Visitor Agreement.
http://cgi.ebay.com/ebaymotors/GMC-Denali-2003-03-OEM-Match-Wood-Dash-Trim-Kit_W- 0QQcmdZViewItemQQcategoryZ33705QQihZ019QQitemZ8031425852QQrdZ1
When I questioned the dealership about my exhaust rattle, they said the heatshield was broken. Of course being a woman I really don't know much about cars but really think I am getting screwed here. Doesn't the dealership have to full with the exhaust when they pulled my transmission out. I didn't have any exhaust problems until after they had. Any suggestions on what to do. Should I continue to fight with GM to have them pay for the rebuilding of my transmission or is it a lost cause. The dealership also said they found the transfer case front output shaft seal was leaking. HELP!
Please help!!!
Air bag lights coming on. Said unable to dup. Overheating again. Replace thermostate.Replace with a larger radiator. Replace waterpump.Still overheating.Add large external cooling fan. Sounds terrible.GM refused to replace Vheicle. Said we drove to many miles.More issues to many to list. Please think twice before buying a denali.
Any suggestions
I have a cherry 2000 GMC Yukon, 61K miles and seems the electric windows are failing one at a time. First to go was the left rear and then right rear and then the passenger. Drivers still working. Rear getting clicks in door when you press driver controls or individual door buttons up and down. Passenger will go down from my controls but not up and will go up with passenger controls.
Replaced driver control panel, thought it was the lock out but it was not. Speak Obyone so that we all may know.
Ron in Katrinaland
BTW, that old guy played by Sir Alec Guinness as Jedi Master Ben aka ObiWan Kenobi is of no relation :P .
Spoke to several dealers and no common fuse, relay, circuit breaker exisits and no connection in the console area is common - according to them.
Everything is stock. Have you had any luck.
Also the lights on my steering column (volume controls for radio) are out. And my 3rd brake light.
Has anyone else had this problem?
My 2004 Yukon Denali makes the exact same noise and it drives me crazy!
Thanks!!
:confuse:
I don't have any noise that I consider "gear" noise, but I do get some resonance coming from the exhaust.
I will comment that I previously had an '05 Denali XL, and the '07 even with 22" wheels, rides smoother, and handles more like a smaller vehicle, and not the "Cow on Rollerskates" feel of the previous generation.
Dave
Thanks in advance for any help.
Andrew
-- Gregg
Boston, Mass
-- Gregg
Boston, Mass
--Angel
Menlo Park, CA
Here is the info they wrote up:
"Tech confirmed failure key fobs using recommendation doc 1861180 put system to sleep removed rcdlr reinstalled fuse retested all OK"
Since they did this fix a couple of months ago everything has worked fine. Hopefully your dealer can find out what that document says.
Good luck, let us know how things work out.
-- Gregg
Boston, Mass
thanks in advance for any advice
I was curious to know the details about the replacing of the solenoid and what it entailed since I seem to be in the same boat.
I am not brave enough to venture into a tranny blind, so I was going to AAMCO tomorrow.
Any guidance would be greatly appreciated.
OnStar to go silent on millions of pre-2006 vehicles (Straightline)
HELP HELP HELP.
Thanks Pete
chemk@bellsouth.net
