leave a mess....right on the exhaust flex pipe.
About the best solution, wrap the flex pipe
with waste rags, aluminum foil, or something.
Otherwise it will be a long time before the
odor of burning oil will be gone.
The new GM's are BETTER for this change !
the mental ability level yo described...
Thanks for a good laugh this morning!
ROFL
My point is that if you tell the consumer it's synthetic, the consumer feels good and you can have the same oil cost!
...And have the add'l "mark-up" profit in your pocket. Schweeet!
An old friend (high school buddy who never really made anything of himself) runs a Jiffy Lube near our hometown. The old manager, in order to increase the numbers on the P&L statement, had all the oil tanks pumped and refilled with SAE 30 bulk (cheapest thing on the market).
A year or so later, my buddy took over, sent samples out while checking all the tanks (supposed to be done annually) and discovered the scam. He had it all changed out, of course.
I hassled him saying they'd give him a 50 cent an hour raise for that one! Or not!
The other fear I have (when I can't visually watch an oil change) is that if I give a mechanic bottles of oil to use, they may just fill from the bulk tank and take the "good stuff" home - something they could do, though less easily, even if you ask for empties back - if they have a container to pour the oil into.
one of his duties is some of the routine equipment
maintenance.
We were chatting while I was working on my car.
When he saw me getting ready to install a new
screw on filter, he said, "Wait a second. Take
this marks-a-lot pen and write the date on the
filter."
Only took a few moments. Now I can see what date
it was installed.
His idea might also help at quick change places. At least it might help insure the filter actually
gets changed.
On the other hand, the "date-on-the-filter" thing isn't a bad idea.
still trying to keep from making more.
I've been around a long time, can sympathize.
Back in 1950 I drove a '47 Ford. Like Chevy,
it used what was called a torque tube from the
transmission to the differential. To pull the
transmission, you had to undo the brake lines,
unbolt the whole rear drive and roll the
transmission and rear end (connected by this
torque tube) out from underneath the car. It
was truly a "pain".
When my throw out bearing needed to be replaced,
I wisely took the car to a Ford dealership.
The day the car was scheduled for pickup, I
stopped at the dealership.
What I saw was my car, sans rear end, sitting in
a bay. The rear wheels, torque tube, rear end
and transmission were propped vertically in a
corner of the shop. The transmission was pointed
up to the sky.
During my discussion with the shop foreman I
mentioned that the way they were doing my
transmission would let all the gear lube run down
the torque tube and over-fill the rear end.
He said no.
Two days later when I picked up the car and
drove home, the first thing I did was roll
under the car on a creeper and pull the fill
plug on the rear end. It gushed. The transmission
needed lots of lube added.
I would have blown the rear wheel seals had
I driven very far and maybe ruined the transmission.
Lesson learned to be careful of dealers too.
I've used Pennzoil chassis lube for lots of years.
Was helping a friend last summer change-out the
ball joints on his old Lincoln. From the color
of the grease around the grease fittings I could
tell that his car was using something like the
cheapest Pennzoil.
I asked him, where do you get your car greased ?
He said Jiffy Lube.
So, I asked, did you know that Jiffy Lube uses
the cheapest Pennzoil greases, there are much
better that Pennzoil makes, but they have to use
what Pennzoil "tells them to" ?
He said, "I didn't know that."
"Well, now you know."
Now I can't speak for any other VW dealerships (other than the ones I've dealt with), but once again - the dealer I go to uses synthetic oil... So it's up to you to believe it or not...to each his own...
If your place does, that's great and they should be applauded.
I commented because I've worked for 4 dealer groups and none would have considered this - I'd say you've found a great place.
Of course, you may have to deal with a $995 doc fee when you buy a new car, so sales can subsidize service!
I have a nice Ford Focus, which has never given me trouble. It is my
first car, so I have tried hard to take good care of it. I follow the
manual, and take it to a quickie oil-change place (whose name I won't
mention) every 5,000 miles. Other than trying to sell me service I
don't want, it has done good work for me. Then in the faculty lounge
at lunch, I heard my co-workers talking about the terrible
experiences they had when getting their oil changed. Apparently, they
know of people who go to the same place I go, who have had their oil
drained out and then not replaced! This did not become clear to these
people until the engine totally seized up and died. They said the
quickie-lube place would take no responsibility, because nothing
could be proven. This terrifies me! Is it only an urban legend, or
does this really happen? -- April
TOM: Oh, it absolutely happens, April. Didn't the Mars lander crash a
couple of times before they got it right? And those guys were rocket
scientists. You think neighborhood mechanics don't screw up sometimes?
RAY: To be fair to Skippy Lube, it's one of those mistakes that any
shop can make. Although when speed is your stated priority, I suppose
mistakes become a bit more likely.
TOM: Here's how it happens: The mechanic drains out the oil, changes
the filter, puts the drain plug back in, takes the car down off the
lift, and then his wife calls to discuss the kid's braces. Then his
bookie stops by, wanting to be paid, and then the roach coach comes
and it's lunchtime. If he's not careful and he doesn't have a good
system, he forgets that he hasn't refilled the crankcase, and he
calls you and says "all set."
RAY: You pick up the car, drive away, and 15 minutes later you're
broken down by the side of the road and the buzzards are circling.
TOM: Now, normally in that situation, a decent shop will immediately
take responsibility, apologize and get you a new engine. Most shops
have "bonehead" insurance, which covers just these kinds of mistakes.
RAY: But I'm sure there are some sleazeballs out there who try to
wriggle out of it. Why? Maybe it's pressure to increase profits
(insurance has deductibles, and premiums go up with each claim). Or
maybe they're just not nice people, and they think they can get away
with it.
TOM: But they usually can't. If your engine seizes up due to lack of
oil, and you can show that you recently had an oil change at a repair
shop, almost any judge in small-claims court will award you a new
engine. It's usually a slam-dunk case for the consumer.
RAY: So, keep two things in mind, April. First of all, mistakes
happen, but catastrophic mistakes like this are pretty rare. And even
if you are ever a victim of such a mistake, you can hold the shop
responsible.
TOM: And second, remember to always pay attention to your oil light.
Your oil light is an emergency warning light. If it ever comes on,
pull over and shut off the engine immediately. And then check to make
sure you have your latest Skippy Lube receipt. The judge will want to
see it.
"Then his bookie stops by, wanting to be paid"
According to these guys, all Jiffy Lube guys are gambling addicts?
What a joke.
It was just a joke...
I have dealt with many, many mistakes by these places when I was a Chevrolet service manager. I knew the manager of the Wal-Mart Lube Express, the local Jiffy Lube, and the Quaker State Q-Lube by first name. I recently spoke with a couple of guys who worked with me in 1997-1998, and we realized that there wasn't a single day in 2 years that we didn't have an engine job in the shop (big dealership) from one of the quickie lube places.
Sure, these places make more mistakes than dealerships or guys who work on their own rides - joke or not, though, outright disrespect isn't deserved.
I'd like to see old Tom and Ray's credentials...like a radio station manager or newspaper editor knows what a real technician or shop manager is...
they're on the radio because they sling BS well and avoid actually calling it BS. factually, they are backchecked by lawyers and such often enough so that they are at least neutral and at best good in accuracy.
what I liked was an article recently wherein somebody said they got all the dirty oil out of their car by running it until it stopped dripping after they drained the oil pan... then put in the new stuff. about fell on the floor laughing and pointing at the screen, folks from neighboring aisles (not just cubes) had to come by and see just what pushed me that far. that was also in Our Heroes' column, but I can't find it at this time in the online index.
What still happens, according to what I have heard, is 1. filler caps left off; 2. rags etc left in engine compartment; 3. hoods bent because the mechanic forgets this is a prop supported hood and not a hydraulic strut; and that biggest problem of all....
stripped oil pans because they tighten the bolt too tight. One place told me they have to tighten too tight because they don't have a full stock of factory washers and drain bolts. Another place told me, don't worry, we have washers for all makes, not just Hondas.
So here it is... I recently purchased a 2000 Accord LX with 42k documented miles. Service records indicate the car was serviced at 7500, 15k, 22.5k, 28k, and 35k miles by a local Honda dealer. The last oil change was performed by the dealer from whom I purchased the vehicle (not a Honda dealer). In an effort to ensure that the engine would continue to hum happily, I decided 4.5 quarts of Castrol 10w30 and a Honda filter were in order. Prior to draining the oil, I noticed a droplet of oil on the drain plug. I remained optimistic, hoping that a new crush washer would seal the deal. After breaking the drain plug lose, it immediately became taught again before easily backing out of the oil pan. The threads of the drain plug were shining (possibly a burr?) but no apparent stripping. After replacing the oil, filter and crush washer, behold, a tiny droplet of oil appears on the drain plug.
I purchased a new drain plug from Honda today. If this simple fix doesn't hold oil, a Honda service tech estimated a cost of $450 to repair/replace drain plug seat, oil pan and seal. Any comments (besides check oil daily)? Thanks!
previous cars 69 VW Bug, 89 CRX HF, 91 CIVIC SI, 96 VW GTI VR6, 00 Ford Mustang GT.
current cars 00 Accord LX, 67 Ford F100.
Here's their newspaper article website :
http://cartalk.cars.com/content/columns/latest.html
Morons.
Really? How do you figure?
The pan costs the same since it's a dealer item. Maybe the independent charges 10.00 less per hour than the dealer does?
Hardly half price wouldn't you agree?
There are two caveats:
Make sure the oil people have the drain tube handy - or they will use a wrench to remove the whole SureDrain, which defeats the purpose. I go to a friendly oil change place that lets me watch them and make sure they don't forget the drain tube is handy (if they can't find it, or don't know how the system works, they will take out the whole plug).
Second, make sure they do not use a "tool" to put the dust cap back on. That only needs to be finger tight.
The instructions are INSIDE the piece of cardboard packing material that comes with the SureDrain. Don't throw it away, pry it out and unfold it. I missed the instructions the first time.
The private shop won't be but a few dollars less on labor, and if you want Taiwanese, made by sweat shop labor parts on your car, that's your choice.
I have to wonder if the original owner of the vehicle witnessed a quarter-sized drop of oil on the driveway and chose to sell the vehicle.
According to driftracer, they are of inferior quality?
since every island above water once a week is producing knoockoff collision parts for cars, only makes sense they would stamp out a few oil pans and valve covers, too.
I've always said you should use whatever your conscience allows. As for me and my family's rides, though, a few extra bucks helps me sleep and night because I KNOW there's a difference.
We were talking about oil pans - feel free to compare wall thickness, weld continuity, corner strength, and pan lip strength when comparing an OEM Honda pan to the junk you'll pick up at Pep Boys. Again, unless you're dealing with Moroso or Milodon, the OEM pan is generally the way to go.
The oil filter comparison - wrong again. Unless you MAKE SURE the Fram or Purolator filter has a check valve (like the OEM version does), you can do top end engine damage and void your warranty.
I'm not going to split hairs with you over everything automotive. I will say that making a general statement like you did leads people wrong, and in many cases, using a private shop, that is getting its parts from the cheapest parts house in town, isn't always the best move for longevity of you rengine and an accolade towards your common sense.
parts are inferior.
Even though I now sell Hondas, I've been around shops all of my life and I, too know the differences.
Don't assume that if Fram for example makes some filters for Honda that they are the same specs as the ones at some discount parts store. Wix, Fram and others build different quality filters for different markets.
Like you said, you have to really compare things.
I just never realized anyone made aftermarket oil pans since they sure aren't a volume seller.
http://www.washingtonpost.com/wp-dyn/business/columns/autos/click- - andclack/
___________________________________________
If you go to the movies today, tickets are close
to $10....
What I've been posting about Tom & Ray is FREE....
True experience.....
There used to be a military post in Indianapolis
called Ft. Benjamin Harrison....
There were two service stations on the post...
I was watching one....
The driver of a Buick that had just been washed
and waxed backed the car out of the service bay...
In the next bay, a grease jockey walked behind
a vehicle he was working on that was still up
on the hoist...
The jockey had a pressure grease gun in his hands.
As he came around at the back of where he was
working, he must have accidentally squeezed the
grease gun...
A column of grease went about 20 feet...
The string went EXACTLY through the two open
rear windows of that recently polished Buick...
Wish I'd be so lucky....
