Dodge Ram - II
The 2500 QC 4X4 Cummins that I ordered six weeks ago has arrived on the dealer lot. I'll be picking it up Monday.
Here's my question. What last-minute sales-pitch can I expect to receive from the dealer. Do they try to sell me an extended warranty? I've already been accosted by the "accessories" guy, who tries to sell you "everything Ram" that you just gotta have for your new truck.
Are the extended warranties worth getting? If anybody else has purchased these, what can I expect to pay for one? What should I pay for one? I got this truck at $100 over invoice, plus the $500 farm bureau rebate on top of that.
I've also read here that I should change the oil after 1K miles. Is that right? Any other hints?
Thanks in advance!
Eric
So...
I call my dealer and explain the situation to the sales manager who says "I've got better news. Your truck is on our lot!"
I'm dumfounded. He says that DC customer svc is using out of date information.
What gives? I thought DC cust svc was the final word.
Any input? For others waiting for your truck, maybe it's best to get several sources of info.
Eric
Thanks for the info on the new towing mirrors. it this this forum is a great resource for information. Keep up the good work. I plan to stay tuned...especially since I just ordered another truck to replace the "towing mirror" mistake. I am hoping my dealer can get a 2500 built as fast a the last one (67 days).
Thanks Again,
Keith
On the axle ratio...I too fretted about this one until I thought about how I would be driving the truck the majority of the time, and that was without towing something. So I figured why lose 10% on fuel economy (I don't know where that figure came from, just remember reading it somewhere once so don't quote me) and why listen to the higher rpms at highway speed due to that axle? I don't know about you, but that would drive me nuts. Most of the guys I know that have the 4.10 are farmers and ranchers....guys that are ALWAYS towing something, the guys that need the extra power to pull a heavy trailer out of the snow and mud where that extra power on the low end is very handy. That's not me and that's not most guys that want to pull a boat on the weekends. The Cummins with the 3.54 will pull pretty much anything I need to pull, so that's why I went with that one.
You will need a 3" lift to accomadate 35x12.50's. Your options:
1).True suspension lift
Replaces Front coils and shocks w/ lift coils and longer shocks. Adds 3" blocks under the rear leaf springs. This is the most expensive of the lift options and will also degrade your ride quality somewhat. (the new coils are longer and stiffer.
2).Body lift
Involves removing stock bolts that hold body onto the frame (6 or 8 in the bed and 6 under the cab and front), adding 3" bushings between the body and the frame, and lengthening tranny and 4wd linkage and adjusting fan shroud (radiator is mounted to body and fan is mounted to engine, so the radiator moves up and the fan remains in the same place.) Also involves raising the bumpers. This is the cheapest of lifts. Does not affect ride, although some people don't care for the looks.
3). Pseudo suspension lift
This, in my opinion is the best lift for your vehicle. It involves blocks under the rear springs (like a true suspension lift) and adds a 3" polyurethane bushing on top of your stock coils. Add lift shocks and you are ready to go.
Cost:
True suspension lift: $500 to $1200 (depending on make, includes shocks)
Body lift: approx: $90 to $150 (depending on make)Pseudo suspension lift: $200 plus 4 new shock @$30 apeice(Heckethorn/Rough Country shocks)
On the tire makes BFGoody TKO's are good tires, although high. Bridgestone makes a good AT tire that is more reasonable, and so does Lee (but dont get any Lee 285's, they have had a lot of problems with them. If you have any more questions about lifts or tires, or where to purchase them (check w/ me first, I can usually beat most folks prices with my contacts) post back or email me at Jerry_the_king@usa.net Good luck with your truck.
--Jerry
AC compressors operate in several positions besides the Max AC and Norm AC positions. Any position that involves the defroster will also use the compressor - this provides the dehumidifying effect that clears the windshield of fog.
kcram
Community Leader/Smart Shopper Conference
1. How long are you going to keep the truck.
2. How likely do you feel it is that something will need a warranty repair.
3. Will you be able to part with the cash if a major out of warranty repair comes.
4. Do you use the truck in a way that could damage parts through even normal work use.
My advice. You bought a deisel and the parts are expensive. I would go for the warranty.
I do not however own a diesel right now and my warranty cost may have been less. It sounds like you went through a major truck dealer with accessory guys etc so you are probably right that the finance manager or someone will talk about the warranty. I believe (confirm this) that you have 2 weeks from delivery to make your decision.
Good luck with the new truck.
Yeah, I think you are right about Toyo not offering 265s, yet. But I bet, with 265s becoming more common, that they will have to supply them.
Thanks for your response. Does that mean there is no way to run the fan without the compressor? My other car has a separate switch for the compressor.
Also:
while at the market the other day waiting for my wife to buy groceries, I looked at a copy of Consumer Reports with the ratings for the 2000 vehicles. Boy, they sure didn't have many good things to say about the Dodge Ram. I can't believe they are actually as bad as they indicate. In almost all reliability categories, they were red meaning higher than normal frequency of repairs. Their summary was also non-flattering. I don't know where they are coming from. I have a 98 Ram 1500 QC SB and have had essentially zilch problems and think the Ram is the best looking truck on the road. What gives?
jerryg
Consumer Reports has a reputation of favoritism that has lasted the years. They absolutely love those hondas and toyotas. They could take a mercedes benz and disguise it as a dodge and consumers reports would still say that it was worthless garbage.
Usually, the vent/fan-only setting will not activate the compressor, provided the temperature setting is suitable enough.
As for CR's bad report, the 94 and 958 Rams had a LOT of bugs, since the truck was still a brand new model and demand far exceeded expectation. There are still issues with brake pull and steering shaft durability in the newer Rams, but the problems are nothing like what was experienced 4-5 years ago. When the Ram is redesigned in 18 months, don't expect as many "bugs", simply because DaimlerChrysler is prepared for production of well over half a million units a year.
kcram
The first sign of steering shaft failure is a clunk during turns. It will start out intermittently, and unchecked, will progress to occurring all the time. It requires complete removal and replacement of the intermediate, and sometimes upper and lower, steering shaft(s) to cure.
Click here for info on the appropriate TSB: Ram steering clunk TSB 19-08-97
kcram
Can you tell me if the 2000 Rams are experiencing this problem as well or did DC modify this at the factory and one of the mods for 2000 year model?
Hard to tell yet. DC claims to have redesigned ythe steering system for 2000, so they may very well have figured out what was wrong. The problem for the 94-99 Rams is, it doesn't always happen, hence they can find a definitive flaw. That's why it's a TSB instead of a recall.
kcram
consumer imports , thats what i call it , a waste of good paper if you ask me , now correct me if i'm wrong but i thought that a red circle was good ? if so the 98 and 99's were just about totally red , and if this is good then how do they call it the most unreliable truck going , then give the best reliability rating to a truck with NO TRACK RECORD ??? the only thing that CR is good for is starting a draft in your fireplace .
outlawig
there are good deals on the 99's but there have been upgrades to the 2000's the biggest being a change in the front brake calipers , the brakes on my 98 , same as 99 , are made by delco , need i say more , they bite , they also made changes to the steering of the 2000 , and the SLT plus is not a 99 option , plus if you get a 2000 you can get it as you want instead of settling for what is left , plus if you shop around you can get a 200o for invoice , all the rebates and such on a 99 , i almost bought one , bring it down to invoice , the dealer i went to took all that stuff MSRP , now that i think of it its not as good a deal as it looks like , if they take that off invoice then its a good deal , but you have to decide , i ordered a 2000 2500 cummins powered ram , i can't wait till it arrives ...
I've got it too. Glad to have read up on it here first so that they don't try to give me a line of BS at the dealership. For those of you that are suffering through this problem, has anyone gotten the problem resolved and if so, how? Most likely the intermediate shaft? And kcram, is there any tie-in between the brakes and the steering? Sometimes it feels like the clunk comes when I hit the brake, and other times when steering. Almost always when the truck is cold. Thanks!
I also have an intermittent pop in the steering wheel when I turn the wheel. Probably just a bearing or something of that nature within the steering column. This doesn't bother me as much as the other problem. The tech at my Dodge dealer said this is also common.
Thanks for the info...despite what your experiences have been, I will try to keep a positive attitude! Will update you with what I find.
Thanks for the update on the 2000 changes. I am going to test drive a few 2000's this weekend. Starting to think about diesel too.
Thanks again.
Outlawig
Also, I have what may be a dumb question. I have looked at a zillion posts concerning the towing capability of a given axle ratio. Most say that with a tall ratio (smaller number), the engine rpm's are to low and don't fall into a favorable area in the torque curve for pulling power. My question is that if that happens, why not shift from OD to 3rd gear to increase the rpm's? Wouldn't that do the same thing? I know that if you applied that technique of downshifting through all of the gears (3-2-1, etc) while going up a steep grade, sooner or later engine power would come into play (the engine would either stall or the wheels would spin) but it doesn't make sense to me to have a 4.1 or 4.3 rearend (instead of a 3.55 or 3.73) just so you wouldn't have to downshift the tranny. Am I missing something here? Please educate me.
Could I cause engine damage by restricting air flow to the intercooler in 20 below weather?
I would appreciate any comments or words of wisdom regarding this question.
The intercooler is actually behind the grille, not the bumper slots - the trans cooler is down there. The Mopar radiator front actually has a gap at the top of the grille to allow the intercooler to receive sufficient airflow (the fan draws it in).
kcram
ALso, make sure you use that block heater - all the engine components will thank you for it, and will substantially improve colsd starts and warming time. You should also remember NOT to sit in the driveway idling to try to warm the engine - won't happen. The extremem combustion efficiency of a diesel doesn't generate heat at idle - you need to be driving at normal operating rpms to get heat going.
kcram
Thank you for the reply to my question.
I installed after market stainless steel panels on the front grill to restrict air flow, and now use the block heater when the truck is parked for more than 2-3 hours. The truck interior warms up much quicker and the temperature gauge does not go higher than before. In addition to the heating benefits, the stainless grill covers look great! I decided to leave the bumper air intakes as is.
I will generally use my block heater when the temperature stays at or below +25F. The intake grid is more than enough to start the engine smoothly in temps warmer than that. In fact, here in NJ, I have yet to use the block heater this season. ALWAYS be sure to obey the "Wait To Start" light, regardless of temperature. If it comes on, that means the outisde air is too cold for initial combustion and the grid needs to be activated. This can occur all the way up to +60F.
As far as idling, you should get under way no more than 3 minutes after cranking - that's how long the grid cycles once the engine has started. Remember, diesel fuel IS an oil, so top lube is far less of a problem than with a gasoline engine. While my 1996 12-valve Cummins is completely mechanical as far as idle and fuel delivery, both the ETC and ETH versions use a Cummins computer to slightly retard or enrich fuel systems during startup, based on the engine's needs. As long as you don't turn and hold the key, or use the accelerator while cranking unless specified in the owner's manual, start-up wear should not be an issue.
Short hops tp the store will not pose a problem as liong as you're not in a rush. This means, don't crank the engine, floor it to the store, dash in/dash out, and hot-rod it back home. Treat the engine the same regardless of how long your trip is, and it will outlast the truck around it.
kcram
Just over a year ago I installed air shocks on my '93-F150 end to level the back end out when towing our camper trailer. I just recently purchased a 2500 Ram QC 2000 with the towing package, but standard oil shocks.
I would like to swap move air shocks from the Ford to the Dodge, and visa-versa. Does anyone have access to after market shocks part numbers so they can tell me if I may be able to swap them?
I had a look under the Dodge and, by eyeball measurement, I think they'll fit.
Ron B
Have your dad change his throttle cable. He probably still has the original unwrapped cable, which was prown to FAST wear, and will cause all sorts of starting and idling problems. The bew cable is plastic coated, with redesigned fittings. I had mine changed in June - it was like a different truck, or more accurately, it behaved like it did when brand new.
There is a report for the cable and related problems - click here
kcram
Just trailered my buddies Ford from Springfield yesterday about 100 miles, mostly hilly terrain, my Y2K Ram Cummins averaged 13 MPG @70MPH up and down hills. That is why I traded my 5.9 (Gas) Ram for it because I got crappy mileage, the best I could squeeze was an extra 1 MPG with Synthetics and a K&N Air Filter.....Bill
since new:
1. The windshield wipers are not parked evenly.
The drivers side is horizontal, while the
passenger side one is parked at an upward angle.
About half the trucks I see are like this, the
other half are both parked horizontally. Anyone
else with this problem ? Should I get it fixed ?
2. When I use the windshield wipers, I smell the
fluid inside, even with the windows closed. Anyone else with this problem, any solutions ?
I didn't see any reference to that issue in the previous posts.
Thanks Mike
