Ford Ranger II
Sorry, I don't know if dealers are required to look into service bulletins. I assume so.
Hope this helps.
It looks like the best weekend for the Medano pass trip is the 8-9 of July. I will get some more input from people and declare a Rough Rangers Off-Road club event for that time, if that works for most. One guy wants to come from Kansas. There are 2-3 other Denver area Ranger owners interested.
For the Rangers in the Colo area, I am organizing a trip over Medano and Hayden passes in So. Colo. Will be a 4 and 3 rate of difficulty pass respectivly. Views are outstanding and the trip runs through the Sand Dunes Nationl Monument.
Interested Ranger/Mazda owners contact me at Cpousnr@aol.com. Will need food, camera and the will to take on a tough 4X4 trail.
http://www.fordranger.com/RangerProgram.html
Premium just went to around $1.80 a gal up here, maybe $2.00 in Westcliffe.
You have to run premium with the chip.
Well, I was already running 89 octane. So I figured that going up to 92 was not that big of a deal. I just wish that Superchips would have been up front with me about the possibility of the module not working on some 3.0L engines. I had no idea that this might happen. I will probably send the module back for a refund. I was not pleased with the way it plugged into the computer. It should have fit flush against the casing, but it did not. There was a good 1/4 or 3/8 inch gap between the casing and the module. This prevented the computer from sliding all the way back into its original installation position. Oh well, I thought it was worth a try...
The vehicle also provides a large electrical 'shock' each time I touch it. It seems to have some sort of short, but the three dealers couldn't find any problems.
Any suggestions?
Rick Rose
About the clutch, I experienced the same thing when I bought my 2.5L 5spd 2000 Ranger in April. I test drove two trucks and the first one did the same thing. The clutch wouldn't engage until I had almost let off the pedal and then the truck would jerk into gear. And this was a brand-new truck. The dealer told me that I was driving it wrong--that I didn't know how to drive a stick. I've always driven stick shifts so I asked to test drive another truck (the one I bought) and it didn't do it. So apparently some of them do it and some don't. I don't know if that helps you are not though. The only thing I have noticed on mine is a stammer at idle, especially on very hot days. Has anyone else experienced this?
The dealer is not required to service a vehicle based on a TSB if there is no concern present on your particular vehicle. E.g. if you aren't having intermittent wiper problems, they don't have to replace your wiper switch and GEM just because there is a TSB. In fact, they don't have to follow a TSB at all. If the technician correctly diagnoses the problem, they won't even check for TSB's. Additionally, if your truck is no longer under warranty, you are responsible for the cost of any repairs.
A TSB is not a recall nor an owner notification program. It is basically a collective knowledge pool for technicians, based on some not-uncommon problems.
I'm pretty sure that a K&N filter will not void the warranty, but if the dealership says it does, just keep your old filter and make sure you switch them out if you go to your dealer for anything. Also I put a Flowmaster muffler on my Ranger and the guys I talked to at the dealership said it wouldn't void anything, but they obviously don't cover the new muffler under warranty. That shouldn't be a problem though because I believe flowmaster has a life time warranty.
You'll have to hope that Ford have another incentive scheme in place, though I imagine the financing % will be higher. But maybe not if they want to push out some metal during the quiet months. Good luck.
Guess I'll have to be happy with my '89 Ranger until December. Hopefully I'll get a call before then to go see 'my' truck on the lot.
Side note - test drove a Dakota Club Cab V8 5spd - really liked that one. Probably hold off for the Ranger though, due to 10% lower price, more maneuverable size, and better fuel economy. Gas prices are crazy!
Take care all.
If this is ok let me know. Looks like 2-3 other Rangers from Denver area will go. If the earlier weekend is better, let me know. I MORE than likely will be there that weekend too as I have 5 days off (we went to a 9/80 schedule, nine days/80 hours with every other friday off.
Let me know.
Where did you hear that the 4x2 isn't going to be as high as a 4x4, because everywhere I read it says they will be the same. Even Ford's website says they will ride at the same height.
thanks-
Actually, what was your total out-of-pocket on the installation? I've put a K&N air filter in the air box of my 2000 3.0l 5-sp Mazda, but am reasonably sure I now have just a cleanable air filter...
Just curious.
Installation of a quality muffler like Flowmaster, Borla, or Gibson are fairly pricey. In my case, it also required new pipe from the cat converter to the muffler as well as a new tail pipe. Parts and labor ended up being about $300. There are kits available (not sure about the 3.0L) that would get you down closer to the $200 dollar mark if you have the facilities and time to do it yourself. Yea, it was a dumb move on my part. Never again...
Noticed you mentioned you've got a K&N air filter on your 3.0L. Ever considered a KKM Tru Rev Induction Kit? It replaces your stock air box. It is easy to install and all sensors remain in place. It is a lifetime filter that you clean every 15K-30K miles. Really helps the engine breathe better. Sounds nice too. Costs about $100.
Check out this link: www.kustomz.com. Click on Ford trucks. I've got one on my B3000. I like it. It's an upgrade that I'm not ashamed of!!!
Got the mounting plate, roller fairline and Ramsey 8000 winch. Get the hitch this afternoon, a Warn.
Well know what I will be doing this weekend.
xen1a, we will be ready for anything over Medano. However, read a trail report for memorial day. Dusty and dry, streams are very low. Will not be the challenge I was expecting. But with the winch, side trips will be less scary. . .
A bit faster acceleration, nice sound, and easy to install/service. Just order a recharge kit or 2 when you order the filter.
Do you folks know that Ford has plans to discontinue (kill) the 3.0 vulcan? BlueOvalNews (source) The Ranger and Explorer uses plastic intake manifolds now instead of aluminum because they are lighter and cheaper but hardly better. It cause more engine noise and rough idle because of warpage. Is that what they mean by "Built Ford Tough"? The only thing tough about Ford trucks is getting it fixed. "Built Ford to Last", yes maybe for driving it 10 blocks from the dealer.
Not to mention the crappy service the dealer is capable of providing. Who in their right mind want this type of product and dealer experience?
People do not have plenty of time and money to be putting up with this. Ford - Built Tough to deal with. Ford Recall Lemon Motor Company.
I have been using penzzoil 5-30 with change every 3,000 miles and am considering switching to synthetic at the 30,000 mile change.
What would be the best brand and viscosity of synthetic or synthetic blend for this engine with this driving scenario. I live in the Denver Colorado area climate.
Sorry for your bad experience with Ford. Its experiences like these that give most folks the belief all Fords are created equal, thus they will all fail. Sorry but not true, my first Ranger went to 96K with absolutely no problems, I'm on my second now a 1998 with about 30K with no problems... You can visit Ranger rooms around the net and will find many Ranger owners out there with 100K, 200K or more miles on them...
Best of luck with your Ranger, peace.
My 99 runs great at 29,000 miles, had an F150 try to, on a short narrowing run, pass me on the right from a light from a dead stop. Well, one of the very few times I put the petal to the floor, but he did not pass me.
vince:
I think granite is talking about the top of the engine, the part that has the embossed 4.0? I want to change mine out as I think it is plastic.
Been running it for maybe 15,000 mile in my 4.0. Runs quiet, cool and accelerates like it did on day one.
Well satisfied.
It was a 2.9 V6, one of the first German 60degree slant v6's
And he was climbing real well, a few leaks here and there, but doing fine. The guy wants to put in a 4/0 to take advantage of the one belt drives all system. Think he has 4 belts on the 2.9 and the one that breaks the most?
The inner belt!
