Yeah, that's the one!
Mike is using the phantom button to activate the relays on the aux-in switcher board, but that's an optional extra step (cool for sure, but a lot of extra and potentially risky tinkering). I would probably put in a separate switch/button to flip to the aux-in, or do some sort of auto-sense that will switch when it detects an aux-in signal (my current FM modulator does that). I wish Apple released the pin-out specs for the iPod dock connector, as that probably has it's own trigger that could be used to activate the aux-in. I tried getting the info out of them through my day job, and they would not do it unless I commited to an actual product. They are keeping that as proprietary as possible I guess.
Craig
Larry
Have you tried cleaning the inside of your windshield? New cars de-gas quite a bit and the result is a film on the inside of the glass. The film gives moisture a place to collect and hence cause film. Try wiping down the inside of your windshield with some glass cleaner and microfiber towels.
Ken
Thanks for your suggestion. I will definetly try this.
Larry
Craig
Subaru is great is some things & pathetic in others. this is one of the pathetic things that they can't fix.
On the audio front I'm debating whether or not to add the factory sub. I got it on my Rex but it seemed awfully boomy...not tight. I'm also interested in a cleaner iPod solution but will likely just go with the Monster FM/charger dongle until something truely better comes along.
I get to keep my P1s off my WRX for the Legacy - same offset/bolt pattern. If anyone needs a fresh set of GT rims and/or a full APS uppipe and TBE (100% catless) for a WRX (or Legacy GT for the uppipe) let me know.
$750 and one Ecutek reflash later I should have >300hp and >310 of twist to own unsuspecting ricers and krautmobiles! Also needs tint and a shave.
Happy trails
The factory sub, IMO, is worth it. I have it on my GT wagon and recently had a chance to listen to an OBXT wagon without it. The difference in sound was noticeable and in favor of the factory sub-woofer.
I also recently installed a wired FM Modulator on my stock headunit for my iPod. I had been using a wirless transmitter (Belkin) for some time. The sound quality from the wired unit is much better and has none of the characteristic noise from wirless transmitters. Very well worth it.
Ken
-juice
I don't know if the sub itself has changed, but if not then I think they must be feeding it a better signal from the new head unit.
Tim.
How much for rims?
Krzys
Craig
Do you park outside overnight?
Have you had any service done recently where they might have done something with the engine coolant??
Craig
Ah, then I am certain you are hearing air in the coolant -- they did not refill it properly, and trapped air in the cooling circuit somewhere. This can potentially be bad for the engine if there is an air pocket that causes local overheating, but most times you just need to purge the air and add coolant.
Right now, you can go check the coolant level (look inside the radiator cap on a *COLD* engine) and top off the radiator with a 50/50 mix of antifreeze/coolant. There should be a procedure listed in the owner's manual for adding coolant as the engine runs (again starting with a COLD engine) which ought to help you get all the air out and fill it completely with coolant.
A final note: Subaru calls for the coolant to be replaced at 30,000 miles. I assume you have not hit that mileage yet on your 05, correct? If so, the dealer may be performing un-needed service on your car. Be sure to consult the maintenance schedule in the owners manual and stick to it. Un-needed service is a waste of money, and can actually lead to problems (as in this case).
Good luck!
Craig
However ... there are a couple of "nice to have" features on the higher trims. Would anyone hazard a guess as to price/feasibility of replacing the stock equipment with any of the following:
1) Body color door handles (as on all other trim levels).
2) Body color side mirrors (as on Limited) or body color with directionals (as on XT and 6-cyl models).
3) Leather-wrapped steering wheel, shift knob, parking brake lever (as on all other trim levels).
4) Rear seat with armrest (as on other cloth-interior models: '05 XT non-lim, '06 3.0R).
Wasn't sure if this should be in the "modifications" thread, but posted here since this involves using Subie OEM gear rather than after-market equipment.
2) easier to do, and the mirrors are pre-painted. The regular mirrors are $180 (each), or $250 (each) with the turn signal.
3) steering wheel: expensive and time consuming, since an airbag is involved (wheel part itself is $327). Shift knob would be easy (it screws on/off) but I did not see part numbers for that. The shop manual only shows a parking brake boot ($100) in beige or black but nothing about the handle/lever.
4) it was difficult to see what was needed for the rear seat (many parts) but it will involve replacing the back cushion/frame and the back cover (these are separate parts). That looked like about $450 in parts. The armrest is another $141. None of the part numbers mention leather or cloth, so it is unclear what is being referred to (they note "black listed, order by aplication").
I think you'd be better off springing for the Ltd model which will also help future resale. Unfortunately, many people (me included) would prefer cloth seats and I could take or leave the moonroof.
As for the gas cost of the turbo/H6, even with today's ridiculous prices, the additional cost of premium is only a couple hundred bucks a year for most drivers. I may have spent $38 to fill my tank with premium last week, but regular would still have cost $34. That extra $4 a week adds up to about $200 per year for me....
Also, note that premium fuel is only required on the turbo models. The H6 models can run on regular, premium is just recommended.
Craig
Is there a disadvantage, i.e., change in performance, when using "regular" with the H6 engine?
Bob
Just a note regarding what the service manager was asking: I did not have problems with my heater either. Everything worked fine, but there WAS air in the system (as could easily be evidenced by the fact that the fluid in my radiator was about 1" below the fill cap at all times). The trickle sound I would hear was, I think, fluid pouring into the cabin heater's radiator after the air settled into it overnight. I cannot say for sure whether any damage was done because of uneven heating, but I could list off all the problems I had with it concurrently and have had since then! (Not that they would necessarly be directly related)
CRaig
If the noise has gone away, maybe the air has worked out. Keep an eye on it for a few days, and re-check the coolant level at some point.
Craig
I'm getting confused about whether the 2006 Legacy 2.5i, Limited, or Spec Ed will have AVLS and \ or AVCS. The sites I've looked at show that AVLS is only available on the OB, and the AVCS is only availbable on the GT & OB. But I'm sure I previously read that all 2006 Legacy's were going to AVLS. Now I'm not so sure, and I can't find it on the web. If I went non-GT, I would need that extra HP.
Does turning the heater "on" actually change the [hot] coolant flow through the heater hoses and core? I know it used the be that way in the old days (my 1966 Mustang operates this way - the temperature lever actually opens a valve that allows coolant to flow through the heater core), but I thought that modern heaters merely changed the airflow over the hot core when "heat" is selected - and routes it elsewhere when the system isn't in the heat mode. Not so in the Outback?
Ken in Seattle
Craig
"New for 2006, all 2.5-liter naturally aspirated four-cylinder Subaru Boxer engines in 2006 Legacy and Outback 2.5i and 2.5i Limited models offer more performance for 2006. The 2.5-liter engines feature a new i-Active Valve Lift system that boosts horsepower to 175 from 168 previously. The new system also increases peak torque to 169 lb.-ft., up from 166 lb.-ft. and improves vehicle drivability. "
Craig
Craig
By the way, what were the symptoms of your bent valve? Did it just happen out of the blue?
Craig
Don't lurk—participate! We look forward to hearing about your experiences with the new car!
Bob
I'm kind of surprised that Subaru dropped the cloth-seat GT model -- that had been attracting a lot of potential WRX buyers into the Legacy GT (which was a better car for the dough). And now they have leather-lined WRX models. Definitely some overlap, and perhaps that is what killed off the cloth GT.
Craig
This was the lowest running Legacy produced last year. Apparently there wasn't enough sales to keep it afloat. If my math and memory are correct, I think it barely beat out the Baja and was behind the Outback Sedan in numbers produced.
Ken
Regarding the coolant, I would think that air got in when they did the engine servicing to fix the bent valve. It is certainly not uncommon to introduce air pockets when an engine is torn down for a major repair. Heck, I have seen them happen from just simple maintenance! So I wouldn't worry about there being a connection, other than the fix for one problem introduced a minor side effect that has probably worked its way out of the system.
I am still puzzled about the bent valve. I would think something fairly catastrophic would have to happen for that to occur. How long did it take them to do the reflash??
Craig
PS - don't let my questions scare you, I am just looking for details to make sense out of it all..... if your car drives OK now, that's a good sign!
Thanks for your extensive research into my shopping list! For me, the Ltd is just not an option, as I find leather upholstery uncomfortable, and find the headroom to be inadequate with moonroof.
The only upgrade that seems feasible involves some of the leather trim pieces. Rather than replacing the wheel, it probably makes sense to get one of the aftermarket leather wraps. The shift knob should be trivial; I did this years ago for my '97 OBW - replaced the vinyl knob with the leather version from the Ltd, and have been using the original one as a paperweight!
In the old days I had a push rod or two bend, but that was 32 years ago........
Now, I CAN see how a valve (and/or valve seat) could get burned in spirited driving, especially with an air pocket in the coolant. Any chance the man said "burned" or "burnt", not "bent"?
Just my 2 cents.
