Visitor Agreement.
Best Regards,
Shipo
My '05 Hyundai Elantra just hit 44k and is getting about 3MPG more than when new.
Yeah, our 1998 Dodge Grand Caravan 3.8 with 142,000 on the clock is still getting 3-4 mpg better than when it was brand new. ;-)
Best Regads,
Shipo
A "variable mile counter", no, I very much disagree with that, it is a variable condition analyzer. As for "not an oil analyzer of any degree", I don't believe that I've ever said anything different. With that in mind though, I was working at MB-USA back in the mid 1990s when they were playing with their OLM system and synthetic oil, and I have to tell you, their "assumptions" with regards to the OLM system were pretty damn spot on according to the multitude of UOAs that the had performed while perfecting said system. I have no doubt that one ones employed by BMW and Porsche are no less sophisticated and accurate.
Best Regards,
Shipo
So, it appear the only reasonable course of action to take is to drive it to the ground.
I have few questions before undertaking this noble endeavor.
1. How long would my car last without changing oil ( I last changed about 9 months/3,000 miles ago)?
2. Is it safe to not change oil?(will the car blow up?)
3. are there any alternates to not changing oil/repair?
Thanks in advance for any helps!
p.s. for those curious, I drove 95 Ford Aerostar.
FWIW, I too have an old minivan and last year I was faced with the option of either junking it or putting a new transmission in it for $2,600. All things considered, the money spent on the new tranny effectively bought me a new (used) car for far less money that I could otherwise have gotten a similar ride for. All and all, money well spent.
Best Regards,
Shipo
Best Regards,
Shipo
Do they mean the area around the drain plug is so rusty that they think it will break away if they try to remove the plug?
If you do a web search you can find information about them.
It's a quck and easy method to do oil changes without getting under the car, assuming the filter is fairly easily accessable from above. This could get you by for some time to come and eliminate the need to deal with the defective pan at all.
Good Luck,
JR
Sounds like a scaredy-cat amateur at the Jiffy Lube who doesn't know how to professionally remove a stuck bolt. You can soak them with a solvent, you can tap them on the corners with a chisel to knock them loose, you can judiciously apply leverage, you can buy special sockets to do this job.
Go someplace else that is reputable. See what they say, preserve evidence if they find some jury-rigged fix from the last oil change. Then go after the jerks how screwed your vehicle.
I thirty plus years of driving, self-maintenance, reading automotive journals, and reading the web, I've NEVER heard of an oil pan rusting. And I've maintained cars far older than your Aerostar.
I'll bet the last time that Quickie Lube place worked on that Aerostar, they buggered up that bolt and forced it in at an angle so it wouldn't leak.
Worst case senario would be a new oil pan and it wouldn't cost anywhere near 1000.00. I would take it to a competant SHOP, not another quickie lube. They can put in an oversized drain plug or install a heli-coil.
I despise these quickie lube shops for this very reason!
Agreed!
And of course there's always the risk of bringing in a fried engine that was serviced with DIY oil changes. God help you if there some bunged up piece on the engine that the dealer can point to.
But if you're out of warranty, got a safe place to do your work, sure why not?
Spilling oil, cleaning up afterwards, getting rid of the old oil etc.
Done too many!
I have access to a lift and oil drain recycling tank at work (we're allowed to use these during lunch or after hours, as long as we have a "buddy" around in case of an emergency).
So I can change my oil in air conditioned comfort, and not have to hassle with the used oil. It gives me a chance also to inspect the underbody of my vehicles and make sure nothing's amiss.
I suppose when I retire I'll have to reconsider, as dragging out the ramps and dealing with the used oil really is a pain. I understand you're not even supposed to put oil filters in the trash, because you can never drain all of the oil out.
Not in our lifetime and that's fine with me!
Do you have a couple of these you'd like to have us test out for you? We've got a couple regulars on the board here (auto enthusiasts), who I'm sure wouldn't mind testing/evaluating this product.
Use good quality oil and change it on a regular basis and you will have no need whatever for anything like this.
I'm sure the hosts will pull his ad as soon as they see it.
I do miss Newport Beach, however.
We thought nothing of this at the time.
I've bookmarked the instructions from an earlier post:
Here's how to do it, from "moeharri" in 2005 (I don't believe the procedure has changed for '07 models):
Begin with the odometer in the normal mode (total accumulated miles, not trip A or trip B mode). Turn the car off, press the trip/odometer "stick" and keep pressing it while turning the ignition key back to the accessory/on position (you don't need to start the engine).
As you continue to press the stick in, the odometer will count down from 5 or 6 dashes to blank, and then the actual mileage will show again. At that point, release the stick and the light should go out.
When I first got the '04 with the "maintenance required" light, my first thought was, "oh no, I'll have to go back to the dealer to get it reset!" But luckily, Toyota made it easy to do yourself.
Engine Oil Replacement Reminder Light
This light acts as a reminder to replace the engine oil.
This light will come on when the ignition key is turned to "ON" and will go off after about a few seconds.
When you drive for about 7200 km (4500 miles) after the engine oil replacement, this light illuminates for about 3 seconds and then flashes for about 12 seconds with the ignition key turned to the "ON" position. If you continue driving without replacing the engine oil, and if the distance driven exceeds 8000 km(5000 miles), the light will come on. The light will remain on thereafter.
If the light is flashing, we recommend that you replace the engine oil at an early opportunity depending on the driving and road conditions. If the light comes on, replace it as soon as possible.
Resetting the system
The system must be reset after the engine oil replacement. Reset the system by the following procedure:
Press the "POWER" switch to the "OFF mode with the odometer reading shown.
Press the "POWER" switch twice to select the "IG-ON" mode while holding down the trip meter reset button.
Hold down the button for at least 5 seconds. The odometer indicates "000000" and the light goes off.
If the system fails to reset, the light will remain flashing.
Well, they could have installed iDrive...
They took a simple procedure, like pushing a button to reset it and over complicated it on not only one model, but 90% of them out there.
Why? Because they know that most vehicle owners won't read the owner's manual or be able to find the procedure information to reset it, so those people will most often return to the dealer to have it done, at a nominal fee of course.
