I agree that sewing the company on these grounds is pointless, but it doesn't mean it's not a valid concern and a problem that needs to be addressed.
"I think exhaust leaks in around the back because if I run with the AC on fresh, the cabin smells clean. So I doubt exhaust is coming in from the front (near the air handling piping) or else I would smell it coming out of my air vents. I strongly suspect it is seeping in from the back hatch (wherever the exhaust circulates around after exiting the tail pipe)."
There might not need to be any problems with door or hatch seals for the smell to get in. For more on this see posts 156 and 275-278 in this thread.
I'm still not sure about the ultimate cause, or why some vehicles smell and others don't, but it will be interesting to see the info from those that plan to try extending/redirecting the engine exhaust. The older 4Runners that I've seen recently, BTW, exhaust to the side.
Without seeing the vents, would it be useful to try some directional caps. Dryer vents were mentioned.....something like this in place in the rear vents. The idea is to have the air get blown upwards, so the exhaust raising up past them cant get allowed in. I know I am not being clear, but think of it as an upside down elbow for a second. Put the elbow on the vent, with the open end facing the sky. This esentially would make it so any air/exhaust trying to enter the vehicle would have to come down into the elbow. Since the exhaust is technically warmer than the surrounding air, it should rise safely past the elbow, and not get diverted into the cab.
I know I am rambling, and it isnt clear...but I am sure there is a workable solution with this....
In addition, there has been some speculation earlier in this thread that the smell may be (also?) be entering through the sunroof drain tubes, which leave the vehicle in the same vicinity. See posts 275-278, as mentioned above.
fl4runner has performed some interesting investigations, and they support previous speculation. If one wanted to drive with the rear window rolled down, I'd be inclined to focus on diverting the exhaust to the side of the vehicle, like the previous generation 4Runners.
Sounds like the rear air vents are definitely the problem. The fix I did is cheap but took me about an hour to do and a little experience in taking stuff apart and putting it back together. You average handy-person can do it but I would not recommend this procedure to someone who doesn't know what a Phillips #2 is. (BTW you'll need one or a socket driver)
In reference to the air leaking up the sunroof drain, I really doubt that could happen. The tube is so small in diameter and so long that minimal airflow takes place. The vents blow air like a hair dryer on medium (each!) The rear vents contribute 99.8% to this problem IMHO. We shall see as I drive my de-stinked vehicle for the next few weeks. Now back to screwing around with the elbow extension project...
of course, you've found something which only mitigates the effects of part of the problem space...
i hope you (or someone else willing to do some "lifting") do try the venting to the side experiment and let everyone know the results. with the vents covered in your car, i don't know how you'll determine if it benefitted the situation at all.
(some of us might remember encountering situations were we were being told to run experiments and when serving the results up to another experimentor after all our hard work, were merely told: "that's fine, now run these different experiments").
oh joy.
ideally you (or someone else) would proceed to the next step - and try to determine, to the best of your ability the root cause of the high concentration of sulfer smell...presumably your vehicle isn't running like others are running. i assume this is true because not all drivers report this problem.
so while you have demonstrated clearly that the location of the vents on the vehicle and the config of the tailpipe results in exhaust gasses being pulled into the cabin compartment...
((and that I think is a VERY important result for other drivers))
...what you haven't uncovered is what is ultimately responsible for the high-sulfer smell to begin with - and that's an important part of the overall equation / experiment, isn't it?
again, assuming the gas formulation / branding / octane / break-in / driving habits arguments didn't hold up in the practical world where you live.
if your car is still producing exhaust with what is apparently a high sulfer content, and while you might now be able to drive without the smell in the cabin (that's good), you might also be driving with a condition which might lead to premature failure of some part of the emissions control system (that's not good)...and let's not forget - your exhaust is now someone else's problem!
ok - so why not pull into an emissions testing center and see if there is something which stands out re: how the emissions system is running? i'm not sure if that would uncover much - but it would be another step i would take in your situation.
if something is blatently off-scale - i'd bring that result to the dealership along with the modified vent configuration. maybe they would be sympathetic and agreable to swap out some O2 sensors, look for indications of rich operation, check for evidence of stuck injectors, incomplete combustion and examine the condition of the CAT convertor.
i don't know why but i'm still hooked (for some reason) on what's happening on the combustion and emissions / controls side.
best regards.
Again, Toyota knows this so don't beat your head against the wall trying to figure this out. It's already been done. What hasn't been done is a cost effective fix. The best fix is a side port exhaust. The cheapest is a check valve inside the vents. I wouldn't use the flap idea because it adds another moving part that can fail and may produce noise very time you stop and go (depending on the ventilation setup. Look at designs that no moving parts.
But I have other 4Runner issues that annoy me. Often my sunroof rattles like a [non-permissible content removed]. It can be very annoying and sometimes quite loud. I heard others complain about it too. That is one where I doubt the dealer will ever get right. The sunroof is very hard to gain access to. I also notice when I steer to one side quickly (hard turn at slow speed usually in parking lots) I hear a rather loud and disturbing "clunk" coming from one of the tire wells in the front. The new 4Runner is a nice vehicle, but boy there are a lot of lose ends to fix. Also have a squeak I have determined is caused by the rear seat latch when it is in the upright position. Drop the seat and put it back, and the noise goes away for varying periods of time, only to eventually return. But that squeak is really minor compared to the rattle of the sunroof!
it wasn't ever clear to me if the problems people were noticing was just during heavy acceleration, or at other times...
anyway, i was wondering if a rear vent alternative might be workable in the doors, specifically, seeing that most doors in most cars have holes at the bottom to allow water running down the windows to exit the doors.
then i got to thinking - maybe if there were speaker cavities in the doors, maybe a modification could be made to them as opposed to the firewall?
lastly, that got me thinking - maybe if you close your doors too fast, you might over-stress your speaker cones if your car is exceptionally air-tight???
regards.
Toyota, ARE you LISTENING (reading). I think someone thought of this already and I recommended against it. I still do, but at least Dodge thought about this. Anyway, there it is.
the follow-up was going to be - you probably don't need to worry as much about your speakers as you should your ears.
there's got to be other considerations w.r.t. having an air tight cabin.
regards.
My buddy had some subs with cones made from kevlar (spelling?), I am guessing if a bullet cant hurt them, an airtight car wont either.
This seems to be exactly what so many people have been talking about – that when you have the A/C set to recirculate, air is drawn into the vehicle through the rear vents. Seems logical that if dust can get in, exhaust can too.
It is right there in the manual .
My in-laws new Pilot had the power steering pump die after 1,300 miles. Good luck.
You have to change the oil in your diffs at 7,500 miles. Honda uses a clutch pack diff, as opposed to the sturdier Toyota gear driven diff. If you tow, your diff change should be more frequent.
Instead you came to this discussion complaining about the smell problem (and your treatment by the dealer) and appeared to take no action on possible fixes recommended by the folks here. Then in post 358 you made an accusation "How many of you people posting work for Toyota?" It seems fairer to ask if you are now working for Honda.
There is apparently a genuine problem with a small minority of 4Runners, but you sure don't seem to be doing anything to help.
The Odyssey-based Pilot seems to be a good vehicle, though I suspect you already know it has some quality and reliability issues if you've read the Pilot discussions here. It is comfortable inside and has great visibility, though it's pretty darned wide for my taste. I drove Pilots a couple of times as I was beginning to shop and learn about the choices out there, and it really isn't the same sort of vehicle as the 4Runner.
I don't claim to speak for others, but I will say I'm not interested in the results of your 5000 mile maintenance. Perhaps your 50,000 mile maintenance, though.
Has anyone been successful in getting Toyota to assist? Or do they deny the problem?
kirstie_h
MODERATOR /ADMINISTRATOR
Review your vehicle
I find it quite amusing that you are still here harping on this 'Toyota conspiracy'. You have wasted countless hours, seconds and days of your life beating a dead horse. If you think it is Toyota's problem, guess again. Since you are so persistant in fighting windmills, why not put your good energy to use in overhauling the federal tax code and Medicare? That ought to keep you busy for awhile. Now that is a problem.
What is the root cause of the problem? The root is where the design engineer placed the vents. Toyota said that not me. Who owns the design? Toyota. Since the problem is the design and Toyota owns the design they own the problem. Simple. Now, we (you) are the ones affected by this "problem" and we may own the vehicle, but Toyota owns flawed design.
Well, I don't even own a 4Runner, so it's not my problem. If it's not their problem then Toyota will never fix it, right? We'll see. However, I bet they fix it. Do you really think they'll do nothing? At least by next redesign they'll think "maybe we should put a flap on that vent".
And it's not wasted energy if only 1 person decides not to buy a Toyota because of this. That's a whole bunch of money for a few hours worth of "work".
Furhtermore, how on earth could an owner be liable for this problem? It doesn't even make sense that you could blame the owner for the exhaust getting sucked in to the cabin. Rediculous.
Cheers and good luck.
I drink tap water with too much chlorine in it. I eat peanut butter with USDA approved rodent feces in it. You and I sleep in hotel beds that have human body fluids dried into the carpet, sheets, pillows, etc. Even though it looks 'clean'. You wear clothes that are treated with Formaldehyde during the manufacturing process. yada, yada, yada.
Bottomline, you are exposed everyday to chemicals and pathogens that are just as harmful, if not more, than what you claim to have smelled in your vehicle. Go find the peanut butter forum and complain about the amount of rodent feces and rodent hair in your Skippy. Reading about your constantly broken record vendetta against Toyota is lame.
Didn't you buy a Honda? Go over there.
I don't have a vendetta either. I'm an engineer and I recognize where the problem is...the design.
Just because you don't smell it, doesn't mean that it isn't there or you don't have a vehicle with a bad design. I guess your 4Runner has different vents, huh?
I didn't bring up all the other stuff and I stick to the subject so maybe you should take your Jiffy and head to the PB forum, pal. Or stick around and write something meaningful and helpful.
BTW...I am not your pal.
i find it interesting, if true, the owner's manual actually mentions dust getting into the cabin and recommending use of the "fresh" setting...
i suppose in that scenario, you're never supposed to be driving down a dusty road with another car in front of you.
I did write a letter and I'm very happy at my current job.
Be constructive and help the folks here. Enough of the nonsense.
To all the rest of you, you have a right to be concerned.
JMHO
This seems counter-intuitive at any rate.
I'm still leaning to a combination of circumstances that may indeed include the vents but does not rely solely on a vent defect.
At least that's what I can cull from all your comments and my own well-behaved 4runner rental vehicle.
The poster who closed his rear air vents, reminded me of my then new 1968 VW bug. It was so air tight it was difficult to close the doors.
BTW why close both rear vents and not just the right rear one near the exhaust ?
One possible explanation why some 4Runners stink more than others could be different tolerances. All massed produced vehicles have tolerances to allow parts compatibility. A small per centage may have a combination of parts that make for stinkers. That would also make it somewhat out of control for specific fixes on individual vehicles by Toyota.
I am a recovering engineer. ;-)
But you are an activist! Who cares about money? If your main goal in life is to 'punk' Toyota and potential Toyota buyers by your ramblings than you cannot be fully happy with your current job. You are in this one chat room continuously chatting about a moot point and you don't even own a Toyota 4Runner! What is your definition of an activist? If you really want to enjoy a job, to make the world a safer smell good place, and to protect people from themselves, I say you are a good fit to be an engineer at Toyota.
I am pretty knowledgeable on current events and world reports. I have not run across ANY people who were asphyxiated by their 4Runner parked [non-permissible content removed] end in a snow bank. Sorry to break your bubble, but this is reality.
Part of the problem with the smell creation is related to driving habits. From a link in a previous post, the explanation of sulfate build-up in the cat converter and subsequent release of hydrogen sulfide under the right conditions would explain the smell associated with higher than normal accelerator use followed by stopping. Anyone who consistently smells the hydrogen sulfide in the exhaust may be so consistent in their driving habits that their cat converter is saturated with sulfates and is giving off the hydrogen sulfide at a steady state.
Those who never smell it may either use low-sulfur gasoline or have an engine that doesn't deposit sulfates on the catalyst.
The 24-thousand dollar question is: Why don't the majority of vehicles smell bad? or restated, what is different about the few that smell bad?
It is certainly not only the 4Runner that give off this smell. I was seriously gassed by a V8 Sequoia the other day. This is the only time in my life I have smelled this exhaust. I would have remembered otherwise. I always drive in traffic with outside air coming in through ventilation, so I would notice any car in front of me that smelled that bad.
Sorry, the above is just speculation.
Use of recirculation is a problem for any length of time since the air inside the cabin becomes stale quickly and may deposit water on the windows. Not to mention the problem associated with terrible body odor...
Shifty
