSTEM - SATELLITE RADIO STATIC
21.020.05 5-Oct DRIVETRAIN - POWER TRANSFER UNIT (PTU) POP/CLICK SOUND
08.013.05A 5-Oct CELL PHONE - UCONNECT® HANDS FREE PHONE INOPERATIVE
23.036.05 5-Aug INTERIOR - HEADLINER GAP AT FRONT DOOR WEATHERSTRIP
24.013.05 5-Aug A/C - MUSTY ODORS WHEN HOT OR HUMID
23.035.05 5-Jul BODY - CIRCULAR/RING MARKS ON GLASS
18.029.05 5-Jun ENGINE CONTROLS - CO-PILOT SUPPORT & CORRECT CABLE USAGE
23.033.05 5-Jun BODY - FRONT DOOR GLASS STICKS/BINDS/WON'T MOVE
23.032.05 5-Jun BODY - FRONT DOOR GLASS SERVICE PROCEDURE REVISION
08.028.05 5-May BODY CONTROLS - MIL ON/KEYLESS ENTRY INOPERATIVE/DTC SET
02.004.05 5-May SUSPENSION - FRONT STRUT SQUEAKING/SQUAWKING SOUND
07.001.05 5-May ENGINE - ACCESSORY DRIVE BELT SHEILD MISSING
08.024.05 5-May ELECTRICAL - RADIO EQUIPMENT INSTALLATION RECOMMENDATION
23.022.05 5-Apr INTERIOR - LOW GLOSS INTERIOR TRIM CARE
08.022.05 5-Mar INSTRUMENTS - PARKING ASSIST TONES NOT LOUD ENOUGH
23.015.05 5-Mar INTERIOR - DIP-SAG IN CENTER OF INSTRUMENT PANEL
08.015.058 5-Mar ENGINE CONTROLS - PCM INITIALIZATION AFTER REPLACEMENT
E04 5-Mar RECALL - HEADLAMP WIRING HARNESS INSPECTION/REPLACEMENT
NHTSA05V066000 5-Mar RECALL 05V.66000 HEADLAMPS INTERMITTENTLY INOPERATIVE
08.014.05 5-Mar ACCESSORIES - MOPAR® REMOTE STARTER INOPERATIVE
08.014.04 4-Dec LIGHTING - ENABLING DAYTIME RUNNING LAMPS
08.038.04 4-Dec ELECTRICAL - DRIVERS SIDE DOOR SWITCHES INOPERATIVE
09.013.04 4-Aug ENGINE - OIL QUALTIY - VISCOSITY REQUIRMENTS
03.005.04 4-Jul DRIVETRAIN - REAR AXLE OIL SEEPAGE DIAGNOSIS
08.001.04 4-Jan AIR BAG SYSTEM - PASSENGER AIR PAG SERVICE PRECAUTIONS
:mad:
'05 Pacifica = 1 recall and 43 TSBs
'05 Honda Pilot = 2 recalls and 77 TSBs
'05 Chevy Trailblazer = 1 recall and 122 TSBs
'05 Ford Explorer = 2 recalls and 48 TSBs
Well, like I said, the choices are limited when the wife refuses to get a minivan. We had a Pilot for 2.5 years and really liked it. But the wife drove the heck out of it (about 55k miles in that time). The numbers worked out to where it just made sense to trade at that time.
Anyway, the honda dealers were very uncooperative when we tried to get a new Pilot. Back before we bought our Pilot, I had wanted the wife to check out the Pacifica, but she wasn't interested. For some reason, this time she was. We also had previously tried the Trailblazer on for size. It just didn't have the fit, finish, and feel of the Pilot or Pacifica. After testing the Pac, she had her mind made up. She felt it was as tight, quiet, and versatile as the Pilot, while adding all the luxury features she had been missing. We had been looking for a lightly used one, but the dealer gave us such an incredible deal on a leftover '05 (this was Sept of '05), we couldn't refuse.
And how was your list useful? What problems are you having? You didn't ask for any advice or state any issues, you merely copied and pasted a public list.
I got the list right here on edmunds. Its in their maintenance section.
I give advice when advice is requested and warranted. Most people don't ask for it here, they merely make a blanket statement that chrylsers or pacificas are garbage. Those are the posts I find annoying and I respond accordingly.
By the way, it has nothing to do with Chrysler. I respond to folks in regards to many different makes and models. Many issues are universal, and many folks have found my experience both as a mechanic and consumer useful. If you don't, that's your perogative, and you are certainly free to ignore my posts.
As far as advice for you ... as you are somewhat now giving a small hint of what you're going through ... is the same I've posted for many people and you apparently don't appreciate. The dealer is not the end of the line, they are the beginning. Go to another dealer. If that doesn't work, contact Chrysler directly.
Well you certainly are a fan of Chrysler and have obviously had a wonderful experience with their service department.
This pretty much strikes at the heart of my pet peeve. Chrylser does not have a service department. A bad dealer is a bad dealer, end of story. It has NOTHING to do with Chrysler!
You are finally giving details as to your problem and what has been done in an attempt to fix it. That's good. You are NOW posting useful info for people. Keep up the good work.
You must have me confused with someone else. I'm pretty darned sure I've never said I "love" this car ... because I don't, so I don't see myself saying it.
It would be nice, but I kinda doubt it. I would think manufacturers would work real hard to hide those numbers.
2035 - Aug 18th - "For the last month I have had repeated failures of the fuel pumps." ... ok, is this repeated failures of the same pump? And now its getting replaced for the first time for $800? Ok, so a part failed. Big deal. It happens. [mind you, i'm just stating my reaction to this first post only, not to your whole situation ... yet]
2064 - Aug 28th - 4th NEW fuel pump. Chrysler will not address the problem (not much here ... what do you mean they won't address it? you called them? what did they say? or are you just referring to a dealer?". You say "its easier for them to keep replacing parts," so I assume you've paid nothing out of pocket and they keep trying to fix it. Yes, in the first post, you said you had to pay, but that was 10 days ago and I, as a reader, should not be expected, nor will I, go back to see if you've posted before with different information.
2069 - Aug 29th - "My dealer would not even let me see a list much less have a copy of it. Come to think of it customer service refused to even discuss the problem once they found I was 3000km past my warranty." Yet more good info. This shows how you've been treated and why you are getting frustrated. This should have been in the first post.
2073 - Aug 30th - "left my wife stranded on a highway" - yet another good bit of info to help explain your frustration. Again, once its all together, I understand why you are upset. Its just too bad I had to do all this work.
Here's the thing. You've got one problem. Is it annoying? Yes. Does it sour your owning experience? Obviously. Posting a list of TSBs of which all but one have NOTHING to do with your car is just silly. You obviously did it in some attempt to show that the list proves the car is junk.
You then got mad at me for pointing out that all vehicles have TSBs, and even vehicles considered much more reliable than Chrysler have LONGER lists of TSBs. I'm sorry, but that's not being defensive, that is just stating pure fact. So rather than posting a list of TSBs as if this somehow proves all PACs are garbage, simply relay YOUR problem in a coherent and succinct manner and you'll be much more successful in getting your grievance across to the reader.
1) How can you get Chrysler to issue a refund given a severe problem on a new car, and if so, what person do you go to at Chrysler?
2) Do you have any data on the market value of a new car vs. new car with a replaced engine? (ie, will this affect our value in a major way?)
3) Has anyone had a similar major problem, and how did you get it resolved?
In our case, we had some chugging / knocking problems at start-up and a slight scree-ing sound from the belt area. Then, while driving along on vacation in Ohio, the belt shredded, got pulled into the crankshaft / timing gears, threw off the timing 6 points and damaged valves and pistons.
So far, Chrysler has helped some, but it's been a bit of a run around. The out of town dealer in Ohio was nice, but took 4 days to determine it needed a new engine. Our dealer in Minnesota said they'd do everything possible to help, but so far is waiting for more information before they contact anyone at Chrysler. Chrysler has set up a file and is evaluating the possible refund. Meanwhile, the Ohio dealer has involved the Chrysler District Manager, and appears to be going through the process of installing a new engine. With a post-factory engine job, we're not confident this car will ever work right once they get it "fixed".
Given the $ millions Chrysler spends on advertising, it seems like a simple process to refund our money and sell the old car at auction, costing them a $ few thousand at the most.
Any ideas on where to go / how to get resolved? Thanks very, very much!
Talking about Chrysler hiding problems they don't want to fix ... does this violate Edmunds policies ?
I didn't get an email explaining why my post was deleted.
Posts on the suspension clunking have been moved to the new Chrysler Pacifica Suspension Issues discussion where you may continue.
Before you post, please check the discussion list for the appropriate discussion. If an issue comes up that we don't have a separate discussion for yet, feel free to create a new one. We're still trying to keep discussions categorized by general type of issue, like the following topics:
New Pacifica Owners - Give Us Your Report
Chrysler Pacifica: Audio & Entertainment Systems
Chrysler Pacifica: MPG-Real World Numbers
Chrysler Pacifica: Starting/Stalling Problems
Chrysler Pacifica Test Drive - What Did You Think?
Chrysler Pacifica NAV System Questions
to give you an idea of where we're headed.
Thanks for you help and understanding as we move the furniture around a bit!
--Arrie--
Thanks for the idea though.
Anything else?????
btw, the donut magnet.. does it automatically put the computer into calibration mode or do you need to have that up on the menu first. I can probably come up with a magnet from work to do this if I need to.
Does anyone know what this refers to?
2006 Chrysler Pacifica
Bulletin #: 2200205
Sequence #: 10018985
Date: 12/07/2005
Component Name: 199000 tires:pressure monitoring and regulating systems
Make: Chrysler
Model: Pacifica
Year: 2006
Summary: Tire pressure monitor - system information. *tt
This particular discussion illustrates why the change is happening. Over 2000 posts about many different types of problems. If you want to find information about Pacifica suspension problems, would you rather dig through 2000 posts, or just go to the Chrysler Pacifica Suspension Issues discussion?
My mpg also has gone up at least 3mpg since raising the pressure. I'm currently running about 38psi.
NO payment was made, Chrysler will gladly pick up the tap I think!. I know the Dealer will not, thats for sure.
The Pac is too smooth running again. :shades:
I do like the handling at the higher pressures though.
When I put the gear shift to drive or autostick it revs up beyond 2500 rpm without any hesitation and the car drives just fine.
Anybody know if this is what it is supposed to do?
--Arrie--
i guess they figure it protects it somehow.
Even my lawnmower has a governor on it.
Same but with computer control.......good idea
Keeps someone....(hint) from blowing up the motor.
It already has a rev limiter to protect the engine ... it is at red line.
but, no, i don't necessarily need to rev past 2500 sitting still. I only discovered it when trying to jump a dead battery.
