Visitor Agreement.
You may think the oil company is responsible and they may be. After this much time has passed, it is doubtful you will get any recourse.
I would park this car or get it fixed before it strands you.
What about YOUR responsibility to check the oil on at least a weekly basis?
I always check the oil level immediately after having the oil and filter changed. My attitude is: "mistakes can happen" - maybe the tech got interrupted, maybe he's having a bad day, maybe his best buddy's bachelor's party was last night. Whatever - I'm covered. Am I paranoid? Maybe - but I've never run an engine with a dry sump either.
And then I check it at least every other fuel fill-up, and always before a long trip. 'Course, I also keep a spare quart in my trunk since I'm using 0w-40 Mobil 1 (which isn't always easy to find).
ON A WEEKLY BASIS???? I've never heard of any maintenance manual suggesting this. Frankly, if a car needs to have the oil level checked weekly, it's indicative of a larger problem. Maybe that was true 25 years ago or more, but today's cars should not be expected to require that level of diligence.
Note I didn't say that I add oil at every check. In fact, neither of our current cars ever needs oil between changes. But our old Mazda Protege developed a sudden (and substantial) leak around 100,000 miles and I'm convinced that my frequent checks prevented us from losing that engine. Once the leak was resolved, it ran another 65,000 miles without needing added oil between changes.
And, yeah, all of our owner's manuals recommend checking the oil at every fueling.
I started checking regularly for level and for color. Sometimes I check at rest areas when I stop.
Yeah, that's a great idea. Check it at every fill up when the car has been running & the oil hasn't drained back into the pan yet.
Point taken. I don't actually check my oil at the gas station (it's "buy and fly" for me), but the next AM when the engine is cool and the oil is all (or mostly, anyway) in the sump.
Actually if you shut off motor and do your gas fill the oil will have drained back into the pan 90% or more or the small fraction that was circulating. When the motor is hot the oil is almost as thin as water and drains into the pan rapidly. If you don't believe that, try driving 50 miles or 10 and then changing your own oil quickly by removing the drain plug.
Great idea, after check the transmission fluid, after all it needs to be a hot check.
Same with my tires. If one looks low, I'll check them.
I know...
I reread your posts, it sure looks like Jiffy lube didn’t put in the correct amount of oil. I know hind site is 100% but it always is a good idea to check oil level after service, humans do make mistakes. I know most people don’t, if a problem comes up then it gets sticky.
I am confused on the part where you stated the oil light comes on at times then goes out, was this taking place after the low oil service? Oil light on, if for oil pressure is a serious concern, it would be like a persons heart stopping.
As far as tires pressure goes I am right on it now with gas $3 a gallon. Times are changing, after hurricane season it will probably be closer to $4 a gallon.
Most high performance street cars use baffles in the oil pan, or hard cornering and braking will allow the pick up tube to suck air and cause gauge fluctuations or oil lights to blink on and off.
Years ago, back in the early to mid 70’s, I changed my own oil and filter (still due but not quite like I used to) religiously at less than 3 months which was always way, way less than 3000 miles (I was very fortunate to work less than 3 miles away). There was a joke in our group that went something like ; “Hey, jmonroe is going to change his oil again this Saturday, whose turn is it to go over and get his drain oil this time for their next oil change”? Heads would pop up from their cubicles saying “ME”. Well, one Saturday morning after I had said, in passing, that I was going to do an oil change this week end, at about 8:30 the door bell rings, I’m thinking it’s a neighbor wanting to borrow something, when I open the door, there’s one of my fellow worker friends standing there with an empty Prestone jug in his hand saying, “when do you plan to start the oil change, Ed and I have a tee off time in about an hour”. Not to act surprised, I said “I did it last night and gave the oil to a neighbor, you should have told me you wanted it”. His response was, “since I’m here what’s for breakfast”?
Like I said, this was years back when an engine that had 40-45K miles on it, was pretty much at its half-life especially when you had many short trips like I did which is probably the most severe use of an engine. In the winter, if I left the car outside, it was barely putting out warm air by the time I pulled into the parking lot. So, when you think of it again, I wasn’t really doing the engine all that much of a favor.
Oil is very, very, very cheap insurance for engine longevity and it didn’t bother me one bit to change it more often vs. less often.
I didn't want to make the story too much longer but since you asked.
Back in those days cars in the north, where they salted the roads heavily in the winter, you were lucky if a car didn't rot away after 5 or 6 years that you could still bare to look at it. So, my cars that were this age had 50-60K miles on them when the wifee pulled the plug on them saying she was embarrassed to go to the supermarket let alone take the kid's anywhere that they would be seen getting out of the car, regardless of how well they ran.
Ended up selling them, with no problems, and the buyers ALWAYS commented on how strong and quiet the big V-8 engines were. Even sold one to a body guy who was thrilled to get it and didn't even try to negotiate the price. In a couple months he brought the car over for me to see what he had done with it, said he'd have the car forever, and asked that I call him anytime I wanted to sell a car. BTW, when the wifee saw it she said, "if I didn't see it with my own eyes I wouldn't have believed it" (boy, isn't that original) to which I said, "see, I told you we should have kept it"
Yes, I tried to call the body guy the next time I was ready to sell, but he had moved without letting me know and the phone company said since they didn't have a forwarding number he probably moved out of the state (Pennsylvania), or was that, he moved to the State Penn. Oh well, his loss.
But if you are filling from quart bottles, what do you think they are going to do with that last half quart?
While I'm not necessarily a fan of synthetics', (I believe that any quality oil and filter changed often is all you really need) I would have been upset to say the least if they didn't give me what I asked for. This, for me, would have been enough to go elsewhere from then on. It's also why I like to do this easy stuff myself.
How did you find out they didn't give you what you wanted, was the type of oil they did use shown on your receipt? Just curious.
Yeah, I think we all know the answer to this but what SHOULD be done is to do it right.
If they did it right they would be able to make more money by saving this 1/2 qt. for the next guy. If I had a shop I'd do this and tell my customers my prices are for full quarts only. If they felt cheated by this, I would gladly give them the left over 1/2 quart. There choice.
Oh no, another guy who thinks like me.
BTW, I read your Bio and I see that you have a 2005 Elantra. I have two Hyundai's; 2005 XG 350 (mine) and I just bought a 2006 Sonata LX in June for the wife. It's just a baby, doesn't even have 1200 miles on it and you can bet I'm going to due the oil changes on it myself since (I'm pretty sure), like the XG 350, it also falls into the something plus 1/2 qt. requirement.
Just can't trust others to do even the most simple of things. When I can't lift a wrench, I guess I'll have to change my thinking.
Actually, I am very lucky to have an extremely good Hyundai shop 10 minutes from the house. So, when the bones don't want to crawl on the floor, Cricket get lubed by the shop.
yes- I did clean it up using wads of newspaper. But that load didn't get recycled- just thrown in the trash.
I've got a garage and proper oil container now!
Doah!
I'm not looking forward to bringing the car back to have the excess oil removed.
How long would it take me to wipe 1/2 quart of the dipstick?
BTW Any damage to the engine by overfilling by 1/2 quart of 50W20 in a Mazda 5?
David
If so you could just remove the filter housing drain it out and then put it back on. Do that a couple of times and you would be set.
I've never understood why folks change the break in oil soooo early & don't follow their manuals. I would think the engineers would know a thing or two about their engines and the tolerances. Just an opinion from someone who usually follows the owners manual.
The Sandman
I have made progress
I looked in the owneer's manual and read that the distance between the min and max on the dipstick uses about 3/4 quart. I then compared that to the distance above the max line and figure it's 1/4 to 1/2 that distance which would make it about. 38 quart overfilled.
The next time I go for an oil change I'll remind the mechanic that the Mazda 5 uses 4.5 quarts not 5 quarts of oil.
BTW I must have wiped the stick 20-30 times over the course of 2 days.
Thanks again for all you feedback.
David
The number of miles was not the reason why I changed the oil at 1000 miles. I decided to change the oil after I read the "date built" on the driver's side door and realized the car had been on the lot for 9 months.
I wish I had seen that before purchasing the car--I would not have purchased it.
David
You must be moving fairly slow to only get 20-30 wipes over a period of 2 days. I'm thinking, after about a couple hours of continuous wipes, you should have been able to get that 1/2 quart of extra oil out.
trying to be neat i would take a full quart out the the bag from the store and put empty back in and take out the next one.
anyways, ended up throwing out a full quart because i forgot to take the last full container out of the bag, after i checked the dip stick and it wasn't down to the 'fill' line. the oil is over 3 dollars a quart.
